[geos-devel] Problems creating polygons with holes
Darren Carman darren.carman at infoterra-global.com
Wed Jun 30 11:13:58 EDT 2004
The way we deal with them holes can contain polygons, which in turn can contain holes, etc. and we still treat holes as polygons -- hence my confusion.
If you would like to use my code as another one of your examples in the distribution - for polygons with holes - then feel free (if you think it may help someone else).
Here is the working code:
#include <geos/io.h>
#include <geos/geom.h>
using namespace std;
using namespace geos;
typedef struct boundaryPt {
  double x;
  double y;
typedef vector<boundaryPt>    boundary;
typedef vector<boundary>      boundaryList;
typedef vector<boundaryList>  polygonList;
void createPolys(polygonList &polys) {
  int i;
  boundaryPt poly1[5];
  boundaryPt hole1[5];
  boundary tmpBoundary;
  boundaryList tmpBoundaryList;
  polygonList ptPolygons;
  poly1[0].x = 339252; poly1[0].y = 1019302;
  poly1[1].x = 339252; poly1[1].y = 1029077;
  poly1[2].x = 348752; poly1[2].y = 1029077;
  poly1[3].x = 346102; poly1[3].y = 1019653;
  poly1[4].x = 339252; poly1[4].y = 1019302;
  hole1[0].x = 340000; hole1[0].y = 1020000;
  hole1[1].x = 340000; hole1[1].y = 1021000;
  hole1[2].x = 341000; hole1[2].y = 1021000;
  hole1[3].x = 341000; hole1[3].y = 1020000;
  hole1[4].x = 340000; hole1[4].y = 1020000;
  for (i=0; i<5; i++) {
    tmpBoundary.push_back(poly1[i]);
  tmpBoundaryList.push_back(tmpBoundary);
  tmpBoundary.clear();
    tmpBoundary.push_back(hole1[i]);
  polys.push_back(tmpBoundaryList);
  for(int i=0; i< static_cast<int>(tmpBoundaryList.size()); i++) {
    tmpBoundaryList[i].clear();
  tmpBoundaryList.clear();
int main(int argc, char *argv[]) {
  vector<Geometry *> *polygons;
  vector<LinearRing *> *holes;
  int i,j,k;
  string resStr = "";
  createPolys(ptPolygons);
  try{
    GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
    // for each outer ring create a CoordinateList and add all the points to it
    polygons = new vector<Geometry *>();
    for(i=0; i< static_cast<int>(ptPolygons.size()); i++) {
      CoordinateList *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
      boundaryList bl = ptPolygons[i];
      boundary b = bl[0];
      cout << "Polygon " << i << endl;
      for(k=0; k< static_cast<int>(b.size()); k++) {
        cout << "Added point " << b[k].x << ',' << b[k].y << endl;
        cl1->add(*(new Coordinate(b[k].x,b[k].y,0.0)));
      // for each hole create a coordinate list like above, create a polygon and add to a Geometry vector
      holes = new vector<LinearRing *>();
      for(j=1; j< static_cast<int>(bl.size()); j++) {
        cout << "Hole " << j << endl;
        boundary b = bl[j];
        CoordinateList *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
          cl2->add(*(new Coordinate(b[k].x,b[k].y,0.0)));
        cout << "Creating polygon for hole " << j << ": " << cl2->toString() << endl;
        //LinearRing *lin1=(LinearRing *)gf->createPolygon(gf->createLinearRing(cl2),NULL);
        LinearRing *lin1=gf->createLinearRing(cl2);
        cout << "Geometry " << j << " : " << lin1->toString() << endl;
        holes->push_back(lin1);
        delete cl2;
      // create a polygon from the 1st CoordinateList and the holes
      cout << "Creating polygon " << i << ": " << cl1->toString() << endl;
      Geometry *geom1=(Geometry *)gf->createPolygon(gf->createLinearRing(cl1),(vector<Geometry *> *)holes);
      cout << "Geometry " << i << " : " << geom1->toString() << endl;
      // save this polygon in another vector
      cout << "Adding polygon " << i << endl;
      polygons->push_back(geom1);
      delete cl1;
    cout << "Creating multi-polygon" << endl;
    // when all done create a MultiPolygon object
    Geometry *geom2=gf->createMultiPolygon((vector<Geometry *> *)polygons);
    cout << "Creating string" << endl;
    resStr = geom2->toString();
    //clean up
    delete geom2;
    delete gf;
  catch (GEOSException *ge) {
    cout << "ERROR: " << ge->toString() << endl;
  cout << resStr << endl;
Cheers,
Darren
-----Original Message-----
From: chodgson at refractions.net [mailto:chodgson at refractions.net]
Sent: 30 June 2004 15:55
To: GEOS Development List
Subject: RE: [geos-devel] Problems creating polygons with holes
> I had assumed that the holes were treated as polygons as well :(
If polygon holes were defined by polygons, then your holes could have holes (which in turn could have holes...)!
Chris
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
"The information in this e-mail and any attachment is confidential and may be privileged. If you have received this e-mail in error, please delete it immediately and destroy any copies on your system. You should not retain, copy or use this e-mail for any purpose, nor disclose all or any part of its content to any other person.
Opinions expressed in this e-mail may not be endorsed by the company and unless explicitly indicated, this e-mail shall not form part of any binding agreement".
