[geos-commits] [SCM] GEOS branch main updated. 335cf85d0a66540bcf4474a00f9f39c1084976b3
Wed May 31 06:30:46 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  335cf85d0a66540bcf4474a00f9f39c1084976b3 (commit)
       via  68c588bf96e07f17ddf1495c67f9e2c06f9ddd83 (commit)
      from  cad9c6fea9314d30d826c9953b0c5ed729688ee6 (commit)
revisions in full, below.
commit 335cf85d0a66540bcf4474a00f9f39c1084976b3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed May 31 09:29:48 2023 -0400
    Add unit test for QGIS reported offset curve weirdness from @strk
    See https://github.com/qgis/QGIS/issues/53165
diff --git a/tests/unit/operation/buffer/OffsetCurveTest.cpp b/tests/unit/operation/buffer/OffsetCurveTest.cpp
index 5faea0fe4..76b01c4df 100644
--- a/tests/unit/operation/buffer/OffsetCurveTest.cpp
+++ b/tests/unit/operation/buffer/OffsetCurveTest.cpp
@@ -553,25 +553,33 @@ void object::test<40> ()
 // testMinQuadrantSegments
 // See https://github.com/qgis/QGIS/issues/53165
 template<>
 template<>
-void object::test<41> ()
+void object::test<42> ()
     checkOffsetCurve(
         "LINESTRING (553772.0645892698 177770.05079236583, 553780.9235869241 177768.99614978794, 553781.8325485934 177768.41771963477)",
         -11, 0, BufferParameters::JOIN_MITRE, -1,
         "LINESTRING (553770.76 177759.13, 553777.54 177758.32)"
+    checkOffsetCurve(
+        "LINESTRING (417.9785426266025752 432.5653800140134990, 447.6161954912822694 436.0936720217578113, 450.6571140550076962 438.0288020166335627)",
+        133.819, // distance
+        0, // number of segments
+        BufferParameters::JOIN_MITRE,
+        2,  // mitre limit
+        "LINESTRING (402.15941192825255 565.4460778784833, 418.95730224139794 567.4458267253115)"
 // testMinQuadrantSegments_QGIS
 // See https://github.com/qgis/QGIS/issues/53165#issuecomment-1563214857
 template<>
 template<>
-void object::test<42> ()
+void object::test<43> ()
     checkOffsetCurve(
         "LINESTRING (421 622, 446 625, 449 627)",
@@ -582,4 +590,4 @@ void object::test<42> ()
-} // namespace tut
+} // namespace tut2
commit 68c588bf96e07f17ddf1495c67f9e2c06f9ddd83
Author: Andrew Hershberger <andrew.d.hershberger at gmail.com>
Date:   Wed May 31 09:20:22 2023 -0400
    Clarify thread safety requirements for C API (#907)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 7818d98bd..76e508e5a 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -87,19 +87,18 @@ extern "C" {
-* Type returned by GEOS_init_r(), for use in multi-threaded
-* applications.
+* Type returned by GEOS_init_r(), for use with the functions ending in `_r`
+* (the reentrant API).
-* There should be only one GEOSContextHandle_t per thread.
+* Contexts must only be used from a single thread at a time.
 typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
 * Callback function for passing GEOS error messages to parent process.
-* Set the \ref GEOSMessageHandler function for error and notice messages in \ref initGEOS
-* for single-threaded programs, or using \ref initGEOS_r for threaded
-* programs
+* Set the \ref GEOSMessageHandler function for error and notice messages using
+* \ref initGEOS or \ref initGEOS_r.
 * \param fmt the message format template
@@ -331,9 +330,10 @@ extern void GEOS_DLL GEOS_interruptCancel(void);
 /* ========== Initialization and Cleanup ========== */
-* Initialize a context for this thread. Pass this context into
-* your other calls of `*_r` functions.
-* \return a GEOS context for this thread
+* Allocate and initialize a context. Pass this context as the first argument
+* when calling other `*_r` functions. Contexts must only be used from a single
+* thread at a time.
+* \return a new GEOS context.
 * \since 3.5
Summary of changes:
 capi/geos_c.h.in                                | 18 +++++++++---------
 tests/unit/operation/buffer/OffsetCurveTest.cpp | 16 ++++++++++++----
 2 files changed, 21 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
