[geos-commits] [SCM] GEOS branch main updated. 4e3fbef9f32588e54157568b07bb840a94a415eb
git at osgeo.org
git at osgeo.org
Fri Apr 28 08:49:51 PDT 2023
the project "GEOS".
The branch, main has been updated
via 4e3fbef9f32588e54157568b07bb840a94a415eb (commit)
via d69e17a7922014a68460a721598273c30bea56bc (commit)
via d7ca8d16155bc4f15c5c25b086b331732a5af520 (commit)
from 6e6afa8c95f6f82bf704a8e11da9e7b25ca3b072 (commit)
revisions in full, below.
commit 4e3fbef9f32588e54157568b07bb840a94a415eb
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Apr 28 08:49:21 2023 -0700
Fix doxygen link
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index c701dc163..6a25e4e4f 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -774,7 +774,7 @@ GEOSCoverageIsValid_r(
double gapWidth,
GEOSGeometry** output);
-/** \see GEOSCoverageSimplify */
+/** \see GEOSCoverageSimplifyVW */
extern GEOSGeometry GEOS_DLL *
GEOSCoverageSimplifyVW_r(
GEOSContextHandle_t extHandle,
commit d69e17a7922014a68460a721598273c30bea56bc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Apr 26 13:19:35 2023 -0700
Add an interrupt check to that in interactive use a user can cancel a long-running MaximumInscribedCircle operation, GH-875
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index d8eba69c4..0175788d9 100644
--- a/src/algorithm/construct/MaximumInscribedCircle.cpp
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -28,6 +28,7 @@
#include <geos/geom/MultiPolygon.h>
#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <geos/util/Interrupt.h>
#include <typeinfo> // for dynamic_cast
#include <cassert>
@@ -184,12 +185,15 @@ MaximumInscribedCircle::compute()
* Carry out the branch-and-bound search
* of the cell space
+ std::size_t iterationCount = 0;
while (!cellQueue.empty()) {
// pick the most promising cell from the queue
Cell cell = cellQueue.top();
cellQueue.pop();
- // std::cout << i << ": (" << cell.getX() << ", " << cell.getY() << ") " << cell.getHSize() << " dist = " << cell.getDistance() << std::endl;
+ if ((iterationCount++ % 1000) == 0) {
+ GEOS_CHECK_FOR_INTERRUPTS();
// update the center cell if the candidate is further from the boundary
if (cell.getDistance() > farthestCell.getDistance()) {
@@ -212,7 +216,6 @@ MaximumInscribedCircle::compute()
cellQueue.emplace(cell.getX()+h2, cell.getY()+h2, h2, distanceToBoundary(cell.getX()+h2, cell.getY()+h2));
- // std::cout << "number of iterations: " << i << std::endl;
// the farthest cell is the best approximation to the MIC center
Cell centerCell = farthestCell;
commit d7ca8d16155bc4f15c5c25b086b331732a5af520
Date: Wed Apr 26 12:56:44 2023 -0700
Fix Coverage ops to handle empty and collapsed cases (#879)
diff --git a/include/geos/coverage/CoverageEdge.h b/include/geos/coverage/CoverageEdge.h
index a75c3ecf8..6404b653f 100644
--- a/include/geos/coverage/CoverageEdge.h
+++ b/include/geos/coverage/CoverageEdge.h
@@ -63,12 +63,12 @@ private:
// Methods
static std::unique_ptr<CoordinateSequence>
- extractEdgePoints(const LinearRing* ring,
+ extractEdgePoints(const CoordinateSequence& ring,
std::size_t start, std::size_t end);
static const Coordinate&
findDistinctPoint(
- const CoordinateSequence* pts,
+ const CoordinateSequence& pts,
std::size_t index,
bool isForward,
const Coordinate& pt);
@@ -91,7 +91,7 @@ public:
* @return a LineSegment representing the key
static LineSegment key(
- const LinearRing* ring);
+ const CoordinateSequence& ring);
* Computes a distinct key for a section of a linear ring.
