[geos-commits] [SCM] GEOS branch main updated. 3e3f7205e743800d951f2e9e7e3cca3a033b7d61
Thu May 4 10:08:26 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  3e3f7205e743800d951f2e9e7e3cca3a033b7d61 (commit)
       via  20ca29f92f1602693ba82badb8ab2049a9da1e4c (commit)
      from  92f4303a0e83d5a5cf216d59e05a2dcc3527f07c (commit)
revisions in full, below.
commit 3e3f7205e743800d951f2e9e7e3cca3a033b7d61
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu May 4 19:06:16 2023 +0200
    Reduce interrupt checks in MCIndexNoder::intersectChains
    Limit the check to once every 100000 iterations
diff --git a/src/noding/MCIndexNoder.cpp b/src/noding/MCIndexNoder.cpp
index 89fd67e1e..6cdd9a45b 100644
--- a/src/noding/MCIndexNoder.cpp
+++ b/src/noding/MCIndexNoder.cpp
@@ -71,7 +71,7 @@ MCIndexNoder::intersectChains()
     index.queryPairs([this, &overlapAction](const MonotoneChain* queryChain, const MonotoneChain* testChain) {
         queryChain->computeOverlaps(testChain, overlapTolerance, &overlapAction);
         nOverlaps++;
-        GEOS_CHECK_FOR_INTERRUPTS();
+        if ( nOverlaps % 100000 == 0 ) GEOS_CHECK_FOR_INTERRUPTS();
         return !segInt->isDone(); // abort early if segInt->isDone()
commit 20ca29f92f1602693ba82badb8ab2049a9da1e4c
Date:   Thu May 4 18:42:31 2023 +0200
    Make MCIndexNoder::intersectChains interruptible
    Improves interruptability of BufferBuilder::computeNodedEdges
    References GH-894 in main branch ( 3.12.0dev )
index 47ffaa4b4..89fd67e1e 100644
@@ -71,6 +71,7 @@ MCIndexNoder::intersectChains()
         nOverlaps++;
+        GEOS_CHECK_FOR_INTERRUPTS();
Summary of changes:
 src/noding/MCIndexNoder.cpp | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
More information about the geos-commits mailing list
