[geos-commits] [SCM] GEOS branch 3.9 updated. a3e58f156eb93fcfa9e130fe49c2c3847175f30b
Thu Nov 9 00:25:55 PST 2023
the project "GEOS".
The branch, 3.9 has been updated
       via  a3e58f156eb93fcfa9e130fe49c2c3847175f30b (commit)
       via  5a3d493dcc7a079926af34b079bfa4c931fa614e (commit)
      from  755b1360d2221e7b560101fab8cb237b0275ece3 (commit)
revisions in full, below.
commit a3e58f156eb93fcfa9e130fe49c2c3847175f30b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 2 14:50:47 2023 -0700
    News entry for #979
diff --git a/NEWS b/NEWS
index 892b2cb82..893baf8f2 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ Changes in 3.9.5
   - DistanceOp: Fix crash on collection containing empty point (GH-842, Dan Baston)
   - GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
   - Remove undefined behaviour in use of null PrecisionModel (GH-931, Jeff Walton)
+  - Skip over testing empty distances for mixed collections (GH-979, Paul Ramsey)
 Changes in 3.9.4
commit 5a3d493dcc7a079926af34b079bfa4c931fa614e
Date:   Thu Nov 2 14:45:36 2023 -0700
    Skip over testing empty distances for mixed collections. Closes #979
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index da7fed148..52a23f31f 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -362,6 +362,10 @@ DistanceOp::computeMinDistanceLines(
     for(const LineString* line0 : lines0) {
         for(const LineString* line1 : lines1) {
+            if (line0->isEmpty() || line1->isEmpty())
+                continue;
             computeMinDistance(line0, line1, locGeom);
             if(minDistance <= terminateDistance) {
                 return;
@@ -378,13 +382,11 @@ DistanceOp::computeMinDistancePoints(
     array<unique_ptr<GeometryLocation>, 2> & locGeom)
     for(const Point* pt0 : points0) {
-        if (pt0->isEmpty()) {
-            continue;
         for(const Point* pt1 : points1) {
-            if (pt1->isEmpty()) {
+            if (pt1->isEmpty() || pt0->isEmpty())
                 continue;
             double dist = pt0->getCoordinate()->distance(*(pt1->getCoordinate()));
 #if GEOS_DEBUG
@@ -418,6 +420,10 @@ DistanceOp::computeMinDistanceLinesPoints(
     for(const LineString* line : lines) {
         for(const Point* pt : points) {
+            if (line->isEmpty() || pt->isEmpty())
+                continue;
             computeMinDistance(line, pt, locGeom);
                 return;
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index e80a0e143..16414a8bb 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -565,6 +565,11 @@ void object::test<21>()
     ensure_equals(g1->distance(g2.get()), 1.9996999774966246);
+// Variations on a theme: testing EMPTY and collections with EMPTY
+// Ignoring empty component
 template<>
 template<>
 void object::test<22>()
@@ -576,6 +581,69 @@ void object::test<22>()
     ensure_equals(g2->distance(g1.get()), 1);
+// Empty is same as empty so zero...?
+template<>
+template<>
+void object::test<23>()
+    auto g1 = wktreader.read("POINT EMPTY");
+    auto g2 = wktreader.read("LINESTRING EMPTY");
+    ensure(g1 != nullptr && g2 != nullptr);
+    ensure_equals(g1->distance(g2.get()), 0);
+    ensure_equals(g2->distance(g1.get()), 0);
+template<>
+template<>
+void object::test<24>()
+    auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY, LINESTRING EMPTY)");
+// But ignore empty if there's a real distance?