@@ -102,15 +102,15 @@ public:
- const LinearRing* ring,
+ const CoordinateSequence& ring,
std::size_t start,
std::size_t end);
static std::unique_ptr<CoverageEdge> createEdge(
std::size_t start,
std::size_t end);
@@ -169,8 +169,3 @@ public:
} // namespace geos.coverage
} // namespace geos
diff --git a/include/geos/coverage/CoveragePolygonValidator.h b/include/geos/coverage/CoveragePolygonValidator.h
index efa739e1f..c0150c895 100644
--- a/include/geos/coverage/CoveragePolygonValidator.h
+++ b/include/geos/coverage/CoveragePolygonValidator.h
@@ -372,6 +372,11 @@ private:
void createRings(const Polygon* poly, std::vector<CoverageRing*>& rings);
+ void addRing(
+ const LinearRing* ring,
+ bool isShell,
+ std::vector<CoverageRing*>& rings);
CoverageRing* createRing(const LinearRing* ring, bool isShell);
@@ -380,11 +385,3 @@ private:
} // namespace geos::coverage
} // namespace geos
diff --git a/include/geos/coverage/CoverageRingEdges.h b/include/geos/coverage/CoverageRingEdges.h
index f57473bcd..a6c82561a 100644
--- a/include/geos/coverage/CoverageRingEdges.h
+++ b/include/geos/coverage/CoverageRingEdges.h
@@ -121,7 +121,7 @@ private:
LineSegment::UnorderedSet& boundarySegs,
std::map<LineSegment, CoverageEdge*>& uniqueEdgeMap);
- void addBoundaryNodes(
+ void addBoundaryInnerNodes(
Coordinate::UnorderedSet& nodes);
@@ -132,24 +132,24 @@ private:
CoverageEdge* createEdge(
std::size_t start, std::size_t end,
std::size_t findNextNodeIndex(
std::size_t start,
Coordinate::UnorderedSet& nodes) const;
static std::size_t next(
std::size_t index,
- Coordinate::UnorderedSet findNodes(
+ Coordinate::UnorderedSet findMultiRingNodes(
std::vector<const Geometry*>& coverage);
Coordinate::UnorderedSet findBoundaryNodes(
@@ -177,8 +177,3 @@ private:
} // namespace geos
diff --git a/include/geos/coverage/VertexCounter.h b/include/geos/coverage/VertexRingCounter.h
similarity index 90%
rename from include/geos/coverage/VertexCounter.h
rename to include/geos/coverage/VertexRingCounter.h
index bf10ea3c0..3d1151cd4 100644
--- a/include/geos/coverage/VertexCounter.h
+++ b/include/geos/coverage/VertexRingCounter.h
@@ -36,12 +36,12 @@ using geos::geom::Geometry;
namespace geos {
namespace coverage { // geos::coverage
-class VertexCounter : public CoordinateSequenceFilter
+class VertexRingCounter : public CoordinateSequenceFilter
public:
- VertexCounter(std::map<Coordinate, std::size_t>& counts)
+ VertexRingCounter(std::map<Coordinate, std::size_t>& counts)
: vertexCounts(counts)
@@ -63,7 +63,7 @@ private:
std::map<Coordinate, std::size_t>& vertexCounts;
-}; // VertexCounter
+}; // VertexRingCounter
diff --git a/src/coverage/CoverageBoundarySegmentFinder.cpp b/src/coverage/CoverageBoundarySegmentFinder.cpp
index 582188613..9744f630b 100644
--- a/src/coverage/CoverageBoundarySegmentFinder.cpp
+++ b/src/coverage/CoverageBoundarySegmentFinder.cpp
@@ -85,5 +85,3 @@ CoverageBoundarySegmentFinder::isBoundarySegment(
} // namespace geos
diff --git a/src/coverage/CoverageEdge.cpp b/src/coverage/CoverageEdge.cpp
index f98ec5111..a2114b992 100644
