[geos-devel] Portability
Norman Vine nhv at cape.com
Fri Aug 30 15:24:37 EDT 2002
Paul Ramsey writes:
> So, working through the compilation bit by bit, some problems seem to be:
> - occasionally stdio.h is not declared where it is needed (maybe VC++
> papers over this automatically)
> - the compiler cannot find declarations for __min() and __max(),
> although it *can* find declarations for min() and max(). What is the
> difference between them? In GeometryCollection.cpp line 55, __max() is
> used while an almost identical function just above it uses max().
My experience with several cross-platform libraries is that we will have
LOTS of problems with MSVC6 and GCC incompatabilities.
One way around this is to have a <compiler.h> file that hides the
platform specifc 'quirks' or have the MSVC folks use the STLPort
STL headers.  The STLPort approach is probably the easiest
For common simple things like min() and max() most libraries
I help develop define their own versions
something like
// geos_inlines.h
// return the sign of a value
template <class T>
inline int GEOS_SIGN(const T x) {
    return x < T(0) ? -1 : 1;
// return the minimum of two values
template <class T>
inline T GEOS_MIN2(const T a, const T b) {
    return a < b ? a : b;
// return the minimum of three values
template <class T>
inline T GEOS_MIN3( const T a, const T b, const T c) {
    return (a < b ? SG_MIN2 (a, c) : SG_MIN2 (b, c));
ect ...
