[geos-commits] [SCM] GEOS branch 3.12 updated. 672e97193d0fc83b8b2fedc070a7e09e097cb138
git at osgeo.org
git at osgeo.org
Thu Nov 9 00:25:52 PST 2023
the project "GEOS".
The branch, 3.12 has been updated
via 672e97193d0fc83b8b2fedc070a7e09e097cb138 (commit)
via 00ecc98ffc5dd3634932c86022d7853770f33377 (commit)
via 53a7f856f54711cd6e7abbff6a5189fc3034ea30 (commit)
via 58f7cc7f191c4c8044d24c7a6aa3b60c1a897c87 (commit)
via c406cea14a54240a44bcf8289e526b3276868bca (commit)
via 1e1a194b3807ab41bf553f61abbcdf81fbbbcd94 (commit)
via 589e9f6c435eb611030bf835c9f65aff5269eda1 (commit)
via 5bb4613a9c8c06f62dd46e3bd344db31d8f95f1c (commit)
from 35c10bfbc79a1af42dc427072a4a3f663288db33 (commit)
revisions in full, below.
commit 672e97193d0fc83b8b2fedc070a7e09e097cb138
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Nov 7 11:06:24 2023 -0800
Clean up simplifier unit test code
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index e2b4ab415..d8d631cd9 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -35,6 +35,24 @@ struct test_dpsimp_data {
wktreader()
+ void
+ checkDP(const std::string& wkt, double tolerance, const std::string& wkt_expected)
+ GeomPtr g(wktreader.read(wkt));
+ GeomPtr simplified = DouglasPeuckerSimplifier::simplify(g.get(), tolerance);
+ ensure("Simplified geometry is invalid!", simplified->isValid());
+ GeomPtr exp(wktreader.read(wkt_expected));
+ ensure_equals_geometry(exp.get(), simplified.get());
+ void
+ checkDPNoChange(const std::string& wkt, double tolerance)
+ checkDP(wkt, tolerance, wkt);
typedef test_group<test_dpsimp_data> group;
@@ -46,262 +64,118 @@ group test_dpsimp_group("geos::simplify::DouglasPeuckerSimplifier");
// Test Cases
-// 1 - PolygonNoReduction
+// 1 - testPolygonWithFlatVertices
template<>
template<>
-void object::test<1>
+void object::test<1>()
- std::string wkt("POLYGON((20 220, 40 220, 60 220, 80 220, 100 220, \
- 120 220, 140 220, 140 180, 100 180, 60 180, 20 180, 20 220))");
- GeomPtr g(wktreader.read(wkt));
- GeomPtr simplified = DouglasPeuckerSimplifier::simplify(
- g.get(), 10.0);
- ensure(simplified->isValid());
- // topology is unchanged
- ensure(simplified->equals(g.get()));
+ checkDP("POLYGON ((20 220, 40 220, 60 220, 80 220, 100 220, 120 220, 140 220, 140 180, 100 180, 60 180, 20 180, 20 220))",
+ 10.0,
+ "POLYGON ((20 220, 140 220, 140 180, 20 180, 20 220))");
// 2 - PolygonReductionWithSplit
template<>
template<>
-void object::test<2>
+void object::test<2>()
- std::string wkt_in("POLYGON ((40 240, 160 241, 280 240, 280 160, \
- 160 240, 40 140, 40 240))");
- std::string wkt_ex("MULTIPOLYGON (((40.0 240.0, 160.0 240.0, 40.0 140.0, 40.0 240.0)), \
- ((160.0 240.0, 280.0 240.0, 280.0 160.0, 160.0 240.0)))");
- GeomPtr g(wktreader.read(wkt_in));
- GeomPtr expected(wktreader.read(wkt_ex));
- // TODO: This test blows because if instability of geos.index.strtree::yComparator() predicate
- g.get(), 10.0);
- ensure(simplified->equalsExact(expected.get()));
+ checkDP("POLYGON ((40 240, 160 241, 280 240, 280 160, 160 240, 40 140, 40 240))",
+ 1,
+ "MULTIPOLYGON (((40 240, 160 240, 40 140, 40 240)), ((160 240, 280 240, 280 160, 160 240)))");
// 3 - PolygonReduction
template<>
template<>
-void object::test<3>
+void object::test<3>()
- std::string wkt_in("POLYGON ((120 120, 121 121, 122 122, 220 120, \
- 180 199, 160 200, 140 199, 120 120))");
- std::string wkt_ex("POLYGON ((120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
- g.get(), 10.0);
+ checkDP("POLYGON ((120 120, 121 121, 122 122, 220 120, 180 199, 160 200, 140 199, 120 120))",
+ 10,
+ "POLYGON ((120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
// 4 - PolygonWithTouchingHole
template<>
template<>
-void object::test<4>
+void object::test<4>()
- std::string wkt_in("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
- (120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
- std::string wkt_ex("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
- g.get(), 10.0);
+ checkDP("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), (120 120, 220 120, 180 199, 160 200, 140 199, 120 120))",
+ 10,
+ "POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), (120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
// 5 - FlattishPolygon
template<>
template<>
-void object::test<5>
+void object::test<5>()
- std::string wkt_in("POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, 70 1, 60 1, 50 1, 40 1, 0 0))");
- std::string wkt_ex("POLYGON EMPTY");
- g.get(), 10.0);
- //ensure_equals( *simplified, *expected );
+ checkDP("POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, 70 1, 60 1, 50 1, 40 1, 0 0))",
+ 10,
+ "POLYGON EMPTY");
// 6 - TinySquare
template<>
template<>
-void object::test<6>
+void object::test<6>()
- std::string wkt_in("POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))");
- g.get(), 10.0);
+ checkDP("POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))",
+ 10,
+ "POLYGON EMPTY");
// TinyHole
template<>
template<>
-void object::test<7>
+void object::test<7>()
- std::string wkt_in("POLYGON ((10 10, 10 310, 370 310, 370 10, 10 10), (160 190, 180 190, 180 170, 160 190))");
- std::string wkt_ex("POLYGON ((10 10, 10 310, 370 310, 370 10, 10 10))");
- g.get(), 30.0);
+ checkDP("POLYGON ((10 10, 10 310, 370 310, 370 10, 10 10), (160 190, 180 190, 180 170, 160 190))",
+ 30,
+ "POLYGON ((10 10, 10 310, 370 310, 370 10, 10 10))");
// 7 - TinyLineString
template<>
template<>
-void object::test<8>
+void object::test<8>()
- std::string wkt_in("LINESTRING (0 5, 1 5, 2 5, 5 5)");
- std::string wkt_ex("LINESTRING (0 5, 5 5)");
- g.get(), 10.0);
+ checkDP("LINESTRING (0 5, 1 5, 2 5, 5 5)",
+ 10,
+ "LINESTRING (0 5, 5 5)");
// 8 - MultiPoint
template<>
template<>
-void object::test<9>
+void object::test<9>()
- std::string wkt_in("MULTIPOINT((80 200), (240 200), (240 60), (80 60), (80 200), (140 199), (120 120))");
- g.get(), 10.0);
- // MultiPoint is *not* simplified
- ensure(simplified->equalsExact(g.get()));
+ checkDPNoChange("MULTIPOINT(80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120)",
+ 10);
// 9 - MultiLineString
template<>
template<>
