[geos-commits] [SCM] GEOS branch main updated. 301bc462db3b8fd3d28137ccbfb8d0ee85d0c479
git at osgeo.org
git at osgeo.org
Tue Nov 21 08:04:58 PST 2023
the project "GEOS".
The branch, main has been updated
via 301bc462db3b8fd3d28137ccbfb8d0ee85d0c479 (commit)
from cbfa2ec36e2e33e3290ce78007c36d46b99517d4 (commit)
revisions in full, below.
commit 301bc462db3b8fd3d28137ccbfb8d0ee85d0c479
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 21 08:04:37 2023 -0800
Return 2D empty linestring on GEOSGeom_createLineString(NULL) (#998)
References GH-993
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 881189fc2..77a8a8995 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -509,6 +509,8 @@ std::unique_ptr<LineString>
GeometryFactory::createLineString(CoordinateSequence::Ptr && newCoords)
const
+ if (!newCoords)
+ return createLineString();
// Can't use make_unique with protected constructor
return std::unique_ptr<LineString>(new LineString(std::move(newCoords), *this));
diff --git a/tests/unit/capi/GEOSGeom_createTest.cpp b/tests/unit/capi/GEOSGeom_createTest.cpp
index 78ca61cf1..6910a74f7 100644
--- a/tests/unit/capi/GEOSGeom_createTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createTest.cpp
@@ -11,13 +11,16 @@
#include <cstdlib>
#include <memory>
+#include "capi_test_utils.h"
namespace tut {
// Test Group
// Common data used in test cases.
-struct test_capigeosgeom_create_data {
+struct test_capigeosgeom_create_data : public capitest::utility
GEOSGeometry* geom1_;
GEOSContextHandle_t handle_;
@@ -177,6 +180,14 @@ void object::test<7>
geom1_ = nullptr;
+template<>
+template<>
+void object::test<8>()
+ input_ = GEOSGeom_createLineString(NULL);
+ ensure_equals(GEOSHasZ(input_), 0);
+ ensure_equals(GEOSHasM(input_), 0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSHasZMTest.cpp b/tests/unit/capi/GEOSHasZMTest.cpp
index ff36ef7b2..346ca97d8 100644
--- a/tests/unit/capi/GEOSHasZMTest.cpp
+++ b/tests/unit/capi/GEOSHasZMTest.cpp
@@ -106,5 +106,6 @@ void object::test<9>()
ensure_equals(GEOSHasM(input_), 1);
} // namespace tut
Summary of changes:
src/geom/GeometryFactory.cpp | 2 ++
tests/unit/capi/GEOSGeom_createTest.cpp | 13 ++++++++++++-
tests/unit/capi/GEOSHasZMTest.cpp | 1 +
3 files changed, 15 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
