[geos-commits] [SCM] GEOS branch main updated. 68a5b4d4bfadee1c580fb6702597fe7cfbcc8118
git at osgeo.org
git at osgeo.org
Mon May 29 07:14:36 PDT 2023
the project "GEOS".
The branch, main has been updated
via 68a5b4d4bfadee1c580fb6702597fe7cfbcc8118 (commit)
via 523cea8a3afef830cee3b2f9b591bc4dbcd4c98e (commit)
via 2efd5ed41009149db31b896cea98aacf765b004c (commit)
from bfe64bd74a6d79bdf30eed7adc0ecc8f14d210e4 (commit)
revisions in full, below.
commit 68a5b4d4bfadee1c580fb6702597fe7cfbcc8118
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon May 29 07:13:30 2023 -0700
* Port https://github.com/locationtech/jts/pull/981
* References https://github.com/qgis/QGIS/issues/53165
* References https://github.com/libgeos/geos/issues/897
diff --git a/include/geos/operation/buffer/OffsetCurve.h b/include/geos/operation/buffer/OffsetCurve.h
index 1a9f450be..403ca98b7 100644
--- a/include/geos/operation/buffer/OffsetCurve.h
+++ b/include/geos/operation/buffer/OffsetCurve.h
@@ -190,6 +190,12 @@ public:
// Constants
static constexpr int MATCH_DISTANCE_FACTOR = 10000;
+ * A QuadSegs minimum value that will prevent generating
+ * unwanted offset curve artifacts near end caps.
+ static constexpr int MIN_QUADRANT_SEGMENTS = 8;
* Creates a new instance for computing an offset curve for a geometry at a given distance.
* with default quadrant segments (BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
@@ -230,7 +236,17 @@ public:
throw util::IllegalArgumentException("OffsetCurve distance must be a finite value");
//-- set buffer params, leaving cap style as the default CAP_ROUND
- bufferParams.setQuadrantSegments( bp.getQuadrantSegments());
+ * Prevent using a very small QuadSegs value, to avoid
+ * offset curve artifacts near the end caps.
+ int quadSegs = bp.getQuadrantSegments();
+ if (quadSegs < MIN_QUADRANT_SEGMENTS) {
+ quadSegs = MIN_QUADRANT_SEGMENTS;
+ bufferParams.setQuadrantSegments(quadSegs);
bufferParams.setJoinStyle( bp.getJoinStyle());
bufferParams.setMitreLimit( bp.getMitreLimit());
diff --git a/tests/unit/capi/GEOSOffsetCurveTest.cpp b/tests/unit/capi/GEOSOffsetCurveTest.cpp
index c2ab6805c..052a5f9df 100644
--- a/tests/unit/capi/GEOSOffsetCurveTest.cpp
+++ b/tests/unit/capi/GEOSOffsetCurveTest.cpp
@@ -104,7 +104,7 @@ void object::test<3>()
checkOffset(
"LINESTRING(0 0, 10 0, 10 10)",
- "LINESTRING (12 10, 12 0, 10 -2, 0 -2)",
+ "LINESTRING (0 -2, 10 -2, 10.3901806 -1.9615705, 10.76536686 -1.8477590, 11.11114046 -1.66293922, 11.41421356 -1.41421356, 11.66293922 -1.11114046, 11.84775906 -0.76536686, 11.96157056 -0.3901806, 12 0, 12 10)",
-2, 1, GEOSBUF_JOIN_ROUND, 2,
0.000001
@@ -132,7 +132,7 @@ void object::test<5>()
"LINESTRING(33282908 6005055,33282900 6005050,33282892 6005042,33282876 6005007,33282863 6004982,33282866 6004971,33282876 6004975,33282967 6005018,33282999 6005031)",
// Old algorithm
// "LINESTRING EMPTY",
- "LINESTRING (33282939.63869393 6005053.735950421, 33282948.754269257 6005058.043310191, 33282949.873293087 6005058.534544423, 33282982.439409934 6005071.764529393)",
+ "LINESTRING (33282951.601378817 6005059.236579252, 33282982.439409934 6005071.764529393)",
44, 1, GEOSBUF_JOIN_MITRE, 1,
0.000001
diff --git a/tests/unit/operation/buffer/OffsetCurveTest.cpp b/tests/unit/operation/buffer/OffsetCurveTest.cpp
index 8ac3a2226..5faea0fe4 100644
--- a/tests/unit/operation/buffer/OffsetCurveTest.cpp
+++ b/tests/unit/operation/buffer/OffsetCurveTest.cpp
@@ -525,7 +525,7 @@ void object::test<38> ()
checkOffsetCurve(
"LINESTRING (20 20, 50 50, 80 20)",
10, 2, -1, -1,
- "LINESTRING (12.93 27.07, 42.93 57.07, 50 60, 57.07 57.07, 87.07 27.07)"
+ "LINESTRING (12.928932188134524 27.071067811865476, 42.928932188134524 57.071067811865476, 44.44429766980398 58.314696123025456, 46.1731656763491 59.23879532511287, 48.04909677983872 59.80785280403231, 50 60, 51.95090322016128 59.80785280403231, 53.8268343236509 59.23879532511287, 55.55570233019602 58.314696123025456, 57.071067811865476 57.071067811865476, 87.07106781186548 27.071067811865476)"
@@ -554,5 +554,32 @@ void object::test<40> ()
+// testMinQuadrantSegments
+// See https://github.com/qgis/QGIS/issues/53165
+template<>
+template<>
+void object::test<41> ()
+ checkOffsetCurve(
+ "LINESTRING (553772.0645892698 177770.05079236583, 553780.9235869241 177768.99614978794, 553781.8325485934 177768.41771963477)",
+ -11, 0, BufferParameters::JOIN_MITRE, -1,
+ "LINESTRING (553770.76 177759.13, 553777.54 177758.32)"
+// testMinQuadrantSegments_QGIS
+// See https://github.com/qgis/QGIS/issues/53165#issuecomment-1563214857
+template<>
+template<>
+void object::test<42> ()
+ checkOffsetCurve(
+ "LINESTRING (421 622, 446 625, 449 627)",
+ 133, 0, BufferParameters::JOIN_MITRE, -1,
+ "LINESTRING (405.15 754.05, 416.3 755.39)"
} // namespace tut
diff --git a/web/content/specifications/geojson.md b/web/content/specifications/geojson.md
index 502f8ea3e..fb3cee7de 100644
--- a/web/content/specifications/geojson.md
+++ b/web/content/specifications/geojson.md
@@ -14,7 +14,7 @@ Unlike [WKB]({{< ref "wkb" >}}) and [WKT]({{< ref "wkt" >}}), GeoJSON does not r
* [Feature](https://datatracker.ietf.org/doc/html/rfc7946#section-3.2), representation of an object that has a "geometry" and an arbitrary set of other non-geometric "properties".
