[geos-commits] [SCM] GEOS branch main updated. e9ea7c1ce4969a15f112b9a2beb60182de0c90a9
Tue May 23 11:52:24 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  e9ea7c1ce4969a15f112b9a2beb60182de0c90a9 (commit)
      from  27833c0575f1a230249c4c9dd1f3d79847abe364 (commit)
revisions in full, below.
commit e9ea7c1ce4969a15f112b9a2beb60182de0c90a9
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue May 23 11:51:45 2023 -0700
    Improve C-API doc for GEOSPolygonize_valid
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 94a39f9ad..27d17459e 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4336,14 +4336,16 @@ extern GEOSGeometry GEOS_DLL *GEOSPolygonize(
     unsigned int ngeoms);
-* Same polygonizing behavior as GEOSPolygonize(), but only returning results
-* that are valid.
+* Has the same polygonizing behavior as GEOSPolygonize(),
+* but returns a result which is a valid polygonal geometry.
+* The result will not contain any edge-adjacent elements.
 * \param geoms Array of linear geometries to polygons. Caller retains ownersihp of both array container and objects.
 * \param ngeoms Size of the geoms array.
 * \return The polygonal output geometry.
 * Caller is responsible for freeing with GEOSGeom_destroy().
 * \see geos::operation::polygonize::Polygonizer
+* \see GEOSBuildArea()
 * \since 3.8
Summary of changes:
 capi/geos_c.h.in | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
