[geos-devel] Current status
strk strk at keybit.net
Thu May 6 13:46:42 EDT 2004
I've got doc/example to run with no leaks.
Now it's time to get results correct.
In particular here are a the issues I'll approach next:
	o  check for leaks with runs against .xml
	o  doc/example catches "side location conflict"
	   TopologyExceptions is it an expected behaviour ?
	o  Every attempt to compute a buffer with original
	   precision (bufferOriginalPrecision) results in a
	   "depth mismatch" exception.
	o  Buffered geoms starts and end with a point
	   from the original geometry.
--strk;
