[geos-commits] [SCM] GEOS branch main updated. f5c3da3342b16da45a81704c6affcf4a855b49b6
git at osgeo.org
git at osgeo.org
Wed Sep 29 13:37:59 PDT 2021
the project "GEOS".
The branch, main has been updated
via f5c3da3342b16da45a81704c6affcf4a855b49b6 (commit)
from 55fb9a19ad3bf8395e8ef2fcee988fa5b9e7fefe (commit)
revisions in full, below.
commit f5c3da3342b16da45a81704c6affcf4a855b49b6
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Sep 29 22:36:44 2021 +0200
Expose a PreparedGeometry::isDistanceWithin method
And have the C-API call that.
The method doesn't have optimized implementations but simply
calls (for now) the isDistanceWithin() method of the base geometry.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index cc6d9e7..3abc02b 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3286,9 +3286,8 @@ extern "C" {
const geos::geom::prep::PreparedGeometry* pg,
const Geometry* g, double dist)
- // TODO: further optimize this ?
return execute(extHandle, 2, [&]() {
- return pg->distance(g) <= dist;
+ return pg->isDistanceWithin(g, dist);
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index 29639e9..714d2f5 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -181,6 +181,11 @@ public:
double distance(const geom::Geometry* g) const override;
+ * Default implementation.
+ bool isDistanceWithin(const geom::Geometry* geom, double dist) const override;
std::string toString();
diff --git a/include/geos/geom/prep/PreparedGeometry.h b/include/geos/geom/prep/PreparedGeometry.h
index 29b7786..eda52ad 100644
--- a/include/geos/geom/prep/PreparedGeometry.h
+++ b/include/geos/geom/prep/PreparedGeometry.h
@@ -216,6 +216,17 @@ public:
virtual double distance(const geom::Geometry* geom) const = 0;
+ /** \brief
+ * Tests whether the base {@link Geometry} is within a given
+ * distance from the given geometry.
+ * @param geom the Geometry to test the distance to
+ * @return true if this Geometry is within the given distance from
+ * the given Geometry.
+ virtual bool isDistanceWithin(const geom::Geometry* geom, double dist) const = 0;
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index 78acb8a..a3e058a 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -171,6 +171,12 @@ BasicPreparedGeometry::distance(const geom::Geometry* g) const
return coords->getAt(0).distance( coords->getAt(1) );
+bool
+BasicPreparedGeometry::isDistanceWithin(const geom::Geometry* g, double dist) const
+ return baseGeom->isWithinDistance(g, dist);
std::string
BasicPreparedGeometry::toString()
Summary of changes:
capi/geos_ts_c.cpp | 3 +--
include/geos/geom/prep/BasicPreparedGeometry.h | 5 +++++
include/geos/geom/prep/PreparedGeometry.h | 11 +++++++++++
src/geom/prep/BasicPreparedGeometry.cpp | 6 ++++++
4 files changed, 23 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