--- a/src/coverage/CoverageEdge.cpp
+++ b/src/coverage/CoverageEdge.cpp
@@ -33,15 +33,15 @@ namespace coverage { // geos.coverage
/* public static */
-CoverageEdge::createEdge(const LinearRing* ring)
+CoverageEdge::createEdge(const CoordinateSequence& ring)
- auto pts = extractEdgePoints(ring, 0, ring->getNumPoints() - 1);
+ auto pts = extractEdgePoints(ring, 0, ring.getSize() - 1);
return detail::make_unique<CoverageEdge>(std::move(pts), true);
/* public static */
-CoverageEdge::createEdge(const LinearRing* ring,
+CoverageEdge::createEdge(const CoordinateSequence& ring,
auto pts = extractEdgePoints(ring, start, end);
@@ -73,19 +73,18 @@ CoverageEdge::toLineString(const GeometryFactory* geomFactory)
/* private static */
-CoverageEdge::extractEdgePoints(const LinearRing* ring,
+CoverageEdge::extractEdgePoints(const CoordinateSequence& ring,
auto pts = detail::make_unique<CoordinateSequence>();
std::size_t size = start < end
? end - start + 1
- : ring->getNumPoints() - start + end;
+ : ring.getSize() - start + end;
std::size_t iring = start;
- auto cs = ring->getCoordinatesRO();
for (std::size_t i = 0; i < size; i++) {
- pts->add(cs->getAt(iring));
+ pts->add(ring.getAt(iring));
iring += 1;
- if (iring >= ring->getNumPoints())
+ if (iring >= ring.getSize())
iring = 1;
return pts;
@@ -94,19 +93,18 @@ CoverageEdge::extractEdgePoints(const LinearRing* ring,
/* public static */
LineSegment
-CoverageEdge::key(const LinearRing* ring)
+CoverageEdge::key(const CoordinateSequence& ring)
- const CoordinateSequence* pts = ring->getCoordinatesRO();
// find lowest vertex index
std::size_t indexLow = 0;
- for (std::size_t i = 1; i < pts->size() - 1; i++) {
- if (pts->getAt(indexLow).compareTo(pts->getAt(i)) < 0)
+ for (std::size_t i = 1; i < ring.size() - 1; i++) {
+ if (ring.getAt(indexLow).compareTo(ring.getAt(i)) < 0)
indexLow = i;
- const Coordinate& key0 = pts->getAt(indexLow);
+ const Coordinate& key0 = ring.getAt(indexLow);
// find distinct adjacent vertices
- const Coordinate& adj0 = findDistinctPoint(pts, indexLow, true, key0);
- const Coordinate& adj1 = findDistinctPoint(pts, indexLow, false, key0);
+ const Coordinate& adj0 = findDistinctPoint(ring, indexLow, true, key0);
+ const Coordinate& adj1 = findDistinctPoint(ring, indexLow, false, key0);
const Coordinate& key1 = adj0.compareTo(adj1) < 0 ? adj0 : adj1;
return LineSegment(key0, key1);
@@ -114,23 +112,22 @@ CoverageEdge::key(const LinearRing* ring)
/* public static */
LineSegment
-CoverageEdge::key(const LinearRing* ring,
+CoverageEdge::key(const CoordinateSequence& ring,
//-- endpoints are distinct in a line edge
- const Coordinate& end0 = pts->getAt(start);
- const Coordinate& end1 = pts->getAt(end);
+ const Coordinate& end0 = ring.getAt(start);
+ const Coordinate& end1 = ring.getAt(end);
bool isForward = 0 > end0.compareTo(end1);
const Coordinate* key0;
const Coordinate* key1;
if (isForward) {
key0 = &end0;
- key1 = &findDistinctPoint(pts, start, true, *key0);
+ key1 = &findDistinctPoint(ring, start, true, *key0);
else {
key0 = &end1;
- key1 = &findDistinctPoint(pts, end, false, *key0);
