[geos-commits] [SCM] GEOS branch main updated. 261ec0fd7eba41d675bbf37b597d4f1e5fba4104
git at osgeo.org
git at osgeo.org
Mon Apr 17 14:40:46 PDT 2023
the project "GEOS".
The branch, main has been updated
via 261ec0fd7eba41d675bbf37b597d4f1e5fba4104 (commit)
from 665890e6e384103dede1553ae8ab468271b0515f (commit)
revisions in full, below.
commit 261ec0fd7eba41d675bbf37b597d4f1e5fba4104
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Apr 17 14:40:24 2023 -0700
Improve GEOS C API header doc
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 0b3589eb5..7e0d75fc3 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -16,13 +16,12 @@
* \brief C API for the GEOS geometry algorithms library.
* \tableofcontents
-* The C API is the supported API to use GEOS in
+* The C API is the supported API for using GEOS in
* your application/library/etc.
-* The GEOS team makes an effort to keep the C API stable, and to
-* deprecate function signatures only over a long time period to allow
-* transition time.
-* While the C++ API is available, the ABI
-* will not be stable between versions, and the API may change.
+* The C API is kept stable, and deprecated function signatures
+* are kept available over a long time period to allow transition time.
+* While the C++ API is available, it may change at any time, and the ABI
+* may not be stable between versions.
* Important programming notes:
@@ -30,7 +29,7 @@
* - Call finishGEOS() when finished using the library.
* - To avoid memory leaks, call GEOSGeom_destroy() on
* \ref GEOSGeometry objects, and call GEOSFree() on
-* all returned char * (unless const).
+* returned `char *` strings and byte buffers (unless marked `const`).
* - Functions ending with `_r` are thread safe (reentrant);
* see details in https://libgeos.org/development/rfcs/rfc03.
* To avoid accidental use of non-reentrant functions,
Summary of changes:
capi/geos_c.h.in | 13 ++++++-------
1 file changed, 6 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