-void object::test<10>
+void object::test<10>()
- std::string wkt_in("MULTILINESTRING( (0 0, 50 0, 70 0, 80 0, 100 0), \
- (0 0, 50 1, 60 1, 100 0) )");
- std::string wkt_ex("MULTILINESTRING( (0 0, 100 0), (0 0, 100 0) )");
- g.get(), 10.0);
+ checkDP("MULTILINESTRING((0 0, 50 0, 70 0, 80 0, 100 0), (0 0, 50 1, 60 1, 100 0) )",
+ 10,
+ "MULTILINESTRING ((0 0, 100 0), (0 0, 100 0))");
// 10 - GeometryCollection
template<>
template<>
-void object::test<11>
+void object::test<11>()
- std::string wkt_in("GEOMETRYCOLLECTION ( \
- MULTIPOINT ((80 200), (240 200), (240 60), (80 60), (80 200), (140 199), (120 120)), \
- POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200)), \
- LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120) )");
- g.get(), 10.0);
- // Non simplification occurs
+ checkDPNoChange("GEOMETRYCOLLECTION (MULTIPOINT (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120), POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200)), LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120))",
+ 10.0);
// 11 - A kind of reversed simplification
template<>
template<>
-void object::test<12>
+void object::test<12>()
using namespace geos::geom;
@@ -373,23 +247,13 @@ void object::test<12>
// 13 - Polygon with inner ring whose extent is less than the simplify distance (#741)
template<>
template<>
-void object::test<13>
+void object::test<13>()
- std::string wkt_in("POLYGON ((0 0,0 1,1 1,0 0),(0.1 0.1,0.2 0.1,0.2 0.2,0.1 0.1))");
- std::string wkt_ex("POLYGON ((0 0,0 1,1 1,0 0))");
- g.get(), 0.5);
+ checkDP(
+ "POLYGON ((0 0,0 1,1 1,0 0),(0.1 0.1,0.2 0.1,0.2 0.2,0.1 0.1))",
+ 0.5,
+ "POLYGON ((0 0,0 1,1 1,0 0))"
@@ -400,16 +264,13 @@ void object::test<13>
template<>
template<>
-void object::test<14>
+void object::test<14>()
- std::string wkt_in("POLYGON ((21.32686 47.78723, 21.32386 47.79023, 21.32186 47.80223, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.33886 47.81123, 21.32686 47.82023, 21.32586 47.82723, 21.32786 47.82323, 21.33886 47.82623, 21.34186 47.82123, 21.36386 47.82223, 21.40686 47.81723, 21.32686 47.78723))");
- std::string wkt_ex("POLYGON ((21.32686 47.78723, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.328068201892744 47.823286782334385, 21.33886 47.82623, 21.34186 47.82123, 21.40686 47.81723, 21.32686 47.78723))");
- GeomPtr simplified = DouglasPeuckerSimplifier::simplify(g.get(), 0.0036);
- ensure_equals_geometry(simplified.get(), expected.get());
+ checkDP(
+ "POLYGON ((21.32686 47.78723, 21.32386 47.79023, 21.32186 47.80223, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.33886 47.81123, 21.32686 47.82023, 21.32586 47.82723, 21.32786 47.82323, 21.33886 47.82623, 21.34186 47.82123, 21.36386 47.82223, 21.40686 47.81723, 21.32686 47.78723))",
+ 0.0036,
+ "POLYGON ((21.32686 47.78723, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.328068201892744 47.823286782334385, 21.33886 47.82623, 21.34186 47.82123, 21.40686 47.81723, 21.32686 47.78723))"
@@ -420,40 +281,57 @@ void object::test<14>
template<>
template<>
-void object::test<15>
+void object::test<15>()
- std::string wkt_in("MULTIPOLYGON (((-76.02716827 36.55671692, -75.99866486 36.55665207, -75.91191864 36.54253006, -75.92480469 36.47397614, -75.97727966 36.4780159, -75.97628784 36.51792526, -76.02716827 36.55671692)), ((-75.90198517 36.55619812, -75.8781662 36.55587387, -75.77315521 36.22925568, -75.78317261 36.22519302, -75.90198517 36.55619812)))");
- std::string wkt_ex("POLYGON ((-76.02716827 36.55671692, -75.91191864 36.54253006, -75.92480469 36.47397614, -76.02716827 36.55671692))");
- GeomPtr simplified = DouglasPeuckerSimplifier::simplify(g.get(), 0.05);
+ checkDP(
+ "MULTIPOLYGON (((-76.02716827 36.55671692, -75.99866486 36.55665207, -75.91191864 36.54253006, -75.92480469 36.47397614, -75.97727966 36.4780159, -75.97628784 36.51792526, -76.02716827 36.55671692)), ((-75.90198517 36.55619812, -75.8781662 36.55587387, -75.77315521 36.22925568, -75.78317261 36.22519302, -75.90198517 36.55619812)))",
+ 0.05,
+ "POLYGON ((-76.02716827 36.55671692, -75.91191864 36.54253006, -75.92480469 36.47397614, -76.02716827 36.55671692))"
// Test that start point of a polygon can be removed
template<>
template<>
-void object::test<16>
+void object::test<16>()
- auto g = wktreader.read("POLYGON ((1 0, 2 0, 2 2, 0 2, 0 0, 1 0))");
- auto simplified = DouglasPeuckerSimplifier::simplify(g.get(), 0);
- auto expected = wktreader.read("POLYGON (( 0 0, 2 0, 2 2, 0 2, 0 0))");
+ checkDP("POLYGON ((1 0, 2 0, 2 2, 0 2, 0 0, 1 0))",
+ 0,
+ "POLYGON (( 0 0, 2 0, 2 2, 0 2, 0 0))");
// Test that start point of a closed LineString is not changed
template<>
template<>
-void object::test<17>
+void object::test<17>()
- auto g = wktreader.read("LINESTRING (1 0, 2 0, 2 2, 0 2, 0 0, 1 0)");
- ensure_equals_geometry(simplified.get(), g.get());
+ checkDPNoChange("LINESTRING (1 0, 2 0, 2 2, 0 2, 0 0, 1 0)",
+ 0);
+// testPolygonRemoveFlatEndpoint
+// see https://trac.osgeo.org/geos/ticket/1064
+template<>
+template<>
+void object::test<18>()
+ checkDP(
+ "POLYGON ((42 42, 0 42, 0 100, 42 100, 100 42, 42 42))",
+ 1,
+ "POLYGON ((100 42, 0 42, 0 100, 42 100, 100 42))"
+// testPolygonEndpointCollapse
+template<>
+template<>
+void object::test<19>()
+ checkDP(
+ "POLYGON ((5 2, 9 1, 1 1, 5 2))",
+ 1,
+ "POLYGON EMPTY"
} // namespace tut
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index c21b2ce42..73190e7a9 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
@@ -46,6 +46,12 @@ struct test_tpsimp_data {
+ void
+ checkTPSNoChange(const std::string& wkt, double tolerance)
+ checkTPS(wkt, tolerance, wkt);
typedef test_group<test_tpsimp_data> group;
@@ -63,28 +69,15 @@ template<>
- std::string wkt("POLYGON EMPTY");
- GeomPtr simplified = TopologyPreservingSimplifier::simplify(g.get(), 10.0);
- ensure("Simplified geometry is invalid!", simplified->isValid());
- ensure_equals_geometry(g.get(), simplified.get());
+ checkTPSNoChange("POLYGON(EMPTY)", 1);
// Point
template<>
template<>
+void object::test<2> ()
- std::string wkt("POINT (10 10)");
+ checkTPSNoChange("POINT (10 10)", 1);
#if 0 // Fails with JTS too !
