[geos-commits] [SCM] GEOS branch main updated. b3c6777b99fdec10a4cbdf26005697df0111f67d
git at osgeo.org
git at osgeo.org
Fri Nov 17 17:51:18 PST 2023
the project "GEOS".
The branch, main has been updated
via b3c6777b99fdec10a4cbdf26005697df0111f67d (commit)
from 18ba837b7ee44bf1f074df6fbbc1b4bbb7e6dc0c (commit)
revisions in full, below.
commit b3c6777b99fdec10a4cbdf26005697df0111f67d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 17 17:50:16 2023 -0800
Clean up CAPI tests to use the CAPI helper headers more and
be a little more terse.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index a7b9773f6..0538293ca 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -185,8 +185,8 @@ message(STATUS "GEOS: Archives output: ${CMAKE_LIBRARY_OUTPUT_DIRECTORY}")
# ./bin/test_geos_unit
-set(CMAKE_C_FLAGS_ASAN "${CMAKE_C_FLAGS_DEBUG} -fsanitize=address -fno-omit-frame-pointer -fno-common")
-set(CMAKE_CXX_FLAGS_ASAN "${CMAKE_CXX_FLAGS_DEBUG} -fsanitize=address -fno-omit-frame-pointer -fno-common")
+set(CMAKE_C_FLAGS_ASAN "${CMAKE_C_FLAGS_DEBUG} -g -O0 -fsanitize=address -fno-omit-frame-pointer -fno-common")
+set(CMAKE_CXX_FLAGS_ASAN "${CMAKE_CXX_FLAGS_DEBUG} -g -O0 -fsanitize=address -fno-omit-frame-pointer -fno-common")
set(CMAKE_EXE_LINKER_FLAGS_ASAN "${CMAKE_EXE_LINKER_FLAGS_DEBUG} -fsanitize=address")
set(CMAKE_SHARED_LINKER_FLAGS_ASAN "${CMAKE_SHARED_LINKER_FLAGS_DEBUG} -fsanitize=address")
diff --git a/tests/unit/capi/GEOSBoundaryTest.cpp b/tests/unit/capi/GEOSBoundaryTest.cpp
index b65883353..005ab388e 100644
--- a/tests/unit/capi/GEOSBoundaryTest.cpp
+++ b/tests/unit/capi/GEOSBoundaryTest.cpp
@@ -20,19 +20,16 @@ template<>
template<>
void object::test<1>()
- GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
- GEOSSetSRID(input, 3857);
+ input_ = fromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ GEOSSetSRID(input_, 3857);
- GEOSGeometry* result = GEOSBoundary(input);
- GEOSGeometry* expected = GEOSGeomFromWKT("MULTILINESTRING ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ result_ = GEOSBoundary(input_);
+ expected_ = fromWKT("MULTILINESTRING ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
- ensure_equals(GEOSEqualsExact(result, expected, 0), 1);
- ensure_equals(GEOSGetSRID(input), GEOSGetSRID(result));
- GEOSGeom_destroy(input);
- GEOSGeom_destroy(result);
- GEOSGeom_destroy(expected);
+ ensure_geometry_equals_exact(result_, expected_, 0.0);
+ ensure_equals(GEOSGetSRID(input_), GEOSGetSRID(result_));
} // namespace tut
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 8216bcc3a..e44d342e7 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -49,17 +49,14 @@ template<>
template<>
- geom1_ = GEOSGeomFromWKT("POINT EMPTY");
- ensure(nullptr != geom1_);
+ geom1_ = fromWKT("POINT EMPTY");
geom2_ = GEOSBufferWithStyle(geom1_, 1, 8,
GEOSBUF_CAP_ROUND,
GEOSBUF_JOIN_BEVEL,
5.0);
ensure(nullptr != geom2_);
- geom3_ = GEOSGeomFromWKT("POLYGON EMPTY");
- ensure(nullptr != geom3_);
+ geom3_ = fromWKT("POLYGON EMPTY");
ensure_geometry_equals(geom2_, geom3_);
@@ -68,17 +65,14 @@ template<>
template<>
void object::test<2>()
- geom1_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+ geom1_ = fromWKT("LINESTRING EMPTY");
GEOSBUF_CAP_ROUND,
GEOSBUF_JOIN_BEVEL,
5.0);
@@ -87,17 +81,14 @@ template<>
template<>
void object::test<3>()
- geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ geom1_ = fromWKT("POLYGON EMPTY");
GEOSBUF_CAP_ROUND,
GEOSBUF_JOIN_BEVEL,
5.0);
@@ -106,9 +97,7 @@ template<>
template<>
void object::test<4>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 20)");
+ geom1_ = fromWKT("LINESTRING(5 10, 10 20)");
geom2_ = GEOSBuffer(geom1_, 5, 1);
@@ -122,9 +111,7 @@ template<>
template<>
void object::test<5>()
geom2_ = GEOSBuffer(geom1_, 5, 2);
@@ -138,8 +125,7 @@ template<>
template<>
void object::test<6>()
bp_ = GEOSBufferParams_create();
ensure_equals(GEOSBufferParams_setQuadrantSegments(bp_, 20), 1);
@@ -160,8 +146,7 @@ template<>
template<>
void object::test<7>()
geom2_ = GEOSBufferWithStyle(geom1_, 5, 20, GEOSBUF_CAP_FLAT,
GEOSBUF_JOIN_ROUND, 5.0);
@@ -177,8 +162,7 @@ template<>
template<>
void object::test<8>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 10)");
+ geom1_ = fromWKT("LINESTRING(5 10, 10 10)");
@@ -188,8 +172,7 @@ void object::test<8>()
ensure(0 != GEOSArea(geom2_, &area_));
ensure_area(area_, 50.0, 0.001);
- geom3_ = GEOSGeomFromWKT("POLYGON ((10.0 15.0, 10.0 5.0, 5.0 5.0, 5.0 15.0, 10.0 15.0))");
+ geom3_ = fromWKT("POLYGON ((10.0 15.0, 10.0 5.0, 5.0 5.0, 5.0 15.0, 10.0 15.0))");
ensure_geometry_equals(geom2_, geom3_, 0.00001);
@@ -198,8 +181,7 @@ template<>
template<>
void object::test<9>()
geom2_ = GEOSBufferWithStyle(geom1_, 5, 20, GEOSBUF_CAP_SQUARE,
@@ -209,8 +191,7 @@ void object::test<9>()
ensure_area(area_, 150.0, 0.001);
- geom3_ = GEOSGeomFromWKT("POLYGON ((10.0 15.0, 15.0 15.0, 15.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 10.0 15.0))");
+ geom3_ = fromWKT("POLYGON ((10.0 15.0, 15.0 15.0, 15.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 10.0 15.0))");
@@ -220,8 +201,7 @@ template<>
template<>
void object::test<10>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 10, 10 20)");
+ geom1_ = fromWKT("LINESTRING(5 10, 10 10, 10 20)");
@@ -237,9 +217,7 @@ template<>
template<>
void object::test<11>()
GEOSBUF_JOIN_MITRE, 5.0);
@@ -248,8 +226,7 @@ void object::test<11>()
ensure_area(area_, 250.0, 0.001);
- geom3_ = GEOSGeomFromWKT("POLYGON ((5.0 15.0, 5.0 20.0, 5.0 25.0, 15.0 25.0, 15.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 5.0 15.0))");
+ geom3_ = fromWKT("POLYGON ((5.0 15.0, 5.0 20.0, 5.0 25.0, 15.0 25.0, 15.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 5.0 15.0))");
@@ -259,8 +236,7 @@ template<>
template<>
void object::test<12>()
GEOSBUF_JOIN_BEVEL, 5.0);
@@ -269,8 +245,7 @@ void object::test<12>()
ensure_area(area_, 237.5, 0.001);
