[geos-commits] [SCM] GEOS branch main updated. b18c7aa44b9c46dd04b60071962bd369b36c787e
Wed May 17 16:43:41 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  b18c7aa44b9c46dd04b60071962bd369b36c787e (commit)
       via  0e6d68edaa2e66946570b2ae86a4a5bc92121f2d (commit)
       via  cb84b4e035ca86bf1fa1628a4d818a0f2a0114e9 (commit)
      from  fb79eb2bc785e21f68e36af2f1c89f93a19e902e (commit)
revisions in full, below.
commit b18c7aa44b9c46dd04b60071962bd369b36c787e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed May 17 16:18:22 2023 +0200
    Fix single-sided buffer of multigeoms (#912)
    References GH-665
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 8ebe484ff..e7de6f69d 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -36,6 +36,7 @@
 #include <geos/operation/overlay/PolygonBuilder.h>
 #include <geos/operation/overlay/OverlayNodeFactory.h>
 #include <geos/operation/polygonize/Polygonizer.h>
+#include <geos/operation/union/UnaryUnionOp.h>
 #include <geos/operation/valid/RepeatedPointRemover.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/algorithm/LineIntersector.h>
@@ -368,6 +369,27 @@ std::unique_ptr<Geometry>
 BufferBuilder::buffer(const Geometry* g, double distance)
 // throw(GEOSException *)
+    // Single-sided buffer only works on single geometries
+    // so we'll need to do it individually and then union
+    // the result
+    if ( bufParams.isSingleSided() && g->getNumGeometries() > 1 )
+        std::vector< std::unique_ptr<Geometry> > geoms_to_delete;
+        for ( size_t i=0, n=g->getNumGeometries(); i<n; ++i )
+            // BufferBuilder class cannot be re-used, so
+            // we create a new one for each subgeom
+            BufferBuilder subbuilder(bufParams);
+            const Geometry *subgeom = g->getGeometryN(i);
+            std::unique_ptr<Geometry> subbuf = subbuilder.buffer(subgeom, distance);
+            geoms_to_delete.push_back( std::move(subbuf) );
+        std::vector< Geometry* > geoms;
+        for ( size_t i=0, n=geoms_to_delete.size(); i<n; ++i )
+            geoms.push_back( geoms_to_delete[i].get() );
+        return operation::geounion::UnaryUnionOp::Union(geoms);
     const PrecisionModel* precisionModel = workingPrecisionModel;
     if(precisionModel == nullptr) {
         precisionModel = g->getPrecisionModel();
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index a1ff2e557..4d4c693d9 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -570,4 +570,26 @@ void object::test<21>
     ensure_equals(int(result->getArea()), 5055);
+// Another test for single-sided buffer
+// See https://github.com/libgeos/geos/issues/665
+template<>
+template<>
+void object::test<22>
+    using geos::operation::buffer::BufferOp;
+    using geos::operation::buffer::BufferParameters;
+    std::string wkt("MULTILINESTRING((0 0,10 0),(20 0,30 0))");
+    GeomPtr geom(wktreader.read(wkt));
+    geos::operation::buffer::BufferParameters bp;
+    bp.setSingleSided(true);
+    geos::operation::buffer::BufferOp op(geom.get(), bp);
+    std::unique_ptr<Geometry> result = op.getResultGeometry(-10);
+    ensure_equals(result->getNumGeometries(), 2u);
+    ensure_equals(result->getArea(), 200);
 } // namespace tut
commit 0e6d68edaa2e66946570b2ae86a4a5bc92121f2d
Author: Mike Taves <mwtoews at gmail.com>
Date:   Wed May 17 13:20:21 2023 +1200
    Improve util/geosop/README.md
diff --git a/util/geosop/README.md b/util/geosop/README.md
index 109bb20a3..34741d3bc 100644
--- a/util/geosop/README.md
+++ b/util/geosop/README.md
@@ -4,8 +4,7 @@
 It can be used to:
 * Run GEOS operations on one or many geometries
-* Output geometry resuls in various formats (WKT and WKB)
-* Convert between WKT and WKB
+* Output geometry results in various formats (WKT, WKB and GeoJSON)
 * Time the performance of operations
 * Check for memory leaks in operations
 * Check the semantics of GEOS operations
@@ -28,14 +27,17 @@ It can be used to:
   geosop [OPTION...] opName opArg
-  -a arg               source for A geometries (WKT, WKB, file, stdin, stdin.wkb)
-  -b arg               source for B geometries (WKT, WKB, file, stdin, stdin.wkb)
+  -a arg               source for A geometries (WKT, WKB, file, stdin,
+                       stdin.wkb)
+  -b arg               source for B geometries (WKT, WKB, file, stdin,
+                       stdin.wkb)
   -l, --limita arg     Limit number of A geometries read
   -o, --offseta arg    Skip reading first N geometries of A