@@ -95,308 +88,166 @@ template<>
- std::string wkt(
- "MULTIPOLYGON(((13.73095 51.024734,13.7309323 51.0247668,13.7306959 51.0247959,13.7292724 51.0249742,13.7280216 51.0251252,13.7266598 51.0252998,13.7259617 51.0254072,13.7258854 51.0254201,13.7253253 51.0255144,13.725276 51.025492,13.724538 51.025631,13.7230288 51.0259021,13.7223529 51.0260273,13.7223299 51.0260863,13.7222292 51.026391,13.7220002 51.0273366,13.7217875 51.0282094,13.721746 51.028243,13.7217693 51.0282803,13.7215512 51.0291967,13.721513 51.029222,13.7215203 51.0292567,13.7212713 51.0295967,13.7222258 51.0299532,13.722234 51.03,13.7222931 51.0299823,13.7232514 51.0303187,13.7242514 51.0306715,13.724263 51.030714,13.7243024 51.0306951,13.7249934 51.0309315,13.7265097 51.0314552,13.7266116 51.0313952,13.7267988 51.0313334,13.7269952 51.0313243,13.72703 51.0314107,13.7271637 51.0313254,13.7272524 51.0313839,13.72739 51.031449,13.7276768 51.0313074,13.7283793 51.0309944,13.7296654 51.0304157,13.7297572 51.0303637,13.729845 51.0303139,13.7299557 51.0301763,13.730096
4 51.0300176,13.730252 51.0298919,13.7304615 51.0297932,13.730668 51.0297363,13.730743 51.029783,13.7307859 51.0298398,13.7307094 51.0301388,13.730624 51.030263,13.7306955 51.0303267,13.7301182 51.0325594,13.7300528 51.0325663,13.7301114 51.0327342,13.7301645 51.0329094,13.7300035 51.0327693,13.7299669 51.0327351,13.7299445 51.0327211,13.7298934 51.032814,13.7298539 51.0328585,13.7297737 51.0328321,13.7288526 51.0325639,13.7288201 51.0324367,13.7284426 51.0324383,13.7276461 51.032179,13.7274569 51.0321976,13.7272787 51.0322421,13.7271265 51.0322903,13.7267034 51.0322495,13.7265364 51.0322161,13.7259018 51.0324269,13.7258649 51.03242,13.725733 51.0326646,13.7251933 51.0328876,13.7247918 51.0331374,13.7244439 51.0331106,13.7242967 51.0334273,13.7239131 51.0337529,13.7237035 51.0338511,13.7235429 51.033967,13.7233375 51.0339148,13.7232064 51.0339347,13.7231786 51.0339863,13.7228848 51.0340776,13.7224481 51.0341888,13.7220471 51.0342483,13.7217493 51.0343198,13.721552 51.0343861,13.7214
718 51.0344095,13.7215108 51.034534,13.7205032 51.0349932,13.7197657 51.0352983,13.7195764 51.0352291,13.7195934 51.0352797,13.7182451 51.0359157,13.7181108 51.0359003,13.7181657 51.0359571,13.717622 51.0361956,13.7159749 51.0369683,13.7159057 51.0369284,13.7158604 51.0370288,13.7157161 51.0370124,13.7157523 51.0370733,13.7153708 51.0372801,13.7150274 51.0374899,13.7144074 51.0379192,13.7138287 51.0383899,13.7137514 51.0383857,13.7137492 51.0384566,13.7134249 51.0387269,13.7130179 51.0390385,13.7125791 51.0393343,13.7120736 51.039611,13.7115839 51.0398558,13.7112945 51.0399894,13.7114637 51.0402313,13.7123153 51.041449,13.7126333 51.0417033,13.713371 51.0421453,13.7138861 51.0424061,13.7142518 51.0425683,13.7164587 51.0435668,13.7167995 51.0437957,13.7170883 51.0439897,13.7190694 51.0451663,13.7196131 51.0458277,13.7197562 51.0461521,13.7198262 51.0464192,13.7198377 51.0467389,13.7205681 51.0455573,13.7210009 51.0450379,13.7214987 51.0445401,13.7220306 51.0442859,13.7227215 51.04395
58,13.7237962 51.0434514,13.723979 51.0435278,13.7241448 51.0435041,13.7241052 51.0436042,13.7247987 51.0438896,13.7250186 51.0439093,13.7250579 51.0440386,13.7257225 51.0443545,13.7259312 51.0443456,13.725955 51.0443813,13.7260235 51.0443873,13.7260682 51.0445303,13.7282191 51.0455848,13.7290532 51.045927,13.7292643 51.0458591,13.7292228 51.0459969,13.729706 51.0461854,13.7303185 51.046393,13.7309107 51.0465601,13.731546 51.0466841,13.7321939 51.0467752,13.7332896 51.0468999,13.7333733 51.0469094,13.7334778 51.0468127,13.7335706 51.0469078,13.733651 51.0470684,13.7338458 51.0471508,13.7346109 51.0472333,13.7346367 51.0471474,13.7346922 51.0470697,13.7346666 51.0470056,13.7346564 51.0468714,13.7345552 51.0467095,13.7336001 51.0465496,13.733427 51.046454,13.7335317 51.0464255,13.7347225 51.0465948,13.7348421 51.0466562,13.7349123 51.0466203,13.736811 51.0468537,13.7382043 51.0469796,13.7383487 51.0469803,13.7394909 51.0469005,13.7400899 51.0467949,13.7405051 51.0464739,13.7408331 51.
0462204,13.7412027 51.0463256,13.741053 51.0466451,13.7407291 51.0469007,13.7405095 51.0469726,13.7400888 51.0470337,13.7393051 51.0471049,13.7393014 51.0472015,13.7393088 51.0473019,13.7395556 51.0473056,13.7404944 51.0472245,13.740932 51.0470192,13.7414421 51.0465652,13.7414893 51.0465576,13.7416494 51.0464916,13.7416003 51.0466074,13.7416246 51.04663,13.741668 51.0466443,13.7417272 51.0467159,13.7417503 51.0466716,13.7423587 51.0468732,13.7426958 51.0470246,13.7429143 51.0471813,13.74318 51.04726,13.7430363 51.0472995,13.7433021 51.047588,13.7434678 51.0475916,13.7433805 51.0477019,13.7436362 51.0479981,13.7446308 51.0491622,13.7447961 51.0491827,13.744722 51.0492509,13.7448536 51.0494078,13.745056 51.0494766,13.7450313 51.0496901,13.7453573 51.0500052,13.7465317 51.0512807,13.7466999 51.0513722,13.746638 51.0514149,13.7468683 51.0516781,13.7470071 51.051777,13.7469985 51.0518746,13.7470732 51.0519866,13.7471316 51.0520528,13.7472989 51.0523089,13.7472368 51.0523858,13.7473063 51
.0524932,13.7473468 51.0527412,13.7473392 51.0531614,13.7472987 51.0533157,13.7473919 51.0534224,13.7472684 51.0534549,13.7472134 51.0536926,13.7472913 51.0537784,13.7473216 51.053725,13.7474649 51.0537575,13.7474492 51.053833,13.7475625 51.0537839,13.7497379 51.0544435,13.7515333 51.0551019,13.7527693 51.0555438,13.7549766 51.0564993,13.7550622 51.0565364,13.755105 51.0566612,13.7552745 51.0566237,13.7558661 51.0560648,13.7559318 51.0560101,13.755908 51.055897,13.7559252 51.0558292,13.7559566 51.0557055,13.7564494 51.0551377,13.7564124 51.0550457,13.7573213 51.0539813,13.7575007 51.0539933,13.757856 51.0540047,13.7580394 51.054028,13.7580896 51.053984,13.7580949 51.0539463,13.7579963 51.0538534,13.7581294 51.0537147,13.7582346 51.0535957,13.758354 51.053433,13.758363 51.053392,13.7583656 51.0533457,13.758359 51.0532095,13.7583338 51.0530937,13.7582902 51.0529647,13.7580365 51.0522637,13.7577683 51.051463,13.7573182 51.0501993,13.7571595 51.0497164,13.7567579 51.0490095,13.7563383 5
1.0482979,13.7557757 51.0473383,13.7557095 51.0472522,13.7555771 51.0471199,13.7554448 51.0470471,13.7548596 51.0462612,13.7547097 51.046054,13.7549127 51.0460086,13.7548633 51.0459174,13.7548127 51.0458413,13.7547176 51.0457237,13.7538293 51.0449222,13.7530218 51.0441346,13.7526711 51.0437838,13.752446 51.0435522,13.7522297 51.0433547,13.751704 51.042833,13.7513058 51.0424448,13.7505766 51.0417281,13.7499967 51.0411283,13.7497695 51.0408943,13.7493849 51.0405205,13.7486222 51.0397896,13.7478209 51.0390261,13.7477474 51.0389532,13.7477041 51.0389189,13.7476277 51.0388729,13.7475781 51.0388513,13.7472699 51.038726,13.747131 51.0386506,13.7469329 51.0385052,13.7468562 51.0384284,13.7466683 51.0383483,13.7467998 51.038236,13.7473841 51.0380129,13.747838 51.0378277,13.7481801 51.0376558,13.7489728 51.0370285,13.7491313 51.0368016,13.7492665 51.0363477,13.7493166 51.0359389,13.7492966 51.0358087,13.7493888 51.0356942,13.7492867 51.0357016,13.7492855 51.0354359,13.7492829 51.034867,13.749
2723 51.0348311,13.7492455 51.0347398,13.7493034 51.0346612,13.7491987 51.0346142,13.748866 51.034723,13.748791 51.034201,13.748335 51.034159,13.748294 51.034034,13.748205 51.033764,13.7488691 51.0333037,13.748962 51.033245,13.7486777 51.0332252,13.7483008 51.032683,13.7484397 51.0324582,13.7469913 51.0327817,13.7466998 51.0326205,13.7459997 51.0314852,13.7460996 51.0313569,13.745967 51.0314864,13.7449355 51.0317377,13.7447301 51.0316513,13.7446705 51.0318463,13.7420262 51.0323659,13.7419131 51.0322884,13.7418636 51.0322552,13.7416501 51.0321425,13.7415567 51.0317708,13.7414972 51.0314666,13.741484 51.0311492,13.741923 51.031003,13.7418649 51.030884,13.74209 51.0304134,13.7422077 51.0300143,13.7421975 51.0299222,13.742286 51.029835,13.7421463 51.0297533,13.7420951 51.0296254,13.7415933 51.0288452,13.7414906 51.0286855,13.7414437 51.0286127,13.7413482 51.0284642,13.7410545 51.0280777,13.7407158 51.0277229,13.7401513 51.0273842,13.7392803 51.0270293,13.7382744 51.0267844,13.737321 51.
