[geos-commits] [SCM] GEOS branch main updated. b53afe675cb21b7f2689eae72f6dd3b10bb87d78
Mon Apr 17 13:19:25 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  b53afe675cb21b7f2689eae72f6dd3b10bb87d78 (commit)
       via  3cab6cb2a8c5a5243a3fa1a8775322d6e290c6a4 (commit)
      from  93540f4c27b6eff81e51203f52b585a7872f884b (commit)
revisions in full, below.
commit b53afe675cb21b7f2689eae72f6dd3b10bb87d78
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Apr 17 13:18:46 2023 -0700
    Add unit test for GEOSCoverageSimplifyVW for inner
diff --git a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
index 8a11cd07a..18c65bd9b 100644
--- a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
@@ -1,5 +1,5 @@
-// Test Suite for C-API GEOSCoverageUnion
+// Test Suite for C-API GEOSCoverageSimplifyVW
 #include <tut/tut.hpp>
 // geos
@@ -38,7 +38,7 @@ group test_capicoveragesimplify_group("capi::GEOSCoverageSimplify");
 // Test Cases
+// GEOSCoverageSimplifyVW - all
 template<>
 template<> void object::test<1>
@@ -61,7 +61,25 @@ template<> void object::test<1>
     ensure_geometry_equals(result_, expected_, 0.1);
+// GEOSCoverageSimplifyVW - inner
+template<>
+template<> void object::test<2>
+    const char* inputWKT = "GEOMETRYCOLLECTION( POLYGON ((1 9, 5 9.1, 9 9, 9 5, 5 5.1, 1 5, 1 9)), POLYGON ((1 1, 1 5, 5 5.1, 9 5, 9 1, 1 1)))";
+    input_ = fromWKT(inputWKT);
+    result_ = GEOSCoverageSimplifyVW(input_, 1.0, 1);
-} // namespace tut
+    ensure( result_ != nullptr );
+    ensure( GEOSGeomTypeId(result_) == GEOS_GEOMETRYCOLLECTION );
+    const char* expectedWKT = "GEOMETRYCOLLECTION(POLYGON ((9 5, 1 5, 1 9, 5 9.1, 9 9, 9 5)), POLYGON ((9 5, 1 5, 1 1, 9 1, 9 5)))";
+    expected_ = fromWKT(expectedWKT);
+    ensure_geometry_equals(result_, expected_, 0.1);
+} // namespace tut
commit 3cab6cb2a8c5a5243a3fa1a8775322d6e290c6a4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Apr 12 19:15:03 2023 -0700
    CAPI: GEOSCoverageIsValid, GEOSCoverageSimplifyVW GH-867
    Expose the CoverateSimplifier and CoverageValidator via the CAPI
diff --git a/NEWS.md b/NEWS.md
index 5cdf51ad1..42484dfc8 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,7 +3,7 @@ xxxx-xx-xx
 - New things:
   - C++14 is now required.