- geom3_ = GEOSGeomFromWKT("POLYGON ((5.0 15.0, 5.0 20.0, 5.0 25.0, 15.0 25.0, 15.0 10.0, 10.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 5.0 15.0))");
+ geom3_ = fromWKT("POLYGON ((5.0 15.0, 5.0 20.0, 5.0 25.0, 15.0 25.0, 15.0 10.0, 10.0 5.0, 5.0 5.0, 0.0 5.0, 0.0 15.0, 5.0 15.0))");
@@ -281,8 +256,7 @@ template<>
template<>
void object::test<13>()
geom2_ = GEOSBufferWithStyle(geom1_, 5, 200, GEOSBUF_CAP_SQUARE,
GEOSBUF_JOIN_BEVEL, 10.0);
@@ -291,8 +265,7 @@ void object::test<13>()
@@ -301,8 +274,7 @@ template<>
template<>
void object::test<14>()
- geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 10 0, 10 10, 0 0))");
+ geom1_ = fromWKT("POLYGON((0 0, 10 0, 10 10, 0 0))");
geom2_ = GEOSBufferWithStyle(geom1_, 2, 200, GEOSBUF_CAP_FLAT,
GEOSBUF_JOIN_MITRE, 1);
@@ -318,8 +290,7 @@ template<>
template<>
void object::test<15>()
GEOSBUF_JOIN_MITRE, 2);
@@ -335,8 +306,7 @@ template<>
template<>
void object::test<16>()
GEOSBUF_JOIN_MITRE, 3);
@@ -352,8 +322,7 @@ template<>
template<>
void object::test<17>()
GEOSBufferParams_setEndCapStyle(bp_, GEOSBUF_CAP_SQUARE);
@@ -361,8 +330,7 @@ void object::test<17>()
- geom3_ = GEOSGeomFromWKT("POLYGON ((10 12, 12 12, 12 8, 5 8, 3 8, 3 12, 10 12))");
+ geom3_ = fromWKT("POLYGON ((10 12, 12 12, 12 8, 5 8, 3 8, 3 12, 10 12))");
@@ -373,8 +341,7 @@ template<>
template<>
void object::test<18>()
@@ -382,8 +349,7 @@ void object::test<18>()
geom2_ = GEOSBufferWithParams(geom1_, bp_, 2);
- geom3_ = GEOSGeomFromWKT("POLYGON ((10 10, 5 10, 5 12, 10 12, 10 10))");
+ geom3_ = fromWKT("POLYGON ((10 10, 5 10, 5 12, 10 12, 10 10))");
@@ -394,8 +360,7 @@ template<>
template<>
void object::test<19>()
@@ -403,8 +368,7 @@ void object::test<19>()
geom2_ = GEOSBufferWithParams(geom1_, bp_, -2);
- geom3_ = GEOSGeomFromWKT("POLYGON ((5 10, 10 10, 10 8, 5 8, 5 10))");
+ geom3_ = fromWKT("POLYGON ((5 10, 10 10, 10 8, 5 8, 5 10))");
@@ -414,14 +378,12 @@ template<>
template<>
void object::test<20>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0, 10 10)");
+ geom1_ = fromWKT("LINESTRING(0 0, 10 0, 10 10)");
geom2_ = GEOSSingleSidedBuffer(geom1_, 10, 8, GEOSBUF_JOIN_BEVEL, 0, 0);
- geom3_ = GEOSGeomFromWKT("LINESTRING (20.0 10.0, 20.0 0.0, 10.0 -10.0, 0.0 -10.0)");
+ geom3_ = fromWKT("LINESTRING (20.0 10.0, 20.0 0.0, 10.0 -10.0, 0.0 -10.0)");
@@ -432,7 +394,7 @@ template<>
template<>
void object::test<21>()
- geom1_ = GEOSGeomFromWKT("POLYGON((-6503873.862740669 -3656747.43316935, -6481859.9985945 -3656747.43316935, -6481859.9985945 -3688545.2369360398, -6506319.8476458 -3688545.2369360398, -6506319.8476458 -3664085.38788474, -6501427.87783554 -3664085.38788474, -6501427.87783554 -3661639.40297961, -6498981.89293041 -3661639.40297961, -6498981.89293041 -3659193.41807448, -6503873.862740669 -3659193.41807448, -6503873.862740669 -3656747.43316935))");
+ geom1_ = fromWKT("POLYGON((-6503873.862740669 -3656747.43316935, -6481859.9985945 -3656747.43316935, -6481859.9985945 -3688545.2369360398, -6506319.8476458 -3688545.2369360398, -6506319.8476458 -3664085.38788474, -6501427.87783554 -3664085.38788474, -6501427.87783554 -3661639.40297961, -6498981.89293041 -3661639.40297961, -6498981.89293041 -3659193.41807448, -6503873.862740669 -3659193.41807448, -6503873.862740669 -3656747.43316935))");
@@ -452,8 +414,7 @@ template<>
template<>
void object::test<22>()
- geom1_ = GEOSGeomFromWKT("LINEARRING(38.7066196617741550 -28.8266827415760860, -48.9228243285119790 100.6496977731573000, 54.4799195800256510 129.8110447359351000, 108.8101748540030500 45.8263654831350490, 86.7372079193139310 22.3209346883718070, 71.8793256882949690 36.0080540867567290, 55.2741306329362700 34.2630391674088840, 52.0696193064635370 19.4304123529519610, 62.0890652576763390 -3.9267923737325212, 38.7066196617741550 -28.8266827415760860)");
+ geom1_ = fromWKT("LINEARRING(38.7066196617741550 -28.8266827415760860, -48.9228243285119790 100.6496977731573000, 54.4799195800256510 129.8110447359351000, 108.8101748540030500 45.8263654831350490, 86.7372079193139310 22.3209346883718070, 71.8793256882949690 36.0080540867567290, 55.2741306329362700 34.2630391674088840, 52.0696193064635370 19.4304123529519610, 62.0890652576763390 -3.9267923737325212, 38.7066196617741550 -28.8266827415760860)");
geom2_ = GEOSBufferWithStyle(geom1_, 22.532378519833863, 6, GEOSBUF_CAP_FLAT, GEOSBUF_JOIN_MITRE, 5);
@@ -490,12 +451,12 @@ template<>
template<>
void object::test<25>()
- geom1_ = GEOSGeomFromWKT("POLYGON ((4.6664239253667485 4.9470840685113275, 4.666423925366749 4.947084068511328, 3.569508914897422 -10.739531408188364, -9.082056557097435 19.893317266250286, 5.639581102785941 18.86388007810711, 4.6664239253667485 4.9470840685113275))");
+ geom1_ = fromWKT("POLYGON ((4.6664239253667485 4.9470840685113275, 4.666423925366749 4.947084068511328, 3.569508914897422 -10.739531408188364, -9.082056557097435 19.893317266250286, 5.639581102785941 18.86388007810711, 4.6664239253667485 4.9470840685113275))");
geom2_ = GEOSBufferWithStyle(geom1_, -1, 8,
GEOSBUF_CAP_ROUND,
GEOSBUF_JOIN_MITRE,
5);
- geom3_ = GEOSGeomFromWKT("POLYGON ((3.3225774291798533 0.0647708524944821, 3.3225774291798555 0.0647708524944812, 2.8688758567150883 -6.4234639154696263, -7.5416226086581215 18.7831577331451953, 4.5722605787819921 17.9360725015914078, 3.3225774291798533 0.0647708524944821))");
+ geom3_ = fromWKT("POLYGON ((3.3225774291798533 0.0647708524944821, 3.3225774291798555 0.0647708524944812, 2.8688758567150883 -6.4234639154696263, -7.5416226086581215 18.7831577331451953, 4.5722605787819921 17.9360725015914078, 3.3225774291798533 0.0647708524944821))");
ensure_geometry_equals(geom3_, geom2_, 0.001);
diff --git a/tests/unit/capi/GEOSBuildAreaTest.cpp b/tests/unit/capi/GEOSBuildAreaTest.cpp
index a06b7e72f..c7f23ac4b 100644
--- a/tests/unit/capi/GEOSBuildAreaTest.cpp
+++ b/tests/unit/capi/GEOSBuildAreaTest.cpp
@@ -17,11 +17,7 @@ namespace tut {
// Common data used in test cases.