* [FeatureCollection](https://datatracker.ietf.org/doc/html/rfc7946#section-3.3), representation of a list of Features.
-Since GEOS is almost 100% concerned with geometry operations, there is no GEOS abstraction to translate the non-geometric properties of GeoJSON Feature into, so handling of Feature properties is only available via the C++ [GeoJSON.h](/libgeos/geos/blob/main/include/geos/io/GeoJSON.h) utilities.
+Since GEOS is almost 100% concerned with geometry operations, there is no GEOS abstraction to translate the non-geometric properties of GeoJSON Feature into, so handling of Feature properties is only available via the C++ [GeoJSON.h](https://github.com/libgeos/geos/blob/main/include/geos/io/GeoJSON.h) utilities.
### Writing GeoJSON
commit 523cea8a3afef830cee3b2f9b591bc4dbcd4c98e
Date: Fri May 26 15:49:06 2023 -0700
Update NEWS for MinimumAreaRectangle
diff --git a/NEWS.md b/NEWS.md
index 881e17287..08cda262c 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -23,6 +23,7 @@ xxxx-xx-xx
- Polygonal coverages: CoverageSimplifier (JTS-911, Martin Davis)
- CAPI: GEOSCoverageIsValid, GEOSCoverageSimplifyVW (GH-867, Paul Ramsey)
- CAPI: GEOSGeom_releaseCollection (GH-848)
+ - CAPI: GEOSMinimumRotatedRectangle now uses MinimumAreaRectangle (Paul Ramsey)
- Fixes/Improvements:
- WKTReader: Fix parsing of Z and M flags in WKTReader (#676 and GH-669, Dan Baston)
commit 2efd5ed41009149db31b896cea98aacf765b004c
Date: Fri May 26 15:46:03 2023 -0700
Add MinimumAreaRectangle, a bounding rectangle algorithm.
Port of https://github.com/locationtech/jts/pull/977
This adds a MinimumAreaRectangle class implementing the
standard "rotating-calipers` algorithm for computing a Minimum-Area Rectangle.
MinimumDiameter.getMinimumRectangle was previously used
for this, but it does not always compute the Minimum-Area
Rectangle. It is kept available, for backwards compatibility.
Also, it computes the Minimum-Width Rectangle, which may be useful.
The CAPI GEOSMinimumRotatedRectangle is now bound to
MinimumAreaRectangle rather than MinimumDiameter.getMinimumRectangle
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 9941292e5..710004c4e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -20,6 +20,7 @@
#include <geos/algorithm/BoundaryNodeRule.h>
#include <geos/algorithm/MinimumBoundingCircle.h>
#include <geos/algorithm/MinimumDiameter.h>
+#include <geos/algorithm/MinimumAreaRectangle.h>
#include <geos/algorithm/Orientation.h>
#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/algorithm/construct/LargestEmptyCircle.h>
@@ -1323,9 +1324,10 @@ extern "C" {
Geometry*
GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ using geos::algorithm::MinimumAreaRectangle;
return execute(extHandle, [&]() {
- geos::algorithm::MinimumDiameter m(g);
- auto g3 = m.getMinimumRectangle();
+ auto g3 = MinimumAreaRectangle::getMinimumRectangle(g);
g3->setSRID(g->getSRID());
return g3.release();
diff --git a/include/geos/algorithm/Distance.h b/include/geos/algorithm/Distance.h
index b74b87bc0..5d82384d5 100644
--- a/include/geos/algorithm/Distance.h
+++ b/include/geos/algorithm/Distance.h
@@ -49,10 +49,11 @@ public:
* another point of the line (must be different to A)
// formerly distanceLineLine
- static double segmentToSegment(const geom::CoordinateXY& A,
- const geom::CoordinateXY& B,
- const geom::CoordinateXY& C,
- const geom::CoordinateXY& D);
+ static double segmentToSegment(
+ const geom::CoordinateXY& A,
+ const geom::CoordinateXY& B,
+ const geom::CoordinateXY& C,
+ const geom::CoordinateXY& D);
* Computes the distance from a point to a sequence of line segments.
@@ -63,8 +64,9 @@ public:
* a sequence of contiguous line segments defined by their vertices
* @return the minimum distance between the point and the line segments
- static double pointToSegmentString(const geom::CoordinateXY& p,
- const geom::CoordinateSequence* seq);
+ static double pointToSegmentString(
+ const geom::CoordinateXY& p,
+ const geom::CoordinateSequence* seq);
* Computes the distance from a point p to a line segment AB
@@ -80,9 +82,10 @@ public:
* @return the distance from p to line segment AB
// formerly distancePointLine
- static double pointToSegment(const geom::CoordinateXY& p,
- const geom::CoordinateXY& A,
- const geom::CoordinateXY& B);
+ static double pointToSegment(
+ const geom::CoordinateXY& B);
* Computes the perpendicular distance from a point p to the (infinite) line
@@ -97,10 +100,15 @@ public:
* @return the distance from p to line AB
// formerly distancePointLinePerpendicular
- static double pointToLinePerpendicular(const geom::CoordinateXY& p,
+ static double pointToLinePerpendicular(
+ static double pointToLinePerpendicularSigned(
} // namespace geos::algorithm
diff --git a/include/geos/algorithm/MinimumAreaRectangle.h b/include/geos/algorithm/MinimumAreaRectangle.h
new file mode 100644
index 000000000..0e340a981
--- /dev/null
+++ b/include/geos/algorithm/MinimumAreaRectangle.h
@@ -0,0 +1,159 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2023 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/export.h>
+#include <vector>
+#include <memory>
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class CoordinateSequence;
+ class CoordinateXY;
+ class Geometry;
+ class GeometryFactory;
+ class LineSegment;
+ class LineString;
+ class Polygon;
+using geos::geom::CoordinateSequence;
+using geos::geom::CoordinateXY;
+using geos::geom::Geometry;
+using geos::geom::GeometryFactory;
+using geos::geom::LineSegment;
+using geos::geom::LineString;
+using geos::geom::Polygon;
+namespace geos {
+namespace algorithm { // geos::algorithm
+ * Computes the minimum-area rectangle enclosing a Geometry.
