[geos-commits] [SCM] GEOS branch main updated. 758238d1330a164738f868504afe0ce073dd3a31
git at osgeo.org
git at osgeo.org
Wed Nov 15 14:53:42 PST 2023
the project "GEOS".
The branch, main has been updated
via 758238d1330a164738f868504afe0ce073dd3a31 (commit)
from e45ab35daa746e0a589d394e8fb76f31a79933f9 (commit)
revisions in full, below.
commit 758238d1330a164738f868504afe0ce073dd3a31
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 15 14:52:59 2023 -0800
Go back to ordinary install on Apple MacOS
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 4c522752e..a7b9773f6 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -301,10 +301,11 @@ target_link_libraries(geos PUBLIC geos_cxx_flags PRIVATE $<BUILD_INTERFACE:ryu>)
# ryu is an object library, nothing is actually being linked here. The BUILD_INTERFACE
# switch was necessary to build on AppVeyor (CMake 3.16.2) but not locally (CMake 3.16.3)
-if(APPLE AND BUILD_SHARED_LIBS)
- set_target_properties(geos PROPERTIES
- INSTALL_NAME_DIR "${CMAKE_INSTALL_FULL_LIBDIR}")
-endif()
+# Leave install with an RPATH approach to linking
+#if(APPLE AND BUILD_SHARED_LIBS)
+# set_target_properties(geos PROPERTIES
+# INSTALL_NAME_DIR "${CMAKE_INSTALL_FULL_LIBDIR}")
+#endif()
add_subdirectory(include)
add_subdirectory(src)
@@ -332,10 +333,11 @@ add_library(geos_c "")
add_library(GEOS::geos_c ALIAS geos_c)
target_link_libraries(geos_c PRIVATE geos)
- set_target_properties(geos_c PROPERTIES
-endif()
+# set_target_properties(geos_c PROPERTIES
+#endif()
if(BUILD_SHARED_LIBS)
target_compile_definitions(geos_c
Summary of changes:
CMakeLists.txt | 18 ++++++++++--------
1 file changed, 10 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