-struct test_capi_buildarea_data : public capitest::utility {
- test_capi_buildarea_data()
+struct test_capi_buildarea_data : public capitest::utility {};
typedef test_group<test_capi_buildarea_data> group;
typedef group::object object;
@@ -34,11 +30,12 @@ group test_capi_buildarea_group("capi::GEOSBuildArea");
template<>
template<>
-void object::test<1>
+void object::test<1>()
- geom1_ = GEOSGeomFromWKT("GEOMETRYCOLLECTION(LINESTRING(0 0,0 1,1 1),LINESTRING(1 1,1 0,0 0))");
- geom2_ = GEOSBuildArea(geom1_);
- ensure_equals(toWKT(geom2_), std::string("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))"));
+ input_ = fromWKT("GEOMETRYCOLLECTION(LINESTRING(0 0,0 1,1 1),LINESTRING(1 1,1 0,0 0))");
+ result_ = GEOSBuildArea(input_);
+ expected_ = fromWKT("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))");
+ ensure_geometry_equals(result_, expected_, 0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index 27f27aa29..0fcdb530d 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -19,25 +19,29 @@ namespace tut {
struct test_capigeosclipbyrect_data : public capitest::utility {
void
- isEqual(GEOSGeom g, const char* exp_wkt)
+ checkClipByRect(
+ const char* wktInput,
+ double xmin, double ymin,
+ double xmax, double ymax,
+ const char* wktExpected)
- ensure(g);
- geom3_ = GEOSGeomFromWKT(exp_wkt);
- bool eq = GEOSEquals(geom3_, g) != 0;
- if(! eq) {
- std::printf("EXP: %s\n", exp_wkt);
- char* obt_wkt = GEOSWKTWriter_write(wktw_, g);
- std::printf("OBT: %s\n", obt_wkt);
- free(obt_wkt);
+ input_ = fromWKT(wktInput);
+ result_ = GEOSClipByRect(input_, xmin, ymin, xmax, ymax);
+ expected_ = fromWKT(wktExpected);
+ bool equal = GEOSEquals(result_, expected_) == 1;
+ if (!equal) {
+ wkt_ = GEOSWKTWriter_write(wktw_, expected_);
+ std::printf("EXP: %s\n", wkt_);
+ GEOSFree(wkt_);
+ wkt_ = GEOSWKTWriter_write(wktw_, result_);
+ std::printf("OBT: %s\n", wkt_);
- ensure(eq);
+ ensure(equal);
- test_capigeosclipbyrect_data()
- GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
typedef test_group<test_capigeosclipbyrect_data> group;
@@ -50,141 +54,181 @@ group test_capigeosclipbyrect_group("capi::GEOSClipByRect");
/// Point outside
-template<> template<> void object::test<1>
+template<>
+template<>
- geom1_ = GEOSGeomFromWKT("POINT(0 0)");
- geom2_ = GEOSClipByRect(geom1_, 10, 10, 20, 20);
- isEqual(geom2_, "POINT EMPTY");
+ checkClipByRect(
+ "POINT(0 0)",
+ 10, 10, 20, 20,
+ "POINT EMPTY"
/// Point inside
-template<> template<> void object::test<2>
+template<>
+template<>
+void object::test<2>()
- geom1_ = GEOSGeomFromWKT("POINT(15 15)");
- isEqual(geom2_, "POINT(15 15)");
+ checkClipByRect(
+ "POINT(15 15)",
+ 10, 10, 20, 20,
+ "POINT(15 15)"
/// Point on boundary
-template<> template<> void object::test<3>
+template<>
+template<>
+void object::test<3>()
- geom1_ = GEOSGeomFromWKT("POINT(15 10)");
+ checkClipByRect(
+ "POINT(15 10)",
+ 10, 10, 20, 20,
+ "POINT EMPTY"
/// Line outside
-template<> template<> void object::test<4>
+template<>
+template<>
+void object::test<4>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, -5 5)");
- isEqual(geom2_, "LINESTRING EMPTY");
+ checkClipByRect(
+ "LINESTRING(0 0, -5 5)",
+ 10, 10, 20, 20,
+ "LINESTRING EMPTY"
/// Line inside
-template<> template<> void object::test<5>
+template<>
+template<>
+void object::test<5>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(15 15, 16 15)");
- isEqual(geom2_, "LINESTRING(15 15, 16 15)");
+ checkClipByRect(
+ "LINESTRING(15 15, 16 15)",
+ 10, 10, 20, 20,
/// Line on boundary
-template<> template<> void object::test<6>
+template<>
+template<>
+void object::test<6>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(10 15, 10 10, 15 10)");
+ checkClipByRect(
+ "LINESTRING(10 15, 10 10, 15 10)",
+ 10, 10, 20, 20,
/// Line splitting rectangle
-template<> template<> void object::test<7>
+template<>
+template<>
+void object::test<7>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(10 5, 25 20)");
- isEqual(geom2_, "LINESTRING (15 10, 20 15)");
+ checkClipByRect(
+ "LINESTRING(10 5, 25 20)",
+ 10, 10, 20, 20,
+ "LINESTRING (15 10, 20 15)"
/// Polygon shell (CCW) fully on rectangle boundary
-template<> template<> void object::test<8>
+template<>
+template<>
+void object::test<8>()
- geom1_ = GEOSGeomFromWKT("POLYGON((10 10, 20 10, 20 20, 10 20, 10 10))");
- isEqual(geom2_, "POLYGON((10 10, 20 10, 20 20, 10 20, 10 10))");
+ checkClipByRect(
+ "POLYGON((10 10, 20 10, 20 20, 10 20, 10 10))",
+ 10, 10, 20, 20,
/// Polygon shell (CW) fully on rectangle boundary
-template<> template<> void object::test<9>
+template<>
+template<>
+void object::test<9>()
- geom1_ = GEOSGeomFromWKT("POLYGON((10 10, 10 20, 20 20, 20 10, 10 10))");
+ checkClipByRect(
+ "POLYGON((10 10, 10 20, 20 20, 20 10, 10 10))",
+ 10, 10, 20, 20,
/// Polygon hole (CCW) fully on rectangle boundary
-template<> template<> void object::test<10>
+template<>
+template<>
