[geos-commits] [SCM] GEOS branch main updated. 665890e6e384103dede1553ae8ab468271b0515f
Mon Apr 17 13:50:09 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  665890e6e384103dede1553ae8ab468271b0515f (commit)
      from  b53afe675cb21b7f2689eae72f6dd3b10bb87d78 (commit)
revisions in full, below.
commit 665890e6e384103dede1553ae8ab468271b0515f
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Apr 17 13:48:37 2023 -0700
    Improve C API doc
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index faac0e8a1..0b3589eb5 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -16,24 +16,25 @@
 * \brief C API for the GEOS geometry algorithms library.
 * \tableofcontents
-* The C API is the preferred API to use when integrating GEOS into
-* your application/library/etc. While the C++ API is available, the ABI
-* will not be stable between versions, and the API may also change.
+* The C API is the supported API to use GEOS in
+* your application/library/etc.
 * The GEOS team makes an effort to keep the C API stable, and to
 * deprecate function signatures only over a long time period to allow
 * transition time.
+* While the C++ API is available, the ABI
+* will not be stable between versions, and the API may change.
 * Important programming notes:
-* - Remember to call initGEOS() before any use of this library's
-*   functions, and call finishGEOS() when done.
-* - Currently you have to explicitly GEOSGeom_destroy() all
-*   GEOSGeom objects to avoid memory leaks, and GEOSFree()
+* - Call initGEOS() before using the library functions.
+* - Call finishGEOS() when finished using the library.
+* - To avoid memory leaks, call GEOSGeom_destroy() on
+*   \ref GEOSGeometry objects, and call GEOSFree() on
 *   all returned char * (unless const).
-* - Functions ending with _r are thread safe (reentrant);
+* - Functions ending with `_r` are thread safe (reentrant);
 *   see details in https://libgeos.org/development/rfcs/rfc03.
 *   To avoid accidental use of non-reentrant functions,
-*   define GEOS_USE_ONLY_R_API before including geos_c.h.
+*   define `GEOS_USE_ONLY_R_API` before including geos_c.h.
Summary of changes:
 capi/geos_c.h.in | 19 ++++++++++---------
 1 file changed, 10 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
