[geos-commits] [SCM] GEOS branch main updated. f526c4f972f9a0caeecbf282698184933b2c42e4
git at osgeo.org
git at osgeo.org
Tue Apr 18 10:16:25 PDT 2023
the project "GEOS".
The branch, main has been updated
via f526c4f972f9a0caeecbf282698184933b2c42e4 (commit)
from 7666268c905bbc2fe5c22ce7745c6b9e24519eb7 (commit)
revisions in full, below.
commit f526c4f972f9a0caeecbf282698184933b2c42e4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 18 10:15:47 2023 -0700
Move CoverageUnion into the coverage section
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index cef509caa..ea370ad84 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -760,8 +760,14 @@ extern void GEOS_DLL GEOSGeom_destroy_r(
/* ========= Coverages ========= */
+/** \see GEOSCoverageUnion */
+extern GEOSGeometry GEOS_DLL *
+GEOSCoverageUnion_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry* g);
/** \see GEOSCoverageIsValid */
-int
+extern int GEOS_DLL
GEOSCoverageIsValid_r(
GEOSContextHandle_t extHandle,
const GEOSGeometry* input,
@@ -927,11 +933,6 @@ extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec_r(
const GEOSGeometry* g,
double gridSize);
-/** \see GEOSCoverageUnion */
-extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion_r(
- GEOSContextHandle_t handle,
- const GEOSGeometry* g);
/** \see GEOSDisjointSubsetUnion */
extern GEOSGeometry GEOS_DLL *GEOSDisjointSubsetUnion_r(
@@ -3504,18 +3505,6 @@ extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec(
double gridSize);
-* Optimized union algorithm for polygonal inputs that are correctly
-* noded and do not overlap. It will generate an error (return NULL)
-* for inputs that do not satisfy this constraint.
-* \param g The input geometry
-* \return A geometry that covers all the points of the input geometry.
-* Caller is responsible for freeing with GEOSGeom_destroy().
-* \since 3.8
-extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion(const GEOSGeometry *g);
* Optimized union algorithm for inputs that can be divided into subsets
* that do not intersect. If there is only one such subset, performance
@@ -3746,6 +3735,19 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
+* Optimized union algorithm for polygonal inputs that are correctly
+* noded and do not overlap. It will generate an error (return NULL)
+* for inputs that do not satisfy this constraint.
+* \param g The input geometry
+* \return A geometry that covers all the points of the input geometry.
+* Caller is responsible for freeing with GEOSGeom_destroy().
+* \since 3.8
+extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion(const GEOSGeometry *g);
* Analyze a coverage (represented as a collection of polygonal geometry
* with exactly matching edge geometry) to find places where the
Summary of changes:
capi/geos_c.h.in | 38 ++++++++++++++++++++------------------
1 file changed, 20 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
