[geos-commits] [SCM] GEOS branch main updated. 4c3bd72ba73e9688b0712d9878d073559c84e4d6
git at osgeo.org
git at osgeo.org
Thu May 4 03:57:52 PDT 2023
the project "GEOS".
The branch, main has been updated
via 4c3bd72ba73e9688b0712d9878d073559c84e4d6 (commit)
via cbe7a6c2f7334d301f7fa4262fbb43b9e394a23b (commit)
via 714af1e46852f3638d4bf81bd374edf597ddbfe5 (commit)
from 2bda4d22238c255ce7f0ddfe61a03da082a8737f (commit)
revisions in full, below.
commit 4c3bd72ba73e9688b0712d9878d073559c84e4d6
Author: Dan Baston <dbaston at gmail.com>
Date: Thu May 4 06:57:25 2023 -0400
Add GEOSOrientPolygons (#818)
* Add GEOSOrientPolygons
Fixes https://github.com/libgeos/geos/issues/779
Co-authored-by: Joris Van den Bossche <jorisvandenbossche at gmail.com>
diff --git a/NEWS.md b/NEWS.md
index 4e3f67489..0eeb49079 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -15,6 +15,7 @@ xxxx-xx-xx
- CAPI: GEOSDisjointSubsetUnion (GH-692, Dan Baston)
- CAPI: GEOSLineSubstring (GH-706, Dan Baston)
- CAPI: GEOSEqualsIdentical (GH-810, Dan Baston)
+ - CAPI: GEOSOrientPolygons (GH-818, Dan Baston)
- CAPI: GEOSSTRtree_build (GH-835, Dan Baston)
- CAPI: GEOSConcaveHullByLength (GH-849, Martin Davis)
- CAPI: GEOSGeomGetM (GH-864, Mike Taves)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 43224e5c9..04e6c4fd3 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -681,6 +681,12 @@ extern "C" {
return GEOSNormalize_r(handle, g);
+ int
+ GEOSOrientPolygons(Geometry* g, int exteriorCW)
+ return GEOSOrientPolygons_r(handle, g, exteriorCW);
int
GEOSGetNumInteriorRings(const Geometry* g)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 4574d6bba..94a39f9ad 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1535,6 +1535,12 @@ extern int GEOS_DLL GEOSNormalize_r(
GEOSContextHandle_t handle,
GEOSGeometry* g);
+/** \see GEOSOrientPolygons */
+extern int GEOS_DLL GEOSOrientPolygons_r(
+ GEOSContextHandle_t handle,
+ GEOSGeometry* g,
+ int exteriorCW);
* Controls the behavior of GEOSGeom_setPrecision()
* when altering the precision of a geometry.
@@ -2916,6 +2922,18 @@ extern void GEOS_DLL GEOSGeom_setUserData(GEOSGeometry* g, void* userData);
extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g);
+* Enforce a ring orientation on all polygonal elements in the input geometry.
+* Non-polygonal geometries will not be modified.
+* \param g Input geometry
+* \param exteriorCW if 1, exterior rings will be clockwise and interior rings
+* will be counter-clockwise
+* \return 0 on success or -1 on exception
+extern int GEOS_DLL GEOSOrientPolygons(GEOSGeometry* g,
+ int exteriorCW);
/* ========== Validity checking ============================================================ */
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 7cf62d528..363e34864 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1671,6 +1671,32 @@ extern "C" {
+ int
+ GEOSOrientPolygons_r(GEOSContextHandle_t extHandle, Geometry* g, int exteriorCW)
+ return execute(extHandle, -1, [&]() {
+ class OrientPolygons : public geos::geom::GeometryComponentFilter {
+ public:
+ OrientPolygons(bool isExteriorCW) : exteriorCW(isExteriorCW) {}
+ void filter_rw(Geometry* g) override {
+ if (g->getGeometryTypeId() == geos::geom::GeometryTypeId::GEOS_POLYGON) {
+ auto p = geos::detail::down_cast<Polygon*>(g);
+ p->orientRings(exteriorCW);
+ private:
+ bool exteriorCW;
+ OrientPolygons op(exteriorCW);
+ g->apply_rw(&op);
+ return 0;
int
GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry* g1)
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 7789565bd..b04b3bd35 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -103,6 +103,8 @@ public:
std::unique_ptr<LinearRing> reverse() const { return std::unique_ptr<LinearRing>(reverseImpl()); }
+ void orient(bool isCW);
protected:
int
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 8720c2ae4..abd5f100f 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -152,6 +152,16 @@ public:
void normalize() override;
+ * \brief
+ * Apply a ring ordering convention to this polygon, with
+ * interior rings having an opposite orientation to the
+ * specified exterior orientation.
