[geos-devel] intersect/intersection() problem under Win
Christian Pschierer pschirus at gmx.net
Thu Oct 16 14:46:48 EDT 2003
On Thu, 16 Oct 2003, strk wrote:
> pschirus wrote:
> > P.S.:
> >  The TopologyException-Class is missing the toString()-Method.
> > Can someone with write-Access to the CVS-Repository please copy this
> > method from source/util/GEOSException.cpp to
> > source/geom/TopologyException.cpp? Thank you.
> I've made TopologyException derive from GEOSException,
> you should get what you need now.
Ok, thanks a lot.
Christian