+void object::test<10>()
- geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))");
- isEqual(geom2_, "POLYGON EMPTY");
+ checkClipByRect(
+ "POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))",
+ 10, 10, 20, 20,
+ "POLYGON EMPTY"
/// Polygon hole (CW) fully on rectangle boundary
-template<> template<> void object::test<11>
+template<>
+template<>
+void object::test<11>()
- geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 10 20, 20 20, 20 10, 10 10))");
+ checkClipByRect(
+ "POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 10 20, 20 20, 20 10, 10 10))",
+ 10, 10, 20, 20,
+ "POLYGON EMPTY"
/// Polygon fully within rectangle
-template<> template<> void object::test<12>
+template<>
+template<>
+void object::test<12>()
const char* wkt = "POLYGON((1 1, 1 30, 30 30, 30 1, 1 1),(10 10, 20 10, 20 20, 10 20, 10 10))";
- geom1_ = GEOSGeomFromWKT(wkt);
- geom2_ = GEOSClipByRect(geom1_, 0, 0, 40, 40);
- isEqual(geom2_, wkt);
+ checkClipByRect(
+ wkt,
+ 0, 0, 40, 40,
+ wkt);
/// Polygon overlapping rectangle
-template<> template<> void object::test<13>
+template<>
+template<>
+void object::test<13>()
- const char* wkt = "POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))";
- geom2_ = GEOSClipByRect(geom1_, 5, 5, 15, 15);
- isEqual(geom2_, "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))");
+ checkClipByRect(
+ 5, 5, 15, 15,
+ "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))"
/// Clipping invalid polygon
-template<> template<> void object::test<14>
+template<>
+template<>
+void object::test<14>
- const char* wkt = "POLYGON((1410 2055, 1410 2056, 1410 2057, 1410 2055))";
+ geom1_ = fromWKT("POLYGON((1410 2055, 1410 2056, 1410 2057, 1410 2055))");
geom2_ = GEOSClipByRect(geom1_, -8, -8, 2056, 2056);
if (geom2_ != nullptr) {
- char* obt_wkt = GEOSWKTWriter_write(wktw_, geom2_);
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
ensure(nullptr == geom2_);
// Polygon fully covering rectangle
// https://trac.osgeo.org/postgis/ticket/4904
-template<> template<> void object::test<15>
+template<>
+template<>
+void object::test<15>
// POLYGON((0 0,10 0,10 10,0 10))
@@ -195,16 +239,17 @@ template<> template<> void object::test<15>
GEOSCoordSeq_setXY(cs, 2, 10, 10);
GEOSCoordSeq_setXY(cs, 3, 0, 10);
GEOSCoordSeq_setXY(cs, 4, 0, 0);
- GEOSGeometry *shell = GEOSGeom_createLinearRing(cs);
- geom1_ = GEOSGeom_createPolygon(shell, NULL, 0);
- geom2_ = GEOSClipByRect(geom1_, 2, 2, 5, 5);
- isEqual(geom2_, "POLYGON ((2 2, 2 5, 5 5, 5 2, 2 2))");
+ GEOSGeometry *shell = GEOSGeom_createLinearRing(cs); // take ownership of cs
+ input_ = GEOSGeom_createPolygon(shell, NULL, 0); // take ownership of shell
+ result_ = GEOSClipByRect(input_, 2, 2, 5, 5);
+ expected_ = GEOSGeomFromWKT("POLYGON ((2 2, 2 5, 5 5, 5 2, 2 2))");
+ ensure_geometry_equals(result_, expected_);
/// Empty combinations - always return GEOMETRYCOLLECTION EMPTY
-template<> template<> void object::test<16>
+template<>
+template<>
+void object::test<16>
std::vector<const char*> variants{
@@ -218,14 +263,11 @@ template<> template<> void object::test<16>
"LINEARRING EMPTY",
for (const auto& wkt : variants) {
- GEOSGeom geom1 = GEOSGeomFromWKT(wkt);
- GEOSGeom geom2 = GEOSClipByRect(geom1, 0, 0, 1, 1);
- char* obt_wkt = GEOSWKTWriter_write(wktw_, geom2);
- std::string obt_wkt2(obt_wkt);
- GEOSFree(obt_wkt);
- GEOSGeom_destroy(geom1);
- GEOSGeom_destroy(geom2);
- ensure_equals(obt_wkt2, "GEOMETRYCOLLECTION EMPTY");
+ GEOSGeometry* a = fromWKT(wkt);
+ GEOSGeometry* b = GEOSClipByRect(a, 0, 0, 1, 1);
+ ensure("GEOS_GEOMETRYCOLLECTION", GEOSGeomTypeId(b) == GEOS_GEOMETRYCOLLECTION);
+ GEOSGeom_destroy(a);
+ GEOSGeom_destroy(b);
diff --git a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
index a5a485e9d..8de6baf54 100644
--- a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
@@ -34,11 +34,10 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("POLYGON EMPTY");
- ensure(nullptr != input_);
+ input_ = fromWKT("POLYGON EMPTY");
geom1_ = GEOSConcaveHullOfPolygons(input_, 0.7, false, false);
- expected_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ expected_ = fromWKT("POLYGON EMPTY");
ensure_geometry_equals(geom1_, expected_);
@@ -46,11 +45,10 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)))");
+ input_ = fromWKT("MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)))");
- expected_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)))");
+ expected_ = fromWKT("MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)))");
diff --git a/tests/unit/capi/GEOSConcaveHullTest.cpp b/tests/unit/capi/GEOSConcaveHullTest.cpp
index ec2eae673..690ce5425 100644
--- a/tests/unit/capi/GEOSConcaveHullTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullTest.cpp
@@ -33,34 +33,24 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("MULTIPOINT ((10 90), (10 10), (90 10), (90 90), (40 40), (60 30), (30 70), (40 60), (60 50), (60 72), (47 66), (90 60))");
