[geos-devel] Patch for 1.0.0 for my single issue
Carl Anderson carl.anderson at vadose.org
Sun Apr 25 23:58:19 EDT 2004
strk,
I tracked down the cause of my problem in geos-1.0.0 and backported the
fix from JTS-1.4
I have made no other changes and the patched lib does not Assert or
Exception for my test set. (of about 1 million objects).
I feel that this is worthwhile as a short term fix to geos-1.0 while
the bigger set of changes in CVS are stabilized.
WRT geos-cvs should I wait or can I start searching for the cause of
the Asserts / Exceptions now?
C.
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20040425/307ed92f/geos-1.0-a.bin
