[geos-commits] [SCM] GEOS branch 3.9 updated. 8fd3b5f7127ab3e38fdc4621cf1aedcfbc165e57
Tue May 30 14:56:35 PDT 2023
the project "GEOS".
The branch, 3.9 has been updated
       via  8fd3b5f7127ab3e38fdc4621cf1aedcfbc165e57 (commit)
      from  18c5034abd31c801afd715ccd0bcce1e89a9eb2a (commit)
revisions in full, below.
commit 8fd3b5f7127ab3e38fdc4621cf1aedcfbc165e57
Author: Mike Taves <mwtoews at gmail.com>
Date:   Wed May 31 09:54:35 2023 +1200
    GEOSClipByRect: Fix case with POINT EMPTY, add more tests (#913)
diff --git a/NEWS b/NEWS
index 379697720..c1887fe5b 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Changes in 3.9.5
   - HausdorffDistance: Fix crash on collection containing empty point (GH-840, Dan Baston)
   - MaximumInscribedCircle: Fix infinite loop with non-finite coordinates (GH-843, Dan Baston)
   - DistanceOp: Fix crash on collection containing empty point (GH-842, Dan Baston)
+  - GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
 Changes in 3.9.4
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 6518debf3..e7569a1e1 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -117,7 +117,7 @@ RectangleIntersection::clip_point(const geom::Point* g,
                                   RectangleIntersectionBuilder& parts,
                                   const Rectangle& rect)
-    if(g == nullptr) {
+    if(g == nullptr || g->isEmpty()) {
         return;
@@ -535,6 +535,10 @@ RectangleIntersection::clip_polygon(const geom::Polygon* g,
                                     const Rectangle& rect,
                                     bool keep_polygons)
+        return;
     if(keep_polygons) {
         clip_polygon_to_polygons(g, parts, rect);
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index e5358436e..7341e3dd5 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -200,5 +200,32 @@ template<> template<> void object::test<13>
     isEqual(geom2_, "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))");
+/// Empty combinations - always return GEOMETRYCOLLECTION EMPTY
+template<> template<> void object::test<14>
+    std::vector<const char*> variants{
+        "POINT EMPTY",
+        "LINESTRING EMPTY",
+        "POLYGON EMPTY",
+        "MULTIPOINT EMPTY",
+        "MULTILINESTRING EMPTY",
+        "MULTIPOLYGON EMPTY",
+        "GEOMETRYCOLLECTION EMPTY",
+        "LINEARRING EMPTY",
+    for (const auto& wkt : variants) {
+        GEOSGeom geom1 = GEOSGeomFromWKT(wkt);
+        GEOSGeom geom2 = GEOSClipByRect(geom1, 0, 0, 1, 1);
+        char* obt_wkt = GEOSWKTWriter_write(w_, geom2);
+        std::string obt_wkt2(obt_wkt);
+        GEOSFree(obt_wkt);
+        GEOSGeom_destroy(geom1);
+        GEOSGeom_destroy(geom2);
+        ensure_equals(obt_wkt2, "GEOMETRYCOLLECTION EMPTY");
 } // namespace tut
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 1aef16e1c..0dfb3b356 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -1678,4 +1678,27 @@ template<> template<> void object::test<208>
     doClipTest(inp, exp, r, 1e-20);
+template<> template<> void object::test<209>
+        "POINT EMPTY",
+        "POLYGON EMPTY",
+    for (const auto& inp : variants) {
+        doClipTest(
+            inp,
+            Rectangle(0, 0, 1, 1)
Summary of changes:
 NEWS                                               |  1 +
 .../intersection/RectangleIntersection.cpp         |  6 ++++-
 tests/unit/capi/GEOSClipByRectTest.cpp             | 27 ++++++++++++++++++++++
 .../intersection/RectangleIntersectionTest.cpp     | 23 ++++++++++++++++++
 4 files changed, 56 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