+ * Unlike the Envelope, the rectangle may not be axis-parallel.
+ * The first step in the algorithm is computing the convex hull of the Geometry.
+ * If the input Geometry is known to be convex, a hint can be supplied to
+ * avoid this computation.
+ * In degenerate cases the minimum enclosing geometry
+ * may be a LineString or a Point.
+ * The minimum-area enclosing rectangle does not necessarily
+ * have the minimum possible width.
+ * Use MinimumDiameter to compute this.
+ * @see MinimumDiameter
+ * @see ConvexHull
+class GEOS_DLL MinimumAreaRectangle {
+private:
+ // Members
+ const Geometry* m_inputGeom;
+ bool m_isConvex;
+ // Methods
+ std::unique_ptr<Geometry> getMinimumRectangle();
+ std::unique_ptr<Geometry> computeConvex(const Geometry* convexGeom);
+ * Computes the minimum-area rectangle for a convex ring of Coordinate.
+ * This algorithm uses the "dual rotating calipers" technique.
+ * Performance is linear in the number of segments.
+ * @param ring the convex ring to scan
+ std::unique_ptr<Polygon> computeConvexRing(const CoordinateSequence* ring);
+ std::size_t findFurthestVertex(
+ const CoordinateSequence* pts,
+ const LineSegment& baseSeg,
+ std::size_t startIndex,
+ int orient);
+ bool isFurtherOrEqual(double d1, double d2, int orient);
+ static double orientedDistance(
+ const LineSegment& seg,
+ const CoordinateXY& p,
+ int orient);
+ static std::size_t getNextIndex(
+ const CoordinateSequence* ring,
+ std::size_t index);
+ * Creates a line of maximum extent from the provided vertices
+ * @param pts the vertices
+ * @param factory the geometry factory
+ * @return the line of maximum extent
+ static std::unique_ptr<LineString> computeMaximumLine(
+ const GeometryFactory* factory);
+public:
+ * Compute a minimum-area rectangle for a given Geometry.
+ * @param inputGeom a Geometry
+ MinimumAreaRectangle(const Geometry* inputGeom)
+ : m_inputGeom(inputGeom)
+ , m_isConvex(false)
+ * Compute a minimum rectangle for a Geometry,
+ * with a hint if the geometry is convex
+ * (e.g. a convex Polygon or LinearRing,
+ * or a two-point LineString, or a Point).
+ * @param inputGeom a Geometry which is convex
+ * @param isConvex true if the input geometry is convex
+ MinimumAreaRectangle(const Geometry* inputGeom, bool isConvex)
+ , m_isConvex(isConvex)
+ * Gets the minimum-area rectangular Polygon which encloses the input geometry.
+ * If the convex hull of the input is degenerate (a line or point)
+ * a LineString or Point is returned.
+ * @param geom the geometry
+ * @return the minimum rectangle enclosing the geometry
+ static std::unique_ptr<Geometry> getMinimumRectangle(const Geometry* geom);
+} // namespace geos::algorithm
diff --git a/include/geos/algorithm/MinimumDiameter.h b/include/geos/algorithm/MinimumDiameter.h
index 956f90d23..ada2d84b7 100644
--- a/include/geos/algorithm/MinimumDiameter.h
+++ b/include/geos/algorithm/MinimumDiameter.h
@@ -3,6 +3,7 @@
* Copyright (C) 2005-2006 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -11,10 +12,6 @@
- * Last port: algorithm/MinimumDiameter.java r966
#pragma once
@@ -53,12 +50,16 @@ namespace algorithm { // geos::algorithm
* This class can also be used to compute a line segment representing
* the minimum diameter, the supporting line segment of the minimum diameter,
- * and a minimum rectangle enclosing the input geometry.
+ * and a minimum-width rectangle of the input geometry.
* This rectangle will have width equal to the minimum diameter, and have
* one side parallel to the supporting segment.
- * @see ConvexHull
+ * In degenerate cases the rectangle may be a LineString or a Point.
+ * (Note that this may not be the enclosing rectangle with minimum area;
+ * use MinimumAreaRectangle to compute this.)
+ * @see ConvexHull
+ * @see MinimumAreaRectangle
class GEOS_DLL MinimumDiameter {
private:
@@ -75,7 +76,7 @@ private:
void computeWidthConvex(const geom::Geometry* geom);
- * Compute the width information for a ring of {@link geom::Coordinate}s.
+ * Compute the width information for a ring of Coordinate.
* Leaves the width information in the instance variables.
* @param pts
@@ -127,7 +128,7 @@ public:
double getLength();
/** \brief
- * Gets the {@link geom::Coordinate} forming one end of the minimum diameter.
+ * Gets the geom::Coordinate forming one end of the minimum diameter.
* @return a coordinate forming one end of the minimum diameter
@@ -148,15 +149,17 @@ public:
std::unique_ptr<geom::LineString> getDiameter();
/** \brief
- * Gets the minimum rectangular Polygon which encloses the input geometry.
+ * Gets the rectangular Polygon which encloses the input geometry
+ * and is based on the minimum diameter supporting segment.
* The rectangle has width equal to the minimum diameter, and a longer
* length. If the convex hill of the input is degenerate (a line or point)
- * The minimum rectangle can be used as an extremely generalized
- * representation for the given geometry.
+ * This is not necessarily the rectangle with minimum area.
+ * Use MinimumAreaRectangle to compute this.
- * @return the minimum rectangle enclosing the input (or a line or point if degenerate)
+ * @return the the minimum-width rectangle enclosing the geometry
std::unique_ptr<geom::Geometry> getMinimumRectangle();
@@ -164,7 +167,8 @@ public:
* Gets the minimum rectangle enclosing a geometry.
- * @return the minimum rectangle enclosing the geometry
+ * @return a rectangle enclosing the input (or a line or point if degenerate)
static std::unique_ptr<geom::Geometry> getMinimumRectangle(geom::Geometry* geom);
diff --git a/include/geos/algorithm/Rectangle.h b/include/geos/algorithm/Rectangle.h
index 000000000..ef073ee47
--- /dev/null
+++ b/include/geos/algorithm/Rectangle.h
@@ -0,0 +1,96 @@
+#pragma once
+#include <geos/geom/LineSegment.h>
+namespace geos {
+namespace geom {
+class Coordinate;
+class GeometryFactory;
+class Polygon;
+namespace geos {
+class GEOS_DLL Rectangle {
+public:
+ * Creates a rectangular {@link Polygon} from a base segment
+ * defining the position and orientation of one side of the rectangle, and
+ * three points defining the locations of the line segments
+ * forming the opposite, left and right sides of the rectangle.