+ key1 = &findDistinctPoint(ring, end, false, *key0);
return LineSegment(*key0, *key1);
@@ -138,16 +135,16 @@ CoverageEdge::key(const LinearRing* ring,
const Coordinate&
CoverageEdge::findDistinctPoint(
std::size_t index,
bool isForward,
std::size_t i = index;
- std::size_t endIndex = pts->size()-1;
+ std::size_t endIndex = pts.size()-1;
do {
- if (! pts->getAt(i).equals2D(pt)) {
- return pts->getAt(i);
+ if (! pts.getAt(i).equals2D(pt)) {
+ return pts.getAt(i);
// increment index with wrapping
if (isForward) {
@@ -173,5 +170,3 @@ CoverageEdge::findDistinctPoint(
} // namespace geos
diff --git a/src/coverage/CoveragePolygonValidator.cpp b/src/coverage/CoveragePolygonValidator.cpp
index 73af48da6..a99643903 100644
--- a/src/coverage/CoveragePolygonValidator.cpp
+++ b/src/coverage/CoveragePolygonValidator.cpp
@@ -373,14 +373,26 @@ CoveragePolygonValidator::createRings(
// Create exterior shell ring
- rings.push_back(createRing(poly->getExteriorRing(), true));
+ addRing( poly->getExteriorRing(), true, rings);
// Create hole rings
for (std::size_t i = 0; i < poly->getNumInteriorRing(); i++) {
- rings.push_back(createRing(poly->getInteriorRingN(i), false));
+ addRing( poly->getInteriorRingN(i), false, rings);
+/* private */
+void
+CoveragePolygonValidator::addRing(
+ bool isShell,
+ if (ring->isEmpty())
+ return;
+ rings.push_back(createRing(ring, isShell));
/* private */
CoverageRing*
CoveragePolygonValidator::createRing(const LinearRing* ring, bool isShell)
@@ -403,5 +415,3 @@ CoveragePolygonValidator::createRing(const LinearRing* ring, bool isShell)
} // namespace geos
diff --git a/src/coverage/CoverageRingEdges.cpp b/src/coverage/CoverageRingEdges.cpp
index dea6f350e..c334e47f5 100644
--- a/src/coverage/CoverageRingEdges.cpp
+++ b/src/coverage/CoverageRingEdges.cpp
@@ -18,7 +18,7 @@
#include <geos/coverage/CoverageBoundarySegmentFinder.h>
#include <geos/coverage/CoverageEdge.h>
#include <geos/coverage/CoverageRingEdges.h>
-#include <geos/coverage/VertexCounter.h>
+#include <geos/coverage/VertexRingCounter.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/Geometry.h>
@@ -27,10 +27,10 @@
#include <geos/geom/LinearRing.h>
#include <geos/geom/Polygon.h>
+#include <geos/operation/valid/RepeatedPointRemover.h>
#include <geos/util/IllegalStateException.h>
#include <geos/constants.h>
using geos::geom::Coordinate;
using geos::geom::CoordinateSequence;
@@ -39,7 +39,7 @@ using geos::geom::LineSegment;
using geos::geom::LinearRing;
using geos::geom::Polygon;
using geos::geom::MultiPolygon;
+using geos::operation::valid::RepeatedPointRemover;
namespace geos { // geos
@@ -63,7 +63,7 @@ CoverageRingEdges::selectEdges(std::size_t ringCount) const
void
CoverageRingEdges::build()
- Coordinate::UnorderedSet nodes = findNodes(m_coverage);
+ Coordinate::UnorderedSet nodes = findMultiRingNodes(m_coverage);
LineSegment::UnorderedSet boundarySegs = CoverageBoundarySegmentFinder::findBoundarySegments(m_coverage);
Coordinate::UnorderedSet boundaryNodes = findBoundaryNodes(boundarySegs);
nodes.insert(boundaryNodes.begin(), boundaryNodes.end());
