[geos-commits] [SCM] GEOS branch main updated. bfe64bd74a6d79bdf30eed7adc0ecc8f14d210e4
Wed May 24 14:37:19 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  bfe64bd74a6d79bdf30eed7adc0ecc8f14d210e4 (commit)
      from  66b552abbb4586b68cc298ff2e2bc16420fa7c18 (commit)
revisions in full, below.
commit bfe64bd74a6d79bdf30eed7adc0ecc8f14d210e4
Author: Mike Taves <mwtoews at gmail.com>
Date:   Thu May 25 09:36:27 2023 +1200
    TST: swap "ensure_equals(y,x)" to correct "ensure_equals(x,y)"
diff --git a/tests/unit/io/GeoJSONFeatureTest.cpp b/tests/unit/io/GeoJSONFeatureTest.cpp
index f76469b57..06f2f3820 100644
--- a/tests/unit/io/GeoJSONFeatureTest.cpp
+++ b/tests/unit/io/GeoJSONFeatureTest.cpp
@@ -51,14 +51,14 @@ void object::test<1>
         {"id",   geos::io::GeoJSONValue(1.0)     },
         {"name", geos::io::GeoJSONValue(std::string{"One"}) },
-    ensure_equals("POINT (-117.000 33.000)", feature.getGeometry()->toText());
-    ensure_equals(1.0, feature.getProperties().at("id").getNumber());
-    ensure_equals("One", feature.getProperties().at("name").getString());
+    ensure_equals(feature.getGeometry()->toText(), "POINT (-117.000 33.000)");
+    ensure_equals(feature.getProperties().at("id").getNumber(), 1.0);
+    ensure_equals(feature.getProperties().at("name").getString(), "One");
     const geos::io::GeoJSONFeature feature2 = feature;
-    ensure_equals("POINT (-117.000 33.000)", feature2.getGeometry()->toText());
-    ensure_equals(1.0, feature2.getProperties().at("id").getNumber());
-    ensure_equals("One", feature2.getProperties().at("name").getString());
+    ensure_equals(feature2.getGeometry()->toText(), "POINT (-117.000 33.000)");
+    ensure_equals(feature2.getProperties().at("id").getNumber(), 1.0);
+    ensure_equals(feature2.getProperties().at("name").getString(), "One");
 // Write a GeoJSON FeatureCollection
@@ -78,12 +78,12 @@ void object::test<2>
     ensure_equals(static_cast<size_t>(2), features.getFeatures().size());
-    ensure_equals("POINT (-117.000 33.000)", features.getFeatures()[0].getGeometry()->toText());
-    ensure_equals(1.0, features.getFeatures()[0].getProperties().at("id").getNumber());
-    ensure_equals("One", features.getFeatures()[0].getProperties().at("name").getString());
-    ensure_equals("POINT (-127.000 53.000)", features.getFeatures()[1].getGeometry()->toText());
-    ensure_equals(2.0, features.getFeatures()[1].getProperties().at("id").getNumber());
-    ensure_equals("Two", features.getFeatures()[1].getProperties().at("name").getString());
+    ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POINT (-117.000 33.000)");
+    ensure_equals(features.getFeatures()[0].getProperties().at("id").getNumber(), 1.0);
+    ensure_equals(features.getFeatures()[0].getProperties().at("name").getString(), "One");
+    ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "POINT (-127.000 53.000)");
+    ensure_equals(features.getFeatures()[1].getProperties().at("id").getNumber(), 2.0);
+    ensure_equals(features.getFeatures()[1].getProperties().at("name").getString(), "Two");
\ No newline at end of file
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 230d6349f..0f43b9e5b 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -52,7 +52,7 @@ void object::test<1>
     std::string geojson { "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}" };
     GeomPtr geom(geojsonreader.read(geojson));
-    ensure_equals("POINT (-117.000 33.000)", geom->toText());
+    ensure_equals(geom->toText(), "POINT (-117.000 33.000)");
     ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 2u);
@@ -64,7 +64,7 @@ void object::test<2>
     std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0],[103.0,1.0],[104.0,0.0],[105.0,1.0]]}" };
-    ensure_equals("LINESTRING (102.000 0.000, 103.000 1.000, 104.000 0.000, 105.000 1.000)", geom->toText());
+    ensure_equals(geom->toText(), "LINESTRING (102.000 0.000, 103.000 1.000, 104.000 0.000, 105.000 1.000)");
@@ -76,7 +76,7 @@ void object::test<3>
     std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[30,10],[40,40],[20,40],[10,20],[30,10]]]}" };
-    ensure_equals("POLYGON ((30.000 10.000, 40.000 40.000, 20.000 40.000, 10.000 20.000, 30.000 10.000))", geom->toText());
+    ensure_equals(geom->toText(), "POLYGON ((30.000 10.000, 40.000 40.000, 20.000 40.000, 10.000 20.000, 30.000 10.000))");
@@ -88,7 +88,7 @@ void object::test<4>
     std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[35,10],[45,45],[15,40],[10,20],[35,10]],[[20,30],[35,35],[30,20],[20,30]]]}" };
-    ensure_equals("POLYGON ((35.000 10.000, 45.000 45.000, 15.000 40.000, 10.000 20.000, 35.000 10.000), (20.000 30.000, 35.000 35.000, 30.000 20.000, 20.000 30.000))", geom->toText());
+    ensure_equals(geom->toText(), "POLYGON ((35.000 10.000, 45.000 45.000, 15.000 40.000, 10.000 20.000, 35.000 10.000), (20.000 30.000, 35.000 35.000, 30.000 20.000, 20.000 30.000))");
@@ -100,7 +100,7 @@ void object::test<5>
     std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[[10, 40], [40, 30], [20, 20], [30, 10]]}" };
-    ensure_equals("MULTIPOINT ((10.000 40.000), (40.000 30.000), (20.000 20.000), (30.000 10.000))", geom->toText());
+    ensure_equals(geom->toText(), "MULTIPOINT ((10.000 40.000), (40.000 30.000), (20.000 20.000), (30.000 10.000))");
@@ -112,7 +112,7 @@ void object::test<6>
     std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[[10, 10], [20, 20], [10, 40]],[[40, 40], [30, 30], [40, 20], [30, 10]]]}" };
-    ensure_equals("MULTILINESTRING ((10.000 10.000, 20.000 20.000, 10.000 40.000), (40.000 40.000, 30.000 30.000, 40.000 20.000, 30.000 10.000))", geom->toText());
+    ensure_equals(geom->toText(), "MULTILINESTRING ((10.000 10.000, 20.000 20.000, 10.000 40.000), (40.000 40.000, 30.000 30.000, 40.000 20.000, 30.000 10.000))");
@@ -124,7 +124,7 @@ void object::test<7>
     std::string geojson { "{\"type\": \"MultiPolygon\", \"coordinates\": [[[[40, 40], [20, 45], [45, 30], [40, 40]]], [[[20, 35], [10, 30], [10, 10], [30, 5], [45, 20], [20, 35]], [[30, 20], [20, 15], [20, 25], [30, 20]]]]}" };
-    ensure_equals("MULTIPOLYGON (((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)), ((20.000 35.000, 10.000 30.000, 10.000 10.000, 30.000 5.000, 45.000 20.000, 20.000 35.000), (30.000 20.000, 20.000 15.000, 20.000 25.000, 30.000 20.000)))", geom->toText());
+    ensure_equals(geom->toText(), "MULTIPOLYGON (((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)), ((20.000 35.000, 10.000 30.000, 10.000 10.000, 30.000 5.000, 45.000 20.000, 20.000 35.000), (30.000 20.000, 20.000 15.000, 20.000 25.000, 30.000 20.000)))");
@@ -136,7 +136,7 @@ void object::test<8>
     std::string geojson { "{\"type\": \"GeometryCollection\",\"geometries\": [{\"type\": \"Point\",\"coordinates\": [40, 10]},{\"type\": \"LineString\",\"coordinates\": [[10, 10], [20, 20], [10, 40]]},{\"type\": \"Polygon\",\"coordinates\": [[[40, 40], [20, 45], [45, 30], [40, 40]]]}]}" };
