[geos-commits] [SCM] GEOS branch 3.12 updated. 87bf94a3227626bba6a94fe65abd3b6bd2344fa6
Tue Aug 15 20:26:05 PDT 2023
the project "GEOS".
The branch, 3.12 has been updated
       via  87bf94a3227626bba6a94fe65abd3b6bd2344fa6 (commit)
      from  60e59750f2476162bbbacafcb6b87a95b57a5e6d (commit)
revisions in full, below.
commit 87bf94a3227626bba6a94fe65abd3b6bd2344fa6
Author: Aaron Barany <aaron.barany at here.com>
Date:   Tue Aug 15 20:25:35 2023 -0700
    Fix CMake on Windows with Visual Studio (#945)
    Avoid setting CMAKE_BUILD_TYPE default when multi-config generators are
    used.
    Avoid setting CMAKE_BUILD_TYPE STRINGS property if it is not a cache
    variable. This avoids CMake errors if CMAKE_BUILD_TYPE isn't set on the
    command-line.
    Closes #932
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 7a2906c73..7888f193c 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -114,8 +114,12 @@ endif()
 # Make sure we know our build type
 if(NOT CMAKE_BUILD_TYPE)
-  set(CMAKE_BUILD_TYPE ${DEFAULT_BUILD_TYPE})
-  message(STATUS "GEOS: Using default build type: ${CMAKE_BUILD_TYPE}")
+  get_property(_is_multi_config_generator GLOBAL PROPERTY GENERATOR_IS_MULTI_CONFIG)
+  if (NOT _is_multi_config_generator)
+    set(CMAKE_BUILD_TYPE ${DEFAULT_BUILD_TYPE})
+    message(STATUS "GEOS: Using default build type: ${CMAKE_BUILD_TYPE}")
+  endif()
+  unset(_is_multi_config_generator)
 else()
   message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
 endif()
@@ -186,7 +190,11 @@ set(CMAKE_CXX_FLAGS_ASAN "${CMAKE_CXX_FLAGS_DEBUG} -fsanitize=address -fno-omit-
 set(CMAKE_EXE_LINKER_FLAGS_ASAN "${CMAKE_EXE_LINKER_FLAGS_DEBUG} -fsanitize=address")
 set(CMAKE_SHARED_LINKER_FLAGS_ASAN "${CMAKE_SHARED_LINKER_FLAGS_DEBUG} -fsanitize=address")
-set_property(CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS "Debug" "Release" "MinSizeRel" "RelWithDebInfo" "ASAN")
+get_property(_cmake_build_type_is_cache CACHE CMAKE_BUILD_TYPE PROPERTY TYPE)
+if (_cmake_build_type_is_cache)
+  set_property(CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS "Debug" "Release" "MinSizeRel" "RelWithDebInfo" "ASAN")
+endif()
+unset(_cmake_build_type_is_cache)
 # Install directories
Summary of changes:
 CMakeLists.txt | 14 +++++++++++---
 1 file changed, 11 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
