[geos-commits] [SCM] GEOS branch main updated. 90fc07bf2363e02e1bc5f2d1979447dc00479f58
git at osgeo.org
git at osgeo.org
Wed Sep 29 13:40:03 PDT 2021
the project "GEOS".
The branch, main has been updated
via 90fc07bf2363e02e1bc5f2d1979447dc00479f58 (commit)
from f5c3da3342b16da45a81704c6affcf4a855b49b6 (commit)
revisions in full, below.
commit 90fc07bf2363e02e1bc5f2d1979447dc00479f58
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Sep 29 22:39:48 2021 +0200
Fix documentation for GEOSDistanceWithin
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 5fe5bda..0d2ac4a 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3317,7 +3317,7 @@ extern int GEOS_DLL GEOSPreparedDistance(
* Using a \ref GEOSPreparedDistanceWithin do a high performance
* calculation to find whether the prepared and provided geometry
-* is within the given max distance.
+* are within the given max distance.
* Useful for situations where
* one geometry is large and static and needs to be tested
* against a large number of other geometries.
@@ -3987,7 +3987,8 @@ extern int GEOS_DLL GEOSDistance(
double *dist);
-* Calculate the distance between two geometries.
+* Test whether the distance between two geometries is
+* within the given dist.
* \param[in] g1 Input geometry
* \param[in] g2 Input geometry
* \param[in] dist max distance
Summary of changes:
capi/geos_c.h.in | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
