[geos-commits] [SCM] GEOS branch main updated. cfad2ab8f338045d0862dde9f205eca0bdc99f32
git at osgeo.org
git at osgeo.org
Mon Nov 20 10:51:41 PST 2023
the project "GEOS".
The branch, main has been updated
via cfad2ab8f338045d0862dde9f205eca0bdc99f32 (commit)
from b3c6777b99fdec10a4cbdf26005697df0111f67d (commit)
revisions in full, below.
commit cfad2ab8f338045d0862dde9f205eca0bdc99f32
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Nov 20 10:50:53 2023 -0800
Clean up CAPI tests to use the CAPI helper headers more and be a little more terse.
diff --git a/tests/unit/capi/GEOSEqualsTest.cpp b/tests/unit/capi/GEOSEqualsTest.cpp
index bc9cad63a..793207f49 100644
--- a/tests/unit/capi/GEOSEqualsTest.cpp
+++ b/tests/unit/capi/GEOSEqualsTest.cpp
@@ -35,19 +35,11 @@ template<>
void object::test<1>
- geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
- geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ geom1_ = fromWKT("POLYGON EMPTY");
+ geom2_ = fromWKT("POLYGON EMPTY");
- ensure(nullptr != geom1_);
- ensure(nullptr != geom2_);
- char const r1 = GEOSEquals(geom1_, geom2_);
- ensure_equals(r1, 1);
- char const r2 = GEOSEquals(geom2_, geom1_);
- ensure_equals(r2, 1);
+ ensure_equals(GEOSEquals(geom1_, geom2_), 1);
+ ensure_equals(GEOSEquals(geom2_, geom1_), 1);
template<>
@@ -55,18 +47,13 @@ template<>
void object::test<2>
- geom1_ = GEOSGeomFromWKT("POINT(2 3)");
- geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ geom1_ = fromWKT("POINT(2 3)");
+ geom2_ = fromWKT("POINT(2 2)");
ensure_equals(int(r1), 0);
ensure_equals(int(r2), 0);
@@ -75,18 +62,13 @@ template<>
void object::test<3>
- geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
- geom2_ = GEOSGeomFromWKT("POLYGON((0 0,0 10,10 10,10 0,0 0))");
+ geom1_ = fromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
+ geom2_ = fromWKT("POLYGON((0 0,0 10,10 10,10 0,0 0))");
ensure_equals(int(r1), 1);
ensure_equals(int(r2), 1);
@@ -111,9 +93,7 @@ void object::test<4>
nullptr, 0);
char const r1 = GEOSEquals(geom1_, geom1_);
ensure_equals(int(r1), 2);
// This is a test for bug #357 (GEOSEquals with inf coords)
@@ -126,17 +106,16 @@ void object::test<5>
"0103000020E61000000100000005000000737979F3DDCC2CC0F92154F9E7534540000000000000F07F000000000000F07F8F806E993F7E55C0304B29FFEA8554400634E8D1DD424540B5FEE6A37FCD4540737979F3DDCC2CC0F92154F9E7534540";
geom1_ = GEOSGeomFromHEX_buf((unsigned char*)hex, std::strlen(hex));
-#if 0 // fails
-// This is a test for bug #752 (GEOSEquals with collection)
+#if 0
+// FAILS
+// https://trac.osgeo.org/geos/ticket/752
+// GEOSEquals with collection inputs
template<>
template<>
void object::test<6>
@@ -147,12 +126,9 @@ void object::test<6>
"POLYGON ((3 3, 3 4, 4 4, 4 3, 3 3))"
- geom1_ = GEOSGeomFromWKT(wkt1);
- ensure(0 != geom1_);
+ geom1_ = fromWKT(wkt1);
#endif
diff --git a/tests/unit/capi/GEOSFrechetDistanceTest.cpp b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
index ab79a48ac..93c0f657e 100644
--- a/tests/unit/capi/GEOSFrechetDistanceTest.cpp
+++ b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
@@ -19,10 +19,7 @@ namespace tut {
// Common data used in test cases.
