[geos-commits] [SCM] GEOS branch main updated. dcde8ad8a15eabdafd3a7c3ef78d6cf20cf800de
Wed Nov 15 15:48:01 PST 2023
the project "GEOS".
The branch, main has been updated
       via  dcde8ad8a15eabdafd3a7c3ef78d6cf20cf800de (commit)
      from  758238d1330a164738f868504afe0ce073dd3a31 (commit)
revisions in full, below.
commit dcde8ad8a15eabdafd3a7c3ef78d6cf20cf800de
Author: Mike Taves <mwtoews at gmail.com>
Date:   Thu Nov 16 12:46:59 2023 +1300
    Rename Angle::sinCos -> sinCosSnap
diff --git a/NEWS.md b/NEWS.md
index 505ddb2eb..faac38bd8 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -2,7 +2,7 @@
 20xx-xx-xx
 - New things:
-  - Add Angle::sinCos to avoid small errors, e.g. with buffer operations (GH-978, Mike Taves)
+  - Add Angle::sinCosSnap to avoid small errors, e.g. with buffer operations (GH-978, Mike Taves)
 - Breaking Changes
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index f4f2f604e..a2ea53a48 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -218,21 +218,22 @@ public:
     static double diff(double ang1, double ang2);
     /// \brief
-    /// Computes both sin and cos of an angle.
+    /// Computes both sin and cos of an angle, snapping near-zero values
+    /// to zero.
     /// The angle does not need to be normalized. Unlike std::sin
-    /// and std::cos, this method will clip near-zero values to zero
+    /// and std::cos, this method will snap near-zero values to zero
     /// for (e.g.) sin(pi) and cos(pi/2).
     /// @param ang the input angle (in radians)
     /// @param rSin the result of sin(ang)
     /// @param rCos the result of cos(ang)
-    static inline void sinCos(const double ang, double& rSin, double& rCos) {
+    static inline void sinCosSnap(const double ang, double& rSin, double& rCos) {
         // calculate both; may be optimized with FSINCOS instruction
         rSin = std::sin(ang);
         rCos = std::cos(ang);
-        // clip near zero values
+        // snap near-zero values
         if (std::fabs(rSin) < 5e-16) rSin = 0.0;
         if (std::fabs(rCos) < 5e-16) rCos = 0.0;
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 41e22a91c..915bbd954 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -222,7 +222,7 @@ OffsetSegmentGenerator::addLineEndCap(const Coordinate& p0, const Coordinate& p1
         // segment endpoints
         Coordinate squareCapSideOffset;
         double sinangle, cosangle;
-        Angle::sinCos(angle, sinangle, cosangle);
+        Angle::sinCosSnap(angle, sinangle, cosangle);
         squareCapSideOffset.x = fabs(distance) * cosangle;
         squareCapSideOffset.y = fabs(distance) * sinangle;
@@ -283,7 +283,7 @@ OffsetSegmentGenerator::addDirectedFillet(const Coordinate& p, double startAngle
     Coordinate pt;
     for (int i = 0; i < nSegs; i++) {
-        Angle::sinCos(startAngle + directionFactor * i * angleInc, sinangle, cosangle);
+        Angle::sinCosSnap(startAngle + directionFactor * i * angleInc, sinangle, cosangle);
         pt.x = p.x + radius * cosangle;
         pt.y = p.y + radius * sinangle;
         segList.addPt(pt);
@@ -583,7 +583,7 @@ Coordinate
 OffsetSegmentGenerator::project(const Coordinate& pt, double d, double dir)
     double sindir, cosdir;
-    Angle::sinCos(dir, sindir, cosdir);
+    Angle::sinCosSnap(dir, sindir, cosdir);
     double x = pt.x + d * cosdir;
     double y = pt.y + d * sindir;
     return Coordinate(x, y);
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index 4a63e0ac3..141ae5939 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -138,7 +138,7 @@ GeometricShapeFactory::createCircle()
     uint32_t iPt = 0;
     double sinang, cosang;
     for(uint32_t i = 0; i < nPts; i++) {
-        Angle::sinCos(i * Angle::PI_TIMES_2 / nPts, sinang, cosang);
+        Angle::sinCosSnap(i * Angle::PI_TIMES_2 / nPts, sinang, cosang);
         double x = xRadius * cosang + centreX;
         double y = yRadius * sinang + centreY;
         (*pts)[iPt++] = coord(x, y);
@@ -170,7 +170,7 @@ GeometricShapeFactory::createArc(double startAng, double angExtent)
     uint32_t iPt = 0;
-        Angle::sinCos(startAng + i * angInc, sinang, cosang);
+        Angle::sinCosSnap(startAng + i * angInc, sinang, cosang);
@@ -201,7 +201,7 @@ GeometricShapeFactory::createArcPolygon(double startAng, double angExtent)
     (*pts)[iPt++] = coord(centreX, centreY);
diff --git a/tests/unit/algorithm/AngleTest.cpp b/tests/unit/algorithm/AngleTest.cpp
index 02eae99e8..cc889c5e9 100644
--- a/tests/unit/algorithm/AngleTest.cpp
+++ b/tests/unit/algorithm/AngleTest.cpp
@@ -162,7 +162,7 @@ void object::test<5>
         TOL);
-// testSinCos()
+// testSinCosSnap()
 template<>
 template<>
 void object::test<6>
@@ -174,7 +174,7 @@ void object::test<6>
     for (int angdeg = -720; angdeg <= 720; angdeg++) {
         const double ang = Angle::toRadians(angdeg);
-        Angle::sinCos(ang, rSin, rCos);
+        Angle::sinCosSnap(ang, rSin, rCos);
         double cSin = std::sin(ang);
         double cCos = std::cos(ang);
@@ -192,7 +192,7 @@ void object::test<6>
     // use radian increments that don't snap to exact degrees or zero
     for (double angrad = -6.3; angrad < 6.3; angrad += 0.013) {
-        Angle::sinCos(angrad, rSin, rCos);
+        Angle::sinCosSnap(angrad, rSin, rCos);
         ensure_equals(std::to_string(angrad), rSin, std::sin(angrad));
         ensure_equals(std::to_string(angrad), rCos, std::cos(angrad));
Summary of changes:
 NEWS.md                                         | 2 +-
 include/geos/algorithm/Angle.h                  | 9 +++++----
 src/operation/buffer/OffsetSegmentGenerator.cpp | 6 +++---
 src/util/GeometricShapeFactory.cpp              | 6 +++---
 tests/unit/algorithm/AngleTest.cpp              | 6 +++---
 5 files changed, 15 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
