[geos-commits] [SCM] GEOS branch main updated. bd42a68a09ae9001a66ad4e1a82cd563639ef30b
Tue May 2 13:04:47 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  bd42a68a09ae9001a66ad4e1a82cd563639ef30b (commit)
      from  1105298873b17260fcbcd7f82901ddcbfff8ff82 (commit)
revisions in full, below.
commit bd42a68a09ae9001a66ad4e1a82cd563639ef30b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue May 2 13:04:16 2023 -0700
    Use the coverage/CoverageUnion for the CAPI GEOSCoverageUnion
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e30efc424..5ca390319 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -29,6 +29,7 @@
 #include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
 #include <geos/coverage/CoverageValidator.h>
 #include <geos/coverage/CoverageSimplifier.h>
+#include <geos/coverage/CoverageUnion.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/Envelope.h>
@@ -79,7 +80,6 @@
 #include <geos/operation/relate/RelateOp.h>
 #include <geos/operation/sharedpaths/SharedPathsOp.h>
 #include <geos/operation/union/CascadedPolygonUnion.h>
-#include <geos/operation/union/CoverageUnion.h>
 #include <geos/operation/union/DisjointSubsetUnion.h>
 #include <geos/operation/valid/IsValidOp.h>
 #include <geos/operation/valid/MakeValid.h>
@@ -1494,7 +1494,7 @@ extern "C" {
     GEOSCoverageUnion_r(GEOSContextHandle_t extHandle, const Geometry* g)
         return execute(extHandle, [&]() {
-            auto g3 = geos::operation::geounion::CoverageUnion::Union(g);
+            auto g3 = geos::coverage::CoverageUnion::Union(g);
             g3->setSRID(g->getSRID());
             return g3.release();
diff --git a/include/geos/coverage/CoverageUnion.h b/include/geos/coverage/CoverageUnion.h
index 2bdfb0101..8983c19c0 100644
--- a/include/geos/coverage/CoverageUnion.h
+++ b/include/geos/coverage/CoverageUnion.h
@@ -48,11 +48,19 @@ public:
     * Unions a polygonal coverage.
-    * @param coverage the polygons in the coverage
+    * @param coverage a vector of polygons in the coverage
     * @return the union of the coverage polygons
     static std::unique_ptr<Geometry> Union(std::vector<const Geometry*>& coverage);
+    * Unions a polygonal coverage.
+    * @param coverage a collection of the polygons in the coverage
+    * @return the union of the coverage polygons
+    static std::unique_ptr<Geometry> Union(const Geometry* coverage);
 } // namespace geos::coverage
diff --git a/include/geos/operation/overlayng/CoverageUnion.h b/include/geos/operation/overlayng/CoverageUnion.h
index 9f9e65128..6c7a8be84 100644
--- a/include/geos/operation/overlayng/CoverageUnion.h
+++ b/include/geos/operation/overlayng/CoverageUnion.h
@@ -79,6 +79,8 @@ private:
 public:
+    static constexpr double AREA_PCT_DIFF_TOL = 1e-6;
     * Unions a valid polygonal coverage or linear network.
diff --git a/src/coverage/CoverageUnion.cpp b/src/coverage/CoverageUnion.cpp
index 4ff5e5fe2..4e2d547e1 100644
--- a/src/coverage/CoverageUnion.cpp
+++ b/src/coverage/CoverageUnion.cpp
@@ -36,7 +36,7 @@ CoverageUnion::Union(std::vector<const Geometry*>& coverage)
     if (coverage.size() == 0)
         return nullptr;
-    //TODO? spatial sort polgyons to improve performance
+    // TODO? spatial sort polygons to improve performance
     // Test results are somewhat inconclusive
     //shape::fractal::HilbertEncoder::sort(coverage.begin(), coverage.end());
@@ -46,5 +46,17 @@ CoverageUnion::Union(std::vector<const Geometry*>& coverage)
+/* public static */
+std::unique_ptr<Geometry>
+CoverageUnion::Union(const Geometry* coverage)
+    const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(coverage);
+    if (col == nullptr) return nullptr;
+    return operation::overlayng::CoverageUnion::geomunion(col);
 } // namespace geos.coverage
 } // namespace geos
diff --git a/src/operation/overlayng/CoverageUnion.cpp b/src/operation/overlayng/CoverageUnion.cpp
index 5483be9bb..c0c8a1458 100644
--- a/src/operation/overlayng/CoverageUnion.cpp
+++ b/src/operation/overlayng/CoverageUnion.cpp
@@ -18,6 +18,7 @@
 #include <geos/noding/BoundaryChainNoder.h>
 #include <geos/operation/overlayng/OverlayNG.h>
 #include <geos/geom/Geometry.h>
+#include <geos/util/TopologyException.h>
 using geos::geom::Geometry;
 using geos::noding::SegmentExtractingNoder;
@@ -32,17 +33,27 @@ namespace overlayng { // geos.operation.overlayng
 CoverageUnion::geomunion(const Geometry* coverage)
+    double area_in = coverage->getArea();
+    std::unique_ptr<Geometry> result;
     // a precision model is not needed since no noding is done
     //-- linear networks require a segment-extracting noder
     if (coverage->getDimension() < 2) {
         SegmentExtractingNoder sen;
-        return OverlayNG::geomunion(coverage, nullptr, &sen);
+        result = OverlayNG::geomunion(coverage, nullptr, &sen);
     else {
         BoundaryChainNoder bcn;
-        return OverlayNG::geomunion(coverage, nullptr, &bcn);
+        result = OverlayNG::geomunion(coverage, nullptr, &bcn);
+    double area_out = result->getArea();
+    if (std::abs((area_out - area_in)/area_in) > AREA_PCT_DIFF_TOL) {
+        throw geos::util::TopologyException("CoverageUnion cannot process overlapping inputs.");
+    return result;
diff --git a/tests/unit/capi/GEOSCoverageUnionTest.cpp b/tests/unit/capi/GEOSCoverageUnionTest.cpp
index 992a685aa..6b8a71e7a 100644
--- a/tests/unit/capi/GEOSCoverageUnionTest.cpp
+++ b/tests/unit/capi/GEOSCoverageUnionTest.cpp
@@ -83,7 +83,7 @@ template<>
 template<>
 void object::test<2>
-    // Overlapping inputs (error)
+    // Overlapping inputs (unchanged output)
     std::vector<std::string> wkt{
             "POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))",
             "POLYGON ((1 0, 0.9 1, 2 1, 2 0, 1 0))"
@@ -96,10 +96,11 @@ void object::test<2>
     auto input = GEOSGeom_createCollection_r(m_context, GEOS_GEOMETRYCOLLECTION, geoms, 2);
     auto result = GEOSCoverageUnion_r(m_context, input);
-    ensure( result == nullptr );
+    ensure( result != nullptr );
+    ensure( GEOSEquals_r(m_context, input, result) );
     GEOSGeom_destroy_r(m_context, input);
+    GEOSGeom_destroy_r(m_context, result);
Summary of changes:
 capi/geos_ts_c.cpp                               |  4 ++--
 include/geos/coverage/CoverageUnion.h            | 10 +++++++++-
 include/geos/operation/overlayng/CoverageUnion.h |  2 ++
 src/coverage/CoverageUnion.cpp                   | 14 +++++++++++++-
 src/operation/overlayng/CoverageUnion.cpp        | 15 +++++++++++++--
 tests/unit/capi/GEOSCoverageUnionTest.cpp        |  7 ++++---
 6 files changed, 43 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