-    ensure_equals("GEOMETRYCOLLECTION (POINT (40.000 10.000), LINESTRING (10.000 10.000, 20.000 20.000, 10.000 40.000), POLYGON ((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)))", geom->toText());
+    ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (40.000 10.000), LINESTRING (10.000 10.000, 20.000 20.000, 10.000 40.000), POLYGON ((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)))");
@@ -148,7 +148,7 @@ void object::test<9>
     std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}}" };
@@ -160,7 +160,7 @@ void object::test<10>
     std::string geojson { "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-122.0,45.0]}}]}" };
-    ensure_equals("GEOMETRYCOLLECTION (POINT (-117.000 33.000), POINT (-122.000 45.000))", geom->toText());
+    ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (-117.000 33.000), POINT (-122.000 45.000))");
@@ -172,7 +172,7 @@ void object::test<11>
     std::string geojson { "{\"type\":\"Point\",\"coordinates\":[]}" };
-    ensure_equals("POINT EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "POINT EMPTY");
@@ -184,7 +184,7 @@ void object::test<12>
     std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[]}" };
-    ensure_equals("LINESTRING EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "LINESTRING EMPTY");
@@ -196,7 +196,7 @@ void object::test<13>
     std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[]}" };
-    ensure_equals("POLYGON EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "POLYGON EMPTY");
@@ -208,7 +208,7 @@ void object::test<14>
     std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[]}" };
-    ensure_equals("MULTIPOINT EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "MULTIPOINT EMPTY");
@@ -220,7 +220,7 @@ void object::test<15>
     std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[]}" };
-    ensure_equals("MULTILINESTRING EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "MULTILINESTRING EMPTY");
@@ -232,7 +232,7 @@ void object::test<16>
     std::string geojson { "{\"type\": \"MultiPolygon\", \"coordinates\": []}" };
-    ensure_equals("MULTIPOLYGON EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "MULTIPOLYGON EMPTY");
@@ -244,7 +244,7 @@ void object::test<17>
     std::string geojson { "{\"type\": \"GeometryCollection\",\"geometries\": []}" };
-    ensure_equals("GEOMETRYCOLLECTION EMPTY", geom->toText());
+    ensure_equals(geom->toText(), "GEOMETRYCOLLECTION EMPTY");
@@ -256,12 +256,12 @@ void object::test<18>
     std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"required\": true} }" };
     geos::io::GeoJSONFeatureCollection features(geojsonreader.readFeatures(geojson));
-    ensure_equals(static_cast<size_t>(1), features.getFeatures().size());
+    ensure_equals(features.getFeatures().size(), static_cast<size_t>(1));
     ensure_equals(static_cast<size_t>(features.getFeatures()[0].getGeometry()->getCoordinateDimension()), 2u);
-    ensure_equals("one", features.getFeatures()[0].getProperties().at("name").getString());
-    ensure_equals(true, features.getFeatures()[0].getProperties().at("required").getBoolean());
+    ensure_equals(features.getFeatures()[0].getProperties().at("name").getString(), "one");
+    ensure_equals(features.getFeatures()[0].getProperties().at("required").getBoolean(), true);
 // Read a Complicated Feature
@@ -272,17 +272,17 @@ void object::test<19>
     std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"items\": [1,2,3,4], \"nested\": {\"id\":2, \"name\":\"two\"}}}" };
     std::vector<geos::io::GeoJSONValue> values = features.getFeatures()[0].getProperties().at("items").getArray();
