[geos-commits] [SCM] GEOS branch 3.11 updated. 16cbc61f0d547f8cc347ed01ab30d75a3c236e30
git at osgeo.org
git at osgeo.org
Fri Apr 28 09:33:47 PDT 2023
the project "GEOS".
The branch, 3.11 has been updated
via 16cbc61f0d547f8cc347ed01ab30d75a3c236e30 (commit)
from 17d1650dd8ad2eebc1dd0ae00e228be0c16b3bd6 (commit)
revisions in full, below.
commit 16cbc61f0d547f8cc347ed01ab30d75a3c236e30
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Apr 28 09:33:20 2023 -0700
Bump up GHA checkout action to v3
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 4d80b06d0..dd75ede8a 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -86,7 +86,7 @@ jobs:
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
- uses: actions/checkout at v2
+ uses: actions/checkout at v3
- name: 'Build'
env:
@@ -142,7 +142,7 @@ jobs:
shell: msys2 {0}
steps:
- name: 'Check Out'
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -171,7 +171,7 @@ jobs:
shell: msys2 {0}
steps:
- name: 'Check Out'
- name: 'Setup'
@@ -197,7 +197,7 @@ jobs:
runs-on: windows-2022
steps:
- name: 'Check Out'
- name: 'Build'
run: |
@@ -217,7 +217,7 @@ jobs:
runs-on: windows-2019
steps:
- name: 'Check Out'
- name: 'Build'
run: |
@@ -237,7 +237,7 @@ jobs:
# runs-on: windows-2016
# steps:
# - name: 'Check Out'
- # uses: actions/checkout at v2
+ # uses: actions/checkout at v3
# - name: 'Build'
# run: |
@@ -266,7 +266,7 @@ jobs:
- name: 'Check Out'
with:
path: geos
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 1f6a6574e..74d5615ce 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -22,7 +22,7 @@ jobs:
steps:
- name: 'Check Out'
- name: Set up Docker Buildx
uses: docker/setup-buildx-action at v1
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 4afb464a6..377aa8d71 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: 'Check Out'
- name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 3a98e7ca2..d91ccbde4 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -26,7 +26,7 @@ jobs:
- name: 'Check Out 📗'
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
.github/workflows/ci.yml | 14 +++++++-------
.github/workflows/container.yml | 2 +-
.github/workflows/release.yml | 2 +-
.github/workflows/web.yml | 2 +-
4 files changed, 10 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