-  -c, --collect        Collect input into single geometry
+  -c, --collect        Collect input into single geometry (automatic for AGG
+                       ops)
   -e, --explode        Explode results into component geometries
-  -f, --format arg     Output format (wkt, wkb or txt)
-  -p, --precision arg  Sets number of decimal places in output coordinates
+  -f, --format arg     Output format (wkt, wkb, txt or geojson)
+  -p, --precision arg  Set number of decimal places in output coordinates
   -q, --quiet          Disable result output
   -r, --repeat arg     Repeat operation N times
   -t, --time           Print execution time
@@ -82,9 +84,9 @@ It can be used to:
     `geosop -a geoms.wkt -f wkb unaryUnion`
-* Compute the buffer of a WKB literal and output as WKT
+* Compute the buffer of a WKB literal and output as GeoJSON
-    `geosop -a 000000000140240000000000004024000000000000 buffer 10`
+    `geosop -a 000000000140240000000000004024000000000000 -f geojson buffer 10`
 * Polygonize lines and output the individual result polygons as WKT
commit cb84b4e035ca86bf1fa1628a4d818a0f2a0114e9
Date:   Wed May 17 13:05:06 2023 +1200
    geosop: add option to output GeoJSON (#911)
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 2e41e3268..1f974c32d 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -18,6 +18,7 @@
 #include <geos/geom/Point.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/operation/valid/MakeValid.h>
+#include <geos/io/GeoJSONWriter.h>
 #include <geos/io/WKTReader.h>
 #include <geos/io/WKTStreamReader.h>
 #include <geos/io/WKTWriter.h>
@@ -84,7 +85,7 @@ int main(int argc, char** argv) {
         ("o,offseta", "Skip reading first N geometries of A", cxxopts::value<int>( cmdArgs.offsetA ) )
         ("c,collect", "Collect input into single geometry (automatic for AGG ops)", cxxopts::value<bool>( cmdArgs.isCollect ))
         ("e,explode", "Explode results into component geometries", cxxopts::value<bool>( cmdArgs.isExplode))
-        ("f,format", "Output format (wkt, wkb or txt)", cxxopts::value<std::string>( ))
+        ("f,format", "Output format (wkt, wkb, txt or geojson)", cxxopts::value<std::string>( ))
         ("p,precision", "Set number of decimal places in output coordinates", cxxopts::value<int>( cmdArgs.precision ) )
         ("q,quiet", "Disable result output", cxxopts::value<bool>( cmdArgs.isQuiet ) )
         ("r,repeat", "Repeat operation N times", cxxopts::value<int>( cmdArgs.repeatNum ) )
@@ -127,12 +128,18 @@ int main(int argc, char** argv) {
     if (result.count("format")) {
         auto fmt = result["format"].as<std::string>();
+        // Use lowercase matching
+        std::transform(fmt.begin(), fmt.end(), fmt.begin(),
+            [](unsigned char c){ return std::tolower(c); });
         if (fmt == "txt" || fmt == "wkt" ) {
             cmdArgs.format = GeosOpArgs::fmtText;
         else if (fmt == "wkb") {
             cmdArgs.format = GeosOpArgs::fmtWKB;
+        else if (fmt == "geojson" || fmt == "json") {
+            cmdArgs.format = GeosOpArgs::fmtGeoJSON;
         else {
             std::cerr << "Invalid format value: " << fmt << std::endl;
             exit(1);
@@ -542,6 +549,12 @@ void GeosOp::outputGeometry(const Geometry * geom) {
         writer.writeHEX(*geom, std::cout);
         std::cout << std::endl;
+    else if (args.format == GeosOpArgs::fmtGeoJSON ) {
+        // output as GeoJSON
+        // TODO: enable args.precision to output
+        geos::io::GeoJSONWriter geojsonwriter;
+        std::cout << geojsonwriter.write(geom) << std::endl;
     else {
         // output as text/WKT
         WKTWriter writer;
diff --git a/util/geosop/GeosOp.h b/util/geosop/GeosOp.h
index b5ded9f18..3fe373700 100644
--- a/util/geosop/GeosOp.h
+++ b/util/geosop/GeosOp.h
@@ -31,7 +31,10 @@ class GeosOpArgs {
 public:
     enum {
-        fmtNone, fmtText, fmtWKB
+        fmtNone,
+        fmtText,
+        fmtWKB,
+        fmtGeoJSON,
     } format = fmtText;
     bool isShowTime = false;
Summary of changes:
 src/operation/buffer/BufferBuilder.cpp       | 22 ++++++++++++++++++++++
 tests/unit/operation/buffer/BufferOpTest.cpp | 22 ++++++++++++++++++++++
 util/geosop/GeosOp.cpp                       | 15 ++++++++++++++-
 util/geosop/GeosOp.h                         |  5 ++++-
 util/geosop/README.md                        | 20 +++++++++++---------
 5 files changed, 73 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