0267454,13.7365929 51.0267541,13.736556 51.026812,13.7364715 51.026754,13.7357088 51.0268017,13.7353967 51.02678,13.73534 51.02685,13.7352667 51.0267757,13.734907 51.0267324,13.734824 51.02679,13.7347684 51.0267064,13.7342093 51.0266674,13.73409 51.026725,13.7340359 51.0266283,13.7335072 51.0265633,13.733407 51.02663,13.7333208 51.0265373,13.7317087 51.0263813,13.7317173 51.0263119,13.73167 51.026241,13.7317563 51.0261602,13.7318473 51.0258395,13.7318647 51.0254971,13.73183 51.0253281,13.7317736 51.0252414,13.731663 51.025181,13.7316826 51.0251114,13.7310803 51.0247604,13.73095 51.024734)),((13.7368533 51.0470386,13.7368426 51.0471226,13.7368067 51.0472669,13.7368255 51.0473828,13.7369099 51.0474154,13.7376695 51.0474677,13.7382756 51.0474245,13.738513 51.0474297,13.7386105 51.0474065,13.738705 51.0473737,13.7385856 51.0473757,13.7385618 51.0473751,13.7385263 51.0473743,13.7384706 51.0473744,13.7383071 51.0473734,13.7383822 51.0473564,13.7390821 51.047287,13.7390933 51.047209,13.739
0933 51.0471421,13.7368533 51.0470386)),((13.7367293 51.0470057,13.7346615 51.0466892,13.7347551 51.0468411,13.7347754 51.0470359,13.7347106 51.0471899,13.7356421 51.0472919,13.7366963 51.0474074,13.736705 51.047249,13.7367293 51.0470057)))"
- GeomPtr simplified = TopologyPreservingSimplifier::simplify(g.get(), 0.0057);
+ checkTPS("MULTIPOLYGON(((13.73095 51.024734,13.7309323 51.0247668,13.7306959 51.0247959,13.7292724 51.0249742,13.7280216 51.0251252,13.7266598 51.0252998,13.7259617 51.0254072,13.7258854 51.0254201,13.7253253 51.0255144,13.725276 51.025492,13.724538 51.025631,13.7230288 51.0259021,13.7223529 51.0260273,13.7223299 51.0260863,13.7222292 51.026391,13.7220002 51.0273366,13.7217875 51.0282094,13.721746 51.028243,13.7217693 51.0282803,13.7215512 51.0291967,13.721513 51.029222,13.7215203 51.0292567,13.7212713 51.0295967,13.7222258 51.0299532,13.722234 51.03,13.7222931 51.0299823,13.7232514 51.0303187,13.7242514 51.0306715,13.724263 51.030714,13.7243024 51.0306951,13.7249934 51.0309315,13.7265097 51.0314552,13.7266116 51.0313952,13.7267988 51.0313334,13.7269952 51.0313243,13.72703 51.0314107,13.7271637 51.0313254,13.7272524 51.0313839,13.72739 51.031449,13.7276768 51.0313074,13.7283793 51.0309944,13.7296654 51.0304157,13.7297572 51.0303637,13.729845 51.0303139,13.7299557 51.0301763,13.7
300964 51.0300176,13.730252 51.0298919,13.7304615 51.0297932,13.730668 51.0297363,13.730743 51.029783,13.7307859 51.0298398,13.7307094 51.0301388,13.730624 51.030263,13.7306955 51.0303267,13.7301182 51.0325594,13.7300528 51.0325663,13.7301114 51.0327342,13.7301645 51.0329094,13.7300035 51.0327693,13.7299669 51.0327351,13.7299445 51.0327211,13.7298934 51.032814,13.7298539 51.0328585,13.7297737 51.0328321,13.7288526 51.0325639,13.7288201 51.0324367,13.7284426 51.0324383,13.7276461 51.032179,13.7274569 51.0321976,13.7272787 51.0322421,13.7271265 51.0322903,13.7267034 51.0322495,13.7265364 51.0322161,13.7259018 51.0324269,13.7258649 51.03242,13.725733 51.0326646,13.7251933 51.0328876,13.7247918 51.0331374,13.7244439 51.0331106,13.7242967 51.0334273,13.7239131 51.0337529,13.7237035 51.0338511,13.7235429 51.033967,13.7233375 51.0339148,13.7232064 51.0339347,13.7231786 51.0339863,13.7228848 51.0340776,13.7224481 51.0341888,13.7220471 51.0342483,13.7217493 51.0343198,13.721552 51.0343861,13
.7214718 51.0344095,13.7215108 51.034534,13.7205032 51.0349932,13.7197657 51.0352983,13.7195764 51.0352291,13.7195934 51.0352797,13.7182451 51.0359157,13.7181108 51.0359003,13.7181657 51.0359571,13.717622 51.0361956,13.7159749 51.0369683,13.7159057 51.0369284,13.7158604 51.0370288,13.7157161 51.0370124,13.7157523 51.0370733,13.7153708 51.0372801,13.7150274 51.0374899,13.7144074 51.0379192,13.7138287 51.0383899,13.7137514 51.0383857,13.7137492 51.0384566,13.7134249 51.0387269,13.7130179 51.0390385,13.7125791 51.0393343,13.7120736 51.039611,13.7115839 51.0398558,13.7112945 51.0399894,13.7114637 51.0402313,13.7123153 51.041449,13.7126333 51.0417033,13.713371 51.0421453,13.7138861 51.0424061,13.7142518 51.0425683,13.7164587 51.0435668,13.7167995 51.0437957,13.7170883 51.0439897,13.7190694 51.0451663,13.7196131 51.0458277,13.7197562 51.0461521,13.7198262 51.0464192,13.7198377 51.0467389,13.7205681 51.0455573,13.7210009 51.0450379,13.7214987 51.0445401,13.7220306 51.0442859,13.7227215 51.
0439558,13.7237962 51.0434514,13.723979 51.0435278,13.7241448 51.0435041,13.7241052 51.0436042,13.7247987 51.0438896,13.7250186 51.0439093,13.7250579 51.0440386,13.7257225 51.0443545,13.7259312 51.0443456,13.725955 51.0443813,13.7260235 51.0443873,13.7260682 51.0445303,13.7282191 51.0455848,13.7290532 51.045927,13.7292643 51.0458591,13.7292228 51.0459969,13.729706 51.0461854,13.7303185 51.046393,13.7309107 51.0465601,13.731546 51.0466841,13.7321939 51.0467752,13.7332896 51.0468999,13.7333733 51.0469094,13.7334778 51.0468127,13.7335706 51.0469078,13.733651 51.0470684,13.7338458 51.0471508,13.7346109 51.0472333,13.7346367 51.0471474,13.7346922 51.0470697,13.7346666 51.0470056,13.7346564 51.0468714,13.7345552 51.0467095,13.7336001 51.0465496,13.733427 51.046454,13.7335317 51.0464255,13.7347225 51.0465948,13.7348421 51.0466562,13.7349123 51.0466203,13.736811 51.0468537,13.7382043 51.0469796,13.7383487 51.0469803,13.7394909 51.0469005,13.7400899 51.0467949,13.7405051 51.0464739,13.740833
1 51.0462204,13.7412027 51.0463256,13.741053 51.0466451,13.7407291 51.0469007,13.7405095 51.0469726,13.7400888 51.0470337,13.7393051 51.0471049,13.7393014 51.0472015,13.7393088 51.0473019,13.7395556 51.0473056,13.7404944 51.0472245,13.740932 51.0470192,13.7414421 51.0465652,13.7414893 51.0465576,13.7416494 51.0464916,13.7416003 51.0466074,13.7416246 51.04663,13.741668 51.0466443,13.7417272 51.0467159,13.7417503 51.0466716,13.7423587 51.0468732,13.7426958 51.0470246,13.7429143 51.0471813,13.74318 51.04726,13.7430363 51.0472995,13.7433021 51.047588,13.7434678 51.0475916,13.7433805 51.0477019,13.7436362 51.0479981,13.7446308 51.0491622,13.7447961 51.0491827,13.744722 51.0492509,13.7448536 51.0494078,13.745056 51.0494766,13.7450313 51.0496901,13.7453573 51.0500052,13.7465317 51.0512807,13.7466999 51.0513722,13.746638 51.0514149,13.7468683 51.0516781,13.7470071 51.051777,13.7469985 51.0518746,13.7470732 51.0519866,13.7471316 51.0520528,13.7472989 51.0523089,13.7472368 51.0523858,13.74730
63 51.0524932,13.7473468 51.0527412,13.7473392 51.0531614,13.7472987 51.0533157,13.7473919 51.0534224,13.7472684 51.0534549,13.7472134 51.0536926,13.7472913 51.0537784,13.7473216 51.053725,13.7474649 51.0537575,13.7474492 51.053833,13.7475625 51.0537839,13.7497379 51.0544435,13.7515333 51.0551019,13.7527693 51.0555438,13.7549766 51.0564993,13.7550622 51.0565364,13.755105 51.0566612,13.7552745 51.0566237,13.7558661 51.0560648,13.7559318 51.0560101,13.755908 51.055897,13.7559252 51.0558292,13.7559566 51.0557055,13.7564494 51.0551377,13.7564124 51.0550457,13.7573213 51.0539813,13.7575007 51.0539933,13.757856 51.0540047,13.7580394 51.054028,13.7580896 51.053984,13.7580949 51.0539463,13.7579963 51.0538534,13.7581294 51.0537147,13.7582346 51.0535957,13.758354 51.053433,13.758363 51.053392,13.7583656 51.0533457,13.758359 51.0532095,13.7583338 51.0530937,13.7582902 51.0529647,13.7580365 51.0522637,13.7577683 51.051463,13.7573182 51.0501993,13.7571595 51.0497164,13.7567579 51.0490095,13.7563
