[geos-commits] [SCM] GEOS branch 3.10 updated. 02c026a103e8a292c04bb9eb77cc17fada6e8b95
git at osgeo.org
git at osgeo.org
Wed May 17 16:44:07 PDT 2023
the project "GEOS".
The branch, 3.10 has been updated
via 02c026a103e8a292c04bb9eb77cc17fada6e8b95 (commit)
from ecb8f54c67d3724bdd9c8f7fb9e279cc11aba1e2 (commit)
revisions in full, below.
commit 02c026a103e8a292c04bb9eb77cc17fada6e8b95
Author: Mike Taves <mwtoews at gmail.com>
Date: Thu May 18 00:33:43 2023 +1200
GeoJSONReader: Fix 2D empty geometry creation
diff --git a/NEWS b/NEWS
index ea4fb351e..a25843690 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.10.6
- Fixes/Improvements:
- LargestEmptyCircle: enhance boundary to allow any polygonal geometry (GH-859, Martin Davis)
- Build issues with gcc-13 (GH-863)
+ - GeoJSONReader: Fix 2D empty geometry creation (GH-910, Mike Taves)
Changes in 3.10.5
2023-03-16
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 4733bbe4d..72849c790 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -240,7 +240,7 @@ std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
const geom::Coordinate& c = readCoordinate(coord);
coordinates.push_back(c);
- auto coordinateSequence = geometryFactory.getCoordinateSequenceFactory()->create(std::move(coordinates));
+ auto coordinateSequence = geometryFactory.getCoordinateSequenceFactory()->create(std::move(coordinates), 2u);
return geometryFactory.createLineString(std::move(coordinateSequence));
@@ -264,7 +264,7 @@ std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
if (!shell) {
shell = geometryFactory.createLinearRing(std::move(coordinateSequence));
@@ -309,7 +309,7 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
coordinates.push_back(geom::Coordinate{c.x, c.y});
lines.push_back(geometryFactory.createLineString(std::move(coordinateSequence)));
return geometryFactory.createMultiLineString(std::move(lines));
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index cfba3f020..a907a49dc 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -54,6 +54,7 @@ void object::test<1>
std::string geojson { "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}" };
GeomPtr geom(geojsonreader.read(geojson));
ensure_equals("POINT (-117.000 33.000)", geom->toText());
+ ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 2u);
// Read a GeoJSON LineString
@@ -65,6 +66,7 @@ void object::test<2>
std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0],[103.0,1.0],[104.0,0.0],[105.0,1.0]]}" };
ensure_equals("LINESTRING (102.000 0.000, 103.000 1.000, 104.000 0.000, 105.000 1.000)", geom->toText());
// Read a GeoJSON Polygon with only an outer ring
@@ -76,6 +78,7 @@ void object::test<3>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[30,10],[40,40],[20,40],[10,20],[30,10]]]}" };
ensure_equals("POLYGON ((30.000 10.000, 40.000 40.000, 20.000 40.000, 10.000 20.000, 30.000 10.000))", geom->toText());
// Read a GeoJSON Point with an outer ring and an inner ring
@@ -87,6 +90,7 @@ void object::test<4>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[35,10],[45,45],[15,40],[10,20],[35,10]],[[20,30],[35,35],[30,20],[20,30]]]}" };
ensure_equals("POLYGON ((35.000 10.000, 45.000 45.000, 15.000 40.000, 10.000 20.000, 35.000 10.000), (20.000 30.000, 35.000 35.000, 30.000 20.000, 20.000 30.000))", geom->toText());
// Read a GeoJSON MultiPoint
@@ -98,6 +102,7 @@ void object::test<5>
std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[[10, 40], [40, 30], [20, 20], [30, 10]]}" };
ensure_equals("MULTIPOINT (10.000 40.000, 40.000 30.000, 20.000 20.000, 30.000 10.000)", geom->toText());
// Read a GeoJSON MultiLineString
@@ -109,6 +114,7 @@ void object::test<6>
std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[[10, 10], [20, 20], [10, 40]],[[40, 40], [30, 30], [40, 20], [30, 10]]]}" };
ensure_equals("MULTILINESTRING ((10.000 10.000, 20.000 20.000, 10.000 40.000), (40.000 40.000, 30.000 30.000, 40.000 20.000, 30.000 10.000))", geom->toText());
// Read a GeoJSON MultiPolygon
@@ -120,6 +126,7 @@ void object::test<7>
std::string geojson { "{\"type\": \"MultiPolygon\", \"coordinates\": [[[[40, 40], [20, 45], [45, 30], [40, 40]]], [[[20, 35], [10, 30], [10, 10], [30, 5], [45, 20], [20, 35]], [[30, 20], [20, 15], [20, 25], [30, 20]]]]}" };
ensure_equals("MULTIPOLYGON (((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)), ((20.000 35.000, 10.000 30.000, 10.000 10.000, 30.000 5.000, 45.000 20.000, 20.000 35.000), (30.000 20.000, 20.000 15.000, 20.000 25.000, 30.000 20.000)))", geom->toText());