-    ensure_equals(static_cast<size_t>(4), values.size());
-    ensure_equals(1.0, values[0].getNumber());
-    ensure_equals(2.0, values[1].getNumber());
-    ensure_equals(3.0, values[2].getNumber());
-    ensure_equals(4.0, values[3].getNumber());
+    ensure_equals(values.size(), static_cast<size_t>(4));
+    ensure_equals(values[0].getNumber(), 1.0);
+    ensure_equals(values[1].getNumber(), 2.0);
+    ensure_equals(values[2].getNumber(), 3.0);
+    ensure_equals(values[3].getNumber(), 4.0);
 // Read a FeatureCollection
@@ -297,14 +297,14 @@ void object::test<20>
         "{\"type\":\"Feature\",\"properties\":{\"id\": 3},\"geometry\":{\"type\":\"Point\",\"coordinates\":[-28.125,39.095]}}"
-    ensure_equals(static_cast<size_t>(3), features.getFeatures().size());
+    ensure_equals(features.getFeatures().size(), static_cast<size_t>(3));
-    ensure_equals("POLYGON ((87.890 64.923, 76.992 55.178, 102.656 46.558, 115.312 60.413, 94.570 58.447, 87.890 64.923))", features.getFeatures()[0].getGeometry()->toText());
-    ensure_equals("LINESTRING (1.406 48.690, 41.835 34.016, 22.500 13.923)", features.getFeatures()[1].getGeometry()->toText());
-    ensure_equals("POINT (-28.125 39.095)", features.getFeatures()[2].getGeometry()->toText());
-    ensure_equals(3.0, features.getFeatures()[2].getProperties().at("id").getNumber());
+    ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POLYGON ((87.890 64.923, 76.992 55.178, 102.656 46.558, 115.312 60.413, 94.570 58.447, 87.890 64.923))");
+    ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "LINESTRING (1.406 48.690, 41.835 34.016, 22.500 13.923)");
+    ensure_equals(features.getFeatures()[2].getGeometry()->toText(), "POINT (-28.125 39.095)");
+    ensure_equals(features.getFeatures()[2].getProperties().at("id").getNumber(), 3.0);
 // Read a GeoJSON Polygon with an empty ring
@@ -315,7 +315,7 @@ void object::test<21>
     std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[]]}" };
@@ -335,7 +335,7 @@ void object::test<22>
         errorMessage = e.what();
     ensure(error == true);
-    ensure_equals("ParseException: Expected two coordinates found one", errorMessage);
+    ensure_equals(errorMessage, "ParseException: Expected two coordinates found one");
 // Throw ParseException for bad GeoJSON
@@ -373,7 +373,7 @@ void object::test<24>
 // Throw error when geometry type is unsupported
@@ -392,7 +392,7 @@ void object::test<25>
-    ensure_equals("ParseException: Unknown geometry type!", errorMessage);
+    ensure_equals(errorMessage, "ParseException: Unknown geometry type!");
 // Throw error when LINESTRING has only one coordinate
@@ -411,7 +411,7 @@ void object::test<26>
 // Read a GeoJSON empty Polygon with empty shell and empty inner rings
@@ -422,7 +422,7 @@ void object::test<27>
     std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[],[]]}" };
@@ -434,7 +434,7 @@ void object::test<28>
     std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[],[],[]]}" };
@@ -454,7 +454,7 @@ void object::test<29>
-    ensure_equals("ParseException: Expected two coordinates found more than two", errorMessage);
+    ensure_equals(errorMessage, "ParseException: Expected two coordinates found more than two");
Summary of changes:
 tests/unit/io/GeoJSONFeatureTest.cpp | 26 +++++-----
 tests/unit/io/GeoJSONReaderTest.cpp  | 92 ++++++++++++++++++------------------
 2 files changed, 59 insertions(+), 59 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