383 51.0482979,13.7557757 51.0473383,13.7557095 51.0472522,13.7555771 51.0471199,13.7554448 51.0470471,13.7548596 51.0462612,13.7547097 51.046054,13.7549127 51.0460086,13.7548633 51.0459174,13.7548127 51.0458413,13.7547176 51.0457237,13.7538293 51.0449222,13.7530218 51.0441346,13.7526711 51.0437838,13.752446 51.0435522,13.7522297 51.0433547,13.751704 51.042833,13.7513058 51.0424448,13.7505766 51.0417281,13.7499967 51.0411283,13.7497695 51.0408943,13.7493849 51.0405205,13.7486222 51.0397896,13.7478209 51.0390261,13.7477474 51.0389532,13.7477041 51.0389189,13.7476277 51.0388729,13.7475781 51.0388513,13.7472699 51.038726,13.747131 51.0386506,13.7469329 51.0385052,13.7468562 51.0384284,13.7466683 51.0383483,13.7467998 51.038236,13.7473841 51.0380129,13.747838 51.0378277,13.7481801 51.0376558,13.7489728 51.0370285,13.7491313 51.0368016,13.7492665 51.0363477,13.7493166 51.0359389,13.7492966 51.0358087,13.7493888 51.0356942,13.7492867 51.0357016,13.7492855 51.0354359,13.7492829 51.034867,1
3.7492723 51.0348311,13.7492455 51.0347398,13.7493034 51.0346612,13.7491987 51.0346142,13.748866 51.034723,13.748791 51.034201,13.748335 51.034159,13.748294 51.034034,13.748205 51.033764,13.7488691 51.0333037,13.748962 51.033245,13.7486777 51.0332252,13.7483008 51.032683,13.7484397 51.0324582,13.7469913 51.0327817,13.7466998 51.0326205,13.7459997 51.0314852,13.7460996 51.0313569,13.745967 51.0314864,13.7449355 51.0317377,13.7447301 51.0316513,13.7446705 51.0318463,13.7420262 51.0323659,13.7419131 51.0322884,13.7418636 51.0322552,13.7416501 51.0321425,13.7415567 51.0317708,13.7414972 51.0314666,13.741484 51.0311492,13.741923 51.031003,13.7418649 51.030884,13.74209 51.0304134,13.7422077 51.0300143,13.7421975 51.0299222,13.742286 51.029835,13.7421463 51.0297533,13.7420951 51.0296254,13.7415933 51.0288452,13.7414906 51.0286855,13.7414437 51.0286127,13.7413482 51.0284642,13.7410545 51.0280777,13.7407158 51.0277229,13.7401513 51.0273842,13.7392803 51.0270293,13.7382744 51.0267844,13.73732
1 51.0267454,13.7365929 51.0267541,13.736556 51.026812,13.7364715 51.026754,13.7357088 51.0268017,13.7353967 51.02678,13.73534 51.02685,13.7352667 51.0267757,13.734907 51.0267324,13.734824 51.02679,13.7347684 51.0267064,13.7342093 51.0266674,13.73409 51.026725,13.7340359 51.0266283,13.7335072 51.0265633,13.733407 51.02663,13.7333208 51.0265373,13.7317087 51.0263813,13.7317173 51.0263119,13.73167 51.026241,13.7317563 51.0261602,13.7318473 51.0258395,13.7318647 51.0254971,13.73183 51.0253281,13.7317736 51.0252414,13.731663 51.025181,13.7316826 51.0251114,13.7310803 51.0247604,13.73095 51.024734)),((13.7368533 51.0470386,13.7368426 51.0471226,13.7368067 51.0472669,13.7368255 51.0473828,13.7369099 51.0474154,13.7376695 51.0474677,13.7382756 51.0474245,13.738513 51.0474297,13.7386105 51.0474065,13.738705 51.0473737,13.7385856 51.0473757,13.7385618 51.0473751,13.7385263 51.0473743,13.7384706 51.0473744,13.7383071 51.0473734,13.7383822 51.0473564,13.7390821 51.047287,13.7390933 51.047209,1
3.7390933 51.0471421,13.7368533 51.0470386)),((13.7367293 51.0470057,13.7346615 51.0466892,13.7347551 51.0468411,13.7347754 51.0470359,13.7347106 51.0471899,13.7356421 51.0472919,13.7366963 51.0474074,13.736705 51.047249,13.7367293 51.0470057)))",
+ 0.0057,
+ "MULTIPOLYGON (((13.73095 51.024734, 13.7123153 51.041449, 13.7552745 51.0566237, 13.7484397 51.0324582, 13.73095 51.024734)), ((13.7390933 51.0471421, 13.7369099 51.0474154, 13.7390933 51.047209, 13.7390933 51.0471421)), ((13.7367293 51.0470057, 13.7346615 51.0466892, 13.7347106 51.0471899, 13.7367293 51.0470057)))");
#endif // fails with JTS too
// PolygonWithSpike
template<>
template<>
- std::string wkt("POLYGON ((3312459.605 6646878.353, \
- 3312460.524 6646875.969, 3312459.427 6646878.421, \
- 3312460.014 6646886.391, 3312465.889 6646887.398, \
- 3312470.827 6646884.839, 3312475.4 6646878.027, \
- 3312477.289 6646871.694, 3312472.748 6646869.547, \
- 3312468.253 6646874.01, 3312463.52 6646875.779, \
- 3312459.605 6646878.353))");
- std::string wkt_expected("POLYGON (( \
- 3312459.605 6646878.353, \
- 3312460.524 6646875.969, \
- 3312459.427 6646878.421, \
- 3312460.014 6646886.391, \
- 3312465.889 6646887.398, \
- 3312470.827 6646884.839, \
- 3312477.289 6646871.694, \
- 3312472.748 6646869.547, \
- GeomPtr simplified = TopologyPreservingSimplifier::simplify(g.get(), 2.0);
- GeomPtr g_expected(wktreader.read(wkt_expected));
- ensure(g_expected->equalsExact(simplified.get()));
+ checkTPS("POLYGON ((3312459.605 6646878.353, 3312460.524 6646875.969, 3312459.427 6646878.421, 3312460.014 6646886.391, 3312465.889 6646887.398, 3312470.827 6646884.839, 3312475.4 6646878.027, 3312477.289 6646871.694, 3312472.748 6646869.547, 3312468.253 6646874.01, 3312463.52 6646875.779, 3312459.605 6646878.353))",
+ 2,
+ "POLYGON ((3312459.605 6646878.353, 3312460.524 6646875.969, 3312459.427 6646878.421, 3312460.014 6646886.391, 3312465.889 6646887.398, 3312470.827 6646884.839, 3312477.289 6646871.694, 3312472.748 6646869.547, 3312459.605 6646878.353))");
// PolygonNoReduction
template<>
template<>
- std::string wkt("POLYGON((20 220, 40 220, 60 220, 80 220, \
- 100 220, 120 220, 140 220, 140 180, 100 180, \
- 60 180, 20 180, 20 220))");
- std::string wkt_exp("POLYGON ((20 220, 140 220, 140 180, 20 180, 20 220))");
- GeomPtr exp(wktreader.read(wkt_exp));
- ensure("Simplified and original geometry inequal", simplified->equals(g.get()));
- ensure_equals_geometry(exp.get(), simplified.get());
+ checkTPSNoChange("POLYGON ((20 220, 140 220, 140 180, 20 180, 20 220))",
+ 10);
// PolygonNoReductionWithConflicts
template<>
template<>
- std::string wkt("POLYGON ((40 240, 160 241, 280 240, 280 160, \
- ensure("Topology has been changed by simplification!", simplified->equals(g.get()));
+ checkTPSNoChange("POLYGON ((40 240, 160 241, 280 240, 280 160, 160 240, 40 140, 40 240))",
+ 10);
// PolygonWithTouchingHole
template<>
template<>
- std::string wkt("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
- std::string wkt_expected("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
+ checkTPS("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), (120 120, 220 120, 180 199, 160 200, 140 199, 120 120))",
+ 10,
// FlattishPolygon
template<>
template<>
- std::string wkt("POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, 70 1, 60 1, 50 1, 40 1, 0 0))");