// Read a GeoJSON GeometryCollection
@@ -131,6 +138,7 @@ void object::test<8>
std::string geojson { "{\"type\": \"GeometryCollection\",\"geometries\": [{\"type\": \"Point\",\"coordinates\": [40, 10]},{\"type\": \"LineString\",\"coordinates\": [[10, 10], [20, 20], [10, 40]]},{\"type\": \"Polygon\",\"coordinates\": [[[40, 40], [20, 45], [45, 30], [40, 40]]]}]}" };
ensure_equals("GEOMETRYCOLLECTION (POINT (40.000 10.000), LINESTRING (10.000 10.000, 20.000 20.000, 10.000 40.000), POLYGON ((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)))", geom->toText());
// Read a GeoJSON Feature with a Point and no properties
@@ -142,7 +150,7 @@ void object::test<9>
std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}}" };
// Read a GeoJSON FeatureCollection with two Feature with Points and no properties
@@ -154,7 +162,7 @@ void object::test<10>
std::string geojson { "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-122.0,45.0]}}]}" };
ensure_equals("GEOMETRYCOLLECTION (POINT (-117.000 33.000), POINT (-122.000 45.000))", geom->toText());
// Read a GeoJSON empty Point
@@ -166,6 +174,7 @@ void object::test<11>
std::string geojson { "{\"type\":\"Point\",\"coordinates\":[]}" };
ensure_equals("POINT EMPTY", geom->toText());
// Read a GeoJSON empty LineString
@@ -177,6 +186,7 @@ void object::test<12>
std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[]}" };
ensure_equals("LINESTRING EMPTY", geom->toText());
// Read a GeoJSON empty Polygon
@@ -188,6 +198,7 @@ void object::test<13>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[]}" };
ensure_equals("POLYGON EMPTY", geom->toText());
// Read a GeoJSON empty MultiPoint
@@ -199,6 +210,7 @@ void object::test<14>
std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[]}" };
ensure_equals("MULTIPOINT EMPTY", geom->toText());
// Read a GeoJSON empty MultiLineString
@@ -210,6 +222,7 @@ void object::test<15>
std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[]}" };
ensure_equals("MULTILINESTRING EMPTY", geom->toText());
// Read a GeoJSON empty MultiPolygon
@@ -221,6 +234,7 @@ void object::test<16>
std::string geojson { "{\"type\": \"MultiPolygon\", \"coordinates\": []}" };
ensure_equals("MULTIPOLYGON EMPTY", geom->toText());
// Read an empty GeometryCollection
@@ -232,6 +246,7 @@ void object::test<17>
std::string geojson { "{\"type\": \"GeometryCollection\",\"geometries\": []}" };
ensure_equals("GEOMETRYCOLLECTION EMPTY", geom->toText());
// Read a Simple Feature
@@ -243,6 +258,7 @@ void object::test<18>
std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"required\": true} }" };
geos::io::GeoJSONFeatureCollection features(geojsonreader.readFeatures(geojson));
ensure_equals(static_cast<size_t>(1), features.getFeatures().size());
+ ensure_equals(static_cast<size_t>(features.getFeatures()[0].getGeometry()->getCoordinateDimension()), 2u);
ensure_equals("POINT (-117.000 33.000)", features.getFeatures()[0].getGeometry()->toText());
ensure_equals(1.0, features.getFeatures()[0].getProperties().at("id").getNumber());
ensure_equals("one", features.getFeatures()[0].getProperties().at("name").getString());
@@ -258,6 +274,7 @@ void object::test<19>
std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"items\": [1,2,3,4], \"nested\": {\"id\":2, \"name\":\"two\"}}}" };
@@ -282,6 +299,7 @@ void object::test<20>
ensure_equals(static_cast<size_t>(3), features.getFeatures().size());
ensure_equals("POLYGON ((87.890 64.923, 76.992 55.178, 102.656 46.558, 115.312 60.413, 94.570 58.447, 87.890 64.923))", features.getFeatures()[0].getGeometry()->toText());
ensure_equals("LINESTRING (1.406 48.690, 41.835 34.016, 22.500 13.923)", features.getFeatures()[1].getGeometry()->toText());
@@ -299,6 +317,7 @@ void object::test<21>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[]]}" };
// Read a GeoJSON Point with only one coordinate
@@ -405,6 +424,7 @@ void object::test<27>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[],[]]}" };
// Read a GeoJSON empty MultiLineString with empty LineStrings
@@ -416,6 +436,7 @@ void object::test<28>
std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[],[],[]]}" };
// Read a GeoJSON Point with too many coordinates
Summary of changes:
NEWS | 1 +
src/io/GeoJSONReader.cpp | 6 +++---
tests/unit/io/GeoJSONReaderTest.cpp | 25 +++++++++++++++++++++++--
3 files changed, 27 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
