[geos-commits] [SCM] GEOS branch main updated. 6e6afa8c95f6f82bf704a8e11da9e7b25ca3b072
git at osgeo.org
git at osgeo.org
Wed Apr 26 11:53:08 PDT 2023
the project "GEOS".
The branch, main has been updated
via 6e6afa8c95f6f82bf704a8e11da9e7b25ca3b072 (commit)
from 787c5541968728105c7a1d1be84869521eab8931 (commit)
revisions in full, below.
commit 6e6afa8c95f6f82bf704a8e11da9e7b25ca3b072
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Apr 26 11:51:57 2023 -0700
Remove Orientation.isCCW exception (#878)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index c68b2ff5e..c701dc163 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2320,8 +2320,7 @@ extern int GEOS_DLL GEOSCoordSeq_getDimensions(
* Check orientation of a coordinate sequence. Closure of the sequence is
-* assumed. Invalid (collapsed) sequences will return false. Short (less
-* than 4 points) sequences will return exception.
+* assumed. Invalid (collapsed) or short (fewer than 4 points) sequences return false.
* \param s the coordinate sequence
* \param is_ccw pointer for ccw value, 1 if counter-clockwise orientation, 0 otherwise
* \return 0 on exception, 1 on success
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index a3edb14c3..55ff3fe82 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -50,8 +50,7 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
int inPts = static_cast<int>(ring->size()) - 1;
// sanity check
if (inPts < 3)
- throw util::IllegalArgumentException(
- "Ring has fewer than 4 points, so orientation cannot be determined");
+ return false;
uint32_t nPts = static_cast<uint32_t>(inPts);
@@ -146,4 +145,3 @@ Orientation::isCCWArea(const geom::CoordinateSequence* ring)
} // namespace geos.algorithm
} //namespace geos
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 9b06b0d91..03feb3efa 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -319,7 +319,8 @@ void object::test<9>
GEOSCoordSeq_setX(cs_, 2, 1);
GEOSCoordSeq_setY(cs_, 2, 0);
- ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
+ ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 1);
+ ensure(!ccw);
template<>
@@ -331,7 +332,8 @@ void object::test<10>
cs_ = GEOSCoordSeq_create(0, 0);
char ccw;
+ ensure(!ccw);
template<>
@@ -765,4 +767,3 @@ void object::test<21>()
} // namespace tut
Summary of changes:
capi/geos_c.h.in | 3 +--
src/algorithm/Orientation.cpp | 4 +---
tests/unit/capi/GEOSCoordSeqTest.cpp | 7 ++++---
3 files changed, 6 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
