[geos-commits] [SCM] GEOS branch main updated. 66b552abbb4586b68cc298ff2e2bc16420fa7c18
git at osgeo.org
git at osgeo.org
Tue May 23 13:34:54 PDT 2023
the project "GEOS".
The branch, main has been updated
via 66b552abbb4586b68cc298ff2e2bc16420fa7c18 (commit)
via 7c152619bda88f601a736b30731fc15cc99d1c96 (commit)
from e9ea7c1ce4969a15f112b9a2beb60182de0c90a9 (commit)
revisions in full, below.
commit 66b552abbb4586b68cc298ff2e2bc16420fa7c18
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed May 24 08:34:34 2023 +1200
Change WKBWriter default output dimension to 4 (#908)
diff --git a/NEWS.md b/NEWS.md
index 2b6e5e104..881e17287 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -71,6 +71,7 @@ xxxx-xx-xx
- Changes:
- Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
- Change MultiPoint WKT to use parentheses in sub-members (GH-903, Mike Taves)
+ - Change WKBWriter default output dimension to 4 (GH-908, Mike Taves)
## Changes in 3.11.0
2022-07-01
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 27d17459e..7818d98bd 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -5586,7 +5586,7 @@ extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(
* Set the output dimensionality of the writer. Either
-* 2, 3, or 4 dimensions.
+* 2, 3, or 4 dimensions. Default since GEOS 3.12 is 4.
* \param writer The writer to read from.
* \param newDimension The dimensionality desired
* \since 3.0
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 0e00ce0c2..0910f52f5 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -58,7 +58,7 @@ namespace io {
* The WKB format is specified in the OGC Simple Features for SQL specification.
* This implementation supports the extended WKB standard for representing
- * 3-dimensional coordinates. The presence of 3D coordinates is signified
+ * Z and M coordinates. The presence of Z and/or M coordinates is signified
* by setting the high bit of the wkbType word.
* Empty Points cannot be represented in WKB; an
@@ -80,15 +80,16 @@ public:
* Initializes writer with target coordinate dimension, endianness
* flag and SRID value.
- * @param dims Supported values are 2 or 3. Note that 3 indicates
- * up to 3 dimensions will be written but 2D WKB is still produced for 2D geometries.
+ * @param dims Supported values are 2, 3 or 4. Note that 4 indicates
+ * up to 4 dimensions will be written but (e.g.) 2D WKB is still produced
+ * for 2D geometries. Default since GEOS 3.12 is 4.
* @param bo output byte order - default to native machine byte order.
* Legal values include 0 (big endian/xdr) and 1 (little endian/ndr).
* @param incudeSRID true if SRID should be included in WKB (an
* extension).
WKBWriter(
- uint8_t dims = 2,
+ uint8_t dims = 4,
int bo = getMachineByteOrder(),
bool includeSRID = false,
int flv = WKBConstants::wkbExtended);
@@ -113,9 +114,9 @@ public:
* Sets the output dimension used by the <code>WKBWriter</code>.
- * @param newOutputDimension Supported values are 2 or 3.
- * Note that 3 indicates up to 3 dimensions will be written but
- * 2D WKB is still produced for 2D geometries.
+ * @param newOutputDimension Supported values are 2, 3 or 4.
+ * Note that 4 indicates up to 4 dimensions will be written but
+ * (e.g.) 2D WKB is still produced for 2D geometries.