-  - Polygonal coverage operations: CoverageValidator, CoveragePolygonValidator,
+  - Polygonal coverages: CoverageValidator, CoveragePolygonValidator,
     CoverageGapFinder, CoverageUnion (JTS-900, Martin Davis & Paul Ramsey)
   - Support reading and writing M values through WKB and WKT readers/writers
     (GH-721, Dan Baston)
@@ -19,6 +19,8 @@ xxxx-xx-xx
   - CAPI: GEOSConcaveHullByLength (GH-849, Martin Davis)
   - CAPI: GEOSGeomGetM (GH-864, Mike Taves)
   - Voronoi: Add option to create diagram in order consistent with inputs (GH-781, Dan Baston)
+  - Polygonal coverages: CoverageSimplifier (JTS-911, Martin Davis)
+  - CAPI: GEOSCoverageIsValid, GEOSCoverageSimplifyVW (GH-867, Paul Ramsey)
 - Fixes/Improvements:
   - WKTReader: Fix parsing of Z and M flags in WKTReader (#676 and GH-669, Dan Baston)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index f67db11c2..5757a6f0b 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1804,4 +1804,20 @@ extern "C" {
                                          cx, cy);
+    int
+    GEOSCoverageIsValid(
+        const Geometry* input,
+        double gapWidth,
+        Geometry** invalidEdges)
+        return GEOSCoverageIsValid_r(handle, input, gapWidth, invalidEdges);
+    Geometry*
+    GEOSCoverageSimplifyVW(const Geometry* input, double tolerance, int preserveBoundary)
+        return GEOSCoverageSimplifyVW_r(handle, input, tolerance, preserveBoundary);
 } /* extern "C" */
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index bc583020e..faac0e8a1 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -757,6 +757,24 @@ extern void GEOS_DLL GEOSGeom_destroy_r(
     GEOSContextHandle_t handle,
     GEOSGeometry* g);
+/* ========= Coverages ========= */
+/** \see GEOSCoverageIsValid */
+int
+GEOSCoverageIsValid_r(
+    GEOSContextHandle_t extHandle,
+    const GEOSGeometry* input,
+    double gapWidth,
+    GEOSGeometry** output);
+/** \see GEOSCoverageSimplify */
+extern GEOSGeometry GEOS_DLL *
+GEOSCoverageSimplifyVW_r(
+    double tolerance,
+    int preserveBoundary);
 /* ========= Topology Operations ========= */
 /** \see GEOSEnvelope */
@@ -3719,6 +3737,74 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
+/** @name Coverages
+* Functions to work with coverages represented by lists of polygons
+* that exactly share edge geometry.
+* Analyze a coverage (represented as a collection of polygonal geometry
+* with exactly matching edge geometry) to find places where the
+* assumption of exactly matching edges is not met.
+* \param input The polygonal coverage to access,
+*        stored in a geometry collection. All members must be POLYGON
+*        or MULTIPOLYGON.
+* \param gapWidth The maximum width of gaps to detect.
+* \param invalidEdges When there are invalidities in the coverage,
+*        this pointer
+*        will be set with a geometry collection of the same length as
+*        the input, with a MULTILINESTRING of the error edges for each
+*        invalid polygon, or an EMPTY where the polygon is a valid
+*        participant in the coverage. Pass NULL if you do not want
+*        the invalid edges returned.
+* \return A value of 1 for a valid coverage, 0 for invalid and 2 for
+*         an exception or error. Invalidity includes polygons that overlap,
+*         that have gaps smaller than the gapWidth, or non-polygonal
+*         entries in the input collection.
+* \since 3.12
+extern int GEOSCoverageIsValid(
+    double gapWidth,
+    GEOSGeometry** invalidEdges);
+* Operates on a coverage (represented as a list of polygonal geometry
+* with exactly matching edge geometry) to apply a Visvalingam–Whyatt
+* simplification to the edges, reducing complexity in proportion with
+* the provided tolerance, while retaining a valid coverage (no edges
+* will cross or touch after the simplification).
+* Geometries never disappear, but they may be simplified down to just
+* a triangle. Also, some invalid geoms (such as Polygons which have too
+* few non-repeated points) will be returned unchanged.
+* If the input dataset is not a valid coverage due to overlaps,
+* it will still be simplified, but invalid topology such as crossing
+* edges will still be invalid.
+*        or MULTIPOLYGON.
+* \param tolerance A tolerance parameter in linear units.
+* \param preserveBoundary Use 1 to preserve the outside edges
+*        of the coverage without simplification,
+*        0 to allow them to be simplified.
+* \return A collection containing the simplified geometries, or null
+*         on error.
