[geos-commits] [SCM] GEOS branch main updated. 1105298873b17260fcbcd7f82901ddcbfff8ff82
Tue May 2 08:57:04 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  1105298873b17260fcbcd7f82901ddcbfff8ff82 (commit)
       via  8d67fd6be1b1c429f4b62376368e3c286b68cfc6 (commit)
       via  d054731ccdafdeae3a094051e47f760b64ecf72f (commit)
      from  8c647cb7c0a849cd05d121fd5cb3778d884c6d73 (commit)
revisions in full, below.
commit 1105298873b17260fcbcd7f82901ddcbfff8ff82
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue May 2 08:56:36 2023 -0700
    Add GEOSGeom_releaseCollection to CAPI (#882)
    Add GEOSGeom_releaseCollection to CAPI, references GH-848
diff --git a/NEWS.md b/NEWS.md
index cb386f976..c440567ea 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -21,6 +21,7 @@ xxxx-xx-xx
   - Voronoi: Add option to create diagram in order consistent with inputs (GH-781, Dan Baston)
   - Polygonal coverages: CoverageSimplifier (JTS-911, Martin Davis)
   - CAPI: GEOSCoverageIsValid, GEOSCoverageSimplifyVW (GH-867, Paul Ramsey)
+  - CAPI: GEOSGeom_releaseCollection (GH-848)
 - Fixes/Improvements:
   - WKTReader: Fix parsing of Z and M flags in WKTReader (#676 and GH-669, Dan Baston)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 5757a6f0b..43224e5c9 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -849,6 +849,12 @@ extern "C" {
         return GEOSGeom_createCollection_r(handle, type, geoms, ngeoms);
+    Geometry**
+    GEOSGeom_releaseCollection(Geometry* collection, unsigned int * ngeoms)
+        return GEOSGeom_releaseCollection_r(handle, collection, ngeoms);
     Geometry*
     GEOSPolygonize(const Geometry* const* g, unsigned int ngeoms)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 6a25e4e4f..5b5e9af03 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -736,6 +736,12 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection_r(
     GEOSGeometry* *geoms,
     unsigned int ngeoms);
+/** \see GEOSGeom_releaseCollection */
+extern GEOSGeometry GEOS_DLL ** GEOSGeom_releaseCollection_r(
+    GEOSContextHandle_t handle,
+    GEOSGeometry * collection,
+    unsigned int * ngeoms);
 /** \see GEOSGeom_createEmptyCollection */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCollection_r(
     GEOSContextHandle_t handle, int type);
@@ -2441,6 +2447,26 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(
     GEOSGeometry** geoms,
+* Release the sub-geometries of a collection for management.
+* by the caller. The input collection remains as an empty collection,
+* that the caller is responsible for destroying. The output geometries
+* are also the responsibility of the caller, as is the containing array,
+* which must be freed with GEOSFree().
+* \param collection The collection that will have its components released.
+* \param ngeoms A pointer to a variable that will be filled with the
+*        size of the output array.
+* \return A newly allocated array of GEOSGeometry pointers.
+* \note The caller is responsible for freeing the returned array
+*       with GEOSFree() and all the elements with GEOSGeom_destroy().
+*       If called with an empty collection, null will be returned
+*       and ngeoms set to zero.
+* \since 3.4
+extern GEOSGeometry GEOS_DLL ** GEOSGeom_releaseCollection(
 * Create an empty geometry collection.
 * \param type The geometry type, enumerated by \ref GEOSGeomTypes
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 7c9333d1d..e30efc424 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2024,6 +2024,38 @@ extern "C" {
+    Geometry**
+    GEOSGeom_releaseCollection_r(GEOSContextHandle_t extHandle, Geometry* collection, unsigned int * ngeoms)
+        return execute(extHandle, [&]() {
+            GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+            if (ngeoms == nullptr) {
+                handle->ERROR_MESSAGE("Parameter ngeoms of GEOSGeom_releaseCollection_r must not be null");
+            GeometryCollection *col = dynamic_cast<GeometryCollection*>(collection);
+            if (!col) {
+                handle->ERROR_MESSAGE("Parameter collection of GEOSGeom_releaseCollection_r must not be a collection");
+            // Early exit on empty/null input
+            *ngeoms = static_cast<unsigned int>(col->getNumGeometries());
+            if (!col || *ngeoms == 0) {
+                return static_cast<Geometry**>(nullptr);
+            std::vector<std::unique_ptr<Geometry>> subgeoms = col->releaseGeometries();
+            Geometry** subgeomArray = static_cast<Geometry**>(malloc(sizeof(Geometry*) * subgeoms.size()));
+            for (std::size_t i = 0; i < subgeoms.size(); i++) {
+                subgeomArray[i] = subgeoms[i].release();
+            return subgeomArray;
     Geometry*
     GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry* const* g, unsigned int ngeoms)
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index 7f8242588..11d640874 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -21,7 +21,11 @@ namespace tut {
 // Common data used in test cases.
