[geos-commits] [SCM] GEOS branch main updated. 79f75266db60f5c69f5ae48ebc8680b2b26c9f01
git at osgeo.org
git at osgeo.org
Wed Sep 29 14:21:27 PDT 2021
the project "GEOS".
The branch, main has been updated
via 79f75266db60f5c69f5ae48ebc8680b2b26c9f01 (commit)
from 90fc07bf2363e02e1bc5f2d1979447dc00479f58 (commit)
revisions in full, below.
commit 79f75266db60f5c69f5ae48ebc8680b2b26c9f01
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Sep 29 23:17:38 2021 +0200
isDistanceWithin -> isWithinDistance, for consistency with Geometry
Also try to fix Doxygen (blindly, as cmake doesn't recognize I do
have Doxygen installed).
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 0d2ac4a..50a19bb 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3321,9 +3321,9 @@ extern int GEOS_DLL GEOSPreparedDistance(
* Useful for situations where
* one geometry is large and static and needs to be tested
* against a large number of other geometries.
-* \param[in] pg1 The prepared geometry
-* \param[in] g2 The geometry to test
-* \param[in] dist The max distance
+* \param pg1 The prepared geometry
+* \param g2 The geometry to test
+* \param dist The max distance
* \return 1 on success
extern char GEOS_DLL GEOSPreparedDistanceWithin(
@@ -3989,9 +3989,9 @@ extern int GEOS_DLL GEOSDistance(
* Test whether the distance between two geometries is
* within the given dist.
-* \param[in] g1 Input geometry
-* \param[in] g2 Input geometry
-* \param[in] dist max distance
+* \param g1 Input geometry
+* \param g2 Input geometry
* \returns 1 on true, 0 on false, 2 on exception
extern char GEOS_DLL GEOSDistanceWithin(
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 3abc02b..cfb4c0e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3287,7 +3287,7 @@ extern "C" {
const Geometry* g, double dist)
return execute(extHandle, 2, [&]() {
- return pg->isDistanceWithin(g, dist);
+ return pg->isWithinDistance(g, dist);
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index 714d2f5..9898ca4 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -184,7 +184,7 @@ public:
* Default implementation.
- bool isDistanceWithin(const geom::Geometry* geom, double dist) const override;
+ bool isWithinDistance(const geom::Geometry* geom, double dist) const override;
std::string toString();
diff --git a/include/geos/geom/prep/PreparedGeometry.h b/include/geos/geom/prep/PreparedGeometry.h
index eda52ad..0e5ec44 100644
--- a/include/geos/geom/prep/PreparedGeometry.h
+++ b/include/geos/geom/prep/PreparedGeometry.h
@@ -222,11 +222,12 @@ public:
* distance from the given geometry.
* @param geom the Geometry to test the distance to
+ * @param dist the distance value to compare
* @return true if this Geometry is within the given distance from
* the given Geometry.
- virtual bool isDistanceWithin(const geom::Geometry* geom, double dist) const = 0;
+ virtual bool isWithinDistance(const geom::Geometry* geom, double dist) const = 0;
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index a3e058a..27b4537 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -172,7 +172,7 @@ BasicPreparedGeometry::distance(const geom::Geometry* g) const
bool
-BasicPreparedGeometry::isDistanceWithin(const geom::Geometry* g, double dist) const
+BasicPreparedGeometry::isWithinDistance(const geom::Geometry* g, double dist) const
return baseGeom->isWithinDistance(g, dist);
Summary of changes:
capi/geos_c.h.in | 12 ++++++------
capi/geos_ts_c.cpp | 2 +-
include/geos/geom/prep/BasicPreparedGeometry.h | 2 +-
include/geos/geom/prep/PreparedGeometry.h | 3 ++-
src/geom/prep/BasicPreparedGeometry.cpp | 2 +-
5 files changed, 11 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
