[geos-commits] [SCM] GEOS branch main updated. 967bbb23eb5735e6755fefb3dcb11c4b34ac677e
git at osgeo.org
git at osgeo.org
Fri Sep 10 16:03:18 PDT 2021
the project "GEOS".
The branch, main has been updated
via 967bbb23eb5735e6755fefb3dcb11c4b34ac677e (commit)
from 9e3aa68491ca56a93181e6a11272bb1feef06161 (commit)
revisions in full, below.
commit 967bbb23eb5735e6755fefb3dcb11c4b34ac677e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Sep 10 16:03:13 2021 -0700
Remove some dead code, turn on some robustness tests that work now
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index a5fe39d..1dbb40e 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -169,7 +169,8 @@ Node::testInvariant() const
-#if 0 // We can't rely on numerical stability with FP computations
+#if 0
+ // We can't rely on numerical stability with FP computations
// ztot is the sum of doubnle sin zvals vector
double ztot_check = 0.0;
for(std::vector<double>::const_iterator
diff --git a/src/geom/Envelope.cpp b/src/geom/Envelope.cpp
index 4563e89..17e8fb5 100644
--- a/src/geom/Envelope.cpp
+++ b/src/geom/Envelope.cpp
@@ -103,19 +103,6 @@ Envelope::Envelope(const std::string& str)
strtod(values[3].c_str(), nullptr));
-#if 0
- * Initialize an <code>Envelope</code> from an existing Envelope.
- *@param env the Envelope to initialize from
-void
-Envelope::init(Envelope env)
- init(env.minx, env.maxx, env.miny, env.maxy);
-#endif // 0
/*public*/
bool
diff --git a/src/geomgraph/DirectedEdge.cpp b/src/geomgraph/DirectedEdge.cpp
index 1400a0a..c2bc731 100644
--- a/src/geomgraph/DirectedEdge.cpp
+++ b/src/geomgraph/DirectedEdge.cpp
@@ -55,23 +55,6 @@ DirectedEdge::depthFactor(Location currLocation, Location nextLocation)
return 0;
-#if 0
-DirectedEdge::DirectedEdge():
- EdgeEnd(),
- isInResultVar(false),
- isVisitedVar(false),
- sym(NULL),
- next(NULL),
- nextMin(NULL),
- edgeRing(NULL),
- minEdgeRing(NULL)
- depth[0] = 0;
- depth[1] = -999;
- depth[2] = -999;
-#endif
DirectedEdge::DirectedEdge(Edge* newEdge, bool newIsForward):
EdgeEnd(newEdge),
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index 11fd77d..3442f83 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
@@ -162,25 +162,12 @@ GeometryNoder::getNoder()
if(! noder.get()) {
const geom::PrecisionModel* pm = argGeom.getFactory()->getPrecisionModel();
-#if 0
- using algorithm::LineIntersector;
- LineIntersector li;
- IntersectionAdder intersectionAdder(li);
- noder.reset(new MCIndexNoder(&intersectionAdder));
-#else
IteratedNoder* in = new IteratedNoder(pm);
- //in->setMaximumIterations(0);
noder.reset(in);
- //using snapround::MCIndexSnapRounder;
- //noder.reset( new MCIndexSnapRounder(*pm) );
-#endif
return *noder;
} // namespace geos.noding
} // namespace geos
diff --git a/src/noding/OrientedCoordinateArray.cpp b/src/noding/OrientedCoordinateArray.cpp
index 352d6fb..ab8af73 100644
--- a/src/noding/OrientedCoordinateArray.cpp
+++ b/src/noding/OrientedCoordinateArray.cpp
@@ -44,19 +44,6 @@ OrientedCoordinateArray::compareTo(const OrientedCoordinateArray& oca) const
int comp = compareOriented(*pts, orientationVar,
*oca.pts, oca.orientationVar);
-#if 0 // MD - testing only
- int oldComp = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
- if((oldComp == 0 || comp == 0) && oldComp != comp) {