- expected_ = GEOSGeomFromWKT("POLYGON ((30 70, 10 90, 60 72, 90 90, 90 60, 90 10, 60 30, 10 10, 40 40, 60 50, 47 66, 40 60, 30 70))");
- ensure(nullptr != expected_);
- GEOSGeometry* output = GEOSConcaveHull(input_, 0, 0);
- ensure(nullptr != output);
- ensure(0 == GEOSisEmpty(output));
- ensure_geometry_equals(output, expected_);
- GEOSGeom_destroy(output);
+ input_ = fromWKT("MULTIPOINT ((10 90), (10 10), (90 10), (90 90), (40 40), (60 30), (30 70), (40 60), (60 50), (60 72), (47 66), (90 60))");
+ expected_ = fromWKT("POLYGON ((30 70, 10 90, 60 72, 90 90, 90 60, 90 10, 60 30, 10 10, 40 40, 60 50, 47 66, 40 60, 30 70))");
+ result_ = GEOSConcaveHull(input_, 0, 0);
+ ensure(nullptr != result_);
+ ensure(0 == GEOSisEmpty(result_));
template<>
template<>
- expected_ = GEOSGeomFromWKT("POLYGON ((30 70, 10 90, 60 72, 90 90, 90 60, 90 10, 60 30, 10 10, 40 40, 30 70))");
- GEOSGeometry* output = GEOSConcaveHullByLength(input_, 50, 0);
+ expected_ = fromWKT("POLYGON ((30 70, 10 90, 60 72, 90 90, 90 60, 90 10, 60 30, 10 10, 40 40, 30 70))");
+ result_ = GEOSConcaveHullByLength(input_, 50, 0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
index 81e3c7d90..24687a6b8 100644
--- a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
@@ -38,7 +38,7 @@ template<>
ensure_equals(GEOSisEmpty(geom1_), 1);
geom2_ = GEOSConstrainedDelaunayTriangulation(geom1_);
@@ -53,7 +53,7 @@ template<>
+ geom1_ = fromWKT("POINT(0 0)");
ensure_equals(GEOSisEmpty(geom2_), 1);
ensure_equals(GEOSGeomTypeId(geom2_), GEOS_GEOMETRYCOLLECTION);
@@ -65,8 +65,8 @@ template<>
- geom1_ = GEOSGeomFromWKT("POLYGON ((10 10, 20 40, 90 90, 90 10, 10 10))");
- geom2_ = GEOSGeomFromWKT("GEOMETRYCOLLECTION (POLYGON ((10 10, 20 40, 90 10, 10 10)), POLYGON ((90 90, 20 40, 90 10, 90 90)))");
+ geom1_ = fromWKT("POLYGON ((10 10, 20 40, 90 90, 90 10, 10 10))");
+ geom2_ = fromWKT("GEOMETRYCOLLECTION (POLYGON ((10 10, 20 40, 90 10, 10 10)), POLYGON ((90 90, 20 40, 90 10, 90 90)))");
geom3_ = GEOSConstrainedDelaunayTriangulation(geom1_);
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index 03a59c36d..7dd017ff7 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -37,18 +37,13 @@ template<>
- geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
- ensure(nullptr != geom2_);
+ geom2_ = fromWKT("POLYGON EMPTY");
char const r1 = GEOSContains(geom1_, geom2_);
ensure_equals(r1, 0);
char const r2 = GEOSContains(geom2_, geom1_);
ensure_equals(r2, 0);
@@ -57,18 +52,13 @@ template<>
- geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
- geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ geom1_ = fromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
+ geom2_ = fromWKT("POINT(2 2)");
ensure_equals(int(r1), 1);
ensure_equals(int(r2), 0);
@@ -77,18 +67,13 @@ template<>
- geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
- geom2_ = GEOSGeomFromWKT("POLYGON((1 1,1 2,2 2,2 1,1 1))");
+ geom1_ = fromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
+ geom2_ = fromWKT("POLYGON((1 1,1 2,2 2,2 1,1 1))");
diff --git a/tests/unit/capi/GEOSConvexHullTest.cpp b/tests/unit/capi/GEOSConvexHullTest.cpp
index f4a162744..9b99c8cad 100644
--- a/tests/unit/capi/GEOSConvexHullTest.cpp
+++ b/tests/unit/capi/GEOSConvexHullTest.cpp
@@ -34,17 +34,12 @@ template<>
- input_ = GEOSGeomFromWKT("MULTIPOINT ((130 240), (130 240), (570 240), (570 290), (650 240))");
- expected_ = GEOSGeomFromWKT("POLYGON ((130 240, 570 290, 650 240, 130 240))");
- GEOSGeometry* output = GEOSConvexHull(input_);
+ input_ = fromWKT("MULTIPOINT ((130 240), (130 240), (570 240), (570 290), (650 240))");
+ expected_ = fromWKT("POLYGON ((130 240, 570 290, 650 240, 130 240))");
+ result_ = GEOSConvexHull(input_);
} // namespace tut
diff --git a/tests/unit/capi/GEOSCoveredByTest.cpp b/tests/unit/capi/GEOSCoveredByTest.cpp
index 19f4a084c..6f9bfc947 100644
--- a/tests/unit/capi/GEOSCoveredByTest.cpp
+++ b/tests/unit/capi/GEOSCoveredByTest.cpp
@@ -21,11 +21,8 @@ template<>
geom1_ = fromWKT("POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))");
geom2_ = fromWKT("POLYGON ((5 5, 5 7, 7 7, 7 5, 5 5))");
geom3_ = fromWKT("POLYGON ((20 20, 20 30, 30 30, 30 20, 20 20))");
ensure_equals(1, GEOSCoveredBy(geom2_, geom1_));
ensure_equals(0, GEOSCoveredBy(geom1_, geom2_));
diff --git a/tests/unit/capi/GEOSCoversTest.cpp b/tests/unit/capi/GEOSCoversTest.cpp
index e7c9b92b7..ee976743a 100644
--- a/tests/unit/capi/GEOSCoversTest.cpp
+++ b/tests/unit/capi/GEOSCoversTest.cpp
ensure_equals(1, GEOSCovers(geom1_, geom2_));
ensure_equals(0, GEOSCovers(geom2_, geom1_));
diff --git a/tests/unit/capi/GEOSCrossesTest.cpp b/tests/unit/capi/GEOSCrossesTest.cpp
index 641c177f7..ab19caa9f 100644
--- a/tests/unit/capi/GEOSCrossesTest.cpp
+++ b/tests/unit/capi/GEOSCrossesTest.cpp
geom1_ = fromWKT("LINESTRING (1 1, 10 10)");
geom2_ = fromWKT("LINESTRING (10 1, 1 10)");
geom3_ = fromWKT("LINESTRING (20 20, 30 30)");