-struct test_capigeosfrechetdistance_data : public capitest::utility {
- test_capigeosfrechetdistance_data() {
+struct test_capigeosfrechetdistance_data : public capitest::utility {};
typedef test_group<test_capigeosfrechetdistance_data> group;
typedef group::object object;
@@ -38,8 +35,8 @@ template<>
- geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 100 0)");
- geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 50 50, 100 0)");
+ geom1_ = fromWKT("LINESTRING (0 0, 100 0)");
+ geom2_ = fromWKT("LINESTRING (0 0, 50 50, 100 0)");
double dist;
int ret = GEOSFrechetDistance(geom1_, geom2_, &dist);
@@ -53,8 +50,8 @@ template<>
double dist;
int ret = GEOSFrechetDistanceDensify(geom1_, geom2_, 0.5, &dist);
@@ -70,13 +67,13 @@ template<>
- geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 3 7, 5 5)");
- geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 9 1, 2 2)");
+ geom1_ = fromWKT("LINESTRING (0 0, 3 7, 5 5)");
+ geom2_ = fromWKT("LINESTRING (0 0, 9 1, 2 2)");
- double dist;
+ double dist = 0;
GEOSFrechetDistanceDensify(geom1_, geom2_, 1e-40, &dist);
- // no crash
+ ensure(dist >= 0); // no crash
// No crash with tiny densify fraction
@@ -86,13 +83,13 @@ template<>
- double dist;
+ double dist = 0;
GEOSFrechetDistanceDensify(geom1_, geom2_, 1e-19, &dist);
- // no crash
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index da1d355c4..c0ac20ce7 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -13,62 +13,33 @@
#include <string>
#include <vector>
+#include "capi_test_utils.h"
namespace tut {
// Test Group
-struct test_capigeosgeom_createcollection_data {
- GEOSContextHandle_t handle_;
- GEOSWKTReader * reader_;
- GEOSGeometry * geom_;
- GEOSGeometry ** geoms_;
- unsigned int ngeoms_;
- enum { geom_size = 3 };
- static void
- notice(const char* fmt, ...)
- std::fprintf(stdout, "NOTICE: ");
- va_list ap;
- va_start(ap, fmt);
- std::vfprintf(stdout, fmt, ap);
- va_end(ap);
- std::fprintf(stdout, "\n");
- GEOSGeometry*
- read(const char* wkt)
- return GEOSWKTReader_read_r(handle_, reader_, wkt);
+struct test_capigeosgeom_createcollection_data : public capitest::utility
+ GEOSGeometry ** m_geoms;
+ unsigned int m_ngeoms;
test_capigeosgeom_createcollection_data()
- : handle_(initGEOS_r(notice, notice))
- , reader_(GEOSWKTReader_create_r(handle_))
- , geom_(nullptr)
- , geoms_(nullptr)
- , ngeoms_(0)
+ : m_geoms(nullptr)
+ , m_ngeoms(0)
~test_capigeosgeom_createcollection_data()
- if (reader_) GEOSWKTReader_destroy_r(handle_, reader_);
- if (geom_) GEOSGeom_destroy_r(handle_, geom_);
- if (geoms_) GEOSFree_r(handle_, geoms_);
- finishGEOS_r(handle_);
- handle_ = nullptr;
- reader_ = nullptr;
- geom_ = nullptr;
- geoms_ = nullptr;
+ if (m_geoms) GEOSFree(m_geoms);
+ m_geoms = nullptr;
+#define geom_size 3
typedef test_group<test_capigeosgeom_createcollection_data> group;
@@ -81,83 +52,87 @@ group test_capigeosgeom_createcollection_group("capi::GEOSGeom_createCollection"
// Create collection from constant length C-array
template<>
template<>
-void object::test<1>
+void object::test<1>()
- GEOSGeom geoms[geom_size];
- geoms[0] = GEOSGeom_createEmptyPoint_r(handle_);
- geoms[1] = GEOSGeom_createEmptyPoint_r(handle_);
- geoms[2] = GEOSGeom_createEmptyPoint_r(handle_);
+ GEOSGeometry* geoms[geom_size];
+ geoms[0] = GEOSGeom_createEmptyPoint();
+ geoms[1] = GEOSGeom_createEmptyPoint();
+ geoms[2] = GEOSGeom_createEmptyPoint();
// takes ownership of individual geometries
- geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTIPOINT, geoms, geom_size);