+* \since 3.12
+extern GEOSGeometry GEOS_DLL * GEOSCoverageSimplifyVW(
+    double tolerance,
 /* ========== Construction Operations ========== */
 /** @name Geometric Constructions
 * Functions for computing geometric constructions.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index facefb9e3..fdf987f2f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -27,6 +27,8 @@
 #include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/algorithm/hull/ConcaveHull.h>
 #include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
+#include <geos/coverage/CoverageValidator.h>
+#include <geos/coverage/CoverageSimplifier.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/Envelope.h>
@@ -4063,4 +4065,83 @@ extern "C" {
+    int
+    GEOSCoverageIsValid_r(GEOSContextHandle_t extHandle,
+        double gapWidth,
+        using geos::coverage::CoverageValidator;
+        return execute(extHandle, 2, [&]() {
+            const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(input);
+            if (!col)
+                throw geos::util::IllegalArgumentException("input is not a collection");
+            // Initialize to nullptr
+            if (invalidEdges) *invalidEdges = nullptr;
+            std::vector<const Geometry*> coverage;
+            for (const auto& g : *col) {
+                coverage.push_back(g.get());
+            CoverageValidator cov(coverage);
+            cov.setGapWidth(gapWidth);
+            std::vector<std::unique_ptr<Geometry>> invalid = cov.validate();
+            bool hasInvalid = CoverageValidator::hasInvalidResult(invalid);
+            if (invalidEdges && hasInvalid) {
+                const GeometryFactory* gf = input->getFactory();
+                for (auto& g : invalid) {
+                    // Replace nullptr with 'MULTILINESTRING EMPTY'
+                    if (g == nullptr) {
+                        auto empty = gf->createEmpty(GEOS_MULTILINESTRING);
+                        g.reset(empty.release());
+                auto r = gf->createGeometryCollection(std::move(invalid));
+                *invalidEdges = r.release();
+            return hasInvalid ? 0 : 1;
+    Geometry*
+    GEOSCoverageSimplifyVW_r(GEOSContextHandle_t extHandle,
+        double tolerance,
+        using geos::coverage::CoverageSimplifier;
+        return execute(extHandle, [&]() -> Geometry* {
+            if (!col)
+                return nullptr;
+            CoverageSimplifier cov(coverage);
+            std::vector<std::unique_ptr<Geometry>> simple;
+            if (preserveBoundary == 1) {
+                simple = cov.simplifyInner(tolerance);
+            else if (preserveBoundary == 0) {
+                simple = cov.simplify(tolerance);
+            else return nullptr;
+            std::unique_ptr<Geometry> r = gf->createGeometryCollection(std::move(simple));
+            return r.release();
 } /* extern "C" */
new file mode 100644
index 000000000..8a11cd07a
--- /dev/null
@@ -0,0 +1,67 @@
+// Test Suite for C-API GEOSCoverageUnion
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capicoveragesimplify_data : public capitest::utility {
+    test_capicoveragesimplify_data() {
+    ~test_capicoveragesimplify_data() {
+typedef test_group<test_capicoveragesimplify_data> group;
+typedef group::object object;
+group test_capicoveragesimplify_group("capi::GEOSCoverageSimplify");
+// Test Cases
+template<>
+template<> void object::test<1>
+    const char* inputWKT = "GEOMETRYCOLLECTION(POLYGON ((100 100, 200 200, 300 100, 200 101, 100 100)), POLYGON ((150 0, 100 100, 200 101, 300 100, 250 0, 150 0)))";
+    result_ = GEOSCoverageSimplifyVW(input_, 10.0, 0);
+    const char* expectedWKT = "GEOMETRYCOLLECTION(POLYGON ((100 100, 200 200, 300 100, 100 100)), POLYGON ((150 0, 100 100, 300 100, 250 0, 150 0)))";
+    // std::cout << toWKT(result_) << std::endl;
+    // std::cout << toWKT(expected_) << std::endl;
+} // namespace tut
Summary of changes:
 NEWS.md                                      |  4 +-
 capi/geos_c.cpp                              | 16 ++++++
 capi/geos_c.h.in                             | 86 ++++++++++++++++++++++++++++
 capi/geos_ts_c.cpp                           | 81 ++++++++++++++++++++++++++
 tests/unit/capi/GEOSCoverageSimplifyTest.cpp | 85 +++++++++++++++++++++++++++
 5 files changed, 271 insertions(+), 1 deletion(-)
 create mode 100644 tests/unit/capi/GEOSCoverageSimplifyTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