+ * The base segment and side points must be presented so that the
+ * rectangle has CW orientation.
+ * The rectangle corners are computed as intersections of
+ * lines, which generally cannot produce exact values.
+ * If a rectangle corner is determined to coincide with a side point
+ * the side point value is used to avoid numerical inaccuracy.
+ * The first side of the constructed rectangle contains the base segment.
+ * @param baseRightPt the right point of the base segment
+ * @param baseLeftPt the left point of the base segment
+ * @param oppositePt the point defining the opposite side
+ * @param leftSidePt the point defining the left side
+ * @param rightSidePt the point defining the right side
+ * @param factory the geometry factory to use
+ * @return the rectangular polygon
+ static std::unique_ptr<Polygon>
+ createFromSidePts(
+ const CoordinateXY& baseRightPt,
+ const CoordinateXY& baseLeftPt,
+ const CoordinateXY& oppositePt,
+ const CoordinateXY& leftSidePt,
+ const CoordinateXY& rightSidePt,
+private:
+ * Computes the constant C in the standard line equation Ax + By = C
+ * from A and B and a point on the line.
+ * @param a the X coefficient
+ * @param b the Y coefficient
+ * @param p a point on the line
+ * @return the constant C
+ static double
+ computeLineEquationC(double a, double b, const CoordinateXY& p);
+ static LineSegment
+ createLineForStandardEquation(double a, double b, double c);
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 21da3212a..714c123d9 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -188,7 +188,21 @@ public:
return orientationIndex(*seg);
+ * Determines the orientation index of a Coordinate relative to this segment.
+ * The orientation index is as defined in Orientation::index(Coordinate, Coordinate, Coordinate).
+ * @param p the coordinate to compare
+ * @return 1 (LEFT) if "p" is to the left of this segment
+ * @return -1 (RIGHT) if "p" is to the right of this segment
+ * @return 0 (COLLINEAR) if "p" is collinear with this segment
+ int orientationIndex(const CoordinateXY& p) const
+ return algorithm::Orientation::index(p0, p1, p);
/** \brief
@@ -255,15 +269,35 @@ public:
return algorithm::Distance::pointToSegment(p, p0, p1);
- /** \brief
* Computes the perpendicular distance between the (infinite)
* line defined by this line segment and a point.
+ * If the segment has zero length this returns the distance between
+ * the segment and the point.
+ * @param p the point to compute the distance to
+ * @return the perpendicular distance between the line and point
double distancePerpendicular(const CoordinateXY& p) const
+ if (p0.equals2D(p1))
+ return p0.distance(p);
return algorithm::Distance::pointToLinePerpendicular(p, p0, p1);
+ * Computes the oriented perpendicular distance between the (infinite) line
+ * defined by this line segment and a point.
+ * The oriented distance is positive if the point on the left of the line,
+ * and negative if it is on the right.
+ * @return the oriented perpendicular distance between the line and point
+ double distancePerpendicularOriented(const CoordinateXY& p) const;
/** \brief
* Computes the Coordinate that lies a given
* fraction along the line defined by this segment.
@@ -375,6 +409,8 @@ public:
void project(const Coordinate& p, Coordinate& ret) const;
+ CoordinateXY project(const CoordinateXY& p) const;
/** \brief
* Project a line segment onto this line segment and return the resulting
* line segment.
diff --git a/src/algorithm/Distance.cpp b/src/algorithm/Distance.cpp
index 278a4002f..ebbba3523 100644
--- a/src/algorithm/Distance.cpp
+++ b/src/algorithm/Distance.cpp
@@ -201,6 +201,29 @@ Distance::pointToSegmentString(const geom::CoordinateXY& p,
+/*public static*/
+double
+Distance::pointToLinePerpendicularSigned(
+ // use comp.graphics.algorithms Frequently Asked Questions method
+ * (2) s = (Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
+ * L^2
+ * Then the distance from C to P = |s|*L.
+ double len2 = (B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y);
+ double s = ((A.y - p.y) * (B.x - A.x) - (A.x - p.x) * (B.y - A.y))
+ / len2;
+ return s * std::sqrt(len2);
} // namespace geos.algorithm
} //namespace geos
diff --git a/src/algorithm/MinimumAreaRectangle.cpp b/src/algorithm/MinimumAreaRectangle.cpp
index 000000000..b3f655fb9
--- /dev/null
+++ b/src/algorithm/MinimumAreaRectangle.cpp
@@ -0,0 +1,269 @@
+#include <geos/algorithm/ConvexHull.h>
+#include <geos/algorithm/Rectangle.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Envelope.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/Polygon.h>
+#include <geos/util.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <geos/constants.h>
+using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+std::unique_ptr<Geometry>
+MinimumAreaRectangle::getMinimumRectangle(const Geometry* geom)
+ MinimumAreaRectangle mar(geom);
+ return mar.getMinimumRectangle();
+/* private */
+MinimumAreaRectangle::getMinimumRectangle()
+ if (m_inputGeom->isEmpty()) {
+ return m_inputGeom->getFactory()->createPolygon();
+ if (m_isConvex) {
+ return computeConvex(m_inputGeom);
+ ConvexHull cvh(m_inputGeom);
+ std::unique_ptr<Geometry> convexGeom = cvh.getConvexHull();
+ return computeConvex(convexGeom.get());
+/* private */
+MinimumAreaRectangle::computeConvex(const Geometry* convexGeom)
+ const CoordinateSequence* convexHullPts;
+ switch (convexGeom->getGeometryTypeId()) {
+ case GEOS_POLYGON:
+ auto poly = static_cast<const Polygon*>(convexGeom);
+ convexHullPts = poly->getExteriorRing()->getCoordinatesRO();
+ break;
+ case GEOS_LINESTRING:
+ auto line = static_cast<const LineString*>(convexGeom);
+ convexHullPts = line->getCoordinatesRO();
+ break;
+ case GEOS_POINT:
+ auto pt = static_cast<const Point*>(convexGeom);
+ convexHullPts = pt->getCoordinatesRO();
+ break;
+ default:
+ throw util::IllegalArgumentException("computeConvex called with unsupported geometry type");
+ // special cases for lines or points or degenerate rings
+ switch (convexHullPts->size())
+ case 1:
+ return m_inputGeom->getFactory()->createPoint(convexHullPts->getAt<CoordinateXY>(0));
+ case 2:
+ case 3:
+ return computeMaximumLine(convexHullPts, m_inputGeom->getFactory());
+ default:
+ // TODO: ensure ring is CW
+ return computeConvexRing(convexHullPts);
+/* private */
+std::unique_ptr<Polygon>
+MinimumAreaRectangle::computeConvexRing(const CoordinateSequence* ring)
+ // Assert: ring is oriented CW
+ double minRectangleArea = DoubleMax;
+ std::size_t minRectangleBaseIndex = NO_COORD_INDEX;
+ std::size_t minRectangleDiamIndex = NO_COORD_INDEX;
+ std::size_t minRectangleLeftIndex = NO_COORD_INDEX;
+ std::size_t minRectangleRightIndex = NO_COORD_INDEX;
+ //-- start at vertex after first one
+ std::size_t diameterIndex = 1;
+ std::size_t leftSideIndex = 1;
+ std::size_t rightSideIndex = NO_COORD_INDEX; // initialized once first diameter is found
+ LineSegment segBase;
+ LineSegment segDiam;
+ // for each segment, find the next vertex which is at maximum distance
+ for (std::size_t i = 0; i < ring->size() - 1; i++) {
+ segBase.p0 = ring->getAt<CoordinateXY>(i);
+ segBase.p1 = ring->getAt<CoordinateXY>(i + 1);
+ diameterIndex = findFurthestVertex(ring, segBase, diameterIndex, 0);
+ const CoordinateXY& diamPt = ring->getAt<CoordinateXY>(diameterIndex);
+ CoordinateXY diamBasePt = segBase.project(diamPt);
+ segDiam.p0 = diamBasePt;
+ segDiam.p1 = diamPt;
+ leftSideIndex = findFurthestVertex(ring, segDiam, leftSideIndex, 1);
+ //-- init the max right index
+ if (i == 0) {
+ rightSideIndex = diameterIndex;
+ rightSideIndex = findFurthestVertex(ring, segDiam, rightSideIndex, -1);
+ double rectWidth = segDiam.distancePerpendicular(ring->getAt<CoordinateXY>(leftSideIndex))
+ + segDiam.distancePerpendicular(ring->getAt<CoordinateXY>(rightSideIndex));
+ double rectArea = segDiam.getLength() * rectWidth;
+ if (rectArea < minRectangleArea) {
+ minRectangleArea = rectArea;
+ minRectangleBaseIndex = i;
+ minRectangleDiamIndex = diameterIndex;
+ minRectangleLeftIndex = leftSideIndex;
+ minRectangleRightIndex = rightSideIndex;
+ return Rectangle::createFromSidePts(
+ ring->getAt<CoordinateXY>(minRectangleBaseIndex),
+ ring->getAt<CoordinateXY>(minRectangleBaseIndex + 1),
+ ring->getAt<CoordinateXY>(minRectangleDiamIndex),
+ ring->getAt<CoordinateXY>(minRectangleLeftIndex),
+ ring->getAt<CoordinateXY>(minRectangleRightIndex),
+ m_inputGeom->getFactory());
+/* private */
+std::size_t
+MinimumAreaRectangle::findFurthestVertex(
+ std::size_t startIndex, int orient)
+ double maxDistance = orientedDistance(baseSeg, pts->getAt<CoordinateXY>(startIndex), orient);
+ double nextDistance = maxDistance;
+ std::size_t maxIndex = startIndex;
+ std::size_t nextIndex = maxIndex;
+ //-- rotate "caliper" while distance from base segment is non-decreasing
+ while (isFurtherOrEqual(nextDistance, maxDistance, orient)) {
+ maxDistance = nextDistance;
+ maxIndex = nextIndex;
+ nextIndex = getNextIndex(pts, maxIndex);
+ if (nextIndex == startIndex)
+ break;
+ nextDistance = orientedDistance(baseSeg, pts->getAt<CoordinateXY>(nextIndex), orient);
+ return maxIndex;
+/* private */
+bool
+MinimumAreaRectangle::isFurtherOrEqual(
+ double d1, double d2,
+ int orient)
+ switch (orient) {
+ case 0: return std::abs(d1) >= std::abs(d2);
+ case 1: return d1 >= d2;
+ case -1: return d1 <= d2;
+ throw util::IllegalArgumentException("Invalid orientation index");
+/* private static */
+double
+MinimumAreaRectangle::orientedDistance(
+ int orient)
+ double dist = seg.distancePerpendicularOriented(p);
+ if (orient == 0) {
+ return std::abs(dist);
+ return dist;
+std::size_t
+MinimumAreaRectangle::getNextIndex(
+ if (index == NO_COORD_INDEX) index = 0;
+ else index = index + 1;
+ if (index >= ring->size() - 1)
+ index = 0;
+ return index;
+std::unique_ptr<LineString>
+MinimumAreaRectangle::computeMaximumLine(
+ //-- find max and min pts for X and Y
+ CoordinateXY ptMinX; ptMinX.setNull();
+ CoordinateXY ptMaxX; ptMaxX.setNull();
+ CoordinateXY ptMinY; ptMinY.setNull();
+ CoordinateXY ptMaxY; ptMaxY.setNull();
+ for (const CoordinateXY& p : pts->items<CoordinateXY>()) {
+ if (ptMinX.isNull() || p.x < ptMinX.x) ptMinX = p;
+ if (ptMaxX.isNull() || p.x > ptMaxX.x) ptMaxX = p;
+ if (ptMinY.isNull() || p.y < ptMinY.y) ptMinY = p;
+ if (ptMaxY.isNull() || p.y > ptMaxY.y) ptMaxY = p;
+ CoordinateXY p0 = ptMinX;
+ CoordinateXY p1 = ptMaxX;
+ //-- line is vertical - use Y pts
+ if (p0.x == p1.x) {
+ p0 = ptMinY;
+ p1 = ptMaxY;
+ CoordinateSequence cs({ p0, p1 });
+ return factory->createLineString(std::move(cs));
+} // namespace geos.algorithm
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 879dedb79..813b161f9 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -3,6 +3,7 @@
* Copyright (C) 2005 Refractions Research Inc.
@@ -11,10 +12,6 @@
@@ -59,7 +56,7 @@ namespace algorithm { // geos.algorithm
* Compute a minimum diameter for a giver {@link Geometry}.