- std::string wkt_exp("POLYGON ((0 0, 50 0, 100 0, 70 1, 0 0))");
+ checkTPS("POLYGON ((0 0, 50 0, 53 0, 55 0, 100 0, 70 1, 60 1, 50 1, 40 1, 0 0))",
+ 10,
+ "POLYGON ((0 0, 50 0, 100 0, 70 1, 0 0))");
// PolygonWithFlattishHole
template<>
template<>
- std::string wkt("POLYGON ((0 0, 0 200, 200 200, 200 0, 0 0), \
- (140 40, 90 95, 40 160, 95 100, 140 40))");
- GeomPtr g_expected(wktreader.read(wkt));
+ checkTPS("POLYGON ((0 0, 0 200, 200 200, 200 0, 0 0), (140 40, 90 95, 40 160, 95 100, 140 40))",
+ 20,
+ "POLYGON ((0 0, 0 200, 200 200, 200 0, 0 0), (140 40, 90 95, 40 160, 95 100, 140 40))");
// TinySquare
template<>
template<>
- std::string wkt("POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))");
- std::string wkt_exp("POLYGON ((0 0, 5 5, 5 0, 0 0))");
+ checkTPS("POLYGON ((0 5, 5 5, 5 0, 0 0, 0 1, 0 5))",
+ 10,
+ "POLYGON ((0 0, 5 5, 5 0, 0 0))");
// TinyLineString
template<>
template<>
- std::string wkt("LINESTRING (0 5, 1 5, 2 5, 5 5)");
- std::string wkt_exp("LINESTRING (0 5, 5 5)");
+ checkTPS("LINESTRING (0 5, 1 5, 2 5, 5 5)",
+ 10,
// TinyClosedLineString
template<>
template<>
- std::string wkt("LINESTRING (0 0, 5 0, 5 5, 0 0)");
+ checkTPSNoChange("LINESTRING (0 0, 5 0, 5 5, 0 0)",
+ 10);
// MultiPoint
template<>
template<>
- std::string wkt("MULTIPOINT((80 200), (240 200), (240 60), \
- (80 60), (80 200), (140 199), (120 120))");
+ checkTPSNoChange("MULTIPOINT(80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120)",
+ 10);
// MultiLineString
template<>
template<>
- std::string wkt("MULTILINESTRING((0 0, 50 0, 70 0, 80 0, 100 0), (0 0, 50 1, 60 1, 100 0))");
+ checkTPS("MULTILINESTRING( (0 0, 50 0, 70 0, 80 0, 100 0), (0 0, 50 1, 60 1, 100 0) )",
+ 10,
- //TODO: investigate why TPS does not prevent lines from collapsing (JTS has same behaviour)
+ //TODO: investigate why TPS does not prevent lines from collapsing
+ // JTS has correct behaviour - result should be:
//std::string wkt_exp("MULTILINESTRING ((0 0, 100 0), (0 0, 50 1, 100 0))");
- std::string wkt_exp("MULTILINESTRING ((0 0, 100 0), (0 0, 100 0))");
- // std::cout << "expected " << *exp << std::endl;
- // std::cout << "result " << *simplified << std::endl;
- /* Temporarily disable this component of the test only for MSVC
- See https://trac.osgeo.org/geos/ticket/1081 */
-#ifndef _MSC_VER
-#endif
// GeometryCollection
template<>
template<>
- std::string wkt("GEOMETRYCOLLECTION ( \
- LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120))");
+ checkTPSNoChange("GEOMETRYCOLLECTION (MULTIPOINT (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120), POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200)), LINESTRING (80 200, 240 200, 240 60, 80 60, 80 200, 140 199, 120 120))",
+ 10);
// GeometryCollection with empty elements
// See http://trac.osgeo.org/geos/ticket/519
template<>
template<>
- LINESTRING (0 0, 10 0), POLYGON EMPTY)");
- GeomPtr simp = TopologyPreservingSimplifier::simplify(g.get(), 1);
- ensure("Simplified geometry is invalid!", simp->isValid());
- ensure_equals(wktwriter.write(simp.get()),
- "GEOMETRYCOLLECTION (LINESTRING (0 0, 10 0))");
+ checkTPS("GEOMETRYCOLLECTION ( LINESTRING (0 0, 10 0), POLYGON EMPTY)",
+ 1,
+ "GEOMETRYCOLLECTION (LINESTRING (0 0, 10 0))");
template<>
template<>
- auto simplified = TopologyPreservingSimplifier::simplify(g.get(), 0);
+ checkTPSNoChange("LINESTRING (1 0, 2 0, 2 2, 0 2, 0 0, 1 0)",
+ 0);
-// Test that removing starting point of ring does not break topology
+// testPolygonKeepFlatEndpointWithTouch
+// Test that flat ring endpoint is not removed if it touches another ring
template<>
template<>
-void object::test<18>
- auto g = wktreader.read("POLYGON ((0 0, 5 2.05, 10 0, 10 10, 0 10, 0 0), (5 2.1, 6 2, 6 4, 4 4, 4 2, 5 2.1))");
- auto simplified = TopologyPreservingSimplifier::simplify(g.get(), 0.1);
+ checkTPSNoChange("POLYGON ((0 0, 5 2.05, 10 0, 10 10, 0 10, 0 0), (5 2.1, 6 2, 6 4, 4 4, 4 2, 5 2.1))",
+ 0.1);
// testPolygonKeepEndpointWithCross
// Test that endpoint is not simplified if it breaks topology
template<>
template<>
-void object::test<19>
checkTPS(
"POLYGON ((50 52, 60 50, 90 60, 90 10, 10 10, 10 90, 60 90, 50 55, 40 80, 20 60, 40 50, 50 52))",
commit 00ecc98ffc5dd3634932c86022d7853770f33377
Author: Mike Taves <mwtoews at gmail.com>
Date: Mon Nov 6 15:21:09 2023 +1300
CI: workaround for https://github.com/actions/runner-images/issues/8659
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index bce5791d0..41aa9050e 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -186,6 +186,15 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
+ # Work around https://github.com/actions/runner-images/issues/8659
+ - name: 'Remove GCC 13 from runner image (workaround)'
+ if: matrix.ci.os == 'ubuntu-22.04' && matrix.ci.cxx_compiler == 'clang++-14'
+ shell: bash
+ run: |
+ sudo rm -f /etc/apt/sources.list.d/ubuntu-toolchain-r-ubuntu-test-jammy.list
+ sudo apt-get update
+ sudo apt-get install -y --allow-downgrades libc6=2.35-0ubuntu3.4 libc6-dev=2.35-0ubuntu3.4 libstdc++6=12.3.0-1ubuntu1~22.04 libgcc-s1=12.3.0-1ubuntu1~22.04
- name: 'Install'
run: |
set -e
commit 53a7f856f54711cd6e7abbff6a5189fc3034ea30
Date: Mon Nov 6 17:21:36 2023 -0800
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 7b728877c..73ef08b6c 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -11,6 +11,7 @@
- Fix error in CoordinateSequence::add when disallowing repeated points (GH-963, Dan Baston)
- Fix InteriorPointPoint to handle empty elements (GH-977, Martin Davis)
- Skip over testing empty distances for mixed collections. (GH-979, Paul Ramsey)
+ - Fix TopologyPreservingSimplifier endpoint handling to avoid self-intersections (GH-986, Martin Davis)
## Changes in 3.12.0
commit 58f7cc7f191c4c8044d24c7a6aa3b60c1a897c87
Date: Mon Nov 6 17:17:44 2023 -0800
Fix TopologyPreservingSimplifier endpoint handling to avoid self-intersections (#986)
diff --git a/include/geos/simplify/TaggedLineStringSimplifier.h b/include/geos/simplify/TaggedLineStringSimplifier.h
index 835f6e870..5ed98e766 100644
--- a/include/geos/simplify/TaggedLineStringSimplifier.h
+++ b/include/geos/simplify/TaggedLineStringSimplifier.h
@@ -113,12 +113,12 @@ private:
double& maxDistance);
bool hasBadIntersection(const TaggedLineString* parentLine,
- const std::pair<std::size_t, std::size_t>& sectionIndex,
+ const size_t excludeStart, const size_t excludeEnd,
const geom::LineSegment& candidateSeg);
bool hasBadInputIntersection(const TaggedLineString* parentLine,
- const geom::LineSegment& candidateSeg);
+ const geom::LineSegment& candidateSeg);
bool hasBadOutputIntersection(const geom::LineSegment& candidateSeg);
@@ -129,16 +129,20 @@ private:
std::size_t start, std::size_t end);
/** \brief
- * Tests whether a segment is in a section of a TaggedLineString
+ * Tests whether a segment is in a section of a TaggedLineString.
