AW: [geos-devel] OGR and Shape.idx
Düster Horst Horst.Duester at bd.so.ch
Mon Feb 16 03:06:08 EST 2004
Darren H. and Tyler
Thank you for yor response. I work with ArcView 3.x and tru64 UNIX and I
need index creation on the shape column only.
I tried to configure ArcView with a startup script to start the index
creation. After creation of the indexes the script shut down ArcView by
itself. I works from the command promt with av <proj>.apr. The problem, when
I start ArcView form a cronjob without a display, ArcView isn't able to
start up, because it is looking out for a display without success.
I'm not shure if there exists ArcObjects for tru64 UNIX.
With best regards
Dr. Horst Düster
GIS-Koordinator
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
4509 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
www.sogis.so.ch <http://www.sogis.so.ch/>
-----Ursprüngliche Nachricht-----
Von: Darren Houston [mailto:darren.houston at edu.sait.ca]
Gesendet am: Freitag, 13. Februar 2004 17:07
An: 'horst.duester at bd.so.ch'
Betreff: Re: [geos-devel] OGR and Shape.idx
Hello Dr. Düster,
What operating system and version of ArcView are you using (ArcGIS ArcView
8.x or ArcView 3.x)?
Do you also need an index built on any of the attribute columns?
I'm not sure, but I assume something could easily be programmed using
ArcObjects. Get back to me, and if I have time/need a break from dreary
research paper writing, I'll look for a solution.
Thank you,
Darren H.