- * @param geom a Geometry
+ * @param newInputGeom a Geometry
MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
@@ -78,8 +75,8 @@ MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
- * @param geom a Geometry which is convex
- * @param isConvex <code>true</code> if the input geometry is convex
+ * @param newInputGeom a Geometry which is convex
+ * @param newIsConvex <code>true</code> if the input geometry is convex
MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom, const bool newIsConvex)
@@ -219,7 +216,7 @@ MinimumDiameter::computeConvexRingMinDiameter(const CoordinateSequence* pts)
unsigned int currMaxIndex = 1;
LineSegment seg;
- // compute the max distance for all segments in the ring, and pick the minimum
+ // for each segment, find a vertex at max distance, and pick the minimum
const std::size_t npts = pts->getSize();
for(std::size_t i = 1; i < npts; ++i) {
seg.p0 = pts->getAt(i - 1);
diff --git a/src/algorithm/Rectangle.cpp b/src/algorithm/Rectangle.cpp
index 000000000..7be35a475
--- /dev/null
+++ b/src/algorithm/Rectangle.cpp
@@ -0,0 +1,126 @@
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/LinearRing.h>
+using geos::geom::Coordinate;
+using geos::geom::LinearRing;
+namespace geos {
+Rectangle::createFromSidePts(
+ //-- deltas for the base segment provide slope
+ double dx = baseLeftPt.x - baseRightPt.x;
+ double dy = baseLeftPt.y - baseRightPt.y;
+ // Assert: dx and dy are not both zero
+ double baseC = computeLineEquationC(dx, dy, baseRightPt);
+ double oppC = computeLineEquationC(dx, dy, oppositePt);
+ double leftC = computeLineEquationC(-dy, dx, leftSidePt);
+ double rightC = computeLineEquationC(-dy, dx, rightSidePt);
+ //-- compute lines along edges of rectangle
+ LineSegment baseLine = createLineForStandardEquation(-dy, dx, baseC);
+ LineSegment oppLine = createLineForStandardEquation(-dy, dx, oppC);
+ LineSegment leftLine = createLineForStandardEquation(-dx, -dy, leftC);
+ LineSegment rightLine = createLineForStandardEquation(-dx, -dy, rightC);
+ * Corners of rectangle are the intersections of the
+ * base and opposite, and left and right lines.
+ * The rectangle is constructed with CW orientation.
+ * If a corner coincides with a input point
+ * the exact value is used to avoid numerical inaccuracy.
+ CoordinateXY p0 = rightSidePt.equals2D(baseRightPt) ? baseRightPt
+ : baseLine.lineIntersection(rightLine);
+ CoordinateXY p1 = leftSidePt.equals2D(baseLeftPt) ? baseLeftPt
+ : baseLine.lineIntersection(leftLine);
+ CoordinateXY p2 = leftSidePt.equals2D(oppositePt) ? oppositePt
+ : oppLine.lineIntersection(leftLine);
+ CoordinateXY p3 = rightSidePt.equals2D(oppositePt) ? oppositePt
+ : oppLine.lineIntersection(rightLine);
+ CoordinateSequence cs({ p0, p1, p2, p3, p0 });
+ return factory->createPolygon(std::move(cs));
+double
+Rectangle::computeLineEquationC(double a, double b, const CoordinateXY& p)
+ return a * p.y - b * p.x;
+LineSegment
+Rectangle::createLineForStandardEquation(double a, double b, double c)
+ Coordinate p0;
+ Coordinate p1;
+ * Line equation is ax + by = c
+ * Slope m = -a/b.
+ * Y-intercept = c/b
+ * X-intercept = c/a
+ * If slope is low, use constant X values; if high use Y values.
+ * This handles lines that are vertical (b = 0, m = Inf )
+ * and horizontal (a = 0, m = 0).
+ if (std::abs(b) > std::abs(a)) {
+ //-- abs(m) < 1
+ p0 = Coordinate(0.0, c/b);
+ p1 = Coordinate(1.0, c/b - a/b);
+ else {
+ //-- abs(m) >= 1
+ p0 = Coordinate(c/a, 0.0);
+ p1 = Coordinate(c/a - b/a, 1.0);
+ return LineSegment(p0, p1);
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 54b85c9ee..c352fc2cf 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -96,11 +96,26 @@ LineSegment::project(const Coordinate& p, Coordinate& ret) const
if(p == p0 || p == p1) {
ret = p;
+ return;
double r = projectionFactor(p);
ret = Coordinate(p0.x + r * (p1.x - p0.x), p0.y + r * (p1.y - p0.y));
+CoordinateXY
+LineSegment::project(const CoordinateXY& p) const
+ if(p == p0 || p == p1) {
+ return p;
+ double r = projectionFactor(p);
+ double x = p0.x + r * (p1.x - p0.x);
+ double y = p0.y + r * (p1.y - p0.y);
+ return CoordinateXY(x, y);
/*private*/
void
LineSegment::project(double factor, CoordinateXY& ret) const
@@ -304,6 +319,17 @@ LineSegment::offset(double offsetDistance)
return ls;
+/* public */
+double
+LineSegment::distancePerpendicularOriented(const CoordinateXY& p) const
+ double dist = distancePerpendicular(p);
+ if (orientationIndex(p) < 0)
+ return -dist;
+ return dist;
/* public */
diff --git a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
index 000000000..dad960837
--- /dev/null
+++ b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
@@ -0,0 +1,182 @@
+// Test Suite for geos::algorithm::MinimumAreaRectangle
+#include <tut/tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <utility.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using geos::algorithm::MinimumAreaRectangle;
+using geos::io::WKTReader;
+namespace tut {
+// Test Group
+// dummy data, not used
+struct test_minimumarearectangle_data {
+ const double TOL = 1e-10;
+ WKTReader reader_;
