[geos-commits] [SCM] GEOS branch main updated. 7d20b1772d57c8eba1c12902c812dae9bf58307b
git at osgeo.org
git at osgeo.org
Wed Apr 19 19:54:27 PDT 2023
the project "GEOS".
The branch, main has been updated
via 7d20b1772d57c8eba1c12902c812dae9bf58307b (commit)
from f526c4f972f9a0caeecbf282698184933b2c42e4 (commit)
revisions in full, below.
commit 7d20b1772d57c8eba1c12902c812dae9bf58307b
Author: Mike Taves <mwtoews at gmail.com>
Date: Thu Apr 20 14:54:00 2023 +1200
Change WKTWriter Old3D option to only add "M" for XYM (#871)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index ea370ad84..2179a4f2a 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -5410,8 +5410,9 @@ extern int GEOS_DLL GEOSWKTWriter_getOutputDimension(GEOSWKTWriter *writer);
* Sets the format for 3D outputs. The "old 3D" format does not
-* include a dimensionality tag, eg. "POINT(1 2 3)" while the new (ISO)
-* format does includes a tag, eg "POINT Z (1 2 3)".
+* include a Z dimension tag, e.g. "POINT (1 2 3)", except for XYM,
+* e.g. "POINT M (1 2 3)". Geometries with XYZM coordinates do not add
+* any dimensionality tags, e.g. "POINT (1 2 3 4)".
* \param writer A \ref GEOSWKTWriter.
* \param useOld3D True to use the old format, false is the default.
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 680efd37b..39740894f 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -252,7 +252,10 @@ WKTWriter::appendGeometryTaggedText(const Geometry& geometry,
void
WKTWriter::appendOrdinateText(OrdinateSet outputOrdinates, Writer& writer) const
- if (old3D && !outputOrdinates.hasM()) {
+ if (old3D) {
+ if (!outputOrdinates.hasZ() && outputOrdinates.hasM()) {
+ writer.write("M ");
return;
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 45859f14c..d12227232 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -260,11 +260,21 @@ void object::test<9>
ensure_equals(wktwriter.write(*ls),
std::string("LINESTRING ZM (1 2 3 4, 5 6 7 8)"));
+ wktwriter.setOld3D(true);
+ ensure_equals(wktwriter.write(*ls),
+ std::string("LINESTRING (1 2 3 4, 5 6 7 8)"));
// If only 3 dimensions are allowed we pick Z instead of M
+ wktwriter.setOld3D(false);
wktwriter.setOutputDimension(3);
std::string("LINESTRING Z (1 2 3, 5 6 7)"));
+ std::string("LINESTRING (1 2 3, 5 6 7)"));
// Test writing XYM
@@ -284,6 +294,11 @@ void object::test<10>
std::string("LINESTRING M (1 2 3, 4 5 6)"));
+ // Same output
+ std::string("LINESTRING M (1 2 3, 4 5 6)"));
// Test writing XY
@@ -302,6 +317,11 @@ void object::test<11>
std::string("LINESTRING (1 2, 3 4)"));
+ // Same output
+ std::string("LINESTRING (1 2, 3 4)"));
// Test writing 3D/4D EMPTY geometries
Summary of changes:
capi/geos_c.h.in | 5 +++--
src/io/WKTWriter.cpp | 5 ++++-
tests/unit/io/WKTWriterTest.cpp | 20 ++++++++++++++++++++
3 files changed, 27 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