+ * \param exteriorCW should exterior ring be clockwise?
+ void orientRings(bool exteriorCW);
std::unique_ptr<Polygon> reverse() const { return std::unique_ptr<Polygon>(reverseImpl()); }
const CoordinateXY* getCoordinate() const override;
diff --git a/src/geom/LinearRing.cpp b/src/geom/LinearRing.cpp
index aa4097b4e..6afc506c0 100644
--- a/src/geom/LinearRing.cpp
+++ b/src/geom/LinearRing.cpp
@@ -17,6 +17,8 @@
+#include <geos/algorithm/Orientation.h>
#include <geos/geom/LinearRing.h>
#include <geos/geom/Dimension.h>
#include <geos/geom/CoordinateSequence.h>
@@ -98,6 +100,19 @@ LinearRing::getGeometryTypeId() const
return GEOS_LINEARRING;
+void
+LinearRing::orient(bool isCW)
+ if (isEmpty()) {
+ return;
+ if (algorithm::Orientation::isCCW(points.get()) == isCW) {
+ points->reverse();
LinearRing*
LinearRing::reverseImpl() const
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 34c6d4560..515275d51 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -363,6 +363,15 @@ Polygon::normalize()
+void
+Polygon::orientRings(bool exteriorCW)
+ shell->orient(exteriorCW);
+ for (auto& hole : holes) {
+ hole->orient(!exteriorCW);
int
Polygon::compareToSameClass(const Geometry* g) const
diff --git a/tests/unit/capi/GEOSOrientPolygonsTest.cpp b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
new file mode 100644
index 000000000..745ac1bc0
--- /dev/null
+++ b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
@@ -0,0 +1,94 @@
+// Test Suite for C-API GEOSOrientationPolygons
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <string>
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeosorientpolygons_data : public capitest::utility {};
+typedef test_group<test_capigeosorientpolygons_data> group;
+typedef group::object object;
+group test_capigeosorientpolygons_group("capi::GEOSOrientPolygons");
+// empty polygon is passed through
+template<>
+template<>
+void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ ensure_equals(GEOSOrientPolygons(geom1_, 1), 0);
+ ensure_equals(toWKT(geom1_), "POLYGON EMPTY");
+// hole orientation is opposite to shell
+template<>
+template<>
+void object::test<2>()
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1))");
+ ensure_equals(GEOSOrientPolygons(geom1_, 0), 0);
+ ensure_equals(toWKT(geom1_), "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ ensure_equals(toWKT(geom1_), "POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1))");
+// all polygons in collection are processed
+template<>
+template<>
+void object::test<3>()
+ geom1_ = GEOSGeomFromWKT("MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1)), ((100 100, 200 100, 200 200, 100 100)))");
+ ensure_equals(toWKT(geom1_), "MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1)), ((100 100, 200 100, 200 200, 100 100)))");
+ ensure_equals(toWKT(geom1_), "MULTIPOLYGON (((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1)), ((100 100, 200 200, 200 100, 100 100)))");
+// polygons in collection are oriented, closed linestring unchanged
+template<>
+template<>
+void object::test<4>()
+ geom1_ = GEOSGeomFromWKT("GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1)), LINESTRING (100 100, 200 100, 200 200, 100 100))");
+ ensure_equals(toWKT(geom1_), "GEOMETRYCOLLECTION (POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1)), LINESTRING (100 100, 200 100, 200 200, 100 100))");
+// nested collection handled correctly
+template<>