@@ -72,12 +72,20 @@ CoverageRingEdges::build()
for (const Geometry* geom : m_coverage) {
for (std::size_t ipoly = 0; ipoly < geom->getNumGeometries(); ipoly++) {
const Polygon* poly = static_cast<const Polygon*>(geom->getGeometryN(ipoly));
+ //-- skip empty elements. Missing elements are copied in result
+ if (poly->isEmpty())
+ continue;
//-- extract shell
const LinearRing* shell = poly->getExteriorRing();
addRingEdges(shell, nodes, boundarySegs, uniqueEdgeMap);
//-- extract holes
for (std::size_t ihole = 0; ihole < poly->getNumInteriorRing(); ihole++) {
const LinearRing* hole = poly->getInteriorRingN(ihole);
+ //-- skip empty rings. Missing rings are copied in result
+ if (hole->isEmpty())
+ continue;
addRingEdges(hole, nodes, boundarySegs, uniqueEdgeMap);
@@ -92,14 +100,16 @@ CoverageRingEdges::addRingEdges(
- addBoundaryNodes(ring, boundarySegs, nodes);
+ addBoundaryInnerNodes(ring, boundarySegs, nodes);
std::vector<CoverageEdge*> ringEdges = extractRingEdges(ring, uniqueEdgeMap, nodes);
- m_ringEdgesMap[ring] = ringEdges;
+ if (ringEdges.size() > 0) {
+ m_ringEdgesMap[ring] = ringEdges;
/* private */
void
-CoverageRingEdges::addBoundaryNodes(
+CoverageRingEdges::addBoundaryInnerNodes(
@@ -124,19 +134,25 @@ CoverageRingEdges::extractRingEdges(
std::map<LineSegment, CoverageEdge*>& uniqueEdgeMap,
+ std::unique_ptr<CoordinateSequence> pts
+ = RepeatedPointRemover::removeRepeatedPoints( ring->getCoordinatesRO() );
std::vector<CoverageEdge*> ringEdges;
- std::size_t first = findNextNodeIndex(ring, NO_COORD_INDEX, nodes);
+ //-- if compacted ring is too short, don't process it
+ if (pts->getSize() < 3)
+ return ringEdges;
+ std::size_t first = findNextNodeIndex(*pts, NO_COORD_INDEX, nodes);
if (first == NO_COORD_INDEX) {
//-- ring does not contain a node, so edge is entire ring
- CoverageEdge* edge = createEdge(ring, uniqueEdgeMap);
+ CoverageEdge* edge = createEdge(*pts, uniqueEdgeMap);
ringEdges.push_back(edge);
else {
std::size_t start = first;
std::size_t end = start;
do {
- end = findNextNodeIndex(ring, start, nodes);
- CoverageEdge* edge = createEdge(ring, start, end, uniqueEdgeMap);
+ end = findNextNodeIndex(*pts, start, nodes);
+ CoverageEdge* edge = createEdge(*pts, start, end, uniqueEdgeMap);
start = end;
} while (end != first);
@@ -147,7 +163,7 @@ CoverageRingEdges::extractRingEdges(
/* private */
CoverageEdge*
CoverageRingEdges::createEdge(
CoverageEdge* edge;
@@ -173,7 +189,7 @@ CoverageRingEdges::createEdge(
/* private */
CoverageEdge*
@@ -200,7 +216,7 @@ CoverageRingEdges::createEdge(
/* private */
std::size_t
CoverageRingEdges::findNextNodeIndex(
std::size_t start,
@@ -214,7 +230,7 @@ CoverageRingEdges::findNextNodeIndex(
isScanned0 = true;
- const Coordinate& pt = ring->getCoordinatesRO()->getAt(index);
+ const Coordinate& pt = ring.getAt(index);
if (nodes.find(pt) != nodes.end()) {
return index;
@@ -224,11 +240,11 @@ CoverageRingEdges::findNextNodeIndex(
std::size_t
-CoverageRingEdges::next(std::size_t index, const LinearRing* ring)
+CoverageRingEdges::next(std::size_t index, const CoordinateSequence& ring)