ensure_equals(1, GEOSCrosses(geom1_, geom2_));
ensure_equals(1, GEOSCrosses(geom2_, geom1_));
diff --git a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
index c55f093fe..a5568e59e 100644
--- a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
@@ -47,69 +47,54 @@ void object::test<1>
- GEOSGeom_destroy(geom2_);
- geom2_ = GEOSDelaunayTriangulation(geom1_, 0, 1);
- ensure_equals(GEOSisEmpty(geom2_), 1);
- ensure_equals(GEOSGeomTypeId(geom2_), GEOS_MULTILINESTRING);
+ geom3_ = GEOSDelaunayTriangulation(geom1_, 0, 1);
+ ensure_equals(GEOSisEmpty(geom3_), 1);
+ ensure_equals(GEOSGeomTypeId(geom3_), GEOS_MULTILINESTRING);
// Single point
template<>
template<>
-void object::test<2>
geom2_ = GEOSDelaunayTriangulation(geom1_, 0, 0);
// Three collinear points
template<>
template<>
-void object::test<3>
- geom1_ = GEOSGeomFromWKT("MULTIPOINT((0 0), (5 0), (10 0))");
+ geom1_ = fromWKT("MULTIPOINT((0 0), (5 0), (10 0))");
- char* wkt_c = GEOSWKTWriter_write(wktw_, geom2_);
- std::string out(wkt_c);
- free(wkt_c);
- ensure_equals(out, "MULTILINESTRING ((5 0, 10 0), (0 0, 5 0))");
+ ensure_geometry_equals(geom3_, "MULTILINESTRING ((5 0, 10 0), (0 0, 5 0))");
// Three points
template<>
template<>
-void object::test<4>
- geom1_ = GEOSGeomFromWKT("MULTIPOINT((0 0), (5 0), (10 10))");
+ geom1_ = fromWKT("MULTIPOINT((0 0), (5 0), (10 10))");
ensure(geom2_ != nullptr);
- ensure_geometry_equals(geom2_,
- "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 10, 5 0, 0 0)))");
+ ensure_geometry_equals(geom2_, "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 10, 5 0, 0 0)))");
- "MULTILINESTRING ((5 0, 10 10), (0 0, 10 10), (0 0, 5 0))");
+ ensure_geometry_equals(geom3_, "MULTILINESTRING ((5 0, 10 10), (0 0, 10 10), (0 0, 5 0))");
// A polygon with a hole
@@ -118,16 +103,15 @@ template<>
- geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 8.5 1, 10 10, 0.5 9, 0 0),(2 2, 3 8, 7 8, 8 2, 2 2))");
+ geom1_ = fromWKT("POLYGON((0 0, 8.5 1, 10 10, 0.5 9, 0 0),(2 2, 3 8, 7 8, 8 2, 2 2))");
"GEOMETRYCOLLECTION (POLYGON ((8 2, 10 10, 8.5 1, 8 2)), POLYGON ((7 8, 10 10, 8 2, 7 8)), POLYGON ((3 8, 10 10, 7 8, 3 8)), POLYGON ((2 2, 8 2, 8.5 1, 2 2)), POLYGON ((2 2, 7 8, 8 2, 2 2)), POLYGON ((2 2, 3 8, 7 8, 2 2)), POLYGON ((0.5 9, 10 10, 3 8, 0.5 9)), POLYGON ((0.5 9, 3 8, 2 2, 0.5 9)), POLYGON ((0 0, 2 2, 8.5 1, 0 0)), POLYGON ((0 0, 0.5 9, 2 2, 0 0)))");
"MULTILINESTRING ((8.5 1, 10 10), (8 2, 10 10), (8 2, 8.5 1), (7 8, 10 10), (7 8, 8 2), (3 8, 10 10), (3 8, 7 8), (2 2, 8.5 1), (2 2, 8 2), (2 2, 7 8), (2 2, 3 8), (0.5 9, 10 10), (0.5 9, 3 8), (0.5 9, 2 2), (0 0, 8.5 1), (0 0, 2 2), (0 0, 0.5 9))");
@@ -137,9 +121,8 @@ template<>
- geom1_ = GEOSGeomFromWKT("MULTIPOINT((0 0), (10 0), (10 10), (11 10))");
+ geom1_ = fromWKT("MULTIPOINT((0 0), (10 0), (10 10), (11 10))");
geom2_ = GEOSDelaunayTriangulation(geom1_, 2, 1);
"MULTILINESTRING ((10 0, 10 10), (0 0, 10 10), (0 0, 10 0))");
diff --git a/tests/unit/capi/GEOSDensifyTest.cpp b/tests/unit/capi/GEOSDensifyTest.cpp
index 006a36834..cd11e1cea 100644
--- a/tests/unit/capi/GEOSDensifyTest.cpp
+++ b/tests/unit/capi/GEOSDensifyTest.cpp
@@ -14,26 +14,23 @@ namespace tut {
struct test_capigeosdensify_data : public capitest::utility
- void testDensify(const std::string &wkt_input,
- const std::string &wkt_output,
- double tolerance)
+ void testDensify(
+ const std::string &wkt_input,
+ const std::string &wkt_output,
+ double tolerance)
int srid = 3857;
- GEOSGeometry *input = GEOSGeomFromWKT(wkt_input.c_str());
- GEOSSetSRID(input, srid);
+ input_ = fromWKT(wkt_input.c_str());
+ GEOSSetSRID(input_, srid);
- GEOSGeometry *expected = GEOSGeomFromWKT(wkt_output.c_str());
+ expected_ = fromWKT(wkt_output.c_str());
- GEOSGeometry *result = GEOSDensify(input, tolerance);
- ensure("result not NULL", result != nullptr);
+ result_ = GEOSDensify(input_, tolerance);
+ ensure("result not NULL", result_ != nullptr);
- ensure_geometry_equals(result, expected);
- ensure_equals("result SRID == expected SRID", GEOSGetSRID(result), srid);
+ ensure_equals("result SRID == expected SRID", GEOSGetSRID(result_), srid);
@@ -153,15 +150,13 @@ template <>
template <>
- GEOSGeometry *input = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+ input_ = fromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
- GEOSGeometry *result = GEOSDensify(input, 0.0);
- ensure("result expected to be NULL", result == nullptr);
+ result_ = GEOSDensify(input_, 0.0);
+ ensure("result expected to be NULL", result_ == nullptr);
- result = GEOSDensify(input, -1.0);
+ result_ = GEOSDensify(input_, -1.0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSDifferencePrecTest.cpp b/tests/unit/capi/GEOSDifferencePrecTest.cpp
index 45e4b82f0..ecd4759b0 100644
--- a/tests/unit/capi/GEOSDifferencePrecTest.cpp
+++ b/tests/unit/capi/GEOSDifferencePrecTest.cpp
@@ -20,24 +20,15 @@ template<>
template<>
- GEOSGeometry* a = GEOSGeomFromWKT("LINESTRING (2 8, 10 8)");
