[geos-commits] [SCM] GEOS branch 3.12 updated. 14926fef3da92787793669f083499354c51ae603
Sun Jan 14 12:39:51 PST 2024
the project "GEOS".
The branch, 3.12 has been updated
       via  14926fef3da92787793669f083499354c51ae603 (commit)
      from  64124d45c18563de4a2fd6f930b3f2ca248797a0 (commit)
revisions in full, below.
commit 14926fef3da92787793669f083499354c51ae603
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon Jan 15 09:38:56 2024 +1300
    Fix StringTokenizer::peekNextToken (#1025)
diff --git a/NEWS.md b/NEWS.md
index 704b54491..c8e4d73a8 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@ xxxx-xx-xx
   - Fix IsSimpleOp for MultiPoint with empty element (GH-1005, Martin Davis)
   - Fix PreparedPolygonContains for GC with MultiPoint (GH-1008, Martin Davis)
   - Fix TopologyPreservingSimplifier to prevent jumping components (GH-1012, Martin Davis)
+  - Fix reading WKT with EMPTY token with white space (GH-1025, Mike Taves)
 ## Changes in 3.12.1
 2023-11-11
diff --git a/src/io/StringTokenizer.cpp b/src/io/StringTokenizer.cpp
index 5735913cc..e016299eb 100644
--- a/src/io/StringTokenizer.cpp
+++ b/src/io/StringTokenizer.cpp
@@ -154,10 +154,8 @@ StringTokenizer::peekNextToken()
         return str[pos];
-    // It's either a Number or a Word, let's
-    // see when it ends
-    pos = str.find_first_of("\n\r\t() ,", static_cast<string::size_type>(iter - str.begin()));
+    // It's either a Number or a Word, let's see when it ends
+    pos = str.find_first_of("\n\r\t() ,", pos + 1);
     if(pos == string::npos) {
         if(iter != str.end()) {
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 3180a6686..37bc3010d 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -447,4 +447,15 @@ void object::test<22>
     ensure_dimension("MULTIPOINT ZM ((0 0 4 3), (1 2 4 5))", true, true);
+// EMPTY token with some white space
+template<>
+template<>
+void object::test<23>
+    GeomPtr geom(wktreader.read("MULTIPOINT( EMPTY, (10 10), (20 20))"));
+    ensure_equals(geom->getNumGeometries(), 3u);
 } // namespace tut
Summary of changes:
 NEWS.md                         |  1 +
 src/io/StringTokenizer.cpp      |  6 ++----
 tests/unit/io/WKTReaderTest.cpp | 11 +++++++++++
 3 files changed, 14 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