+ * Sections may wrap around the endpoint of the line,
+ * to support ring endpoint simplification.
+ * This is indicated by excludedStart > excludedEnd
* @param line line to be checked for the presence of `seg`
- * @param sectionIndex start and end indices of the section to check
+ * @param excludeStart the index of the first segment in the excluded section
+ * @param excludeEnd the index of the last segment in the excluded section
* @param seg segment to look for in `line`
- * @return
+ * @return true if the test segment intersects some segment in the line not in the excluded section
static bool isInLineSection(
const TaggedLineString* line,
const TaggedLineSegment* seg);
/** \brief
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index c266816fb..185218f4b 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -38,7 +38,6 @@
#endif
-using std::pair;
using std::unique_ptr;
using std::vector;
@@ -149,7 +148,7 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
// test if flattened section would cause intersection
LineSegment candidateSeg(linePts->getAt(i), linePts->getAt(j));
- if(hasBadIntersection(line, std::make_pair(i, j), candidateSeg)) {
+ if(hasBadIntersection(line, i, j, candidateSeg)) {
isValidToSimplify = false;
@@ -182,8 +181,8 @@ TaggedLineStringSimplifier::simplifyRingEndpoint()
LineSegment candidateSeg(lastSeg->p0, firstSeg->p1);
if (candidateSeg.distance(firstSeg->p0) <= distanceTolerance &&
- !hasBadIntersection(line, std::make_pair(0, line->getSegments().size()), candidateSeg)) {
- auto newSeg = detail::make_unique<TaggedLineSegment>(candidateSeg.p0, candidateSeg.p1);
+ ! hasBadIntersection(line, line->getSegments().size() - 2, 0, candidateSeg)) {
+ //auto newSeg = detail::make_unique<TaggedLineSegment>(candidateSeg.p0, candidateSeg.p1);
line->removeRingEndpoint();
@@ -207,14 +206,14 @@ TaggedLineStringSimplifier::flatten(std::size_t start, std::size_t end)
bool
TaggedLineStringSimplifier::hasBadIntersection(
- const pair<size_t, size_t>& sectionIndex,
const LineSegment& candidateSeg)
if(hasBadOutputIntersection(candidateSeg)) {
return true;
- if(hasBadInputIntersection(parentLine, sectionIndex, candidateSeg)) {
+ if(hasBadInputIntersection(parentLine, excludeStart, excludeEnd, candidateSeg)) {
return true;
@@ -252,7 +251,7 @@ TaggedLineStringSimplifier::hasInteriorIntersection(
bool
TaggedLineStringSimplifier::hasBadInputIntersection(
- const pair<std::size_t, std::size_t>& sectionIndex,
const auto& foundSegs = inputIndex->query(&candidateSeg);
@@ -260,7 +259,7 @@ TaggedLineStringSimplifier::hasBadInputIntersection(
for(const LineSegment* ls : *foundSegs) {
const TaggedLineSegment* foundSeg = static_cast<const TaggedLineSegment*>(ls);
- if(!isInLineSection(parentLine, sectionIndex, foundSeg) && hasInteriorIntersection(*foundSeg, candidateSeg)) {
+ if(!isInLineSection(parentLine, excludeStart, excludeEnd, foundSeg) && hasInteriorIntersection(*foundSeg, candidateSeg)) {
return true;
@@ -272,7 +271,7 @@ TaggedLineStringSimplifier::hasBadInputIntersection(
bool
TaggedLineStringSimplifier::isInLineSection(
// not in this line
@@ -281,10 +280,16 @@ TaggedLineStringSimplifier::isInLineSection(
std::size_t segIndex = seg->getIndex();
- if(segIndex >= sectionIndex.first && segIndex < sectionIndex.second) {
+ if (excludeStart <= excludeEnd) {
+ //-- section is contiguous
+ if (segIndex >= excludeStart && segIndex < excludeEnd)
return true;
+ else {
+ //-- section wraps around the end of a ring
+ if (segIndex >= excludeStart || segIndex <= excludeEnd)
+ return true;
return false;
index b36ad12a3..c21b2ce42 100644
@@ -34,6 +34,18 @@ struct test_tpsimp_data {
, wktwriter()
+ void
+ checkTPS(const std::string& wkt, double tolerance, const std::string& wkt_expected)
+ GeomPtr simplified = TopologyPreservingSimplifier::simplify(g.get(), tolerance);
@@ -379,4 +391,18 @@ void object::test<18>
+// testPolygonKeepEndpointWithCross
+// Test that endpoint is not simplified if it breaks topology
+template<>
+template<>
+ checkTPS(
+ "POLYGON ((50 52, 60 50, 90 60, 90 10, 10 10, 10 90, 60 90, 50 55, 40 80, 20 60, 40 50, 50 52))",
+ 10,
+ "POLYGON ((50 52, 90 60, 90 10, 10 10, 10 90, 60 90, 50 55, 40 80, 20 60, 50 52))"
} // namespace tut
commit c406cea14a54240a44bcf8289e526b3276868bca
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 2 14:47:23 2023 -0700
News entry for #979
index 04982b314..7b728877c 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@
- Fix PreparedLineStringDistance for lines within envelope and polygons (GH-959, Martin Davis)
+ - Skip over testing empty distances for mixed collections. (GH-979, Paul Ramsey)
commit 1e1a194b3807ab41bf553f61abbcdf81fbbbcd94
Date: Thu Nov 2 14:45:36 2023 -0700
Skip over testing empty distances for mixed collections. Closes #979
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index 2f3cb6663..952c68d96 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -358,6 +358,10 @@ DistanceOp::computeMinDistanceLines(
for(const LineString* line0 : lines0) {
for(const LineString* line1 : lines1) {
+ if (line0->isEmpty() || line1->isEmpty())
+ continue;
computeMinDistance(line0, line1, locGeom);
if(minDistance <= terminateDistance) {
return;
@@ -374,13 +378,11 @@ DistanceOp::computeMinDistancePoints(
std::array<std::unique_ptr<GeometryLocation>, 2> & locGeom)
for(const Point* pt0 : points0) {
- if (pt0->isEmpty()) {
- continue;
for(const Point* pt1 : points1) {
- if (pt1->isEmpty()) {
+ if (pt1->isEmpty() || pt0->isEmpty())
continue;
double dist = pt0->getCoordinate()->distance(*(pt1->getCoordinate()));
#if GEOS_DEBUG
@@ -414,6 +416,10 @@ DistanceOp::computeMinDistanceLinesPoints(
for(const LineString* line : lines) {
for(const Point* pt : points) {
+ if (line->isEmpty() || pt->isEmpty())
+ continue;
computeMinDistance(line, pt, locGeom);
return;
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 9b862e377..9df481a39 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -565,6 +565,11 @@ void object::test<21>()
ensure_equals(g1->distance(g2.get()), 1.9996999774966246);
+// Variations on a theme: testing EMPTY and collections with EMPTY
+// Ignoring empty component
template<>
template<>
void object::test<22>()
@@ -576,6 +581,69 @@ void object::test<22>()
ensure_equals(g2->distance(g1.get()), 1);
+// Empty is same as empty so zero...?
