[geos-devel] PostGIS Leak
Yury A. Bychkov me at yury.ca
Mon Oct 20 13:51:12 EDT 2003
I wonder if that leak could also be caused by the caching problem (from
libstdc++ smart memory management). Unfortunately (as all of you probably know
by now), my leak detector doesn't detect that. Can anyone with valgrind check if
that is the case?
Yury
----- Original Message -----
To: "GEOS Development List" <geos-devel at geos.refractions.net>
Sent: Monday, October 20, 2003 10:47 AM
Subject: Re: [geos-devel] PostGIS Leak
> pramsey wrote:
> > About the PostGIS/GEOS leak I reported, I do not know if I quantified it
> > in my email. Even though I was only running isvalid() with a limit of
> > 100, I was adding over 1Mb of size to the postgres backend with each
> > invocation. So, not a memory leak so much as a memory deluge. Could we
> > have a bad PostGIS/GEOS interface now, after some of the GEOS changes?
> > Paul
> Yes. May be. I'll check tomorrow (tuesday).
> --strk;
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
