[geos-devel] Current status
strk strk at keybit.net
Mon May 17 08:32:41 EDT 2004
I've fixed a but in PrecisionModel::makePrecise().
Now the testLeaksBig.xml test gives the same result in both
jts-1.4 and geos CVS (5 isValid failures).
I've also run with success all jts-1.4 tests in test/validate.
Tests in test/vivid with failures are:
	TestFunctionPLPrec.xml
	TestSimple.xml
	TestValid.xml
	TestValid2-big.xml
	TestValid2.xml
	TestWithinDistance.xml
Other tests succeed.
--strk;
On Thu, May 06, 2004 at 07:46:42PM +0200, strk wrote:
> I've got doc/example to run with no leaks.
> Now it's time to get results correct.
> In particular here are a the issues I'll approach next:
> 	o  check for leaks with runs against .xml
> 	o  doc/example catches "side location conflict"
> 	   TopologyExceptions is it an expected behaviour ?
> 	o  Every attempt to compute a buffer with original
> 	   precision (bufferOriginalPrecision) results in a
> 	   "depth mismatch" exception.
> 	o  Buffered geoms starts and end with a point
> 	   from the original geometry.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
