[geos-commits] [SCM] GEOS branch main updated. cad9c6fea9314d30d826c9953b0c5ed729688ee6
Tue May 30 14:43:41 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  cad9c6fea9314d30d826c9953b0c5ed729688ee6 (commit)
      from  68a5b4d4bfadee1c580fb6702597fe7cfbcc8118 (commit)
revisions in full, below.
commit cad9c6fea9314d30d826c9953b0c5ed729688ee6
Author: Mike Taves <mwtoews at gmail.com>
Date:   Wed May 31 09:32:28 2023 +1200
    GEOSClipByRect: Fix case with POINT EMPTY, add more tests (#913)
diff --git a/NEWS.md b/NEWS.md
index 08cda262c..7e3c57ba1 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -68,6 +68,7 @@ xxxx-xx-xx
   - OffsetCurve: fix EndCap parameter handling (GH-899, Martin Davis)
   - Reduce artifacts in single-sided Buffers: (GH-665 #810 and #712, Sandro Santilli)
   - GeoJSONReader: Fix 2D empty geometry creation (GH-909, Mike Taves)
+  - GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
 - Changes:
   - Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 108a97768..e9ddc3142 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -117,7 +117,7 @@ RectangleIntersection::clip_point(const geom::Point* g,
                                   RectangleIntersectionBuilder& parts,
                                   const Rectangle& rect)
-    if(g == nullptr) {
+    if(g == nullptr || g->isEmpty()) {
         return;
@@ -534,6 +534,10 @@ RectangleIntersection::clip_polygon(const geom::Polygon* g,
                                     const Rectangle& rect,
                                     bool keep_polygons)
+        return;
     if(keep_polygons) {
         clip_polygon_to_polygons(g, parts, rect);
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index b0f4ef43b..1e6f4fe4c 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -204,6 +204,31 @@ template<> template<> void object::test<15>
     isEqual(geom2_, "POLYGON ((2 2, 2 5, 5 5, 5 2, 2 2))");
+/// Empty combinations - always return GEOMETRYCOLLECTION EMPTY
+template<> template<> void object::test<16>
+    std::vector<const char*> variants{
+        "POINT EMPTY",
+        "LINESTRING EMPTY",
+        "POLYGON EMPTY",
+        "MULTIPOINT EMPTY",
+        "MULTILINESTRING EMPTY",
+        "MULTIPOLYGON EMPTY",
+        "GEOMETRYCOLLECTION EMPTY",
+        "LINEARRING EMPTY",
+    for (const auto& wkt : variants) {
+        GEOSGeom geom1 = GEOSGeomFromWKT(wkt);
+        GEOSGeom geom2 = GEOSClipByRect(geom1, 0, 0, 1, 1);
+        char* obt_wkt = GEOSWKTWriter_write(wktw_, geom2);
+        std::string obt_wkt2(obt_wkt);
+        GEOSFree(obt_wkt);
+        GEOSGeom_destroy(geom1);
+        GEOSGeom_destroy(geom2);
+        ensure_equals(obt_wkt2, "GEOMETRYCOLLECTION EMPTY");
 } // namespace tut
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 37080edd6..8e126fcb9 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -1679,4 +1679,27 @@ template<> template<> void object::test<208>
     doClipTest(inp, exp, r, 1e-10);
+template<> template<> void object::test<209>
+        "POINT EMPTY",
+        "POLYGON EMPTY",
+    for (const auto& inp : variants) {
+        doClipTest(
+            inp,
+            Rectangle(0, 0, 1, 1)
Summary of changes:
 NEWS.md                                            |  1 +
 .../intersection/RectangleIntersection.cpp         |  6 +++++-
 tests/unit/capi/GEOSClipByRectTest.cpp             | 25 ++++++++++++++++++++++
 .../intersection/RectangleIntersectionTest.cpp     | 23 ++++++++++++++++++++
 4 files changed, 54 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