+ test_minimumarearectangle_data() {};
+ void
+ checkMinRectangle(const std::string& wkt, const std::string& wktExpected)
+ std::unique_ptr<Geometry> geom = reader_.read(wkt);
+ std::unique_ptr<Geometry> actual = MinimumAreaRectangle::getMinimumRectangle(geom.get());
+ std::unique_ptr<Geometry> expected = reader_.read(wktExpected);
+ ensure_equals_geometry(expected.get(), actual.get(), TOL);
+typedef test_group<test_minimumarearectangle_data> group;
+typedef group::object object;
+group test_minimumarearectangle_group("geos::algorithm::MinimumAreaRectangle");
+// Test Cases
+// testEmpty
+template<>
+template<>
+void object::test<1>()
+ "POLYGON EMPTY",
+ "POLYGON EMPTY");
+// testLineLengthZero
+template<>
+template<>
+void object::test<2>()
+ "LINESTRING (1 1, 1 1)",
+ "POINT (1 1)");
+// testLineHorizontal
+template<>
+template<>
+void object::test<3>()
+ "LINESTRING (1 1, 3 1, 5 1, 7 1)", "LINESTRING (1 1, 7 1)");
+// testLineVertical
+template<>
+template<>
+void object::test<4>()
+ "LINESTRING (1 1, 1 4, 1 7, 1 9)",
+ "LINESTRING (1 1, 1 9)");
+// testLineObtuseAngle
+template<>
+template<>
+void object::test<5>()
+ "LINESTRING (1 2, 3 8, 9 8)",
+ "POLYGON ((9 8, 1 2, -1.16 4.88, 6.84 10.88, 9 8))");
+// testLineAcuteAngle
+template<>
+template<>
+void object::test<6>()
+ "LINESTRING (5 2, 3 8, 9 8)",
+ "POLYGON ((5 2, 3 8, 8.4 9.8, 10.4 3.8, 5 2))");
+// testNotMinDiameter
+template<>
+template<>
+void object::test<7>()
+ "POLYGON ((150 300, 200 300, 300 300, 300 250, 280 120, 210 100, 100 100, 100 240, 150 300))",
+ "POLYGON ((100 100, 100 300, 300 300, 300 100, 100 100))");
+// testTriangle
+template<>
+template<>
+void object::test<8>()
+ "POLYGON ((100 100, 200 200, 160 240, 100 100))",
+ "POLYGON ((100 100, 160 240, 208.2758620689651 219.31034482758352, 148.2758620689666 79.31034482758756, 100 100))");
+// testConvex
+template<>
+template<>
+void object::test<9>()
+ checkMinRectangle("POLYGON ((3 8, 6 8, 9 5, 7 3, 3 1, 2 4, 3 8))",
+ "POLYGON ((0.2 6.6, 6.6 9.8, 9.4 4.2, 3 1, 0.2 6.6))");
+* Failure case from https://trac.osgeo.org/postgis/ticket/5163
+* @throws Exception
+// testFlatDiagonal
+template<>
+template<>
+void object::test<10>()
+ // bool error = false;
+ // try {
+ "LINESTRING(-99.48710639268086 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102 34.784713675318976)",
+ "POLYGON ((-99.48710639268066 34.790298392318675, -99.48710639268066 34.790298392318675, -99.48152167568082 34.78471367531866, -99.48152167568082 34.78471367531866, -99.48710639268066 34.790298392318675))");
+ // } catch (std::exception& e) {
+ // error = true;
+ // // errorMessage = e.what();
+ // ensure("caught exception", error == true);
+// testBadRectl
+template<>
+template<>
+void object::test<11>()
+ // try {
+ "POLYGON ((-5.21175 49.944633, -5.77435 50.021367, -5.7997 50.0306, -5.81815 50.0513, -5.82625 50.073567, -5.83085 50.1173, -6.2741 56.758767, -5.93245 57.909, -5.1158 58.644533, -5.07915 58.661733, -3.42575 58.686633, -3.1392 58.6685, -3.12495 58.666233, -1.88745 57.6444, 1.68845 52.715133, 1.7057 52.6829, 1.70915 52.6522, 1.7034 52.585433, 1.3867 51.214033, 1.36595 51.190267, 1.30485 51.121967, 0.96365 50.928567, 0.93025 50.912433, 0.1925 50.7436, -5.21175 49.944633))",
+ "POLYGON ((1.8583607388069103 50.41649058582797, -5.816631979932251 49.904263313964535, -6.395241388167441 58.57389735949991, 1.2797513305717105 59.08612463136336, 1.8583607388069103 50.41649058582797))");
+ // error = true;
+} // namespace tut
diff --git a/tests/unit/algorithm/RectangleTest.cpp b/tests/unit/algorithm/RectangleTest.cpp
index 000000000..c68810eb8
--- /dev/null
+++ b/tests/unit/algorithm/RectangleTest.cpp
@@ -0,0 +1,104 @@
+// Test Suite for geos::algorithm::Rectangle
+// geos
+// std
+#include <string>
+#include <memory>
+using geos::algorithm::Rectangle;
+namespace tut {
+// Test Group
+struct test_rectangle_data {
+ test_rectangle_data() {};
+ void
+ checkRectangle(const std::string& wkt, const std::string& wktExpected)
+ const LineString *line = static_cast<LineString*>(geom.get());
+ const Coordinate& baseRightPt = line->getCoordinateN(0);
+ const Coordinate& baseLeftPt = line->getCoordinateN(1);
+ const Coordinate& leftSidePt = line->getCoordinateN(2);
+ const Coordinate& oppositePt = line->getCoordinateN(3);
+ const Coordinate& rightSidePt = line->getCoordinateN(4);
+ std::unique_ptr<Polygon> actual = Rectangle::createFromSidePts(
+ baseRightPt, baseLeftPt,
+ oppositePt, leftSidePt,
+ rightSidePt, line->getFactory());
+ expected.get(),
+ static_cast<Geometry*>(actual.get()),
+ TOL);
+typedef test_group<test_rectangle_data> group;
+group test_rectangle_group("geos::algorithm::Rectangle");
+// Test Cases
+// testOrthogonal()
+template<>
+template<>
+ checkRectangle(
+ "LINESTRING (9 1, 1 1, 0 5, 7 10, 10 6)",
+ "POLYGON ((0 1, 0 10, 10 10, 10 1, 0 1))"
+// test45()
+template<>
+template<>
+ checkRectangle(
+ "LINESTRING (10 5, 5 0, 2 1, 2 7, 9 9)",
+ "POLYGON ((-1 4, 6.5 11.5, 11.5 6.5, 4 -1, -1 4))"
+// testCoincidentBaseSides()
+template<>
+template<>
+ checkRectangle(
+ "LINESTRING (10 5, 7 0, 7 0, 2 7, 10 5)",