- GEOSGeometry* b = GEOSGeomFromWKT("LINESTRING (3.9 8.1, 6.1 7.9)");
+ geom1_ = fromWKT("LINESTRING (2 8, 10 8)");
+ geom2_ = fromWKT("LINESTRING (3.9 8.1, 6.1 7.9)");
+ GEOSSetSRID(geom1_, 4326);
- ensure(a);
- ensure(b);
+ result_ = GEOSDifferencePrec(geom1_, geom2_, 2);
+ ensure(result_);
- GEOSSetSRID(a, 4326);
- GEOSGeometry* result = GEOSDifferencePrec(a, b, 2);
- ensure(result);
- ensure_geometry_equals(result, "MULTILINESTRING ((6 8, 10 8), (2 8, 4 8))");
- ensure_equals(GEOSGetSRID(a), GEOSGetSRID(result));
- GEOSGeom_destroy(a);
- GEOSGeom_destroy(b);
+ ensure_geometry_equals(result_, "MULTILINESTRING ((6 8, 10 8), (2 8, 4 8))");
+ ensure_equals(GEOSGetSRID(geom1_), GEOSGetSRID(result_));
} // namespace tut
diff --git a/tests/unit/capi/GEOSDifferenceTest.cpp b/tests/unit/capi/GEOSDifferenceTest.cpp
index b2ff86a2c..efaf1ad0d 100644
--- a/tests/unit/capi/GEOSDifferenceTest.cpp
+++ b/tests/unit/capi/GEOSDifferenceTest.cpp
@@ -20,24 +20,16 @@ template<>
template<>
- GEOSGeometry* b = GEOSGeomFromWKT("LINESTRING (4 8, 6 8)");
+ geom2_ = fromWKT("LINESTRING (4 8, 6 8)");
- ensure(a);
- ensure(b);
+ result_ = GEOSDifference(geom1_, geom2_);
+ ensure(result_);
- GEOSGeometry* result = GEOSDifference(a, b);
- ensure(result);
} // namespace tut
diff --git a/tests/unit/capi/GEOSDisjointSubsetUnionTest.cpp b/tests/unit/capi/GEOSDisjointSubsetUnionTest.cpp
index 4099c15b5..456b39ee9 100644
--- a/tests/unit/capi/GEOSDisjointSubsetUnionTest.cpp
+++ b/tests/unit/capi/GEOSDisjointSubsetUnionTest.cpp
@@ -27,7 +27,7 @@ template<>
template<>
GEOSSetSRID(input_, 1234);
result_ = GEOSDisjointSubsetUnion(input_);
@@ -40,10 +40,9 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("MULTIPOLYGON (((0 0, 1 0, 1 1, 0 1, 0 0)), ((1 0, 2 0, 2 1, 1 1, 1 0)), ((3 3, 4 3, 4 4, 3 3)))");
- expected_ = GEOSGeomFromWKT("MULTIPOLYGON (((0 0, 1 0, 2 0, 2 1, 1 1, 0 1, 0 0)), ((3 3, 4 3, 4 4, 3 3)))");
+ input_ = fromWKT("MULTIPOLYGON (((0 0, 1 0, 1 1, 0 1, 0 0)), ((1 0, 2 0, 2 1, 1 1, 1 0)), ((3 3, 4 3, 4 4, 3 3)))");
+ expected_ = fromWKT("MULTIPOLYGON (((0 0, 1 0, 2 0, 2 1, 1 1, 0 1, 0 0)), ((3 3, 4 3, 4 4, 3 3)))");
diff --git a/tests/unit/capi/GEOSDisjointTest.cpp b/tests/unit/capi/GEOSDisjointTest.cpp
index 1a127f4be..cb8fde2a2 100644
--- a/tests/unit/capi/GEOSDisjointTest.cpp
+++ b/tests/unit/capi/GEOSDisjointTest.cpp
geom1_ = fromWKT("POINT (0 0)");
- ensure(geom1_);
geom2_ = fromWKT("LINESTRING(2 0, 0 2)");
- ensure(geom2_);
geom3_ = fromWKT("LINESTRING(0 0, 0 2)");
- ensure(geom3_);
ensure_equals(1, GEOSDisjoint(geom1_, geom2_));
ensure_equals(0, GEOSDisjoint(geom1_, geom3_));
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index 4c953c4bf..5bf03c90b 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -22,8 +22,33 @@ namespace tut {
struct test_capigeosdistance_data : public capitest::utility {
- test_capigeosdistance_data() {
+ test_capigeosdistance_data() {};
+ GEOSGeometry*
+ random_polygon(double x, double y, double r, std::size_t num_points)
+ std::vector<double> angle(num_points);
+ std::vector<double> radius(num_points);
+ for(std::size_t i = 0; i < num_points; i++) {
+ angle[i] = 2 * geos::MATH_PI * std::rand() / RAND_MAX;
+ radius[i] = r * std::rand() / RAND_MAX;
+ std::sort(angle.begin(), angle.end());
+ GEOSCoordSequence* seq_1 = GEOSCoordSeq_create(static_cast<unsigned int>(num_points), 2);
+ for(unsigned int i = 0; i < num_points; i++) {
+ auto idx = i == (num_points - 1) ? 0 : i;
+ GEOSCoordSeq_setX(seq_1, i, x + radius[idx] * cos(angle[idx]));
+ GEOSCoordSeq_setY(seq_1, i, y + radius[idx] * sin(angle[idx]));
+ return GEOSGeom_createPolygon(GEOSGeom_createLinearRing(seq_1), nullptr, 0);
typedef test_group<test_capigeosdistance_data> group;
@@ -41,8 +66,8 @@ template<>
- geom1_ = GEOSGeomFromWKT("POINT(10 10)");
- geom2_ = GEOSGeomFromWKT("POINT(3 6)");
+ geom1_ = fromWKT("POINT(10 10)");
+ geom2_ = fromWKT("POINT(3 6)");
double dist;
int ret = GEOSDistance(geom1_, geom2_, &dist);
@@ -51,31 +76,6 @@ void object::test<1>
ensure_distance(dist, 8.06225774829855, 1e-12);
-GEOSGeometry*
-random_polygon(double x, double y, double r, std::size_t num_points)
- std::vector<double> angle(num_points);
- std::vector<double> radius(num_points);
- for(std::size_t i = 0; i < num_points; i++) {
- angle[i] = 2 * geos::MATH_PI * std::rand() / RAND_MAX;
- radius[i] = r * std::rand() / RAND_MAX;
- std::sort(angle.begin(), angle.end());
- GEOSCoordSequence* seq_1 = GEOSCoordSeq_create(static_cast<unsigned int>(num_points), 2);
- for(unsigned int i = 0; i < num_points; i++) {
- auto idx = i == (num_points - 1) ? 0 : i;
- GEOSCoordSeq_setX(seq_1, i, x + radius[idx] * cos(angle[idx]));
- GEOSCoordSeq_setY(seq_1, i, y + radius[idx] * sin(angle[idx]));
- return GEOSGeom_createPolygon(GEOSGeom_createLinearRing(seq_1), nullptr, 0);
/* Generate two complex polygons and verify that GEOSDistance and GEOSDistanceIndexed
* return identical results.