if (index == NO_COORD_INDEX) return 0;
index = index + 1;
- if (index >= ring->getNumPoints() - 1)
+ if (index >= ring.getSize() - 1)
index = 0;
return index;
@@ -236,17 +252,17 @@ CoverageRingEdges::next(std::size_t index, const LinearRing* ring)
/* private */
-CoverageRingEdges::findNodes(std::vector<const Geometry*>& coverage)
+CoverageRingEdges::findMultiRingNodes(std::vector<const Geometry*>& coverage)
- std::map<Coordinate, std::size_t> vertexCount;
- VertexCounter::count(coverage, vertexCount);
+ std::map<Coordinate, std::size_t> vertexRingCount;
+ VertexRingCounter::count(coverage, vertexRingCount);
Coordinate::UnorderedSet nodes;
// for (Coordinate v : vertexCount.keySet()) {
// if (vertexCount.get(v) > 2) {
// nodes.add(v);
- for (const auto &mapPair : vertexCount) {
+ for (const auto &mapPair : vertexRingCount) {
const Coordinate& v = mapPair.first;
std::size_t count = mapPair.second;
if (count > 2)
@@ -258,26 +274,26 @@ CoverageRingEdges::findNodes(std::vector<const Geometry*>& coverage)
/* private */
-CoverageRingEdges::findBoundaryNodes(LineSegment::UnorderedSet& lineSegments)
+CoverageRingEdges::findBoundaryNodes(LineSegment::UnorderedSet& boundarySegments)
std::map<Coordinate, std::size_t> counter;
- for (const LineSegment& line : lineSegments) {
+ for (const LineSegment& seg : boundarySegments) {
// counter.put(line.p0, counter.getOrDefault(line.p0, 0) + 1);
// counter.put(line.p1, counter.getOrDefault(line.p1, 0) + 1);
- auto search0 = counter.find(line.p0);
+ auto search0 = counter.find(seg.p0);
if (search0 != counter.end()) {
- counter[line.p0] = search0->second + 1;
+ counter[seg.p0] = search0->second + 1;
else {
- counter[line.p0] = 0;
+ counter[seg.p0] = 0;
- auto search1 = counter.find(line.p1);
+ auto search1 = counter.find(seg.p1);
if (search1 != counter.end()) {
- counter[line.p1] = search1->second + 1;
+ counter[seg.p1] = search1->second + 1;
else {
- counter[line.p1] = 0;
+ counter[seg.p1] = 0;
@@ -360,8 +376,8 @@ CoverageRingEdges::buildRing(const LinearRing* ring) const
// List<CoverageEdge> ringEdges = m_ringEdgesMap.get(ring);
auto result = m_ringEdgesMap.find(ring);
if (result == m_ringEdgesMap.end()) {
- // return nullptr;
- throw util::IllegalStateException("buildRing");
+ //-- if ring is not in map, must have been invalid. Just copy original
+ return ring->clone();
else {
ringEdges = &(result->second);
@@ -404,5 +420,3 @@ CoverageRingEdges::isEdgeDirForward(
} // namespace geos
diff --git a/src/coverage/CoverageSimplifier.cpp b/src/coverage/CoverageSimplifier.cpp
index cd4b7d164..73b5a5e44 100644
--- a/src/coverage/CoverageSimplifier.cpp
+++ b/src/coverage/CoverageSimplifier.cpp
@@ -17,7 +17,6 @@
#include <geos/coverage/TPVWSimplifier.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/MultiLineString.h>
diff --git a/src/coverage/VertexCounter.cpp b/src/coverage/VertexRingCounter.cpp
similarity index 88%
rename from src/coverage/VertexCounter.cpp
rename to src/coverage/VertexRingCounter.cpp
index 6415b9138..c0d79cab9 100644
--- a/src/coverage/VertexCounter.cpp
