[geos-commits] [SCM] GEOS branch main updated. 7666268c905bbc2fe5c22ce7745c6b9e24519eb7
git at osgeo.org
git at osgeo.org
Mon Apr 17 21:54:48 PDT 2023
the project "GEOS".
The branch, main has been updated
via 7666268c905bbc2fe5c22ce7745c6b9e24519eb7 (commit)
via f97a996cf50984051e3a0d36baf9b14e56004086 (commit)
from 4dc426119d3fbbc85f42c2cf0613d1a7d001190d (commit)
revisions in full, below.
commit 7666268c905bbc2fe5c22ce7745c6b9e24519eb7
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Apr 17 21:54:20 2023 -0700
C API doc formatting
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index e8ef1fed9..cef509caa 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -5129,7 +5129,7 @@ extern void GEOS_DLL GEOSSTRtree_insert(
* \param callback a function to be executed for each item in the tree whose envelope intersects
* the envelope of 'g'. The callback function should take two parameters: a void
* pointer representing the located item in the tree, and a void userdata pointer.
-* \param userdata an optional pointer to pe passed to 'callback' as an argument
+* \param userdata an optional pointer to pe passed to `callback` as an argument
* \since 3.2
@@ -5168,11 +5168,11 @@ extern const GEOSGeometry GEOS_DLL *GEOSSTRtree_nearest(
* \param distancefn a function that can compute the distance between two items
* in the STRtree. The function should return zero in case of error,
* and should store the computed distance to the location pointed to by
-* the 'distance' argument. The computed distance between two items
+* the `distance` argument. The computed distance between two items
* must not exceed the Cartesian distance between their envelopes.
-* \param userdata optional pointer to arbitrary data; will be passed to distancefn
+* \param userdata optional pointer to arbitrary data; will be passed to `distancefn`
* each time it is called.
-* \return a const pointer to the nearest item in the tree to 'item', or NULL in
+* \return a const pointer to the nearest item in the tree to `item`, or NULL in
* case of exception
* \since 3.6
commit f97a996cf50984051e3a0d36baf9b14e56004086
Date: Mon Apr 17 16:33:42 2023 -0700
Minor C API doc improvements
index 53ff9bc70..e8ef1fed9 100644
@@ -97,7 +97,7 @@ typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
* Callback function for passing GEOS error messages to parent process.
-* Set the GEOSMessageHandler for error and notice messages in \ref initGEOS
+* Set the \ref GEOSMessageHandler function for error and notice messages in \ref initGEOS
* for single-threaded programs, or using \ref initGEOS_r for threaded
* programs
@@ -127,10 +127,10 @@ typedef void (*GEOSMessageHandler_r)(const char *message, void *userdata);
#ifndef GEOSGeometry
-* Geometry generic type. Geometry can be a point, linestring, polygon,
-* multipoint, multilinestring, multipolygon, or geometrycollection.
-* Geometry type can be read with \ref GEOSGeomTypeId. Most functions
-* in GEOS either have GEOSGeometry* as a parameter or a return type.
+* The generic type for a geometry. A geometry can be a Point, LineString, Polygon,
+* MultiPoint, MultiLineString, MultiPolygon, or GeometryCollection.
+* The geometry type can be read with \ref GEOSGeomTypeId. Most functions
+* in GEOS have `GEOSGeometry *` as either a parameter or a return type.
* \see GEOSGeom_createPoint
* \see GEOSGeom_createLineString
* \see GEOSGeom_createPolygon
@@ -147,7 +147,8 @@ typedef struct GEOSGeom_t GEOSGeometry;
typedef struct GEOSPrepGeom_t GEOSPreparedGeometry;
-* Coordinate sequence.
+* Coordinate sequence type representing fixed-size lists of coordinates.
+* Contains the list of vertices defining the location of a \ref GEOSGeometry.
* \see GEOSCoordSeq_create()
* \see GEOSCoordSeq_destroy()
Summary of changes:
capi/geos_c.h.in | 21 +++++++++++----------
1 file changed, 11 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