+template<>
+template<>
+void object::test<23>()
+ auto g1 = wktreader.read("POINT EMPTY");
+ auto g2 = wktreader.read("LINESTRING EMPTY");
+ ensure(g1 != nullptr && g2 != nullptr);
+ ensure_equals(g1->distance(g2.get()), 0);
+ ensure_equals(g2->distance(g1.get()), 0);
+template<>
+template<>
+void object::test<24>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY, LINESTRING EMPTY)");
+// But ignore empty if there's a real distance?
+template<>
+template<>
+void object::test<25>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(LINESTRING EMPTY, POINT(2 1))");
+ auto g2 = wktreader.read("POINT(1 1)");
+ ensure_equals(g1->distance(g2.get()), 1);
+ ensure_equals(g2->distance(g1.get()), 1);
+template<>
+template<>
+void object::test<26>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT(-2 0), POINT EMPTY)");
+ auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0),LINESTRING(0 0,1 0))");
+ ensure_equals(g1->distance(g2.get()), 2);
+ ensure_equals(g2->distance(g1.get()), 2);
+template<>
+template<>
+void object::test<27>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY)");
+ auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0))");
// TODO: finish the tests by adding:
// LINESTRING - *all*
// MULTILINESTRING - *all*
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index 4ce6d0fed..3835c919d 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -6,6 +6,7 @@
<a> POINT(10 10) </a>
<b> POINT EMPTY </b>
<test><op name="distance" arg1="A" arg2="B"> 0.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A"> 0.0 </op></test>
</case>
<case>
@@ -13,6 +14,31 @@
<b> POINT (10 0) </b>
<test><op name="distance" arg1="A" arg2="B"> 10.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A"> 10.0 </op></test>
+</case>
+<case>
+ <desc>PP - point to multipoint</desc>
+ <a> POINT(10 10) </a>
+ <b> MULTIPOINT ((10 0), (30 30)) </b>
+<test><op name="distance" arg1="A" arg2="B"> 10.0 </op></test>
+</case>
+<case>
+ <desc>PP - point to multipoint with empty element</desc>
+ <b> MULTIPOINT ((10 0), EMPTY) </b>
+</case>
+<case>
+ <desc>LL - line to empty line</desc>
+ <a> LINESTRING (0 0, 0 10) </a>
+ <b> LINESTRING EMPTY </b>
+<test><op name="distance" arg1="A" arg2="B"> 0.0 </op></test>
</case>
<case>
@@ -20,6 +46,31 @@
<b> LINESTRING (10 0, 10 10) </b>
+</case>
+<case>
+ <desc>LL - line to multiline</desc>
+ <b> MULTILINESTRING ((10 0, 10 10), (50 50, 60 60)) </b>
+</case>
+<case>
+ <desc>LL - line to multiline with empty element</desc>
+ <b> MULTILINESTRING ((10 0, 10 10), EMPTY) </b>
+</case>
+<case>
+ <desc>PA - point to empty polygon</desc>
+ <a> POINT (240 160) </a>
+ <b> POLYGON EMPTY </b>
+<test><op name="distance" arg1="A" arg2="B" > 0.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 0.0 </op></test>
</case>
<case>
@@ -27,6 +78,7 @@
<b> POLYGON ((100 260, 340 180, 100 60, 180 160, 100 260)) </b>
</case>
<case>
@@ -34,6 +86,7 @@
<a> LINESTRING (40 300, 280 220, 60 160, 140 60) </a>
<b> LINESTRING (140 360, 260 280, 240 120, 120 160) </b>
</case>
<case>
@@ -41,6 +94,7 @@
<a> POLYGON ((60 260, 260 180, 100 60, 60 160, 60 260)) </a>
<b> POLYGON ((220 280, 120 160, 300 60, 360 220, 220 280)) </b>
</case>
<case>
@@ -48,6 +102,7 @@
<a> POLYGON ((100 320, 60 120, 240 180, 200 260, 100 320)) </a>
<b> POLYGON ((420 320, 280 260, 400 100, 420 320)) </b>
<test><op name="distance" arg1="A" arg2="B" > 71.55417527999327 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 71.55417527999327 </op></test>
</case>
<case>
@@ -55,13 +110,23 @@
<a> MULTIPOLYGON (((40 240, 160 320, 40 380, 40 240)), ((100 240, 240 60, 40 40, 100 240))) </a>
<b> MULTIPOLYGON (((220 280, 120 160, 300 60, 360 220, 220 280)), ((240 380, 280 300, 420 340, 240 380))) </b>
</case>
<case>
- <desc>mAmA - multipolygon with empty component</desc>
+ <desc>mAmA - multipolygon with empty element</desc>
<a> MULTIPOLYGON (EMPTY, ((98 200, 200 200, 200 99, 98 99, 98 200))) </a>
<b> POLYGON ((300 200, 400 200, 400 100, 300 100, 300 200)) </b>
<test><op name="distance" arg1="A" arg2="B" > 100.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 100.0 </op></test>
+</case>
+<case>
+ <desc>GCGC - geometry collections with mixed dimensions</desc>
+ <a> GEOMETRYCOLLECTION (LINESTRING (10 10, 50 10), POINT (90 10)) </a>
+ <b> GEOMETRYCOLLECTION (POLYGON ((90 20, 60 20, 60 50, 90 50, 90 20)), LINESTRING (10 50, 30 70)) </b>
+<test><op name="distance" arg1="A" arg2="B" > 10.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 10.0 </op></test>
</case>
</run>
commit 589e9f6c435eb611030bf835c9f65aff5269eda1
Date: Sun Oct 29 08:32:11 2023 -0700
Update NEWS
index b670a4dad..04982b314 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -9,6 +9,7 @@
- Improve scale handling for PrecisionModel (GH-956, Martin Davis)
+ - Fix InteriorPointPoint to handle empty elements (GH-977, Martin Davis)
commit 5bb4613a9c8c06f62dd46e3bd344db31d8f95f1c
Date: Sun Oct 29 08:26:44 2023 -0700
Fix InteriorPointPoint to handle empty elements (#977)
diff --git a/src/algorithm/InteriorPointPoint.cpp b/src/algorithm/InteriorPointPoint.cpp
index 6fb48f397..9070aa670 100644
--- a/src/algorithm/InteriorPointPoint.cpp
+++ b/src/algorithm/InteriorPointPoint.cpp
@@ -47,6 +47,9 @@ InteriorPointPoint::InteriorPointPoint(const Geometry* g)
void
InteriorPointPoint::add(const Geometry* geom)
+ if (geom->isEmpty())
+ return;
const Point* po = dynamic_cast<const Point*>(geom);
if (po) {
add(po->getCoordinate());
diff --git a/tests/xmltester/tests/general/TestInteriorPoint.xml b/tests/xmltester/tests/general/TestInteriorPoint.xml
index 0d765caca..23b4a8705 100644
--- a/tests/xmltester/tests/general/TestInteriorPoint.xml
+++ b/tests/xmltester/tests/general/TestInteriorPoint.xml
@@ -14,12 +14,19 @@
</case>
<case>
- <desc>P - single point</desc>
+ <desc>P - multipoint</desc>
<a> MULTIPOINT ((60 300), (200 200), (240 240), (200 300), (40 140), (80 240), (140 240), (100 160), (140 200), (60 200))
</a>
<test><op name="getInteriorPoint" arg1="A" > POINT (140 240) </op></test>
</case>
+<case>
+ <desc>P - multipoint with EMPTY</desc>
+ <a> MULTIPOINT((0 0), EMPTY)
+ </a>
+<test><op name="getInteriorPoint" arg1="A" > POINT (0 0) </op></test>
+</case>
<case>
<desc>L - linestring with single segment</desc>
<a> LINESTRING (0 0, 7 14)
Summary of changes:
.github/workflows/ci.yml | 9 +
NEWS.md | 3 +
include/geos/simplify/TaggedLineStringSimplifier.h | 18 +-
src/algorithm/InteriorPointPoint.cpp | 3 +
src/operation/distance/DistanceOp.cpp | 16 +-
src/simplify/TaggedLineStringSimplifier.cpp | 27 +-
tests/unit/operation/distance/DistanceOpTest.cpp | 68 ++++
.../unit/simplify/DouglasPeuckerSimplifierTest.cpp | 344 +++++++--------------
.../simplify/TopologyPreservingSimplifierTest.cpp | 309 ++++++------------
tests/xmltester/tests/general/TestDistance.xml | 67 +++-
.../xmltester/tests/general/TestInteriorPoint.xml | 9 +-
11 files changed, 399 insertions(+), 474 deletions(-)
hooks/post-receive
More information about the geos-commits