- ensure_equals(GEOSGetNumGeometries_r(handle_, geom_), (int)geom_size);
+ geom1_ = GEOSGeom_createCollection(GEOS_MULTIPOINT, geoms, geom_size);
+ ensure_equals(GEOSGetNumGeometries(geom1_), geom_size);
// Create collection from constant length std::array
template<>
template<>
-void object::test<2>
+void object::test<2>()
- std::array<GEOSGeom, geom_size> geoms = {{
- GEOSGeom_createEmptyLineString_r(handle_),
+ std::array<GEOSGeometry*, geom_size> geoms = {{
+ GEOSGeom_createEmptyLineString(),
- geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTILINESTRING,
- geoms.data(), static_cast<unsigned int>(geoms.size()));
- ensure_equals(GEOSGetNumGeometries_r(handle_, geom_), geom_size);
+ GEOS_MULTILINESTRING,
+ geoms.data(),
+ static_cast<unsigned int>(geoms.size()));
// Create collection from dynamic length std::vector of geometries
template<>
template<>
-void object::test<3>
+void object::test<3>()
- std::vector<GEOSGeom> geoms;
- geoms.push_back(GEOSGeom_createEmptyPolygon_r(handle_));
+ std::vector<GEOSGeometry*> geoms;
+ geoms.push_back(GEOSGeom_createEmptyPolygon());
- geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTIPOLYGON,
- ensure_equals(static_cast<size_t>(GEOSGetNumGeometries_r(handle_, geom_)), geoms.size());
+ GEOS_MULTIPOLYGON,
+ geoms.data(),
+ ensure_equals(static_cast<size_t>(GEOSGetNumGeometries(geom1_)), geoms.size());
// Error on invalid collection type, ownership is still transferred
template<>
template<>
-void object::test<4>
+void object::test<4>()
- geom_ = GEOSGeom_createCollection_r(handle_, 12345,
- ensure(geom_ == nullptr);
+ 12345,
+ geoms.data(),
+ ensure(geom1_ == nullptr);
- geom_ = GEOSGeom_createEmptyCollection_r(handle_, 12345);
+ geom1_ = GEOSGeom_createEmptyCollection(12345);
// Release empty collection
template<>
template<>
-void object::test<5>
+void object::test<5>()
- const char *wkt = "MULTIPOLYGON EMPTY";
- geom_ = read(wkt);
- ensure(geom_ != nullptr);
+ geom1_ = fromWKT("MULTIPOLYGON EMPTY");
- geoms_ = GEOSGeom_releaseCollection_r(handle_, geom_, &ngeoms_);
- ensure(geoms_ == nullptr);
- ensure(ngeoms_ == 0);
+ m_geoms = GEOSGeom_releaseCollection(geom1_, &m_ngeoms);
+ ensure(m_geoms == nullptr);
+ ensure(m_ngeoms == 0);
@@ -167,19 +142,16 @@ template<>
- const char *wkt = "GEOMETRYCOLLECTION(POINT(0 0), POINT(1 1))";
+ geom1_ = fromWKT("GEOMETRYCOLLECTION(POINT(0 0), POINT(1 1))");
- ensure(geoms_ != nullptr);
- ensure(ngeoms_ == 2);
+ ensure(m_geoms != nullptr);
+ ensure(m_ngeoms == 2);
- for (size_t i = 0 ; i < ngeoms_; i++) {
- ensure(GEOSGeomTypeId_r(handle_, geoms_[i]) == GEOS_POINT);
- GEOSGeom_destroy_r(handle_, geoms_[i]);
+ for (size_t i = 0 ; i < m_ngeoms; i++) {
+ ensure(GEOSGeomTypeId(m_geoms[i]) == GEOS_POINT);
+ GEOSGeom_destroy(m_geoms[i]);
// Release typed collection
@@ -188,19 +160,16 @@ template<>
void object::test<7>
- const char *wkt = "MULTIPOINT((0 0), (1 1))";
+ geom1_ = fromWKT("MULTIPOINT((0 0), (1 1))");
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
index c9f6148dc..258ac7629 100644
--- a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
@@ -19,18 +19,14 @@ void object::test<1>
GEOSCoordSequence* seq = GEOSCoordSeq_create(3, 2);
GEOSCoordSeq_setXY(seq, 0, 1, 2);
GEOSCoordSeq_setXY(seq, 1, 4, 5);
GEOSCoordSeq_setXY(seq, 2, 9, -2);
- GEOSGeometry* result = GEOSGeom_createLineString(seq);
- GEOSGeometry* expected = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
+ result_ = GEOSGeom_createLineString(seq);