+template<>
+void object::test<5>()
+ geom1_ = GEOSGeomFromWKT("GEOMETRYCOLLECTION (GEOMETRYCOLLECTION (MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0)))))");
+ ensure_equals(toWKT(geom1_), "GEOMETRYCOLLECTION (GEOMETRYCOLLECTION (MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0)))))");
+ ensure_equals(toWKT(geom1_), "GEOMETRYCOLLECTION (GEOMETRYCOLLECTION (MULTIPOLYGON (((0 0, 0 10, 10 10, 10 0, 0 0)))))");
+} // namespace tut
commit cbe7a6c2f7334d301f7fa4262fbb43b9e394a23b
Author: Mike Taves <mwtoews at gmail.com>
Date: Thu May 4 15:25:02 2023 +1200
CAPI: fix GEOSHasZ with empty geometries (#887)
index c440567ea..4e3f67489 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -62,6 +62,7 @@ xxxx-xx-xx
- Tri: add exceptions for invalid indexes (GH-853, Martin Davis)
- LargestEmptyCircle: enhance boundary to allow any polygonal geometry (GH-859, Martin Davis)
- Fix MaximumInscribedCircle and LargestEmptyCircle performance and memory issues (GH-883, Martin Davis)
+ - GEOSHasZ: Fix handling with empty geometries (GH-887, Mike Taves)
- Changes:
- Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
index 5ca390319..7cf62d528 100644
@@ -2410,10 +2410,6 @@ extern "C" {
GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry* g)
return execute(extHandle, 2, [&]() {
- if(g->isEmpty()) {
- return false;
return g->hasZ();
diff --git a/tests/unit/capi/GEOSHasZMTest.cpp b/tests/unit/capi/GEOSHasZMTest.cpp
index 1b2ab36c4..54b0431cf 100644
--- a/tests/unit/capi/GEOSHasZMTest.cpp
+++ b/tests/unit/capi/GEOSHasZMTest.cpp
@@ -46,5 +46,35 @@ void object::test<3>()
ensure_equals(GEOSHasM(input_), 0);
+template<>
+template<>
+ input_ = GEOSGeomFromWKT("POINT Z EMPTY");
+ ensure_equals(GEOSHasZ(input_), 1);
+ ensure_equals(GEOSHasM(input_), 0);
+template<>
+template<>
+ input_ = GEOSGeomFromWKT("POINT M EMPTY");
+ ensure_equals(GEOSHasZ(input_), 0);
+ ensure_equals(GEOSHasM(input_), 1);
+template<>
+template<>
+void object::test<6>()
+ input_ = GEOSGeomFromWKT("POINT ZM EMPTY");
} // namespace tut
commit 714af1e46852f3638d4bf81bd374edf597ddbfe5
Author: Peter Stace <peterstace at gmail.com>
Date: Thu May 4 11:34:30 2023 +1000
Clarify coverage union behaviour with unmet constraints (#890)
index 5b5e9af03..4574d6bba 100644
@@ -3762,8 +3762,9 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
* Optimized union algorithm for polygonal inputs that are correctly
-* noded and do not overlap. It will generate an error (return NULL)
-* for inputs that do not satisfy this constraint.
+* noded and do not overlap. It may generate an error (return NULL)
+* for inputs that do not satisfy this constraint, however this is not
+* guaranteed.
* \param g The input geometry
* \return A geometry that covers all the points of the input geometry.
* Caller is responsible for freeing with GEOSGeom_destroy().
Summary of changes:
NEWS.md | 2 +
capi/geos_c.cpp | 6 ++
capi/geos_c.h.in | 23 +++++++-
capi/geos_ts_c.cpp | 30 ++++++++--
include/geos/geom/LinearRing.h | 2 +
include/geos/geom/Polygon.h | 10 ++++
src/geom/LinearRing.cpp | 15 +++++
src/geom/Polygon.cpp | 9 +++
tests/unit/capi/GEOSHasZMTest.cpp | 30 ++++++++++
tests/unit/capi/GEOSOrientPolygonsTest.cpp | 94 ++++++++++++++++++++++++++++++
10 files changed, 215 insertions(+), 6 deletions(-)
create mode 100644 tests/unit/capi/GEOSOrientPolygonsTest.cpp
hooks/post-receive
More information about the geos-commits