+ "POLYGON ((0.2352941176470591 4.0588235294117645, 3.2352941176470598 9.058823529411764, 10 5, 7 0, 0.2352941176470591 4.0588235294117645))"
+} // namespace tut
diff --git a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
index 89a1283b5..e8251f466 100644
--- a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
@@ -28,10 +28,12 @@ struct test_minimumrotatedrectangle_data : public capitest::utility {
// input
geom1_ = GEOSGeomFromWKT(wkt);
ensure(nullptr != geom1_);
+ GEOSSetSRID(geom1_, 1234);
// result
geom2_ = GEOSMinimumRotatedRectangle(geom1_);
ensure(nullptr != geom2_);
+ ensure("SRID equal", GEOSGetSRID(geom2_) == GEOSGetSRID(geom1_));
// expected
if (expected) {
@@ -93,7 +95,9 @@ template<>
- checkMinRectangle("LINESTRING (1 2, 3 8, 9 6)", "POLYGON ((9 6, 7 10, -1 6, 1 2, 9 6))");
+ "LINESTRING (1 2, 3 8, 9 6)",
+ "POLYGON ((1 2, 3 8, 9 6, 7 0, 1 2))");
// Failure case from https://trac.osgeo.org/postgis/ticket/5163
@@ -104,8 +108,20 @@ void object::test<6>
checkMinRectangle(
- "LINESTRING (-99.48710639268086 34.79029839231914, -99.48152167568102 34.784713675318976)"
+ "POLYGON ((-99.48710639 34.79029839, -99.48710639 34.79029839, -99.48152168 34.78471368, -99.48152168 34.78471368, -99.48710639 34.79029839))"
+// Collection Input
+template<>
+template<>
+ "MULTILINESTRING ((1 2, 3 8, 9 6))",
} // namespace tut
diff --git a/tests/unit/geom/LineSegmentTest.cpp b/tests/unit/geom/LineSegmentTest.cpp
index c2212b324..31bb2dc7c 100644
--- a/tests/unit/geom/LineSegmentTest.cpp
+++ b/tests/unit/geom/LineSegmentTest.cpp
@@ -29,9 +29,11 @@ struct test_lineseg_data {
geos::geom::LineSegment v1;
double MAX_ABS_ERROR_INTERSECTION = 1e-5;
- void checkLineIntersection(double p1x, double p1y, double p2x, double p2y,
- double q1x, double q1y, double q2x, double q2y,
- double expectedx, double expectedy) {
+ void checkLineIntersection(
+ double p1x, double p1y, double p2x, double p2y,
+ double q1x, double q1y, double q2x, double q2y,
+ double expectedx, double expectedy)
LineSegment seg1(p1x, p1y, p2x, p2y);
LineSegment seg2(q1x, q1y, q2x, q2y);
@@ -93,6 +95,30 @@ struct test_lineseg_data {
ensure_equals(expectedOrient, orient);
+ void checkDistancePerpendicular(
+ double x0, double y0,
+ double x1, double y1,
+ double px, double py,
+ double expected)
+ LineSegment seg(x0, y0, x1, y1);
+ Coordinate c(px, py);
+ double dist = seg.distancePerpendicular(c);
+ ensure_equals("checkDistancePerpendicular", expected, dist, 0.000001);
+ void checkDistancePerpendicularOriented(
+ double expected)
+ double dist = seg.distancePerpendicularOriented(c);
+ ensure_equals("checkDistancePerpendicularOriented", expected, dist, 0.000001);
test_lineseg_data()
: ph1(0, 2), ph2(10, 2), pv1(0, 0), pv2(0, 10), h1(ph1, ph2), v1(pv1, pv2)
@@ -275,4 +301,36 @@ void object::test<11>()
checkOrientationIndex(seg, 105, 105, 110, 100, -1);
+// testDistancePerpendicular
+template<>
+template<>
+void object::test<12>()
+ checkDistancePerpendicular(1,1, 1,3, 2,4, 1);
+ checkDistancePerpendicular(1,1, 1,3, 0,4, 1);
+ checkDistancePerpendicular(1,1, 1,3, 1,4, 0);
+ checkDistancePerpendicular(1,1, 2,2, 4,4, 0);
+ //-- zero-length line segment
+ checkDistancePerpendicular(1,1, 1,1, 1,2, 1);
+// testDistancePerpendicularOriented
+template<>
+template<>
+void object::test<13>()
+ //-- right of line
+ checkDistancePerpendicularOriented(1,1, 1,3, 2,4, -1);
+ //-- left of line
+ checkDistancePerpendicularOriented(1,1, 1,3, 0,4, 1);
+ //-- on line
+ checkDistancePerpendicularOriented(1,1, 1,3, 1,4, 0);
+ checkDistancePerpendicularOriented(1,1, 2,2, 4,4, 0);
+ //-- zero-length segment
+ checkDistancePerpendicularOriented(1,1, 1,1, 1,2, 1);
} // namespace tut
Summary of changes:
NEWS.md | 1 +
capi/geos_ts_c.cpp | 6 +-
include/geos/algorithm/Distance.h | 32 ++-
include/geos/algorithm/MinimumAreaRectangle.h | 159 ++++++++++++
include/geos/algorithm/MinimumDiameter.h | 30 ++-
include/geos/algorithm/Rectangle.h | 96 ++++++++
include/geos/geom/LineSegment.h | 40 ++-
include/geos/operation/buffer/OffsetCurve.h | 18 +-
src/algorithm/Distance.cpp | 23 ++
src/algorithm/MinimumAreaRectangle.cpp | 269 +++++++++++++++++++++
src/algorithm/MinimumDiameter.cpp | 13 +-
src/algorithm/Rectangle.cpp | 126 ++++++++++
src/geom/LineSegment.cpp | 26 ++
tests/unit/algorithm/MinimumAreaRectangleTest.cpp | 182 ++++++++++++++
tests/unit/algorithm/RectangleTest.cpp | 104 ++++++++
.../unit/capi/GEOSMinimumRotatedRectangleTest.cpp | 20 +-
tests/unit/capi/GEOSOffsetCurveTest.cpp | 4 +-
tests/unit/geom/LineSegmentTest.cpp | 64 ++++-
tests/unit/operation/buffer/OffsetCurveTest.cpp | 29 ++-
web/content/specifications/geojson.md | 2 +-
20 files changed, 1197 insertions(+), 47 deletions(-)
create mode 100644 include/geos/algorithm/MinimumAreaRectangle.h
create mode 100644 include/geos/algorithm/Rectangle.h
create mode 100644 src/algorithm/MinimumAreaRectangle.cpp
create mode 100644 src/algorithm/Rectangle.cpp
create mode 100644 tests/unit/algorithm/MinimumAreaRectangleTest.cpp
create mode 100644 tests/unit/algorithm/RectangleTest.cpp
hooks/post-receive
More information about the geos-commits