+ expected_ = fromWKT("LINESTRING (1 2, 4 5, 9 -2)");
- ensure_equals(GEOSEqualsExact(result, expected, 0), 1);
- GEOSGeom_destroy(result);
- GEOSGeom_destroy(expected);
+ ensure_geometry_equals(result_, expected_, 0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_extentTest.cpp b/tests/unit/capi/GEOSGeom_extentTest.cpp
index 9b44ce670..bf31bd9c8 100644
--- a/tests/unit/capi/GEOSGeom_extentTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extentTest.cpp
@@ -21,50 +21,43 @@ group test_capigeosgeom_extent_group("capi::GEOSGeom_extent");
template<>
template<>
- GEOSGeometry* g = GEOSGeomFromWKT("LINESTRING (3 8, -12 -4)");
+ geom1_ = fromWKT("LINESTRING (3 8, -12 -4)");
double xmin, ymin, xmax, ymax;
- ensure(GEOSGeom_getXMin(g, &xmin) != 0);
- ensure(GEOSGeom_getYMin(g, &ymin) != 0);
- ensure(GEOSGeom_getXMax(g, &xmax) != 0);
- ensure(GEOSGeom_getYMax(g, &ymax) != 0);
+ ensure(GEOSGeom_getXMin(geom1_, &xmin) != 0);
+ ensure(GEOSGeom_getYMin(geom1_, &ymin) != 0);
+ ensure(GEOSGeom_getXMax(geom1_, &xmax) != 0);
+ ensure(GEOSGeom_getYMax(geom1_, &ymax) != 0);
ensure_equals(xmin, -12);
ensure_equals(xmax, 3);
ensure_equals(ymin, -4);
ensure_equals(ymax, 8);
- ensure(GEOSGeom_getExtent(g, &xmin, &ymin, &xmax, &ymax) != 0);
+ ensure(GEOSGeom_getExtent(geom1_, &xmin, &ymin, &xmax, &ymax) != 0);
- GEOSGeom_destroy(g);
template<>
template<>
- GEOSGeometry* g = GEOSGeomFromWKT("POLYGON EMPTY");
double d;
- ensure_equals(GEOSGeom_getXMax(g, &d), 0);
- ensure_equals(GEOSGeom_getYMax(g, &d), 0);
- ensure_equals(GEOSGeom_getXMin(g, &d), 0);
- ensure_equals(GEOSGeom_getYMin(g, &d), 0);
+ ensure_equals(GEOSGeom_getXMax(geom1_, &d), 0);
+ ensure_equals(GEOSGeom_getYMax(geom1_, &d), 0);
+ ensure_equals(GEOSGeom_getXMin(geom1_, &d), 0);
+ ensure_equals(GEOSGeom_getYMin(geom1_, &d), 0);
- ensure_equals(GEOSGeom_getExtent(g, &d, &d, &d, &d), 0);
+ ensure_equals(GEOSGeom_getExtent(geom1_, &d, &d, &d, &d), 0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
index afd99076e..b2b531b36 100644
--- a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
@@ -9,52 +9,15 @@
#include <cstdio>
#include <cstdlib>
namespace tut {
// Test Group
-struct test_capigeosextractuniquepoints_data {
- GEOSGeometry* geom1_;
- GEOSGeometry* geom2_;
- GEOSGeometry* geom3_;
- static void
- va_list ap;
- va_end(ap);
- test_capigeosextractuniquepoints_data()
- : geom1_(nullptr), geom2_(nullptr), geom3_(nullptr)
- handle_ = initGEOS_r(notice, notice);
- ~test_capigeosextractuniquepoints_data()
- GEOSGeom_destroy_r(handle_, geom1_);
- GEOSGeom_destroy_r(handle_, geom2_);
- if(geom3_) {
- GEOSGeom_destroy_r(handle_, geom3_);
- geom1_ = nullptr;
- geom2_ = nullptr;
- geom3_ = nullptr;
+struct test_capigeosextractuniquepoints_data : public capitest::utility {};
typedef test_group<test_capigeosextractuniquepoints_data> group;
@@ -70,10 +33,11 @@ template<>
- geom1_ = GEOSGeomFromWKT_r(handle_, "POLYGON EMPTY");
- /* ensure_equals(GEOSGetNumGeometries_r(handle_, geom2_), 0); */
- geom3_ = GEOSGeom_extractUniquePoints_r(handle_, geom1_);
- ensure(0 != GEOSisEmpty_r(handle_, geom3_));
+ // ensure_equals(GEOSGetNumGeometries(geom2_), 0);
+ geom3_ = GEOSGeom_extractUniquePoints(geom1_);
+ ensure(geom3_ != nullptr);
+ ensure(0 != GEOSisEmpty(geom3_));
template<>
@@ -81,11 +45,12 @@ template<>
- geom1_ = GEOSGeomFromWKT_r(handle_, "MULTIPOINT((0 0), (0 0), (1 1))");
- geom2_ = GEOSGeomFromWKT_r(handle_, "MULTIPOINT((0 0), (1 1))");
- ensure(0 != GEOSEquals_r(handle_, geom3_, geom2_));