 struct test_capigeosgeom_createcollection_data {
     GEOSContextHandle_t handle_;
-    GEOSGeom geom_; // collection result
+    GEOSWKTReader * reader_;
+    GEOSGeometry * geom_;
+    GEOSGeometry ** geoms_;
+    unsigned int ngeoms_;
     enum { geom_size = 3 };
     static void
@@ -37,16 +41,31 @@ struct test_capigeosgeom_createcollection_data {
         std::fprintf(stdout, "\n");
+    GEOSGeometry*
+    read(const char* wkt)
+        return GEOSWKTReader_read_r(handle_, reader_, wkt);
     test_capigeosgeom_createcollection_data()
-        : handle_(initGEOS_r(notice, notice)), geom_(nullptr)
+        : handle_(initGEOS_r(notice, notice))
+        , reader_(GEOSWKTReader_create_r(handle_))
+        , geom_(nullptr)
+        , geoms_(nullptr)
+        , ngeoms_(0)
     ~test_capigeosgeom_createcollection_data()
-        GEOSGeom_destroy(geom_);
-        geom_ = nullptr;
+        if (reader_) GEOSWKTReader_destroy_r(handle_, reader_);
+        if (geom_)   GEOSGeom_destroy_r(handle_, geom_);
+        if (geoms_)  GEOSFree_r(handle_, geoms_);
         finishGEOS_r(handle_);
+        handle_ = nullptr;
+        reader_ = nullptr;
+        geom_ = nullptr;
+        geoms_ = nullptr;
@@ -126,5 +145,63 @@ void object::test<4>
     ensure(geom_ == nullptr);
+// Release empty collection
+template<>
+template<>
+void object::test<5>
+    const char *wkt = "MULTIPOLYGON EMPTY";
+    geom_ = read(wkt);
+    ensure(geom_ != nullptr);
+    geoms_ = GEOSGeom_releaseCollection_r(handle_, geom_, &ngeoms_);
+    ensure(geoms_ == nullptr);
+    ensure(ngeoms_ == 0);
+// Release generic collection
+template<>
+template<>
+void object::test<6>
+    const char *wkt = "GEOMETRYCOLLECTION(POINT(0 0), POINT(1 1))";
+    ensure(geoms_ != nullptr);
+    ensure(ngeoms_ == 2);
+    for (size_t i = 0 ; i < ngeoms_; i++) {
+        ensure(GEOSGeomTypeId_r(handle_, geoms_[i]) == GEOS_POINT);
+        GEOSGeom_destroy_r(handle_, geoms_[i]);
+// Release typed collection
+template<>
+template<>
+void object::test<7>
+    const char *wkt = "MULTIPOINT(0 0, 1 1)";
 } // namespace tut
commit 8d67fd6be1b1c429f4b62376368e3c286b68cfc6
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sat Apr 29 21:29:03 2023 -0700
    Update NEWS
index 9ea02451c..cb386f976 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -62,6 +62,9 @@ xxxx-xx-xx
   - LargestEmptyCircle: enhance boundary to allow any polygonal geometry (GH-859, Martin Davis)
   - Fix MaximumInscribedCircle and LargestEmptyCircle performance and memory issues (GH-883, Martin Davis)
+- Changes:
+  - Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
 ## Changes in 3.11.0
 2022-07-01
commit d054731ccdafdeae3a094051e47f760b64ecf72f
Author: Casper van der Wel <caspervdw at gmail.com>
Date:   Sun Apr 30 00:50:56 2023 +0200
    Construction of XYZ points with NaN coordinates (#881)
    Coerce all-NaN points to empty at construction, constructing an empty point if its first coordinate is all-NaN
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 34a725bd3..3070ec834 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -197,6 +197,20 @@ public:
         return m_vect.empty();
+    /// Returns <code>true</code> if there is 1 coordinate and if it is null.