void setOutputDimension(uint8_t newOutputDimension);
diff --git a/tests/unit/capi/GEOSWKBWriterTest.cpp b/tests/unit/capi/GEOSWKBWriterTest.cpp
index 0c6ae13ab..c50dfa55b 100644
--- a/tests/unit/capi/GEOSWKBWriterTest.cpp
+++ b/tests/unit/capi/GEOSWKBWriterTest.cpp
@@ -31,6 +31,7 @@ typedef group::object object;
group test_geoswkbwriter("capi::GEOSWKBWriter");
+// WKBWriter defaults
template<>
template<>
void object::test<1>()
@@ -38,7 +39,7 @@ void object::test<1>()
ensure_equals(GEOSWKBWriter_getIncludeSRID(wkbwriter_), 0);
ensure_equals(GEOSWKBWriter_getByteOrder(wkbwriter_), getMachineByteOrder());
ensure_equals(GEOSWKBWriter_getFlavor(wkbwriter_), GEOS_WKB_EXTENDED);
- ensure_equals(GEOSWKBWriter_getOutputDimension(wkbwriter_), 2);
+ ensure_equals(GEOSWKBWriter_getOutputDimension(wkbwriter_), 4);
template<>
@@ -83,7 +84,6 @@ void object::test<4>()
GEOSSetSRID(geom1_, 32145);
GEOSWKBWriter_setIncludeSRID(wkbwriter_, 1);
- GEOSWKBWriter_setOutputDimension(wkbwriter_, 3);
std::size_t hex_size = 0;
buf_ = GEOSWKBWriter_writeHEX(wkbwriter_, geom1_, &hex_size);
@@ -112,5 +112,76 @@ void object::test<5>()
ensure_equals(hexstr, "000000000140080000000000004020000000000000");
+template<>
+template<>
+void object::test<6>()
+ geom1_ = fromWKT("POINT M (3 8 2)");
+ GEOSWKBWriter_setOutputDimension(wkbwriter_, 2);
+ ensure_equals(GEOSWKBWriter_getOutputDimension(wkbwriter_), 2);
+ std::size_t hex_size = 0;
+ buf_ = GEOSWKBWriter_writeHEX(wkbwriter_, geom1_, &hex_size);
+ std::string hexstr = std::string((const char*) buf_, (const char*) buf_ + hex_size);
+ // POINT (3 8)
+ ensure_equals(hexstr, "010100000000000000000008400000000000002040");
+template<>
+template<>
+void object::test<7>()
+ GEOSWKBWriter_setOutputDimension(wkbwriter_, 3);
+ ensure_equals(GEOSWKBWriter_getOutputDimension(wkbwriter_), 3);
+ // POINT M (3 8 2)
+ ensure_equals(hexstr, "0101000040000000000000084000000000000020400000000000000040");
+template<>
+template<>
+void object::test<8>()
+ geom1_ = fromWKT("POINT ZM (3 8 1 2)");
+ // POINT (3 8)
+template<>
+template<>
+void object::test<9>()
+ // POINT Z (3 8 1)
+ ensure_equals(hexstr, "010100008000000000000008400000000000002040000000000000F03F");
} // namespace tut
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 1f974c32d..bad3bb40d 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -545,7 +545,6 @@ void GeosOp::outputGeometry(const Geometry * geom) {
if (args.format == GeosOpArgs::fmtWKB ) {
// output as hex-encoded WKB
WKBWriter writer;
- writer.setOutputDimension(4);
writer.writeHEX(*geom, std::cout);
std::cout << std::endl;
diff --git a/web/content/specifications/wkb.md b/web/content/specifications/wkb.md
index 6d4a82b81..585b2c0eb 100644
--- a/web/content/specifications/wkb.md
+++ b/web/content/specifications/wkb.md
@@ -254,8 +254,9 @@ GEOSWKBReader* reader = GEOSWKBReader_create();
GEOSGeom* geom = GEOSWKTReader_read(reader, linestring);
GEOSSetSRID(geom, 4326);
-/* Write it out as ISO WKB */
+/* Write it out as Extended WKB */
GEOSWKBWriter* writer = GEOSWKBWriter_create();
+/* Next line only needed before GEOS 3.12 */
GEOSWKBWriter_setOutputDimension(writer, 3);
GEOSWKBWriter_setFlavor(writer, GEOS_WKB_EXTENDED);
GEOSWKBWriter_setIncludeSRID(writer, 1);
@@ -294,6 +295,7 @@ GEOSGeom* geom = GEOSWKTReader_read(reader, linestring);
GEOSWKBWriter_setFlavor(writer, GEOS_WKB_ISO);
commit 7c152619bda88f601a736b30731fc15cc99d1c96
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue May 23 12:18:31 2023 -0700
Add geosOp polygonizeValid
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 5424b92e1..59c01b644 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -472,6 +472,21 @@ std::vector<GeometryOpCreator> opRegistry {
return new Result( std::move(geoms) ) ;
+{"polygonizeValid", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "polygonize lines into a valid polygonal geometry",
+ [](const std::unique_ptr<Geometry>& geom) {
+ geos::operation::polygonize::Polygonizer p(true);
+ p.add(geom.get());
+ std::vector<std::unique_ptr<Polygon>> polys = p.getPolygons();
+ std::vector<std::unique_ptr<const Geometry>> geoms;
+ for(unsigned int i = 0; i < polys.size(); i++) {
+ geoms.push_back( std::move(polys[i]) );
+ return new Result( std::move(geoms) ) ;
{"buildArea", [](std::string name) { return GeometryOp::create(name,
catConst,
"build area from lines",
Summary of changes:
NEWS.md | 1 +
capi/geos_c.h.in | 2 +-
include/geos/io/WKBWriter.h | 15 +++----
tests/unit/capi/GEOSWKBWriterTest.cpp | 75 ++++++++++++++++++++++++++++++++++-
util/geosop/GeometryOp.cpp | 15 +++++++
util/geosop/GeosOp.cpp | 1 -
web/content/specifications/wkb.md | 4 +-
7 files changed, 101 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
