[geos-commits] [SCM] GEOS branch main updated. 15185e65b3e7bc671cf693c97cf103125fb4a171
Mon Aug 28 14:29:08 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  15185e65b3e7bc671cf693c97cf103125fb4a171 (commit)
       via  40da3a61338068549eabe19f68d1cf082cece853 (commit)
      from  feaa331749598866ffc47c3f2bef828eaa4eff8f (commit)
revisions in full, below.
commit 15185e65b3e7bc671cf693c97cf103125fb4a171
Author: Mike Taves <mwtoews at gmail.com>
Date:   Tue Aug 29 09:28:35 2023 +1200
    Doc: describe empty geometry for getNumGeometries (#950)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 271624334..37502912c 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2580,6 +2580,8 @@ extern void GEOS_DLL *GEOSGeom_getUserData(const GEOSGeometry* g);
 * multi-geometry or collection or 1 for a simple geometry.
 * For nested collections, remember to check if returned
 * sub-geometries are **themselves** also collections.
+* Empty collection or multi-geometry types return 0,
+* and empty simple geometry types return 1.
 * \param g Input geometry
 * \return Number of direct children in this collection
 * \warning For GEOS < 3.2 this function may crash when fed simple geometries
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 38343cee2..cfa989a9a 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -302,8 +302,13 @@ public:
     /// Return an integer representation of this Geometry type
     virtual GeometryTypeId getGeometryTypeId() const = 0; //Abstract
-    /// Returns the number of geometries in this collection
-    /// (or 1 if this is not a collection)
+     * \brief Returns the number of geometries in this collection,
+     * or 1 if this is not a collection.
+     * Empty collection or multi-geometry types return 0,
+     * and empty simple geometry types return 1.
     virtual std::size_t
     getNumGeometries() const
commit 40da3a61338068549eabe19f68d1cf082cece853
Author: Aaron Barany <aaron.barany at here.com>
Date:   Tue Aug 15 20:25:35 2023 -0700
    Fix CMake on Windows with Visual Studio (#945)
    Avoid setting CMAKE_BUILD_TYPE default when multi-config generators are
    used.
    Avoid setting CMAKE_BUILD_TYPE STRINGS property if it is not a cache
    variable. This avoids CMake errors if CMAKE_BUILD_TYPE isn't set on the
    command-line.
    Closes #932
diff --git a/CMakeLists.txt b/CMakeLists.txt
index c64f5a375..f5537d0c1 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -114,8 +114,12 @@ endif()
 # Make sure we know our build type
 if(NOT CMAKE_BUILD_TYPE)
-  set(CMAKE_BUILD_TYPE ${DEFAULT_BUILD_TYPE})
-  message(STATUS "GEOS: Using default build type: ${CMAKE_BUILD_TYPE}")
+  get_property(_is_multi_config_generator GLOBAL PROPERTY GENERATOR_IS_MULTI_CONFIG)
+  if (NOT _is_multi_config_generator)
+    set(CMAKE_BUILD_TYPE ${DEFAULT_BUILD_TYPE})
+    message(STATUS "GEOS: Using default build type: ${CMAKE_BUILD_TYPE}")
+  endif()
+  unset(_is_multi_config_generator)
 else()
   message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
 endif()
@@ -186,7 +190,11 @@ set(CMAKE_CXX_FLAGS_ASAN "${CMAKE_CXX_FLAGS_DEBUG} -fsanitize=address -fno-omit-
 set(CMAKE_EXE_LINKER_FLAGS_ASAN "${CMAKE_EXE_LINKER_FLAGS_DEBUG} -fsanitize=address")
 set(CMAKE_SHARED_LINKER_FLAGS_ASAN "${CMAKE_SHARED_LINKER_FLAGS_DEBUG} -fsanitize=address")
-set_property(CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS "Debug" "Release" "MinSizeRel" "RelWithDebInfo" "ASAN")
+get_property(_cmake_build_type_is_cache CACHE CMAKE_BUILD_TYPE PROPERTY TYPE)
+if (_cmake_build_type_is_cache)
+  set_property(CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS "Debug" "Release" "MinSizeRel" "RelWithDebInfo" "ASAN")
+endif()
+unset(_cmake_build_type_is_cache)
 # Install directories
Summary of changes:
 CMakeLists.txt               | 14 +++++++++++---
 capi/geos_c.h.in             |  2 ++
 include/geos/geom/Geometry.h |  9 +++++++--
 3 files changed, 20 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
