[geos-commits] [SCM] GEOS branch 3.11 updated. 2d2febc50e3e61af5d0ebe56d689613417d7a36a
Sun Jan 14 12:49:24 PST 2024
the project "GEOS".
The branch, 3.11 has been updated
       via  2d2febc50e3e61af5d0ebe56d689613417d7a36a (commit)
      from  e2d99091724171ffb0d8716739580bac7d355780 (commit)
revisions in full, below.
commit 2d2febc50e3e61af5d0ebe56d689613417d7a36a
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon Jan 15 09:47:45 2024 +1300
    Fix StringTokenizer::peekNextToken (#1025)
diff --git a/NEWS.md b/NEWS.md
index b48a7b69f..c368a0ad0 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -6,6 +6,7 @@ xxxx-xx-xx
   - Fix DiscreteHausdorffDistance for LinearRing (GH-1000, Martin Davis)
   - PointOnSurface crashes with a collection containing a empty linestring (GH-1002, Paul Ramsey)
   - Fix IsSimpleOp for MultiPoint with empty element (GH-1005, Martin Davis)
+  - Fix reading WKT with EMPTY token with white space (GH-1025, Mike Taves)
 ## Changes in 3.11.3
 2023-11-11
diff --git a/src/io/StringTokenizer.cpp b/src/io/StringTokenizer.cpp
index 5735913cc..e016299eb 100644
--- a/src/io/StringTokenizer.cpp
+++ b/src/io/StringTokenizer.cpp
@@ -154,10 +154,8 @@ StringTokenizer::peekNextToken()
         return str[pos];
-    // It's either a Number or a Word, let's
-    // see when it ends
-    pos = str.find_first_of("\n\r\t() ,", static_cast<string::size_type>(iter - str.begin()));
+    // It's either a Number or a Word, let's see when it ends
+    pos = str.find_first_of("\n\r\t() ,", pos + 1);
     if(pos == string::npos) {
         if(iter != str.end()) {
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 477f3cb08..245d67e42 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -317,4 +317,15 @@ void object::test<13>
+// EMPTY token with some white space
+template<>
+template<>
+void object::test<14>
+    GeomPtr geom(wktreader.read("MULTIPOINT( EMPTY, (10 10), (20 20))"));
+    ensure_equals(geom->getNumGeometries(), 3u);
 } // namespace tut
Summary of changes:
 NEWS.md                         |  1 +
 src/io/StringTokenizer.cpp      |  6 ++----
 tests/unit/io/WKTReaderTest.cpp | 11 +++++++++++
 3 files changed, 14 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
