[geos-devel] Current Status
Carl Anderson carl.anderson at vadose.org
Mon Apr 26 22:09:20 EDT 2004
On 04/26/2004 12:20:42 PM, strk wrote:
> On Mon, Apr 26, 2004 at 09:11:04AM -0700, Martin Davis wrote:
> > no need to pass it to the toGeometry method.  Really, the
> toGeometry
> > method is only there to support converting Envelopes to a Geometry
> > it's not intended for outside use.  Probably should be
> package-private
> > in JTS.
> > Make sense?
> Sure, so the bug is in the comment alone :)
> If that function is not part of the API, what code was trying to use
> it Carl ?
> --strk;
in PostGIS-0.8.1
postgis_geos_wrapper.cpp:
    g = geomFactory->toGeometry(envelope,geomFactory-
>getPrecisionModel(), SRID);
matches a function in GEOS-1.0 but does not match anything in GEOS-CVS
Pls remember that my original email was addressing two seperate issues
   (1) - the API creep
   (2) - the stability of the geos library due to Asserts /
        Exceptions / SegFaults.  Especially in the context of the
        C program Postgres
the latter involve bugs, the former with tagging and whether fixes to
1.0.0 or CVS would be appropriate.
C.
Carl Anderson
GIS Manager Fulton County Georgia
carl.anderson at co.fulton.ga.us
