[geos-commits] [SCM] GEOS branch 3.8 updated. a4631692706716576734d7779dfb7173ac197c9c
git at osgeo.org
git at osgeo.org
Tue May 30 15:33:29 PDT 2023
the project "GEOS".
The branch, 3.8 has been updated
via a4631692706716576734d7779dfb7173ac197c9c (commit)
from 09cca89f8617c3a3dbf5f330a7d15299a15be7bf (commit)
revisions in full, below.
commit a4631692706716576734d7779dfb7173ac197c9c
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed May 31 09:54:35 2023 +1200
GEOSClipByRect: Fix case with POINT EMPTY, add more tests (#913)
diff --git a/NEWS b/NEWS
index 93e08fa03..b2dfcc6d6 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.8.4
- Bug fixes / improvements
- Fix PreparedGeometry to avoid crashes with EMPTY elements in input (GH-678, Martin Davis)
+ - GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
Changes in 3.8.3
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 23febb66c..472663614 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -117,7 +117,7 @@ RectangleIntersection::clip_point(const geom::Point* g,
RectangleIntersectionBuilder& parts,
const Rectangle& rect)
- if(g == nullptr) {
+ if(g == nullptr || g->isEmpty()) {
return;
@@ -535,6 +535,10 @@ RectangleIntersection::clip_polygon(const geom::Polygon* g,
const Rectangle& rect,
bool keep_polygons)
+ return;
if(keep_polygons) {
clip_polygon_to_polygons(g, parts, rect);
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index e5358436e..7341e3dd5 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -200,5 +200,32 @@ template<> template<> void object::test<13>
isEqual(geom2_, "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))");
+/// Empty combinations - always return GEOMETRYCOLLECTION EMPTY
+template<> template<> void object::test<14>
+ std::vector<const char*> variants{
+ "POINT EMPTY",
+ "LINESTRING EMPTY",
+ "POLYGON EMPTY",
+ "MULTIPOINT EMPTY",
+ "MULTILINESTRING EMPTY",
+ "MULTIPOLYGON EMPTY",
+ "GEOMETRYCOLLECTION EMPTY",
+ "LINEARRING EMPTY",
+ for (const auto& wkt : variants) {
+ GEOSGeom geom1 = GEOSGeomFromWKT(wkt);
+ GEOSGeom geom2 = GEOSClipByRect(geom1, 0, 0, 1, 1);
+ char* obt_wkt = GEOSWKTWriter_write(w_, geom2);
+ std::string obt_wkt2(obt_wkt);
+ GEOSFree(obt_wkt);
+ GEOSGeom_destroy(geom1);
+ GEOSGeom_destroy(geom2);
+ ensure_equals(obt_wkt2, "GEOMETRYCOLLECTION EMPTY");
} // namespace tut
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 1aef16e1c..0dfb3b356 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -1678,4 +1678,27 @@ template<> template<> void object::test<208>
doClipTest(inp, exp, r, 1e-20);
+template<> template<> void object::test<209>
+ "POINT EMPTY",
+ "POLYGON EMPTY",
+ for (const auto& inp : variants) {
+ doClipTest(
+ inp,
+ Rectangle(0, 0, 1, 1)
Summary of changes:
NEWS | 1 +
.../intersection/RectangleIntersection.cpp | 6 ++++-
tests/unit/capi/GEOSClipByRectTest.cpp | 27 ++++++++++++++++++++++
.../intersection/RectangleIntersectionTest.cpp | 23 ++++++++++++++++++
4 files changed, 56 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