+template<>
+template<>
+void object::test<25>()
+    auto g1 = wktreader.read("GEOMETRYCOLLECTION(LINESTRING EMPTY, POINT(2 1))");
+    auto g2 = wktreader.read("POINT(1 1)");
+    ensure_equals(g1->distance(g2.get()), 1);
+    ensure_equals(g2->distance(g1.get()), 1);
+template<>
+template<>
+void object::test<26>()
+    auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT(-2 0), POINT EMPTY)");
+    auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0),LINESTRING(0 0,1 0))");
+    ensure_equals(g1->distance(g2.get()), 2);
+    ensure_equals(g2->distance(g1.get()), 2);
+template<>
+template<>
+void object::test<27>()
+    auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY)");
+    auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0))");
 // TODO: finish the tests by adding:
 // 	LINESTRING - *all*
 // 	MULTILINESTRING - *all*
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index 4ce6d0fed..3835c919d 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -6,6 +6,7 @@
   <a>    POINT(10 10)  </a>
   <b>    POINT EMPTY  </b>
 <test><op name="distance" arg1="A" arg2="B">    0.0   </op></test>
+<test><op name="distance" arg1="B" arg2="A">    0.0   </op></test>
 </case>
 <case>
@@ -13,6 +14,31 @@
   <b>    POINT (10 0)  </b>
 <test><op name="distance" arg1="A" arg2="B">    10.0   </op></test>
+<test><op name="distance" arg1="B" arg2="A">    10.0   </op></test>
+</case>
+<case>
+  <desc>PP - point to multipoint</desc>
+  <a>    POINT(10 10)  </a>
+  <b>    MULTIPOINT ((10 0), (30 30))  </b>
+<test><op name="distance" arg1="A" arg2="B">    10.0   </op></test>
+</case>
+<case>
+  <desc>PP - point to multipoint with empty element</desc>
+  <b>    MULTIPOINT ((10 0), EMPTY)  </b>
+</case>
+<case>
+  <desc>LL - line to empty line</desc>
+  <a>    LINESTRING (0 0, 0 10)  </a>
+  <b>    LINESTRING EMPTY  </b>
+<test><op name="distance" arg1="A" arg2="B">    0.0   </op></test>
 </case>
 <case>
@@ -20,6 +46,31 @@
   <b>    LINESTRING (10 0, 10 10)  </b>
+</case>
+<case>
+  <desc>LL - line to multiline</desc>
+  <b>    MULTILINESTRING ((10 0, 10 10), (50 50, 60 60))  </b>
+</case>
+<case>
+  <desc>LL - line to multiline with empty element</desc>
+  <b>    MULTILINESTRING ((10 0, 10 10), EMPTY)  </b>
+</case>
+<case>
+  <desc>PA - point to empty polygon</desc>
+  <a>    POINT (240 160)  </a>
+  <b>    POLYGON EMPTY  </b>
+<test><op name="distance" arg1="A" arg2="B" >    0.0   </op></test>
+<test><op name="distance" arg1="B" arg2="A" >    0.0   </op></test>
 </case>
 <case>
@@ -27,6 +78,7 @@
   <b>    POLYGON ((100 260, 340 180, 100 60, 180 160, 100 260))  </b>
 </case>
 <case>
@@ -34,6 +86,7 @@
   <a>    LINESTRING (40 300, 280 220, 60 160, 140 60)  </a>
   <b>    LINESTRING (140 360, 260 280, 240 120, 120 160)  </b>
 </case>
 <case>
@@ -41,6 +94,7 @@
   <a>    POLYGON ((60 260, 260 180, 100 60, 60 160, 60 260))  </a>
   <b>    POLYGON ((220 280, 120 160, 300 60, 360 220, 220 280))  </b>
 </case>
 <case>
@@ -48,6 +102,7 @@
   <a>    POLYGON ((100 320, 60 120, 240 180, 200 260, 100 320))  </a>
   <b>    POLYGON ((420 320, 280 260, 400 100, 420 320))  </b>
 <test><op name="distance" arg1="A" arg2="B" >   71.55417527999327  </op></test>
+<test><op name="distance" arg1="B" arg2="A" >   71.55417527999327  </op></test>
 </case>
 <case>
@@ -55,13 +110,23 @@
   <a>    MULTIPOLYGON (((40 240, 160 320, 40 380, 40 240)),   ((100 240, 240 60, 40 40, 100 240)))  </a>
   <b>    MULTIPOLYGON (((220 280, 120 160, 300 60, 360 220, 220 280)),   ((240 380, 280 300, 420 340, 240 380)))  </b>
 </case>
 <case>
-  <desc>mAmA - multipolygon with empty component</desc>
+  <desc>mAmA - multipolygon with empty element</desc>
   <a> MULTIPOLYGON (EMPTY, ((98 200, 200 200, 200 99, 98 99, 98 200))) </a>
   <b> POLYGON ((300 200, 400 200, 400 100, 300 100, 300 200)) </b>
 <test><op name="distance" arg1="A" arg2="B" >    100.0   </op></test>
+<test><op name="distance" arg1="B" arg2="A" >    100.0   </op></test>
+</case>
+<case>
+  <desc>GCGC - geometry collections with mixed dimensions</desc>
+  <a> GEOMETRYCOLLECTION (LINESTRING (10 10, 50 10), POINT (90 10)) </a>
+  <b> GEOMETRYCOLLECTION (POLYGON ((90 20, 60 20, 60 50, 90 50, 90 20)), LINESTRING (10 50, 30 70)) </b>
+<test><op name="distance" arg1="A" arg2="B" >    10.0   </op></test>
+<test><op name="distance" arg1="B" arg2="A" >    10.0   </op></test>
 </case>
 </run>
Summary of changes:
 NEWS                                             |  1 +
 src/operation/distance/DistanceOp.cpp            | 16 ++++--
 tests/unit/operation/distance/DistanceOpTest.cpp | 68 ++++++++++++++++++++++++
 tests/xmltester/tests/general/TestDistance.xml   | 67 ++++++++++++++++++++++-
 4 files changed, 146 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