- System.out.println("bidir mismatch");
- boolean orient1 = orientation(pts);
- boolean orient2 = orientation(oca.pts);
- int comp2 = compareOriented(pts, orientation,
- oca.pts, oca.orientation);
- int oldComp2 = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
-#endif
return comp;
diff --git a/src/operation/overlay/ElevationMatrix.cpp b/src/operation/overlay/ElevationMatrix.cpp
index f5682d3..a3074a1 100644
--- a/src/operation/overlay/ElevationMatrix.cpp
+++ b/src/operation/overlay/ElevationMatrix.cpp
@@ -124,16 +124,6 @@ ElevationMatrix::add(const Geometry* geom)
-#if 0
-void
-ElevationMatrix::add(const CoordinateSequence* cs)
- unsigned int ncoords = cs->getSize();
- for(unsigned int i = 0; i < ncoords; i++) {
- add(cs->getAt(i));
-#endif
void
ElevationMatrix::add(const Coordinate& c)
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index 0e3ef2b..8ee79e2 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -381,7 +381,6 @@ void object::test<6>
0);
-#if 0 // fails: finds an intersection (we don't have DD)
* Test from Tomas Fa - JTS list 6/13/2012
@@ -399,9 +398,7 @@ void object::test<7>
"LINESTRING (-5.9 163.1, 76.1 250.7)",
"LINESTRING (14.6 185.0, 96.6 272.6)");
-#endif // fails
@@ -419,7 +416,7 @@ void object::test<8>
"LINESTRING (-42.0 163.2, 21.2 265.2)",
"LINESTRING (-26.2 188.7, 37.0 290.7)");
-#endif // fails
* Following cases were failures when using the CentralEndpointIntersector heuristic.
diff --git a/tests/unit/capi/GEOSEqualsTest.cpp b/tests/unit/capi/GEOSEqualsTest.cpp
index a686424..053835d 100644
--- a/tests/unit/capi/GEOSEqualsTest.cpp
+++ b/tests/unit/capi/GEOSEqualsTest.cpp
@@ -142,12 +142,10 @@ template<>
- const char* wkt1 = "GEOMETRYCOLLECTION(POLYGON ("
- "(0 0, 0 4, 4 4, 4 0, 0 0)"
- "POLYGON ("
- "(3 3, 3 4, 4 4, 4 3, 3 3)"
+ const char* wkt1 = "GEOMETRYCOLLECTION("
+ "POLYGON ((0 0, 0 4, 4 4, 4 0, 0 0)),"
+ "POLYGON ((3 3, 3 4, 4 4, 4 3, 3 3))"
geom1_ = GEOSGeomFromWKT(wkt1);
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index f85dcec..5eb22e1 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -488,20 +488,14 @@ void object::test<27>
10, -10, "LINESTRING (10 0, 10 0)");
#if 0
template<>
template<>
-void object::test<28>
+void object::test<28>()
GeomPtr linearGeom(reader.read(
- "MULTILINESTRING ((0 -2, 0 2),(-2 0, 2 0))"
+ "MULTILINESTRING ((0 -2, 0 2),(-2 0, 2 0))"
LengthIndexedLine indexedLine(linearGeom.get());
double projIndex = indexedLine.project(Coordinate(2, 1.9));
@@ -518,8 +512,7 @@ void object::test<28>
template<>
template<>
-void object::test<29>
+void object::test<29>()
GeomPtr linearGeom(reader.read("LINESTRING EMPTY"));
Summary of changes:
include/geos/geomgraph/Node.h | 3 ++-
src/geom/Envelope.cpp | 13 -------------
src/geomgraph/DirectedEdge.cpp | 17 -----------------
src/noding/GeometryNoder.cpp | 15 +--------------
src/noding/OrientedCoordinateArray.cpp | 13 -------------
src/operation/overlay/ElevationMatrix.cpp | 10 ----------
tests/unit/algorithm/RobustLineIntersectionTest.cpp | 5 +----
tests/unit/capi/GEOSEqualsTest.cpp | 10 ++++------
tests/unit/linearref/LengthIndexedLineTest.cpp | 15 ++++-----------
9 files changed, 12 insertions(+), 89 deletions(-)
hooks/post-receive
More information about the geos-commits
