[geos-commits] [SCM] GEOS branch 3.7 updated. 1d587ff39d7653d08f0c3327474de9085463d1b5
git at osgeo.org
git at osgeo.org
Wed May 31 06:30:37 PDT 2023
the project "GEOS".
The branch, 3.7 has been updated
via 1d587ff39d7653d08f0c3327474de9085463d1b5 (commit)
from 0935e18ea216cc641213314c5dab93f7a340fbf2 (commit)
revisions in full, below.
commit 1d587ff39d7653d08f0c3327474de9085463d1b5
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed May 31 10:50:50 2023 +1200
GEOSClipByRect: Fix case with POINT EMPTY, add more tests (#913)
diff --git a/NEWS b/NEWS
index a85a9db9d..ad4be5f13 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,9 @@
+Changes in 3.7.6
+20xx-xx-xx
+- Bug fixes / improvements
+ - GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
Changes in 3.7.5
2022-06-08
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 04f5615bc..e91561881 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -109,7 +109,7 @@ RectangleIntersection::clip_point(const geom::Point * g,
RectangleIntersectionBuilder & parts,
const Rectangle & rect)
- if(g == nullptr)
+ if(g == nullptr || g->isEmpty())
return;
double x = g->getX();
@@ -552,6 +552,9 @@ RectangleIntersection::clip_polygon(const geom::Polygon * g,
const Rectangle & rect,
bool keep_polygons)
+ return;
if(keep_polygons)
clip_polygon_to_polygons(g, parts, rect);
else
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index b0eb02fac..cc6fc5b03 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -187,5 +187,31 @@ namespace tut
isEqual(geom2_, "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))");
+ // Empty combinations - always return GEOMETRYCOLLECTION EMPTY
+ template<> template<> void object::test<14>
+ std::vector<const char*> variants{
+ "POINT EMPTY",
+ "LINESTRING EMPTY",
+ "POLYGON EMPTY",
+ "MULTIPOINT EMPTY",
+ "MULTILINESTRING EMPTY",
+ "MULTIPOLYGON EMPTY",
+ "GEOMETRYCOLLECTION EMPTY",
+ "LINEARRING EMPTY",
+ for (const auto& wkt : variants) {
+ GEOSGeom geom1 = GEOSGeomFromWKT(wkt);
+ GEOSGeom geom2 = GEOSClipByRect(geom1, 0, 0, 1, 1);
+ char* obt_wkt = GEOSWKTWriter_write(w_, geom2);
+ std::string obt_wkt2(obt_wkt);
+ GEOSFree(obt_wkt);
+ GEOSGeom_destroy(geom1);
+ GEOSGeom_destroy(geom2);
+ ensure_equals(obt_wkt2, "GEOMETRYCOLLECTION EMPTY");
} // namespace tut
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 89c60ed89..dbfc5d7f6 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -1528,4 +1528,27 @@ namespace tut
doClipTest(inp, exp, r, 1e-20);
+ template<> template<> void object::test<209>()
+ "POINT EMPTY",
+ "POLYGON EMPTY",
+ for (const auto& inp : variants) {
+ doClipTest(
+ inp,
+ Rectangle(0, 0, 1, 1)
Summary of changes:
NEWS | 6 +++++
.../intersection/RectangleIntersection.cpp | 5 ++++-
tests/unit/capi/GEOSClipByRectTest.cpp | 26 ++++++++++++++++++++++
.../intersection/RectangleIntersectionTest.cpp | 23 +++++++++++++++++++
4 files changed, 59 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