+++ b/src/coverage/VertexRingCounter.cpp
@@ -13,7 +13,7 @@
@@ -32,11 +32,11 @@ namespace coverage { // geos.coverage
/* public static */
void
-VertexCounter::count(
+VertexRingCounter::count(
std::vector<const Geometry*>& geoms,
- VertexCounter vertextCounter(counts);
+ VertexRingCounter vertextCounter(counts);
for (const Geometry* geom : geoms) {
geom->apply_ro(vertextCounter);
@@ -45,7 +45,7 @@ VertexCounter::count(
/* public */
void
-VertexCounter::filter_ro(const CoordinateSequence& seq, std::size_t i)
+VertexRingCounter::filter_ro(const CoordinateSequence& seq, std::size_t i)
//-- for rings don't double-count duplicate endpoint
if (seq.isRing() && i == 0)
diff --git a/tests/unit/coverage/CoverageRingEdgesTest.cpp b/tests/unit/coverage/CoverageRingEdgesTest.cpp
index 9c8b17648..43c25140e 100644
--- a/tests/unit/coverage/CoverageRingEdgesTest.cpp
+++ b/tests/unit/coverage/CoverageRingEdgesTest.cpp
@@ -137,5 +137,15 @@ void object::test<5> ()
"MULTILINESTRING ((1 2, 2 2), (2 1, 2 2), (2 2, 2 3), (2 2, 3 2))");
+// testMultiPolygons
+template<>
+template<>
+void object::test<6> ()
+ checkEdges(
+ "GEOMETRYCOLLECTION (MULTIPOLYGON (((5 9, 2.5 7.5, 1 5, 5 5, 5 9)), ((5 5, 9 5, 7.5 2.5, 5 1, 5 5))), MULTIPOLYGON (((5 9, 6.5 6.5, 9 5, 5 5, 5 9)), ((1 5, 5 5, 5 1, 3.5 3.5, 1 5))))",
+ "MULTILINESTRING ((1 5, 2.5 7.5, 5 9), (1 5, 3.5 3.5, 5 1), (1 5, 5 5), (5 1, 5 5), (5 1, 7.5 2.5, 9 5), (5 5, 5 9), (5 5, 9 5), (5 9, 6.5 6.5, 9 5))"
} // namespace tut
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index 64e4a1a01..04bd69c33 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -367,21 +367,101 @@ void object::test<19> ()
-// all inputs empty
-// template<>
-// template<>
-// void object::test<20> ()
-// checkResult(readArray({
-// "POLYGON EMPTY",
-// "POLYGON EMPTY" }),
-// 1.5,
-// readArray({
+// testRepeatedPointRemoved
+template<>
+template<>
+void object::test<20> ()
+ checkResult(readArray({
+ "POLYGON ((5 9, 6.5 6.5, 9 5, 5 5, 5 5, 5 9))" }),
+ 2,
+ readArray({
+ "POLYGON ((5 5, 5 9, 9 5, 5 5))" })
+// testRepeatedPointCollapseToLine
+template<>
+template<>
+void object::test<21> ()
+checkResult(readArray({
+ "MULTIPOLYGON (((10 10, 10 20, 20 19, 30 20, 30 10, 10 10)), ((10 30, 20 29, 30 30, 30 20, 20 19, 10 20, 10 30)), ((10 20, 20 19, 20 19, 10 20)))" }),
+ 5,
+ readArray({
+ "MULTIPOLYGON (((10 20, 20 19, 30 20, 30 10, 10 10, 10 20)), ((30 20, 20 19, 10 20, 10 30, 30 30, 30 20)), ((10 20, 20 19, 10 20)))" })
+// testRepeatedPointCollapseToPoint()
+template<>
+template<>
+void object::test<22> ()
+ "MULTIPOLYGON (((10 10, 10 20, 20 19, 30 20, 30 10, 10 10)), ((10 30, 20 29, 30 30, 30 20, 20 19, 10 20, 10 30)), ((20 19, 20 19, 20 19)))" }),
+ 5,
+ readArray({
+ "MULTIPOLYGON (((10 10, 10 20, 20 19, 30 20, 30 10, 10 10)), ((10 20, 10 30, 30 30, 30 20, 20 19, 10 20)), ((20 19, 20 19, 20 19)))" })
+// testRepeatedPointCollapseToPoint2
+template<>
+template<>
+void object::test<23> ()
+ "MULTIPOLYGON (((100 200, 150 195, 200 200, 200 100, 100 100, 100 200)), ((150 195, 150 195, 150 195, 150 195)))" }),