@@ -86,17 +86,14 @@ void object::test<2>
std::srand(12345);
- GEOSGeometry* g1 = random_polygon(-3, -8, 7, 1000);
- GEOSGeometry* g2 = random_polygon(14, 22, 6, 500);
+ geom1_ = random_polygon(-3, -8, 7, 1000);
+ geom2_ = random_polygon(14, 22, 6, 500);
double d_raw, d_indexed;
- ensure(GEOSDistance(g1, g2, &d_raw) != 0);
- ensure(GEOSDistanceIndexed(g1, g2, &d_indexed) != 0);
+ ensure(GEOSDistance(geom1_, geom2_, &d_raw) != 0);
+ ensure(GEOSDistanceIndexed(geom1_, geom2_, &d_indexed) != 0);
ensure_equals(d_indexed, d_raw);
- GEOSGeom_destroy(g1);
- GEOSGeom_destroy(g2);
// https://github.com/libgeos/geos/issues/295
@@ -105,16 +102,13 @@ template<>
- GEOSGeometry* g1 = GEOSGeomFromWKT("MultiPolygon Z (EMPTY,((-0.14000000000000001 44.89999999999999858 0, -0.14699999999999999 44.90400000000000347 0, -0.14729999999999999 44.90500000000000114 0, -0.14000000000000001 44.89999999999999858 0)))");
- GEOSGeometry* g2 = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ geom1_ = fromWKT("MultiPolygon Z (EMPTY,((-0.14000000000000001 44.89999999999999858 0, -0.14699999999999999 44.90400000000000347 0, -0.14729999999999999 44.90500000000000114 0, -0.14000000000000001 44.89999999999999858 0)))");
+ geom2_ = fromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
double d;
- int status = GEOSDistance(g1, g2, &d);
+ int status = GEOSDistance(geom1_, geom2_, &d);
ensure_equals(status, 1);
// point distance does not raise floating point exception
@@ -123,14 +117,14 @@ template<>
- GEOSGeometry* g1 = GEOSGeomFromWKT("POINT (0 0)");
- GEOSGeometry* g2 = GEOSGeomFromWKT("POINT (1 1)");
+ geom1_ = fromWKT("POINT (0 0)");
+ geom2_ = fromWKT("POINT (1 1)");
// clear all floating point exceptions
feclearexcept (FE_ALL_EXCEPT);
double d;
ensure_equals(d, std::sqrt(2));
@@ -138,9 +132,6 @@ void object::test<4>
// check for floating point overflow exceptions
int raised = fetestexcept(FE_OVERFLOW);
ensure_equals(raised & FE_OVERFLOW, 0);
// same distance between boundables should not raise floating point exception
@@ -149,14 +140,14 @@ template<>
- GEOSGeometry* g1 = GEOSGeomFromWKT("LINESTRING (0 0, 1 1)");
- GEOSGeometry* g2 = GEOSGeomFromWKT("LINESTRING (2 1, 1 2)");
+ geom1_ = fromWKT("LINESTRING (0 0, 1 1)");
+ geom2_ = fromWKT("LINESTRING (2 1, 1 2)");
double d;
// ensure_equals(d, std::sqrt(2));
@@ -164,9 +155,6 @@ void object::test<5>
} // namespace tut
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index 19218b13f..a76aa05e9 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -21,22 +21,16 @@ namespace tut {
struct test_capigeosdistancewithin_data : public capitest::utility {
- void testGEOSDistanceWithin(const char* wkt1, const char* wkt2,
- double distance, char expectedResult) {
- GEOSGeometry *input1 = GEOSGeomFromWKT(wkt1);
- ensure(input1 != nullptr);
- GEOSGeometry *input2 = GEOSGeomFromWKT(wkt2);
- ensure(input2 != nullptr);
- char ret = GEOSDistanceWithin(input1, input2, distance);
- GEOSGeom_destroy(input1);
- GEOSGeom_destroy(input2);
- ensure_equals("return code", (int)ret, (int)expectedResult);
+ void testGEOSDistanceWithin(
+ const char* wkt1, const char* wkt2,
+ double distance, char expectedResult)
+ geom1_ = fromWKT(wkt1);
+ geom2_ = fromWKT(wkt2);
+ char ret = GEOSDistanceWithin(geom1_, geom2_, distance);
+ ensure_equals("return code", (int)ret, (int)expectedResult);
typedef test_group<test_capigeosdistancewithin_data> group;
diff --git a/tests/unit/capi/GEOSEnvelopeTest.cpp b/tests/unit/capi/GEOSEnvelopeTest.cpp
index ce609a1bc..99b603103 100644
--- a/tests/unit/capi/GEOSEnvelopeTest.cpp
+++ b/tests/unit/capi/GEOSEnvelopeTest.cpp
@@ -9,7 +9,18 @@ namespace tut {
// Test Group
-struct test_geosenvelope_data : public capitest::utility {};
+struct test_geosenvelope_data : public capitest::utility
+ void
+ checkEnvelope(const char* wktIn, const char* wktExp)
+ input_ = fromWKT(wktIn);
+ result_ = GEOSEnvelope(input_);
+ expected_ = fromWKT(wktExp);
typedef test_group<test_geosenvelope_data> group;
@@ -19,72 +30,42 @@ group test_geosenvelope("capi::GEOSEnvelope");
// non-degenerate input
template<>
template<>
- GEOSGeometry* input = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
- GEOSGeometry* result = GEOSEnvelope(input);
- GEOSGeometry* expected = GEOSGeomFromWKT("POLYGON ((1 -2, 9 -2, 9 5, 1 5, 1 -2))");
+ checkEnvelope(
+ "LINESTRING (1 2, 4 5, 9 -2)",
+ "POLYGON ((1 -2, 9 -2, 9 5, 1 5, 1 -2))"
// point input
template<>
template<>
- GEOSGeometry* input = GEOSGeomFromWKT("POINT (3 8)");
- GEOSGeometry* expected = GEOSGeomFromWKT("POINT (3 8)");
+ checkEnvelope(
+ "POINT (3 8)",
+ "POINT (3 8)");
// empty point input
template<>
template<>
- GEOSGeometry* input = GEOSGeomFromWKT("POINT EMPTY");
- GEOSGeometry* expected = GEOSGeomFromWKT("POINT EMPTY");
+ checkEnvelope(
+ "POINT EMPTY",
+ "POINT EMPTY");
// empty polygon input
template<>
template<>
- GEOSGeometry* input = GEOSGeomFromWKT("POLYGON EMPTY");
+ checkEnvelope(
+ "POLYGON EMPTY",
+ "POINT EMPTY");
} // namespace tut
Summary of changes:
CMakeLists.txt | 4 +-
tests/unit/capi/GEOSBoundaryTest.cpp | 17 +-
tests/unit/capi/GEOSBufferTest.cpp | 111 +++-------
tests/unit/capi/GEOSBuildAreaTest.cpp | 17 +-
tests/unit/capi/GEOSClipByRectTest.cpp | 244 ++++++++++++---------
tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp | 10 +-
tests/unit/capi/GEOSConcaveHullTest.cpp | 34 +--
.../GEOSConstrainedDelaunayTriangulationTest.cpp | 8 +-
tests/unit/capi/GEOSContainsTest.cpp | 27 +--
tests/unit/capi/GEOSConvexHullTest.cpp | 17 +-
tests/unit/capi/GEOSCoveredByTest.cpp | 3 -
tests/unit/capi/GEOSCoversTest.cpp | 3 -
tests/unit/capi/GEOSCrossesTest.cpp | 3 -
tests/unit/capi/GEOSDelaunayTriangulationTest.cpp | 61 ++----
tests/unit/capi/GEOSDensifyTest.cpp | 37 ++--
tests/unit/capi/GEOSDifferencePrecTest.cpp | 23 +-
tests/unit/capi/GEOSDifferenceTest.cpp | 22 +-
tests/unit/capi/GEOSDisjointSubsetUnionTest.cpp | 7 +-
tests/unit/capi/GEOSDisjointTest.cpp | 3 -
tests/unit/capi/GEOSDistanceTest.cpp | 94 ++++----
tests/unit/capi/GEOSDistanceWithinTest.cpp | 24 +-
tests/unit/capi/GEOSEnvelopeTest.cpp | 77 +++----
22 files changed, 361 insertions(+), 485 deletions(-)
hooks/post-receive
More information about the geos-commits