+    bool isNullPoint() const {
+        if (size() != 1) {
+            return false;
+        switch(getCoordinateType()) {
+            case CoordinateType::XY: return getAt<CoordinateXY>(0).isNull();
+            case CoordinateType::XYZ: return getAt<Coordinate>(0).isNull();
+            case CoordinateType::XYZM: return getAt<CoordinateXYZM>(0).isNull();
+            case CoordinateType::XYM: return getAt<CoordinateXYM>(0).isNull();
+            default: return false;
     /** \brief
     * Tests whether an a {@link CoordinateSequence} forms a ring,
     * by checking length and closure. Self-intersection is not checked.
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 5b933b010..d30ee4906 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -224,16 +224,19 @@ GeometryFactory::createPoint(std::size_t coordinateDimension) const
 std::unique_ptr<Point>
 GeometryFactory::createPoint(std::unique_ptr<CoordinateSequence>&& coords) const
-    return std::unique_ptr<Point>(new Point(
-                                      coords ? std::move(*coords) : CoordinateSequence(),
-                                      this));
+    if (!coords) {
+        return createPoint();
+    } else if ((*coords).isNullPoint()) {
+        return createPoint((*coords).getDimension());
+    return std::unique_ptr<Point>(new Point(std::move(*coords), this));
 GeometryFactory::createPoint(const CoordinateXY& coordinate) const
     if(coordinate.isNull()) {
-        return createPoint();
+        return createPoint(2);
     else {
         return std::unique_ptr<Point>(new Point(coordinate, this));
@@ -245,7 +248,7 @@ std::unique_ptr<Point>
 GeometryFactory::createPoint(const Coordinate& coordinate) const
+        return createPoint(3);
     else {
@@ -256,7 +259,7 @@ std::unique_ptr<Point>
 GeometryFactory::createPoint(const CoordinateXYM& coordinate) const
+        return createPoint(4);  // can't do XYM!
     else {
@@ -267,7 +270,7 @@ std::unique_ptr<Point>
 GeometryFactory::createPoint(const CoordinateXYZM& coordinate) const
     else {
@@ -278,6 +281,9 @@ GeometryFactory::createPoint(const CoordinateXYZM& coordinate) const
 GeometryFactory::createPoint(const CoordinateSequence& fromCoords) const
+    if (fromCoords.isNullPoint()) {
+        return createPoint(fromCoords.getDimension());
     CoordinateSequence newCoords(fromCoords);
     return std::unique_ptr<Point>(new Point(std::move(newCoords), this));
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 86cf54ccc..b5c77570c 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -105,16 +105,7 @@ Point::getNumPoints() const
 bool
 Point::isEmpty() const
-    if (coordinates.isEmpty()) {
-        return true;
-    const CoordinateXY& c = coordinates.getAt<CoordinateXY>(0);
-    if (std::isnan(c.x) && std::isnan(c.y)) {
-        return true;
-    return false;
+    return coordinates.isEmpty();
 bool
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 39740894f..7f1552240 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -281,7 +281,7 @@ WKTWriter::appendPointTaggedText(const Point& point, OrdinateSet outputOrdinates
     appendOrdinateText(outputOrdinates, writer);
     const CoordinateXY* coord = point.getCoordinate();
-    if (coord == nullptr || (std::isnan(coord->x) && std::isnan(coord->y))) {
+    if (coord == nullptr) {
         writer.write("EMPTY");
     } else {
         appendSequenceText(*point.getCoordinatesRO(), outputOrdinates, p_level, false, writer);
Summary of changes:
 NEWS.md                                           |  4 ++
 capi/geos_c.cpp                                   |  6 ++
 capi/geos_c.h.in                                  | 26 +++++++
 capi/geos_ts_c.cpp                                | 32 +++++++++
 include/geos/geom/CoordinateSequence.h            | 14 ++++
 src/geom/GeometryFactory.cpp                      | 20 ++++--
 src/geom/Point.cpp                                | 11 +--
 src/io/WKTWriter.cpp                              |  2 +-
 tests/unit/capi/GEOSGeom_createCollectionTest.cpp | 85 +++++++++++++++++++++--
 9 files changed, 178 insertions(+), 22 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
