[geos-commits] [SCM] GEOS branch 3.12 updated. eabf22113cc24416f6ae5df97bc7abc89bebff85
Tue Nov 21 08:35:51 PST 2023
the project "GEOS".
The branch, 3.12 has been updated
       via  eabf22113cc24416f6ae5df97bc7abc89bebff85 (commit)
      from  10254fe4493d7482769e935700410653e712b711 (commit)
revisions in full, below.
commit eabf22113cc24416f6ae5df97bc7abc89bebff85
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Nov 21 08:04:37 2023 -0800
    Return 2D empty linestring on GEOSGeom_createLineString(NULL) (#998)
    References GH-993
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index d30ee4906..25b78613c 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -534,6 +534,8 @@ std::unique_ptr<LineString>
 GeometryFactory::createLineString(CoordinateSequence::Ptr && newCoords)
 const
+    if (!newCoords)
+        return createLineString();
     // Can't use make_unique with protected constructor
     return std::unique_ptr<LineString>(new LineString(std::move(newCoords), *this));
diff --git a/tests/unit/capi/GEOSGeom_createTest.cpp b/tests/unit/capi/GEOSGeom_createTest.cpp
index b2a2d7376..9b8afa520 100644
--- a/tests/unit/capi/GEOSGeom_createTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createTest.cpp
@@ -11,13 +11,16 @@
 #include <cstdlib>
 #include <memory>
+#include "capi_test_utils.h"
 namespace tut {
 // Test Group
 // Common data used in test cases.
-struct test_capigeosgeom_create_data {
+struct test_capigeosgeom_create_data  : public capitest::utility
     GEOSGeometry* geom1_;
     GEOSContextHandle_t handle_;
@@ -149,6 +152,14 @@ void object::test<7>
     geom1_ = nullptr;
+template<>
+template<>
+void object::test<8>()
+    input_ = GEOSGeom_createLineString(NULL);
+    ensure_equals(GEOSHasZ(input_), 0);
+    ensure_equals(GEOSHasM(input_), 0);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSHasZMTest.cpp b/tests/unit/capi/GEOSHasZMTest.cpp
index ff36ef7b2..346ca97d8 100644
--- a/tests/unit/capi/GEOSHasZMTest.cpp
+++ b/tests/unit/capi/GEOSHasZMTest.cpp
@@ -106,5 +106,6 @@ void object::test<9>()
     ensure_equals(GEOSHasM(input_), 1);
 } // namespace tut
Summary of changes:
 src/geom/GeometryFactory.cpp            |  2 ++
 tests/unit/capi/GEOSGeom_createTest.cpp | 13 ++++++++++++-
 tests/unit/capi/GEOSHasZMTest.cpp       |  1 +
 3 files changed, 15 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
