[geos-commits] [SCM] GEOS branch main updated. 92f4303a0e83d5a5cf216d59e05a2dcc3527f07c
git at osgeo.org
git at osgeo.org
Thu May 4 09:17:45 PDT 2023
the project "GEOS".
The branch, main has been updated
via 92f4303a0e83d5a5cf216d59e05a2dcc3527f07c (commit)
from 4c3bd72ba73e9688b0712d9878d073559c84e4d6 (commit)
revisions in full, below.
commit 92f4303a0e83d5a5cf216d59e05a2dcc3527f07c
Author: Sandro Santilli <strk at kbt.io>
Date: Thu May 4 18:17:23 2023 +0200
Use xml prefix for xml tests (#893)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 94b71bc93..05dc1b950 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -36,7 +36,7 @@ foreach(_testdir general issue misc robust validate)
CONFIGURE_DEPEND)
foreach(_testfile ${_testfiles})
get_filename_component(_testname ${_testfile} NAME_WE)
- add_test(NAME ${_testdir}-${_testname}
+ add_test(NAME xml-${_testdir}-${_testname}
COMMAND test_xmltester -v --test-valid-output ${_testfile})
list(APPEND _xmltests ${_testfile})
endforeach()
@@ -52,7 +52,7 @@ add_test(NAME all-xml-tests
unset(_xmltests)
# Disable tests that are known to fail on 32-bit systems.
-set_tests_properties(issue-issue-geos-837 PROPERTIES DISABLED $<EQUAL:4,${CMAKE_SIZEOF_VOID_P}>)
+set_tests_properties(xml-issue-issue-geos-837 PROPERTIES DISABLED $<EQUAL:4,${CMAKE_SIZEOF_VOID_P}>)
unset(_testdir)
unset(_testname)
Summary of changes:
tests/xmltester/CMakeLists.txt | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