+ 40,
+ readArray({
+ "MULTIPOLYGON (((150 195, 200 200, 200 100, 100 100, 100 200, 150 195)), ((150 195, 150 195, 150 195, 150 195)))" })
+// testAllEmpty()
+template<>
+template<>
+void object::test<24> ()
+ "POLYGON EMPTY",
+ "POLYGON EMPTY" }),
+ 1,
+ readArray({
+ "POLYGON EMPTY",
+// testOneEmpty
+template<>
+template<>
+void object::test<25> ()
+ "POLYGON ((1 9, 5 9.1, 9 9, 9 1, 1 1, 1 9))",
+ 1,
+ readArray({
+ "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+// testEmptyHole()
+template<>
+template<>
+void object::test<26> ()
+ "POLYGON ((1 9, 5 9.1, 9 9, 9 1, 1 1, 1 9), EMPTY)",
+ 1,
+ readArray({
+ "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9), EMPTY)",
} // namespace tut
diff --git a/tests/unit/coverage/CoverageValidatorTest.cpp b/tests/unit/coverage/CoverageValidatorTest.cpp
index fd8bc6cd6..1f7259e5b 100644
--- a/tests/unit/coverage/CoverageValidatorTest.cpp
+++ b/tests/unit/coverage/CoverageValidatorTest.cpp
@@ -282,6 +282,73 @@ void object::test<10> ()
checkValid(coverage);
+template<>
+template<>
+void object::test<11> ()
+ std::vector<std::string> coverage{
+ "MULTIPOLYGON (((1 9, 5 9, 5 5, 1 5, 1 9)), ((9 1, 5 1, 5 5, 9 5, 9 1)))",
+ "MULTIPOLYGON (((1 1, 1 5, 5 5, 5 1, 1 1)), ((9 9, 9 5, 5 5, 5 9, 9 9)))"
+ checkValid(coverage);
+// testValidDuplicatePoints
+template<>
+template<>
+void object::test<12> ()
+ "POLYGON ((1 9, 5 9, 5 5, 1 5, 1 5, 1 5, 1 9))",
+ "POLYGON ((9 9, 9 5, 5 5, 5 9, 9 9))",
+ "POLYGON ((1 1, 1 5, 5 5, 5 1, 1 1))",
+ "POLYGON ((9 1, 5 1, 5 5, 9 5, 9 1))"
+// testRingCollapse
+template<>
+template<>
+void object::test<13> ()
+ "POLYGON ((1 9, 5 9, 1 9))",
+ //======== Valid cases with EMPTY =============================
+// testPolygonEmpty
+template<>
+template<>
+void object::test<14> ()
+ "POLYGON ((1 9, 5 9, 5 5, 1 5, 1 9))",
+ "POLYGON EMPTY"
+// testMultiPolygonWithEmptyRing
+template<>
+template<>
+void object::test<15> ()
+ "MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7 7, 9 9)), EMPTY)"
Summary of changes:
capi/geos_c.h.in | 2 +-
include/geos/coverage/CoverageEdge.h | 17 ++--
include/geos/coverage/CoveragePolygonValidator.h | 13 +--
include/geos/coverage/CoverageRingEdges.h | 17 ++--
.../{VertexCounter.h => VertexRingCounter.h} | 6 +-
src/algorithm/construct/MaximumInscribedCircle.cpp | 7 +-
src/coverage/CoverageBoundarySegmentFinder.cpp | 2 -
src/coverage/CoverageEdge.cpp | 49 +++++----
src/coverage/CoveragePolygonValidator.cpp | 18 +++-
src/coverage/CoverageRingEdges.cpp | 80 ++++++++-------
src/coverage/CoverageSimplifier.cpp | 1 -
.../{VertexCounter.cpp => VertexRingCounter.cpp} | 8 +-
tests/unit/coverage/CoverageRingEdgesTest.cpp | 10 ++
tests/unit/coverage/CoverageSimplifierTest.cpp | 110 ++++++++++++++++++---
tests/unit/coverage/CoverageValidatorTest.cpp | 67 +++++++++++++
15 files changed, 285 insertions(+), 122 deletions(-)
rename include/geos/coverage/{VertexCounter.h => VertexRingCounter.h} (90%)
rename src/coverage/{VertexCounter.cpp => VertexRingCounter.cpp} (88%)
hooks/post-receive
More information about the geos-commits