+ geom1_ = fromWKT("MULTIPOINT((0 0), (0 0), (1 1))");
+ geom2_ = fromWKT("MULTIPOINT((0 0), (1 1))");
+ /* ensure_equals(GEOSGetNumGeometries(geom2_), 0); */
+ ensure(geom3_);
+ ensure_geometry_equals(geom3_, geom2_);
template<>
@@ -93,12 +58,11 @@ template<>
- "GEOMETRYCOLLECTION(MULTIPOINT((0 0), (0 0), (1 1)),LINESTRING(1 1, 2 2, 2 2, 0 0),POLYGON((5 5, 0 0, 0 2, 2 2, 5 5)))");
- geom2_ = GEOSGeomFromWKT_r(handle_, "MULTIPOINT((0 0), (1 1), (2 2), (5 5), (0 2))");
+ geom1_ = fromWKT("GEOMETRYCOLLECTION(MULTIPOINT((0 0), (0 0), (1 1)),LINESTRING(1 1, 2 2, 2 2, 0 0),POLYGON((5 5, 0 0, 0 2, 2 2, 5 5)))");
+ geom2_ = fromWKT("MULTIPOINT((0 0), (1 1), (2 2), (5 5), (0 2))");
diff --git a/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
index cbb134df9..bd8459788 100644
--- a/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
@@ -21,7 +21,7 @@ template<>
- input_ = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
+ input_ = fromWKT("LINESTRING (1 2, 4 5, 9 -2)");
const GEOSCoordSequence* seq = GEOSGeom_getCoordSeq(input_);
double x = -1;
@@ -36,7 +36,7 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("POLYGON ((1 1, 2 1, 2 2, 1 1))");
+ input_ = fromWKT("POLYGON ((1 1, 2 1, 2 2, 1 1))");
ensure(seq == nullptr); // can't get seq from Polygon
@@ -46,7 +46,7 @@ template<>
template<>
- input_ = GEOSGeomFromWKT("POINT (3 8)");
+ input_ = fromWKT("POINT (3 8)");
double x = -1;
diff --git a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
index 9f3eda5a1..8d0b0ce6f 100644
--- a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
@@ -21,17 +21,14 @@ template<>
- GEOSGeometry* point = GEOSGeomFromWKT("POINT (4 2 7)");
- GEOSGeometry* line = GEOSGeomFromWKT("LINESTRING (4 2 7 1, 8 2 9 5)");
- GEOSGeometry* poly = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ geom1_ = fromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ ensure_equals(GEOSGeom_getCoordinateDimension(geom1_), 2);
- ensure_equals(GEOSGeom_getCoordinateDimension(point), 3);
- ensure_equals(GEOSGeom_getCoordinateDimension(line), 4);
- ensure_equals(GEOSGeom_getCoordinateDimension(poly), 2);
+ geom2_ = fromWKT("POINT (4 2 7)");
+ ensure_equals(GEOSGeom_getCoordinateDimension(geom2_), 3);
- GEOSGeom_destroy(point);
- GEOSGeom_destroy(line);
- GEOSGeom_destroy(poly);
+ geom3_ = fromWKT("LINESTRING (4 2 7 1, 8 2 9 5)");
+ ensure_equals(GEOSGeom_getCoordinateDimension(geom3_), 4);
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
index d81d1d2d4..c90e3e0ae 100644
--- a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
+ ensure_equals(GEOSGeom_getDimensions(geom1_), 2);
- ensure_equals(GEOSGeom_getDimensions(point), 0);
- ensure_equals(GEOSGeom_getDimensions(line), 1);
- ensure_equals(GEOSGeom_getDimensions(poly), 2);
+ ensure_equals(GEOSGeom_getDimensions(geom3_), 1);
+ ensure_equals(GEOSGeom_getDimensions(geom2_), 0);
} // namespace tut
Summary of changes:
tests/unit/capi/GEOSEqualsTest.cpp | 50 ++----
tests/unit/capi/GEOSFrechetDistanceTest.cpp | 29 ++--
tests/unit/capi/GEOSGeom_createCollectionTest.cpp | 185 +++++++++------------
tests/unit/capi/GEOSGeom_createLineStringTest.cpp | 10 +-
tests/unit/capi/GEOSGeom_extentTest.cpp | 35 ++--
.../unit/capi/GEOSGeom_extractUniquePointsTest.cpp | 74 +++------
tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp | 6 +-
.../capi/GEOSGeom_getCoordinateDimensionTest.cpp | 15 +-
tests/unit/capi/GEOSGeom_getDimensionsTest.cpp | 15 +-
9 files changed, 154 insertions(+), 265 deletions(-)
hooks/post-receive
More information about the geos-commits
